madness
21.09.2008 10:15:35
| Miks kõik räägivad, et vanades videotes oli mäng parem. Nagu creature creatoris sai väheke keerukamaid tegelasi teha, muu kõik sama..
| Kommentaarid: 13 loe/lisa |
DeTHiCa.
140 |
Syncmahv
21.09.2008 23:43:00
| Mismõttes?
102 |
xpander
22.09.2008 00:29:48
| xpander kirjutas: |
kahjuks mina veel testida eiriti ei saa
selline pilt mul
see algus kui vees olin, siis oli veel normaalne  |
Wine 1.1.5 - SPORE toimib korralikult
hea vahelduseks mängida
_________________ Linux Gaming Videos: Xpander69 |
| Kommentaarid: 18 loe/lisa |
16 |
wicked
| Kommentaarid: 68 loe/lisa |
63 |
monty11
24.09.2008 23:13:14
Lugege parem seda ... päris põhjalik postitus ... ma muidugi ei jõua ära oodata erinevaid "tarkurite" kommenaare, mis sellele raudselt järgnevad.
http://forum.spore.com/jforum/posts/list/589.page
_________________ Both the universe and stupidity are infinite. I'm not so sure about the former. - A. Einstein
Tule ja kiika minu fotomaailma. |
| Kommentaarid: 4 loe/lisa |
Mario.
24.09.2008 23:40:49
See on siiski mäng kuid kui hakata rääkima et teaduslik lähenemine on mängule ja seda pole, siis Väga hea postitus.
6 :: |
217 |
monty11
25.09.2008 10:33:17
Intervjuu Alex Hutchinsoniga
http://www.rockpapershotgun.com/2008/09/22/spores-lead-designer-on-spores-design/
| Alex: Theres a challenge with granularity - we originally had a formula for speed which was basically a curve that said that getting more legs made you faster until you had more than four legs, after which is it made you slower, but never made you as slow as someone with one leg, all of which was modified by the level and type of feet that you had and the mass of the entire creature. What we found however was that even people who thought they wanted that sort of calculation both didnt understand it and didnt like it when they were actually playing - the problem switched to my guy looks like he should run real fast but he doesnt, why? and wed say, well, you put five legs on him and that bulbous tail is actually really heavy, and people were both disappointed by the result and didnt understand it and they thought their creativity had been crushed. |
Huvitav, kas testijate IQ oli <75? Tänu sellele siis ongi võimalik panna ringi jooksma selliseid elukaid, mille pildi ma eelnevalt postitasin. Mul tuli veel üks idee, mida proovida ... vaatame, kas õnnestub
Scart
25.09.2008 10:37:08
Lihtsalt kurb on lugeda. Testijateks olid vist keskmised jänkid.
101 |
Heineken
25.09.2008 12:20:27
Testijateks olid üle keskmise ikka . Ei nojah kurb tõesti lugeda , et nii "tarku" inimesi on olemas .
| Kommentaarid: 24 loe/lisa |
23 |
kaalu8
27.09.2008 23:59:53
Mul on selline jama, et kui ma teen 1. maailma(seal kus sa see kala oled)läbi, siis teeb arvuti restardi . Tahaks nagu täiega 2 maailma mängida. :Cry:
| Kommentaarid: 6 loe/lisa |
Mario.
28.09.2008 13:32:38
| Sitt lugu lilleke. Proovi reinstalli.
6 :: |
217 |
-RaiTz-
28.09.2008 14:22:24
| kaalu8 kirjutas: |
Mul on selline jama, et kui ma teen 1. maailma(seal kus sa see kala oled)läbi, siis teeb arvuti restardi . Tahaks nagu täiega 2 maailma mängida. :Cry: |
Seal tuleb videole väike koormus taha, vb sul toide nõrk vms. Olen sellist asja ennem ka kohanud.
| Kommentaarid: 36 loe/lisa |
30 |
Araablane
28.09.2008 15:48:24
Proovisin täna ka Spore ära ja pean ütlema et suhteline pettumus.
Esimesed kaks taset olid väga head ja see paaritumine ajas täiega lihtsalt naerma aga siis Tribel tasemesse jõudsin andis juba tunda et mäng kipub igavaks aga kui selle läbi sain ja linna tasemesse jõudsin viskas täielikult üle sest kui ma tangi valmis (ülilaheda btw ) ei hakanud kahurid tööle vaid lasi mingi suure kaarega junne, like wtf, peale seda oli pettumus täielik ja lükkasin mängu kinni.
Need kaks esimest taset võiks ainult olla siis oleks jube lahe mäng
| Kommentaarid: 30 loe/lisa |
28 |
kaalu8
29.09.2008 13:25:49
| -RaiTz- kirjutas: |
| kaalu8 kirjutas: |
Seal tuleb videole väike koormus taha, vb sul toide nõrk vms. Olen sellist asja ennem ka kohanud. |
Mis tegema pean siis?
NATAS999
29.09.2008 15:57:33
no kui toide nõrk, siis parem toide osta.
aga mul sai spoorist kõrini, panin tsiidid peale, et galaktika keskele saada, noh, muidu tapavad groxid ära. väga mage lahendus sealgi. galaktika keskele lähed, siis seal põmst sama jura mis mustas auguski, et käib mingi surra-murra-sigri-migri, selle vahega et värve on rohkem ja mingi kolli hääl hakkab mingi iba ajama. kui lõpuks siis see tunnel läbi saab, siis saad mingi imevidina, millega saab planeedile eluvaimu sisse puhuda 1 liigutusega. aga oh imet, ei saagi lõputult kasutada seda, mingi 40 tükki oli neid vist. aa, ja mingi väike nummi ufokene seletab ka mingit jama seal ehk siis üsna pointless, noh, teglt EA või see maxise tegijad kindlasti arvasid, et tegu jube deep teemaga, noh, tulemus siis teglt selline keskmise viruplondiini tasemega... vaimusünnitis.
| Kommentaarid: 41 loe/lisa |
39 |
Scart
04.10.2008 13:11:17
link :: kae siit
It looks like the first addon for Spore will arrive very soon indeed. Called the Spore Cute & Creepy Parts Pack has a retail price of $19.99 and will be available on the 18th of November.
101 |
Heineken
04.10.2008 13:25:42
20 dollarit uute eluka juppide eest ... nojah , veel midagi Simside sarnast , mida pidevalt uuendatakse väikeste juppidega , ja iga jupp maksab oma hinna . Aga eks näis , ehk lisatakse midagi muud kah ( mida ma kuigi hästi ei usu ) .
23 |
Deadlock
04.10.2008 18:43:53
Selle asjaga annab veidi rohkem nalja teha kui muidu. Data folderisse tõmmata fail ja ongi valmis..
| Kommentaarid: 8 loe/lisa |
| Kommentaarid: 92 loe/lisa |
marras
23.02.2009 22:44:20
| kas keegi tark siit võiks vastata mõnele rumalale küsimusele? ma ei saa täpselt aru, mis jama selle installimisega on, et peab registreerima. kas seda ei saa rohkemasse, kui ühte arvutisse installida? või saab, kui ei taha neid online võimalusi? ja kas ta nõuab mängimiseks plaati ka?
tige kala
25.05.2009 15:14:34
Nii sain ka nüüd väheke mängida aga juba esimene probleem, jõudsin Tribal Stage'i ja Chieftan suutis surma saada ühe korra. Nüüd on aga selline jama, et tekib küll uus chieftan aga see hõljub ringi niisama ja lõpuks jääb üldse kosmosesse hõljuma, liikuda sellega kusagile ei saa
| Kommentaarid: 66 loe/lisa |
