noh.. usas ei pea inimesed ise oma kaardivõlgu otseselt tagasi maksma jms. läheb see kinni makstud pinnavirvendus üle ja kõik läheb jälle vana rada pidi edasi.. _________________ Kontrollitud ja hooldatud sülerid: https://www.yaga.ee/mox-fulder küsi akut, klaviatuuri ja laadijat. 5213582 - helista.
Scart, katsu olla.
su info on kõik õige, aga sinu tõlgendused on nagu konkreetselt läbi mustade prillide.
nagu ma ennegi vist öelnud olen - olukord on sitt, aga mitte nii sitt.
põhimõtteliselt siis laksust tõusis $10+ bailout uudise peale. ja rohkemgi loomulikult... eelkõige tingituna dollari langusest. _________________ - londiste
Scart, katsu olla.
Et siis, 14 taala tõusu ja müümise peatamine turgude lukustumise tõttu ei ole vertikaaltõus?
Oil extended last week's massive gains and rose above $117 a barrel on Monday, on hopes that the U.S. government's $700 billion rescue plan would restore stability in the financial system and support global energy demand.
Nearly 90 percent of oil production in the U.S. Gulf of Mexico, home to a quarter of all U.S. oil output, remains shut along with seven refineries.
Oil prices were also supported by news China increased crude imports 11.54 percent in August from a year earlier, recovering from a steep July fall, the General Administration of Customs said on Friday, confirming earlier data.
Oil surged in afternoon trading, reaching as high as $130.00 - a $25 gain - but dropped back down to settle at $120.92 a barrel up $16.37 from Friday's close.
"We're dry. We've got no gas here," Hussain, the station's manager, said Monday morning.
He said he has "no idea" when the next shipment will come, even though he's been in constant contact with the local terminal.
"There was no gas to be found, then panic set in as I approached a gas station with a 40-car line," he said. "This is causing complete chaos. Why is this happening, and what actions are being taken to prevent this from happening again, and why did it happen in the first place?" _________________ "Believe you can, believe you can't; either way, you're right." - Henry Ford
She got just enough to continue looking for a cheaper price.
About a mile away, she found a station with long lines for gas around $4.29.
"I waited 30 minutes to get gas," she said. "It does concern me. I'm actually frustrated that the prices are so high."
Scart,
päris paljud on sulle juba öelnud, võta rahulikumalt. Eile jälle tüüpiline näide - kuniks nafta hind tõusis, oli vaja jooksvalt uuendada siin postitusi. Päeva lõpus toimunud veel järsema languse kohta aga pole sõnakestki.
Kas eilse nafta hinna liikumise tagamaadest ka teadlik oled? Kui jah, siis võib sinu teguviisi teadlikuks paanikakülvamiseks nimetada. Kui ei - oled lihtsalt tühipaljas eputis.
Scart,
Kui sa arvad, et ma elan arvuti taga 24 tundi ööpäevas, siis eksid ikka päris rängalt. Siin on piisavalt targad inimesed, et ise asja jälgida läbi sadade meediakanalite, mis on kättesaadavad läbi interneti ja ma nagu nägin, et juba täna hommikul oli olemas Bloombergi quote ühe kaas-kasutaja poolt, kes oli hinnakõikumine numbrites täiesti olemas.
Samas jah, kõigi aegade suurim tõus koos kõigi aegade suurima dollari väärtuse langusega on tühiasi ju. Keda huvitav selline asi, ma kuulsin just raadiost, et Liis Lassi kassil on jälle kõhutuule mure - räägime sellest 8)
ma ei tea, ma kiikasin ka korra uudiseid ja seejärel vähe asjalikumaid andmeid sinu postide peale. oli küll ilusasti näha.
sa nagu tuledki alati mingi vahva musta uudisega ja tagamaid ei vaevu isegi mitte seletama, pärast mokaotsast mainid, et oli jah sellepärast.
see, et mina või sina või siis enamik siin teema lugejatest ise läheb infot juurde ammutama ei olegi siinkohal oluline. tee oma väited pisut rohkem puust ette ja punasemaks. ja mitte maailmalõpu näidetega. _________________ - londiste
Kui ma olen rääkinud maailmalõpust midagi nagu sa koguaeg vatrad, siis tulista see kvõut. Vaataks isegi, mida ma pole päris pikalt väitnud ühegi praegu aktuaalse teemaga seoses.
Huvitav törts tinfoililik arvamusartikkel taalast siin
The biggest Wall Street story most Americans haven't yet heard of is the $62 trillion unregulated credit default swaps market.
Here is one scenario: A hedge fund buys insurance in case a company defaults on its bonds a so-called credit default swap when the hedge fund doesn't necessarily own the bonds. Then it immediately shorts the stock, driving down the company's share price, leading to a downgrade, and eventually triggering a default. It is the ultimate moral hazard, like taking out fire insurance for a home you don't own: There is an obvious motivation to set the house on fire and collect the insurance.
Meanwhile, that same hedge fund may also be issuing its own credit default swaps, where it promises to cover a company's bonds if it defaults, in exchange for the buyer of the swap paying out a premium. The premium is paid out in regular intervals, much like an insurance premium, and is a simple means for the hedge fund to generate additional income. This is especially true because the hedge fund does not have to put aside any capital to cover the swaps it is writing. Riskier still, no bond has to actually be delivered to settle the swap in case of a default.
"The credit default swap market is the ultimate bubble, and it is about to collapse," the managing director of Institutional Risk Analytics, Christopher Whalen, said. "It is a Ponzi scheme, and is basically the same method as a bookie uses."
Soomlased on viimasel ajal küll kaardile pääsenud ainult mingite eriti kummaliste fantaasiate (igasugused bäkmännid ja lipponenid) ja üksteise kõmmutamise abil. Oma nokia on vist ikka raske koorem kanda, katus sõidab lõpuks ära. _________________ verba volant, scripta manent Hoiatus! Olen sinu postituses olevate lolluste ja nõmeduste vastu allergiline. Lolluste ilmnemisel võib kaasneda raskekujuline sarkastiline reaktsioon.
ega ma ausalt öeldes ise ka nüüd utreerin kohati sajaga, nii et ise samuti patune poiss sellest nurgast.
aga said aru küll, mida ma silmas pidasin, ei ole vaja tähti närida
namstoop, kaardile? kui massimeediat mõtled, siis on jah viimase paari nädalaga ainult vahvaid asju näha olnud. _________________ - londiste
Almost exactly seven years ago Al Qaeda terrorists targeted their hijacked planes into the Twin Towers at the heart of New Yorks financial centre and the world was transformed.
There were no deaths this week, but the effects of the carnage on the financial
markets will be far more profound and destabilising than the 9/11 atrocity.
For almost all of us, it will, I predict, be a change for the worse, and for a large
minority the consequences will be extremely distressing.
Corporate India is in shock after a mob of sacked workers bludgeoned to death the chief executive who had dismissed them from a factory in a suburb of Delhi.
Lalit Kishore Choudhary, 47, the head of the Indian operations of Graziano Transmissioni, an Italian-headquartered manufacturer of car parts, died of severe head wounds on Monday afternoon after being attacked by scores of laid-off employees, police said.
The incident, in Greater Noida, just outside the Indian capital, followed a long-running dispute between the factory's management and workers who had demanded better pay and permanent contracts.
Individuals and businesses located in areas of Louisiana affected by Hurricane Gustav will get more time to pay their taxes, the Internal Revenue Service said Wednesday.
Peaasi, et seal hästi läheb. Siis läheb siinmail ka mittehalvasti?
Ja inimloomust.
Kui igale täiskasvanule anda sealmail see ebardnumber raha, siis enamus vaevalt midagi vajalikku kinni maksaks.
Aga idee on muidugi üldiselt "suurepärane".
Taxpayers and tax preparers in areas affected by Hurricane Ike will get an extra week to file returns and make payments due Sept. 15, the Internal Revenue Service said Friday.
https://foorum.hinnavaatlus.ee/viewtopic.php?p=4655754#4655754 _________________ Teach a man to reason and he'll think for a lifetime
Republican presidential candidate John McCain announced Wednesday he is suspending his campaign to return to Washington and focus on the "historic" crisis facing the U.S. economy. He urged organizers of Friday's presidential debate to postpone the event.
