ufo56
11.02.2008 14:05:19
CINEBENCH |
Testimine käib hetkel siis CINEBENCH R10 'ga.
Paar sõna programmi kohta nende kodulehelt
What Is MAXON CINEBENCH?
CINEBENCH is a real-world test suite that assesses your computer's performace capabilities. MAXON CINEBENCH is based on MAXON's award-winning animation software, CINEMA 4D, which is used extensively by studios and production houses worldwide for 3D content creation. MAXON software has been used in blockbuster movies such as Spider-Man, Star Wars, The Chronicles of Narnia and many more.
MAXON CINEBENCH runs several tests on your computer to measure the performance of the main processor and the graphics card under real world circumstances. The benchmark application makes use of up to 16 CPUs or CPU cores and is available for Windows (32-bit and 64-Bit) and Macintosh (PPC and Intel-based).
Ilmselt peab hakkama keegi mingit tabelit ka pidama asjast?
Tulemused postitada siia koos screenshotiga, screen võiks sisaldada siin teada tuntuid näitajaid( cpuz'i prose aknast ja mälude omast)
Lööge näkku kui midagi puudu on siit, targemad täiendage mind
Lae pildid -> pilt.io
viimati muutis ufo56 11.02.2008 15:39:05, muudetud 1 kord |
Kommentaarid: 78 loe/lisa |
67 |
symmi
Kommentaarid: 27 loe/lisa |
25 |
excalibur
13.02.2008 23:04:53
selle ankeedi pärast mis seal täitma peab (täielik idiootsus) ma seda testi ei tee
Kommentaarid: 316 loe/lisa |
262 |
ivar43
14.02.2008 02:19:57
"@ excalibur mis ankeet ? tõmba sealt lingist [1 post] Cinebench 51 mb zip (CINEBENCHR10.zip)
mitte maxton Cinema 4d demo see vist tahtis seda ankeeti
läpakas FS Amilo Si 1520
CINEBENCH R10
Tester : ivar - si 1520
Processor : Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz
MHz : 1660
Number of CPUs : 2
Operating System : WINDOWS 32 BIT 6.0.6000
Graphics Card : Intel 945GM
Rendering (Single CPU): 951 CB-CPU
Rendering (Multiple CPU): 2798 CB-CPU
Multiprocessor Speedup: 2.94
Shading (OpenGL Standard) : 325 CB-GFX
Kommentaarid: 14 loe/lisa |
CoiL
14.02.2008 23:21:58
Profiili masin nr.1 24/7 sätetel - 7135
tsitaat: |
Ilmselt peab hakkama keegi mingit tabelit ka pidama asjast? |
Keegi kes tabelit viitsib tegema hakata võiks uue teema teha imo
Kommentaarid: 95 loe/lisa |
83 |
ak.90
27.02.2008 10:25:03
Testi ajal läks läppar päris kuumaks, 90 C
MacBook
2 GHz Core Duo
2GB@667Mhz
Mac OS Tiger
3637 punkti
Kommentaarid: 209 loe/lisa |
188 |
CoiL
03.08.2008 19:45:15
CorsairX kirjutas: |
Ei tea kumb, kas 64-bit OS või uued mälud annavad boosti aga tulemus tunduvalt parem (7831) :
Enne oli 32-bit XP SP2, E6750 @ 3,6GHz, 2x1GB DDR2 @ 900MHz 4-4-4-12
Nüüd 64-bit Vista Ultimate SP1, E6750 @ 3,6GHz, 2x2GB DDR2 @ 1080MHz 5-5-5-15
AHV-id võiks nüüd E8200, E8400, E8500, Q9300, Q9450, tulemusi ka normaalse 24/7 klokiga lasta
Isiklikult oleksin väga huvitatud Q9300 ja Q9450 skooridest kuna tegelen renderdamisega suht palju.
83 |
One
03.08.2008 20:48:22
CPU: AMD Athlon X2 4850E @ 2.8GHz / 1.2v
MBD: Biostar TA770 A2+
RAM: 2 x 1024MB A-Data PC2-8500
4770
Kommentaarid: 1009 loe/lisa |
728 |
CoiL
03.08.2008 22:25:35
Winterwind, väga hea et keegi viitsib ikka seda testi jooksutada ka AMD prosedega
AHV-id ärge pipardage, visake tulemusi Kui viitsin teen isegi tabeli, sest imo on see test väga hea jõudluse näide neile kes tegelevad CAD ja 3D programmidega.
Ühe tabeli osa tahaks teha sellise kus kõik prosed on DEFAULT seadetel (multicore rendering). Teine tabeli pool kus 24/7 klokiga (multicore rendering).
Kolmas tabeli osa võiks olla puhtalt kiiremate ühetuumaliste jaoks (single core rendering) kus võib ka kahe- ja neljatuumalisi jne. kasutada, tehes testi ainult ühe kiirema tuumaga (set affinity).
Tabelisse läheks kirja ka mitu bit OS on. Loomulikult oleks skriinidel nõudeks CPU-Z prose ja mälu aknad.
Eks vaatab kuidas tulemusi tuleb, siis teen võib-olla sellise tabeli valma.
83 |
Aah
Kommentaarid: 21 loe/lisa |
21 |
CoiL
04.08.2008 20:42:19
Aah, multicore rendering nii väike (7771) ? Ja seda E8400 @ 3,7GHz? E6750 @ 3,6GHz saab 7831
Kui viitsid pane igasugu winampid jms. taustal kinni ja vaata palju siis saad? Ning tee teine cpu-z aken ka lahti et mälude kohta ka infi saaks.
83 |
Nu
04.08.2008 20:50:22
64bit vista vs. 32bit xp teeb juba juba 700-800p vahet.
c2d teemas sai neid tulemusi võrreldud juba pool aastat tagasi
tookord:
tsitaat: |
proovisin 4ghz kah - 9433 |
_________________ DO you want it.. And if you had it would you flaunt it...
ss |
Kommentaarid: 177 loe/lisa |
157 |
CoiL
04.08.2008 20:55:13
Nu, nojah tal 32-bit OS küll aga skoor ikkagi ju väike imo E8400 peaks ometigi ju parem olema?
E6750 @ 3,6GHz ja 32-bit OS = 7135
E8400 @ 3,7GHz ja 32-bit OS = 7771 ...ainult ~650p rohkem ja seda 100MHz kõrgemal taktil. Veider imo.
83 |
One
29.11.2008 21:14:55
CPU: AMD Phenom X4 9550 @ 2.55GHz / 1.15v
MBD: Gigabyte GA-MA790GP-DS4H
RAM: 2 x 2GB A-Data Over Clock Extreme 1066+ @ 928MHz / 5-4-4-18 / 2.1v
GFX: Powercolor Radeon PCS HD4670
64bit Vista
1CPU: 2184
xCPU: 8031
Multiprocessor speedup 3.68
OpenGL: 3614
panin prime skriinile selle "cut"-i, et kellad õiged oleks.
Tegelikult benchi ajal prime ei jooksnud
728 |
