| Mis pesaga Intel lauaarvuti emaplaat on kasutuses 2014 1. oktoobri seisuga? |
| Socket 478 |
2% |
[ 13 ] |
| LGA 775 |
13% |
[ 83 ] |
| LGA 1366 |
4% |
[ 30 ] |
| LGA 1155 |
32% |
[ 209 ] |
| LGA 1150 |
38% |
[ 243 ] |
| LGA 1156 |
3% |
[ 23 ] |
| LGA 2011 |
5% |
[ 35 ] |
| hääli kokku : 636 |
G80
19.08.2008 22:40:18
| wanawoll kirjutas: |
With the entry of the Core i7 Bloomfield series processors this September thru October, the computing world will witness the entry of a new motherboard processor socket
Vat nüüd juba peab 8) |
Ma olen ainult oktoobrit näinud, vaevalt septembri lõpuks midagi saada oleks.
210 |
WäntWõll
make.believe
19.08.2008 22:43:27
G80, kle sinu vaeval sõna siin muudab midagi,oleme optimistid
300 |
| Kommentaarid: 92 loe/lisa |
G80
20.08.2008 11:22:11
the sky is falling, nehalem sucks at games
Deem.
| Most Games are about fast caches and super integer performance. After all, most of the Floating point action is already happening on the GPU. All Core 2 CPUs were a huge step forward in integer performance (not in the least because of memory disambiguation) compared to the CPUs of that time (P4 and K8). Nehalem is only a small step forward in integer performance. And the gains due to slightly increased integer performance are mostly negated by the new cache system. In a previous post I told you that most games really like the huge L2 of the Core family. With Nehalem they are getting a 32 KB L1 with a 4 cycle latency, next a very small (compared to the older Intel CPUs) 256 KB L2 cache with 12 cycle latency and after that a pretty slow 40 cycle 8 MB L3. When running on Penryn, they used to get a 3 cycle L1 and a 14 cycle 6144 KB L2. That is a 24 times larger L2 than Nehalem! |
Mängudes mingit perfi juurde ei tule, tundub, et esialgu küll ei tasu nehalemile üle minna, ise Vantage skoor on QX6800 parem, kui samal taktil Nehalemiga...
Ei näe hullu mõtet osta X58+kallis DDR3+4kilone nehalem ja perfi nagu juurde ei tule.
Ei osand arvata, et Nehalem võib mängudes kehvem olla Pernyst, see polnd hea uudis tegelt.
Samas AMD-le on see kasuks, saab nüüd järgi tulla natuke oma Deneb-iga ja võib olla jõuab järgmise põlvkonnaga ettegi Intelist, tore oleks.
http://anandtech.com/weblog/showpost.aspx?i=480
http://www.hexus.net/content/item.php?item=15015&page=8
210 |
Ho Ho
20.08.2008 11:47:38
| Hexus kirjutas: |
| it is abundantly clear that something was awry in the test box. |
Mina Nehalemi nii kiirelt maha ei kannaks. Cache koha pealt on Nehalemil kindel eelis kui C2Q puhul üritab üks chip teise chipiga suhelda. Nehalem saab otse läbi L3, C2Q peab käima läbi põhjasilla. Nehalemi mälu latentsus peaks samuti madalama olema kui Penrynil, vähemalt kui kasutada võrdseid mälusid. Hexus pani C2'le sisse 1.6GHz mälud, Nehalemi 1.066GHz
viimati muutis Ho Ho 20.08.2008 11:49:30, muudetud 1 kord |
86 |
G80
20.08.2008 11:47:42
| Ho Ho kirjutas: |
| Hexus kirjutas: |
Mina Nehalemi nii kiirelt maha ei kannaks. Cache koha pealt on Nehalemil kindel eelis kui C2Q puhul üritab üks chip teise chipiga suhelda. Nehalem saab otse läbi L3, C2Q peab käima läbi põhjasilla. |
Ei tea jah, kas oli mingi kala, kui polnd ja nehalem tulebki selline siis vaevalt paljud teda ostavad.
210 |
G80
210 |
One
20.08.2008 19:59:38
sata pesad on sel gigabytel jamas kohas, kahe video korral saab vaid 0 ja 1 pesa kasutada.
foxconni pildilt tundub vabsee, et kahe pikema kaardi korral tuleb ide ketas kasutada
või noh, tegelikult võib neid musta värvi pcie slotte ka vast kasutada.. eeldusel, et kõik 4 on ikka 16x
728 |
20.08.2008 20:08:23
| Winterwind kirjutas: |
või noh, tegelikult võib neid musta värvi pcie slotte ka vast kasutada.. eeldusel, et kõik 4 on ikka 16x |
Tõepoolest.Millal õpivad emaplaaditootjad ükskord ära,et SATA pordid kõik panna nurga all platele .Nagu igalühel oleks mustmiljon 90 kraadise nurgaga SATA kaablit kodus vingerdamas .Samas kahtlen,et kõik need slotid 16x on.Ilmselt 16x16x16x8 parimal juhul.Kui mitte 16x16x16x4
G80
20.08.2008 20:09:54
| tomorrow kirjutas: |
Tõepoolest.Millal õpivad emaplaaditootjad ükskord ära,et SATA pordid kõik panna nurga all platele .Nagu igalühel oleks mustmiljon 90 kraadise nurgaga SATA kaablit kodus vingerdamas .Samas kahtlen,et kõik need slotid 16x on.Ilmselt 16x16x16x8 parimal juhul.Kui mitte 16x16x16x4  |
2x16PCI-E ja 4x8PCI-E peaks olema.
Jah Asusel on need sata pesad ilusasti.
210 |
omgwtf
20.08.2008 21:54:34
Quad PCI-E .Labelid on kah head.Paraku kondekad socketi ääres tunduvad reegel olevat.Juba 4-l erineval X58 mobol on socketi ääres seal kondekad .Suuremate jahutitega võib probleeme tekkida. |
Need konded on nii madalad,et ei sega need ühtegi jahutust.. Mul X48 on sama(nagu paljudel teistel giga platedel) ainult,et 1xrida jookseb ja prose on kõrgemale ulatuv kui need konded
137 |
WäntWõll
make.believe
21.08.2008 14:45:32
EDIT2: MSI announce its X58 Motherboard Named "ECLIPSE" .Paistab kena:
Kena küll aga täpne Asus Maximuse koopia,isegi comos on sama kohapeal
300 |
WäntWõll
make.believe
21.08.2008 14:55:15
tomorrow, Seda veel ei tea kuna asi ilma torudetta pildil
300 |
G80
21.08.2008 14:57:53
tomorrow, Seda veel ei tea kuna asi ilma torudetta pildil  |
Kui torude all jahutust mõtlesid, siis palun:
Suht palju vaske tundub.
210 |
WäntWõll
make.believe
300 |
One
22.08.2008 08:49:27
24GB on muidugi vajalik. eriti veel ddr3 hinna juures
728 |
WäntWõll
make.believe
22.08.2008 09:08:45
Early Look: Asus P6T Deluxe
I want that
300 |
AJ
| Kommentaarid: 37 loe/lisa |
36 |
