excalibur
16.07.2008 20:27:58
| proovi 3ghz peal palju siis punkte saab
262 |
Gljukats
16.07.2008 22:52:48
Intel Core 2 Quad Q6600 2.4 @ 3.6 GHz (9x400)
2x2Gb DDR2-800 @ 950 Apacer CL5-5-5-15 2.2V
ASUS Striker 2 Formula BIOS 1401
x86 Vista Premium, Cat 8.7beta
Gigabyte Radeon HD4870 512 mb 800/4500
P9421 (GPU score 8776 + CPU score 12084)
H5953 (GPU score 5464 + CPU score 12075)
X3735 (GPU score 3605 + CPU score 11991)
_________________ LEGO, LEGO, LEGO ... |
| Kommentaarid: 147 loe/lisa |
129 |
AJ
| Kommentaarid: 37 loe/lisa |
36 |
WäntWõll
make.believe
18.07.2008 22:02:42
Õige ka
300 |
G80
19.07.2008 00:26:41
| G80 kirjutas: |
Intel Core 2 Duo E8400 @ 4.0GHz
Asus P5E X38
4X1GB A-DATA Extreme Edition DDR2 800+ @ 445MHz 5-5-5-12
Gigabyte HD 4870 512MB @ 790/1100MHz
3DMark Score P8601 3DMarks
CPU Score 7948
Graphics Score 8843
Asus P5E X38
Gigabyte HD 4870 / 4850 CF X deff
[b]3DMark Score P10253 3DMarks
CPU Score 8131
Graphics Score 11230
Alustuseks hea küll.
210 |
Viilutaja
| Kommentaarid: 226 loe/lisa |
196 |
| Kommentaarid: 92 loe/lisa |
G80
19.07.2008 01:17:41
| tomorrow kirjutas: |
| Viilutaja kirjutas: |
| Sa Extrem presetiga lasta ei saa? |
See nõuab 1920x1200 molu .Ta saab maksimaalselt High lasta(1680x1050).Muidugi on alati võimalus custom settingud sisse panna mis on 1:1 Extreme-ga(v.a reso)  |
Kahjuks tõesti pole nii vägevat molu, tahtsin ise ka Extreme lasta aga siis tuli meelde, et deem seal 1920x1200 reso vaja.
210 |
One
20.07.2008 10:51:41
link :: Futuremark: NVIDIA GPU PhysX not allowed
Hi,
I've changed a couple of e-mails between Futuremark CEO Tero Sarkkinen who quickly commented current confusing situation in ORB and Hall of Fame.
NVIDIA's GPU PhysX was launched in the middle of summer and most of FM's staff are on holidays (Most people are here in Finland). Tero said timing couldn't have been worse but they have updated filtering system coming up which will handle the runs which are not following Futuremark's guidelines.
When I asked more specific about NVIDIA's GPU PhysX, he confirmed that it won't be allowed. (Since Vantage's CPU test 2 is designed to measure CPU physics calculations and it is clearly stated in the rules that GPU or driver can't affect the result significantly).
So from now on if you want to run offical 3DMark result or Hall of Fame result with NVIDIA gfx you have to use Futuremark approved WHQL driver and do not install NVIDIA PhysX System Software. |
728 |
Firefly
20.07.2008 11:07:24
ATI mehed hakkasid vinguma, kui mul endal ATI oleks siis mulle ka ei meeldiks aga vähemalt oli näha, et NVIDAI PhysX tööta väga hästi
142 |
G80
22.07.2008 14:07:23
Asus Maximus Formula X38
4X1GB A-DATA Extreme Edition DDR2 800+ @ 445MHz 4-4-4-12
Gigabyte HD 4870 @ 790/1100 + 4850 680/1100
3D Mark score P11447
210 |
Estnx
22.07.2008 14:23:12
| G80 kirjutas: |
| 3D Mark score P11447 |
Sama Siin, et pane teine 4870 kõrvale ja lööd minu tulemuse üle
Edit. Ja krt. sul on siin ka 2 kaarti
_________________ Just see vidin, mida sa oled otsinud... |
205 |
WäntWõll
make.believe
22.07.2008 15:08:19
Üks asi on eraldi füüsiline kaart,teine jutt aga ainult softi muudatus.
Ei ole tark jätta välja pretsedent nimega DX10.1 tugi
Mis oleks vast punaste poolele väikse eelise andnud ja seega pidid nad käituma võrdselt mõlema tootja suhtes
300 |
Firefly
22.07.2008 15:30:03
Võiks olla kolme sorti testid, GPU, CPU ja füüsika test kus siis kasutatakse kõike mida masin anda suudab. Puhtalt GPU arvel CPU skoori kolmekordistamine päris õiglane ei ole jah.
G80, GPU skoor on hea, sirka sama mis 4870X2 lubatakse. Prose skoor on aga jube pidur sul, kui sa saaks NVIDIA PhysX kasutada siis oleks üldskoor ilmselt 15k
142 |
G80
22.07.2008 15:38:36
| Firefly kirjutas: |
G80, GPU skoor on hea, sirka sama mis 4870X2 lubatakse. Prose skoor on aga jube pidur sul, kui sa saaks NVIDIA PhysX kasutada siis oleks üldskoor ilmselt 15k |
NVIDIA PhysX+45nm Yorkfield heal kellal annaks ikka rämedalt juurde jah.
3800-seeria puhul saadi see NVIDIA PhysX tööle.
210 |
Estnx
205 |
WäntWõll
make.believe
22.07.2008 15:45:48
Mingi seltskond modis jah midagi,aga link oleks hea kuna saaks ka proovida. 8)
Jutt oli et töötab 2900 seeriaga
300 |
G80
210 |
1dumbpcuser
97 |
Gljukats
29.07.2008 11:19:13
x86 Vista Premium, Nvidia GeForce 177.72
Gigabyte GeForce GTX260 896 mb 575(1240)/2000
P8672 (GPU score 7907 + CPU score 12218)
H5940 (GPU score 5444 + CPU score 12277)
X3912 (GPU score 3777 + CPU score 12158)
Gigabyte GeForce GTX260 896 mb 702(1404)/2430
P9956 (GPU score 9399 + CPU score 12113)
P11517 (GPU score 9395 + CPU score 35720) + Nvidia PhysX Enabled
H6961 (GPU score 6476 + CPU score 12093)
X4624 (GPU score 4478 + CPU score 12136)
129 |
siLc
01.08.2008 07:44:57
Q6600 @ 3GHz (333x9)
3x1GB Adata DDR2-800 def
ASUS P5Q-E
Club 3D HD 4870 def
Vista Business x64
Catalyst 8.7
P8238
CPU: 10037
GPU: 7773
186 |
Killzone88
01.08.2008 23:27:17
GIGABYTE GA-P35-DS3L
CLUB 3D HD 4870 @855/1090 (Asus TOP Bios)
2x A-DATA 2GB DDRII 16C-128Mx8 DDR800
Intel Core 2 Duo E8400 @ 3,2GHz
Chieftec 500W
Vista Ultimate 64 sp1
3D mark score P8233
GPU score 9075
CPU score 6446
| Kommentaarid: 20 loe/lisa |
Cb4
05.08.2008 12:58:03
| Gljukats kirjutas: |
X4624 (GPU score 4478 + CPU score 12136) |
Pole paha
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
| Kommentaarid: 113 loe/lisa |
95 |
excalibur
05.08.2008 14:35:29
| qx6850 def 9800gx2 def 10200pointsi
262 |
CoiL
| Kommentaarid: 95 loe/lisa |
83 |
excalibur
05.08.2008 15:47:19
| ei viitsi praegu enam teha. varsti teen formati siis panen õige tulemus mis peaks veel suurem tulema.
262 |
06.08.2008 00:53:09
Seoses uue PhysX softi väljalaskega mis toetab ka G80 gpu-sid lasksin uued testid:
AMD Athlon X2 3800+ @2.5ghz
4x512MB Corsair & OCZ @DDR 358 2-2-2-5 CR2
1x Nvidia GeForce 8800GTS 320MB @640/1621/920 (Core/Shader/Mem)
Windows Vista Ultimate x86 Build 6.0.6001.18000 Service Pack 1
750GB WD 7500AAKS
Nvidia GeForce v.177.79 WHQL Candidate Drivers + PhysX v.08.07.18
Entry: +54%
Performance: +26%
High: +34%
Protsendid lõpus näitavad palju PhysX üldskoorile juurde andis võrreldes varasemaga .Kui veab lasen nädala lõpus ka GTS SLI testid
Eelnevaid skoore näete siit: https://foorum.hinnavaatlus.ee/viewtopic.php?p=4501666#4501666
windsurfer
06.08.2008 02:29:26
Intel C2D E8400@ 4050mhz
Gigabyte P35C DS3R
A-data 2x1gb 800mhz@ 900mhz; 5-5-4-10
ATI Gigabyte HD4850 @680/1080
Vista SP1 32bit
CCC 8,7
| Kommentaarid: 42 loe/lisa |
39 |
Gljukats
07.08.2008 21:56:17
Intel Core 2 Duo E8200 2.66 @ 3.6 GHz (8x450)
2x2Gb DDR2-800 Apacer CL5-5-5-18 2.2V
ASUS Striker 2 Formula BIOS 1601
x86 Vista Premium, Nvidia GeForce 177.79
SLI 2xGigabyte GeForce GTX260 896 mb 575(1240)/2000
P11756 (GPU score 14989 + CPU score 7137)
P17050 (GPU score 14900 + CPU score 30066) + Nvidia PhysX Enabled
H9753 (GPU score 10422 + CPU score 7150)
X7136 (GPU score 7143 + CPU score 7016)
129 |
Stabby
09.08.2008 13:26:01
E6600 @ 3.2 GHz
HD4870 @ 790/1100
Vista 32-bit
Kingston 2x1 PC-6400 800MHz
ASUS P5N32-E SLI
| Kommentaarid: 35 loe/lisa |
trip
10.08.2008 15:38:22
q6600 2.4 @ 3.33 GHz (9x375)
Adata OC 800+ 2x1Gb DDR2-800 @ 938 CL5-5-5-15 2.1V
xfx 8800gtx
Abit ip35-e
x86 Vista Ultimate, Nvidia GeForce 177.79+physx enabled
P8154
gpu: 6530 cpu:32065
303 |
Cb4
95 |
Cb4
12.08.2008 16:39:37
Ma usun et nii 7+ peaks ise ka kätte saama!
Kui öhtul aeg, ajan masina pöördesse
tomorrow sa lased 177.83 jah?
Kus asud, lenan sulle proset
95 |
Firefly
12.08.2008 16:43:36
Cb4, ma sain GTS kasutades veel beta aegadest 8+ kätte, prose skoor oli kolmekordne tavalisest
142 |
WäntWõll
make.believe
12.08.2008 16:50:33
Free versiooni ei saa linkida,ainult ise näed
300 |
Cb4
12.08.2008 16:56:54
| Firefly kirjutas: |
Cb4, ma sain GTS kasutades veel beta aegadest 8+ kätte, prose skoor oli kolmekordne tavalisest  |
Sul oli 8800gts 512
Mul 320-nene ja revison A2!
Eks õhtul vaatab mis saab
wanawoll: Selge
95 |
Viilutaja
196 |
ufo56
12.08.2008 19:59:37
Vana hanguv win on. Performance test oli. Peal viimased driverid. prose 2.7ghz
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
Viilutaja
196 |
excalibur
13.08.2008 16:21:25
qx6850 def ja 9800gx2 def 1920x1200 resol lõppskoori ei andnudki kuid muud nr on olemas.
extreme ver kah samadel setingutel (8800gtx jooksis kotti selle peale)
262 |
Viilutaja
196 |
Viilutaja
196 |
Cb4
14.08.2008 11:43:20
q6600 @ 3.5ghz (stabiilne 3.92)
ram: 1124mhz (stabiilne 1300+)
8800gts 320 @ 708/1025mhz (mõned mhz-id saaks vast juurde kruvida)
7 kuud vana vista.
177.79+PhysX_8.07.18
Ning sain P7160.
Scriini ei teinud veel, seega tõestuseta jutt. Aga 8k-ni vist välja ei vea! Kui õhtul jahe, proovin korraliku OC-ga!
Vantage järgi vaadates on mu vana gts ikka päris hea veel
95 |
G80
14.08.2008 11:56:54
Cb4, seda kõike selle nvidia füüsika pärast.
210 |
Gljukats
14.08.2008 12:32:10
2x2Gb DDR2-904 Apacer CL5-5-5-18 2.2V
x86 Vista Premium, Nvidia GeForce 177.83
SLI 2xGigabyte GeForce GTX260 896 mb 666(1350)/2306
P12647 (GPU score 16737 + CPU score 7297)
P19064 (GPU score 16743 + CPU score 32639) + Nvidia PhysX Enabled
H10893 (GPU score 11934 + CPU score 7291)
X8244 (GPU score 8299 + CPU score 7324)
129 |
