DODONPACHI
01.10.2008 16:01:29
| DODONPACHI kirjutas: |
| irem'i mäng on suure tõenäosusega Bumpy Trot 2. |
Ei olnudki! Nad kavatsevad hoopis PSN'i tarbeks teha remake'i sellisest mängust nagu Spelunker. Huvitav!
( allikas )
Ja siis kuulutati PS3'le veel selline Action RPG nagu Demon's Souls välja. Developer: From Software.
-From Software are huge fans of kings field.
-Sony Approached From Software to make a game for them.
-The director thinks it was a great timing when sony asked about the game. He was working on Armored Core game and his company was working on an rpg (Probably Enchanted Arms?). It was a while since they worked on a fantasy game (I think more of an action rpg game).
-From Software gets complete freedom to make the game.
-They get also lots of help from Sony when they need to.
-The main character is a From Software like character. They want to have their From Software flavour with the game and characters.
-The game doesn't necessary have to look amazing, they are more aiming for a good game with the right balance.
-You can swap items in realtime? (Not sure about that).
-They want the game to look very rpg like and it has elements to remind you from older rpgs.
-They had of like a trial and error with the balance of the game many times.
-They are not planning on making the game too hard like other action rpg games. |
( allikas ) ( skännid )
Edit: lol
_________________ It is easier to imagine the end of the world than the end of capitalism. -- nüüd saadaval ka eesti keeles
viimati muutis DODONPACHI 01.10.2008 23:15:55, muudetud 1 kord |
| Kommentaarid: 23 loe/lisa |
22 |
d3t
01.10.2008 19:54:41
| Ho Ho kirjutas: |
Ja mida me sealt välja loeme? Seda, et SPU'de arvu tõenäoliselt tõstetaks N korda ja suurt rohkemat miskit
Esialgne plaan olevat olnud kasutada 2-4 Celli kogu töö ära tegemiseks ning kaasata üle glan'i kõikvõimalikud külmkapid-pesumasinad appi. Paraku ei jõutud asjaga nii kaugele piisava kiirusega, olen üsna kindel, et ei jõuta ka PS4 ajaks. Kahju iseenesest, puhta Cellidel põhineva aparaadiga saaks teha ära kõiksugu imevigureid mis tavalise CPU+GPU peal ei pruugi nii lihtne olla. |
Khm, mina lugesin välja et parem gpu ja rohkem rammi peaks olema. Cell sama või tsipa parem. Ja see külmkapi jutt oli siis ja on ka praegu ulme. Ehk kunagi tulevikus pole nii väga ulme.
_________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
| Kommentaarid: 85 loe/lisa |
72 |
iDemon
| Kommentaarid: 122 loe/lisa |
104 |
Ho Ho
01.10.2008 20:54:05
| d3t kirjutas: |
| Khm, mina lugesin välja et parem gpu ja rohkem rammi peaks olema. |
Kas see pole justkui loogiline et asjad on uuemas masinas paremad? Kui jutt on paremast GPU'st siis pole see kindlasti enam sama konseptsioon millest räägiti paar aastat enne PS3 tulekut vaid lihtsalt eksisteeriva platformi laiendamine.
87 |
EvilKatarn
diivanilill
01.10.2008 20:58:00
| Korpus tuleb ka teistsugune.
81 |
hondaa
01.10.2008 21:07:47
| no pigem tuleb too siis PS3 Slim, lubati ju aastaks 2011, ega nii kiiresti ometi ps4 ei tule
| Kommentaarid: 24 loe/lisa |
24 |
iDemon
104 |
weasel
02.10.2008 09:39:03
PlayTV kohta viimased uudised on sellised, et novembris tuleb see Uus-Meremaal välja, aga seal kasutatakse sama kodeeringut, mis meil
_________________ PSN: weaselEST |
| Kommentaarid: 38 loe/lisa |
486
02.10.2008 12:23:43
V6ikski olla otsene järg Shadow of Colosseousele.
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
DODONPACHI
22 |
emm sii
02.10.2008 19:51:59
Võrdlesin PES2009 ja FIFA09 demosi ja no minuarvates on ikka Fifa üle igas osas, aga eriti just graafilises pooles, pes pole eelmise variandiga küll eriti edusamme minuarvates teinud! Ma enne kahtlesin, et millist jalkamängu osta(vahepeal mõtlesin, et oskaks odavama mingi eelmise osa) aga siis võrdlesin fifa 08 ja 09 demosi ja jõudsin arusaamani, et vanemat kehvemat asja ei taha kuidagi. Kui nüüd pes 09 demo ka proovitud tellisingi fifa09 ära game.co.uk-st, sest see on ikka pes2009 ikka minuarvates peajagu üle!
| Kommentaarid: 17 loe/lisa |
14 |
Sprocket
Aeg maha 60
02.10.2008 19:54:46
| emm sii kirjutas: |
Võrdlesin PES2009 ja FIFA09 demosi ja no minuarvates on ikka Fifa üle igas osas, aga eriti just graafilises pooles, pes pole eelmise variandiga küll eriti edusamme minuarvates teinud! Ma enne kahtlesin, et millist jalkamängu osta(vahepeal mõtlesin, et oskaks odavama mingi eelmise osa) aga siis võrdlesin fifa 08 ja 09 demosi ja jõudsin arusaamani, et vanemat kehvemat asja ei taha kuidagi. Kui nüüd pes 09 demo ka proovitud tellisingi fifa09 ära game.co.uk-st, sest see on ikka pes2009 ikka minuarvates peajagu üle!  |
26 |
gj
212 |
weasel
03.10.2008 08:29:54
Sellest sai jah siin mõnda aega tagasi räägitud. Ise võtsin ka game.co.uk-st, aga mängida pole veel jõudnudki.
beastbeats
03.10.2008 18:40:38
Sega plaanib Valkyria Chronicles'i müüki lasta 14. november, demo juba nädala pärast saadaval
http://www.eurogamer.net/article.php?article_id=249060
M: Schwalbe G-One Allround rehvid - 2tk/30€
M: Shimano XT kiirkinnitused - 2tk/15€ |
284 |
iDemon
104 |
beastbeats
04.10.2008 10:19:10
PlayStation Store Update
http://blog.us.playstation.com/2008/10/02/playstation-store-update-54/
EDIT: BiA: Hell`s Highway jättis kehva mulje (just graafika poole pealt); BioShock ootab oma korda
284 |
ppg
04.10.2008 11:59:59
| Hei, küsiksin järgmist 40gb, 80gb ja 400gb-ne versioon ei toeta ükski ps2 mänge ning mälukaarti lugeja puudub samuti nagu aru sain, paar usb porti vist samuti.
138 |
hondaa
04.10.2008 12:08:41
400gb kus sa seda nägid, aga muidu ei, neist enam ükski ei toeta (v.a 400gb vers, sellega pole tutvunud) ps2 mängude mängimist ja paar usb porti vähem, samuti pole mingeid mälukaardi auke, samas ma pole ühestki neist veel puudust tundnud
24 |
ppg
138 |
beastbeats
04.10.2008 12:46:30
See a) seal typo b) kohalikke "seppade" tuuning - kõvaketta vahetus garantiid ei katkesta ja kindlasti leidub inimesi, kes on pigem nõus natuke rohkem maksma juba "valmis lahenduse" eest kui ise vahetama hakkama...
Ametlikult Sony sellist mudelit valmistanud pole
284 |
486
04.10.2008 13:16:17
M6tted ka nendel suurtematel ketastel. Tehku etem see terve kolakas väiksemaks. Väga loodan, et varsti tuleb mingi slim versioon.
39 |
SaIm85
Cander
04.10.2008 21:41:15
| emm sii kirjutas: |
ma pole veel PES09 demo kohanud..äkki annaksid viite ?
| Kommentaarid: 39 loe/lisa |
34 |
hondaa
04.10.2008 21:48:15
| Cander kirjutas: |
| emm sii kirjutas: |
ma pole veel PES09 demo kohanud..äkki annaksid viite ? |
nii EU kui US store-i läbi vaatanud?
24 |
weasel
04.10.2008 22:57:27
EU stores ju ilusti olemas asi.
05.10.2008 03:16:53
Kas PS3 oskab USB SATA kettaga midagi peale hakata või ei?
FAT32 peaks hakkama saama, aga mul NTFS failisüsteemiga
| Kommentaarid: 94 loe/lisa |
81 |
beastbeats
05.10.2008 10:41:52
Proovisin siis ka BioShock'i ja Eternal Sonata demod ära - polnud viga, kuid ostma neid vast ei hakkaks
284 |
aivo80
05.10.2008 16:04:30
| Keegi viimasel ajal endale USA accoundi on teinud ja sealt midagi osta üritand? Kas töötab? Proovisin täna erinevaid aadresse ka, aga ei lase krediit kaarti ära registreerida, ütleb, et andmed valed.
| Kommentaarid: 31 loe/lisa |
29 |
weasel
05.10.2008 16:06:28
aivo80, nädal tagasi alles kandsin oma valletisse raha ja sain osta ka (Burnout Paradise).
aivo80
05.10.2008 16:39:47
| weasel kirjutas: |
| aivo80, nädal tagasi alles kandsin oma valletisse raha ja sain osta ka (Burnout Paradise). |
Tegin uue accoundi, aga ikka ei midagi.
29 |
47th ronin
05.10.2008 19:30:12
| aivo80 kirjutas: |
| weasel kirjutas: |
Tegin uue accoundi, aga ikka ei midagi. |
loe vanemaid poste, seal on kirjas, mis ja kuidas. põmst pead lihtsalt endale miski suvalise nime välja mõtlema, jänkistanis ehtsa eksisteeriva aadressi sisestama (hotell, pizzasöökla, suurfirma kontor) ning siis tagasihoidlikult, viie doltsi kaupa rahhi lisama. walletist raha kulutamisel limiiti ei ole, ainult lisamisel.
_________________ rgrds,
ronin, neljakümne seitsmes |
| Kommentaarid: 52 loe/lisa |
50 |
Labukana
05.10.2008 19:31:55
| 47th ronin kirjutas: |
| aivo80 kirjutas: |
| weasel kirjutas: |
loe vanemaid poste, seal on kirjas, mis ja kuidas. põmst pead lihtsalt endale miski suvalise nime välja mõtlema, jänkistanis ehtsa eksisteeriva aadressi sisestama (hotell, pizzasöökla, suurfirma kontor) ning siis tagasihoidlikult, viie doltsi kaupa rahhi lisama. walletist raha kulutamisel limiiti ei ole, ainult lisamisel. |
nii ongi, aga mingi hetk kadus mul see walletisse raha lisamise limiit ära imo, viimasel ajal võin asju otse välja osta ja võtab kaardilt paraja koguse, wipeouthd näiteks sai nii ostetud just...
| Kommentaarid: 32 loe/lisa |
30 |
aivo80
05.10.2008 21:22:55
| Labukana kirjutas: |
| aivo80 kirjutas: |
| weasel kirjutas: |
nii ongi, aga mingi hetk kadus mul see walletisse raha lisamise limiit ära imo, viimasel ajal võin asju otse välja osta ja võtab kaardilt paraja koguse, wipeouthd näiteks sai nii ostetud just... |
No värk ongi selles, et panin ikka korralikult miski hotelli aadressi jne. Aga ikka ütleb, et kaardi andmed ei sobi...
Ütleb, et "Credit card information is not valid" Ma ei saagi nagu aru, kas mina olen bloki maha pannud või mis värk on
29 |
Auron
05.10.2008 22:48:52
| aivo80, sa ikka nö. panid accounti tehes, et oled usamaalane ja siis üritasid usa adret panna?
133 |
aivo80
06.10.2008 08:36:11
| Auron kirjutas: |
| aivo80, sa ikka nö. panid accounti tehes, et oled usamaalane ja siis üritasid usa adret panna? |
No ikka panin. Keegi katsetada ei taha nii, et teeb endale ka uue accoundi ja katsetab siis krediit kaarti autentida?
29 |
weasel
06.10.2008 15:26:31
Huvitav tähelepanek: alates 1.10.2008 on PS-i ametlikus foorumis PS3 alamjaotuse all uus kategooria - "Home".
beastbeats
284 |
tann84
06.10.2008 16:49:48
sai ka ennast kirja pandud,loodan et olen üks õnnelikest kes seda proovida saab
| Kommentaarid: 47 loe/lisa |
emm sii
06.10.2008 19:24:16
Game.co.uk üllatas mind täna positiivselt tohutult! Tellisin, neljapäeva õhtul Fifa09 mis pandi reedel posti ja juba täna hommikul oli see minu Rakvere postkastis, mind pani just see imestama, et nädalavahetus jäi ka ju selle aja sisse, ning ainult 4 päevaga(tegelikult isegi vähem kui 4) toimetati see mitte Tallinna vaid lausa väikelinna postkasti
Mäng ise on muidu ülihea, rahul oma ostuga!
14 |
tann84
06.10.2008 19:47:23
mul juhtus täna esimest korda selline asi kui mängust välja läksin,läks järsku pilt mustaks,ei funkanud puldi pealt ükski nupp ega power nupp.
Pidin külmalt tagant välja lülitama.On kellelgi veel sellist asja juhtund?
_________________ PSN: karl877 |
angel
06.10.2008 20:08:28
PSP on kokku jooksnud paar korda. Lihtsalt Freeze ja reboot (vahest peab ise sisse lülitama vist). PS3 minuteada kah pange pannud.
157 |
malukas
06.10.2008 20:48:15
mul battlefield bad company demos netis mängides paar korda kokku pannud.
Siis olen ka eest nupust kinni lülitanud, aga nii et tagant peaks poweri välja võtma pole juhtunud veel.
_________________ Müün konsoole, tarvikuid, mänge! Küsi hinda!
M: Playstation 3 Slim 160GB (UUS) + GT5 P - 275€ |
| Kommentaarid: 124 loe/lisa |
95 |
Schumi
06.10.2008 21:42:01
| PS3 on lihtsalt suurepärane! Elamus paraneb iga päevaga! Elagu PlayStation 3! Ei oska muud öelda, kui et soovitaks igalühel PS3 soetada.
virx
06.10.2008 22:11:58
| Schumi, mis seal sind siis niiväga hämmastab, kui sinna Blu-ray just ei kuulu, siis millega ta veel üllatada suudab? Mul on vist midagi kahe silma vahele jäänud ehk valgustad mind ka sellega.
| Kommentaarid: 363 loe/lisa |
308 |
EvilKatarn
diivanilill
06.10.2008 22:13:18
| virx, pane tähele. Ta ju ütles, et see on suurepärane!
81 |
Labukana
06.10.2008 22:25:25
| virx kirjutas: |
| Schumi, mis seal sind siis niiväga hämmastab, kui sinna Blu-ray just ei kuulu, siis millega ta veel üllatada suudab? Mul on vist midagi kahe silma vahele jäänud ehk valgustad mind ka sellega. |
sul on alati võimalus ise järele proovida kusagil, ilmselgelt pole sa seda aparaati kunagi näppida saanud...
30 |
weasel
06.10.2008 22:27:27
virx, amddude, hapud viinamarjad või? Ta ei tulnud isegi iksboksi teemasse. Ikka jäi teile ette.
virx
06.10.2008 22:40:08
| tegelikult ongi PS3ga niipidi, nii kui ära proovid enam ei tahagi aga ootaks Schumi vastuse ära ehk paneb meid xbotte paika korralikult..
308 |
Labukana
06.10.2008 22:44:27
| virx kirjutas: |
| tegelikult ongi PS3ga niipidi, nii kui ära proovid enam ei tahagi aga ootaks Schumi vastuse ära ehk paneb meid xbotte paika korralikult.. |
ma tema asemel ei laskuks ritadega mingisse kakaloopimisse, pole mõtet ps3 teemat risustada.
pole näinud et sa xboxi teemas samalaadsete xboxi teemaliste postituste kallal nokiksid.
30 |
