07.05.2008 21:49:17
Doom 4 |
http://www.gamasutra.com/php-bin/news_index.php?story=18544
Mesquite, Texas-based independent developer id Software has announced that it is currently developing the fourth game in the long-running Doom franchise, a series notable for helping define the first-person shooter genre.
Doom 4 will be developed in-house at id. The company has not released an internally-developed game since 2004's Doom 3; it is currently also working on the Mad Max-esque post-apocalyptic shooter Rage.
No platforms were announced, but the new game is likely to be heading to PC, Xbox 360, and PS3. With the announcement of Rage came details on id's new multiplatform engine tech, known as id Tech 5.
Since the release of Doom 3, id has produced the externally-developed Quake 4 (Raven Software) and Enemy Territory: Quake Wars (Splash Damage). In the last decade, it has gone significant amounts of time between its own internal releases, making the current setup of two teams on large titles unusual for the company.
Said CEO Todd Hollenshead, "Doom is part of the id Software DNA and demands the greatest talent and brightest minds in the industry to bring the next installment of our flagship franchise to Earth."
No details were given on the content of the game or its expected release period. id Software has traditionally worked with publisher Activision but has not announced a partner for either Rage or Doom 4, and has confirmed in the past it has no existing exclusivity agreements. |
_________________ - londiste
217 |
EvilKatarn
diivanilill
07.05.2008 23:27:28
| Doom 4 võiks olla sama revolutsiooniline graafika poolest, nagu Doom 3 oli.
81 |
mutabor
07.05.2008 23:51:16
olgem ausad revolutsioonilisem oli siiski far cry kuna jõudis ette.
_________________ /allkiri |
| Kommentaarid: 24 loe/lisa |
22 |
Anisse
08.05.2008 09:59:24
võiks jah revolutsiooni teha ja vahelduseks valgemas ümbruses tegevus toimuda.
Pimedas joostes pole vahet mis graafika on
08.05.2008 10:07:22
ot:
mutabor, mis osas far cry revolutsiooniline oli?
217 |
08.05.2008 10:45:12
| amddude kirjutas: |
| Doom 4 võiks olla sama revolutsiooniline graafika poolest, nagu Doom 3 oli. |
...ja graafikale lisaks võiks vähegi põnev stoori olla, Doom3 ei köitnud kohe absoluutselt, samas Quake 4 oli ja on vägagi nauditav.
147 |
kallur777
külaline
08.05.2008 15:27:09
| Eitea millal pilte näha võib..
Scart
08.05.2008 15:31:16
| londiste kirjutas: |
ot:
mutabor, mis osas far cry revolutsiooniline oli? |
Selles, et Kauge Karje tuli välja täiesti tundmatuna enne, kui Kaks Suurt ja paugutas nad mõlemad oma graafika ja mängitavusega ribadeks?
101 |
486
08.05.2008 21:36:01
Vaevalt, et see samad haippi tekitab nagu Doom3
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
heretic666
08.05.2008 21:38:08
| Anisse kirjutas: |
Pimedas joostes pole vahet mis graafika on |
Sõna silmad ka väsitab see muidu ära jubedalt.
| Kommentaarid: 73 loe/lisa |
UB
16.06.2008 23:37:00
Doom 4 |
link :: Kotaku
Kuigi uudised väidavad midagi muud, ei olnud minu arvates Doom 3 väga edukas, kuigi seda tehti päris kaua. Nüüd igatahes on algust tehtud mängu järje valmistamisega nagu lingilt leida võib. Üheks ebaedu märgiks on minu arvates ka see, et Doom3 laienduspakett leidis väga kiiresti tee poelettidele, sellest aga võib teha kaks järeldust - kas müük ei läinud nii hästi kui taheti või oli laienduspakett juba eelnevalt valmis tehtud ning saadeti müüki koheselt kui ka kõige laisemad mängijad olid põhimängu lbi saanud, et siis sama soojaga edasi minna. Võta sa kinni, kumb on õige...
7. mail andis ID Software teada, et alustatakse Doomi 4 osa tegemist. Eks siis nüüd on jälle mida oodata, sest meeldib see kellelegi või mitte, on Doom olnud alati üks nendest mängudest mis paneb märgi maha mida teised peavad ületama. Praegu on vara oodata mingisuguseid pilte või videosid, kuid ma usun, et sügisel võib juba esimesi pildikesi netist kindlasti leida. Eks siis jagage teistega ka
| Kommentaarid: 45 loe/lisa |
39 |
KillerXP
17.06.2008 02:08:51
hmm järgmine närvesööv mäng turule tulemas. Mäletan kolmandat osa, kus juba närvid olid pidevalt pinges kui mängisin. Eriti pingeline on see nõrganärvilistele. Lõpptulemusena ma eriti kaugele ei suutnudki mängida
Kõige naljakam kogemus 3ndast versioonist oli siiski, kus läksin rõdule välja vaatama õlle käes, toas olid kardinad ees, sõber mängis doom 3'e just ja käis rõve pauk ära, vaatasin siis mis juhtus ja sõber oli tooliga ümber kukkunud ehmatusest
| Kommentaarid: 98 loe/lisa |
93 |
WäntWõll
make.believe
17.06.2008 02:46:36
Järgmine mäng mis tahab 25 generatsiooni graafikat
ei saa vait olla
Aga tegelikult Nv 280GTX tõmbab lõtsi
300 |
heretic666
17.06.2008 13:18:54
KillerXP, jah, pean nõustuma, et Doom 3 on üks üksikuid mänge, mis tõesti oskab ehmatada. Eriti kui mingi uks tuleb lahti ja siis Imp kargab BÖÖ sulle sülle. Tahaks juba screene näha
UB
17.06.2008 13:56:10
Mind huvitab rohkem see, milleks uus mootor võimeline on ning kas seekord osatakse mängu veidi rohkem avarust tuua. Doom 3-s tekkis selline santehniku tunne
39 |
Simmi
17.06.2008 14:51:01
ei tea kas selles osas on teip leiutatud ? või relvadele taskulambi monteerimis detail
heretic666
17.06.2008 14:54:39
Esialgu oli jah Doom 3 mootor selline, mis ei saanud väliruumidega kuigi hakkama, kuid nüüd loodi MegaTexture, millega saad Doom 3 ka õues hästi hakkama (Quake Wars praegu ainuke mäng, millel see feature, Return To Castle Wolfenstein 2 hakkab sama asja kasutama).
Foxxx
17.06.2008 15:11:14
| Quake 4 oli ju ka suuresti väljas. Ei ütleks, et midagi häda oleks olnud.
| Kommentaarid: 64 loe/lisa |
61 |
piimaPAKK
17.06.2008 15:40:23
Et mootorist aimu saada tasub vaste Rage screene piiluda, see ID uusim mäng millest pildid olemas.
Kasutab ennem mainitud MegaTexture tehnoloogiat ja toimub väljas suurel kaardil.
UB
20.06.2008 08:26:32
ot:
Far Cry puhul oli revolutsiooniline kindlasti see, et seda oli põnev mängida ning läbimiseks oli mitmeid võimalusi. Aasta alguses mängisin selle mängu veelkord läbi ning siis pakkus ta mulle jälle üllatusi
39 |
madness
20.06.2008 17:11:35
| UB kirjutas: |
ot:
Far Cry puhul oli revolutsiooniline kindlasti see, et seda oli põnev mängida ning läbimiseks oli mitmeid võimalusi. |
a selles ju midagi revolutsioonilist küll ei ole.
| Kommentaarid: 13 loe/lisa |
melofan
20.06.2008 17:46:29
| Doomi sõna ise juba ongi vanematel inimestel seostatav kui labürint shooter mäng. See on klassika. Doom3 ainuke muutus oli graafika. Ma loodan, et Doom jääbki labürindiks kus käid kitsastes koridorides ega muutu mingiks viljapõldudel uitamismänguks. Vastasel korral ta pole enam see vana hea Doom!
| Kommentaarid: 7 loe/lisa |
v2hja
20.06.2008 20:27:15
| mutabor kirjutas: |
| olgem ausad revolutsioonilisem oli siiski far cry kuna jõudis ette. |
far cry oli lihtsalt värviline - doom mängis real-time valgusega ja varjudega
doom3 > farcry
_________________ www.ninjatune.net
RIP Monkey Radio |
| Kommentaarid: 74 loe/lisa |
60 |
mutabor
20.06.2008 21:58:39
v2hja, erm... doom mängis real-time valgusega ja varjudega, nõus. per-pixel shader oli tõesti doom3's kasutuses. see oli ka Far Cry's - ainult et 5 kuud varem. värviline või mitte, ei mängi minu jaoks rolli. mõlemad mängud meeldisid mulle erinevatel põhjustel ja ausalt öeldes ma ei oskagi öelda kumb rohkem. küll ma ei eira fakti et Far Cry tõstis latti ysna kõrgele teiste mängutootjate jaoks sel hetkel kui jõudis poelettidele seninägematu graafiliste võimalustega.
22 |
UB
21.06.2008 10:17:30
melofan, Mis sa räägid - võta Doom või Doom 2 ette ning sa näed millised suured väljakud seal on - annab ikka oodata millal rakett ühest väljaku otsast teisse jõuab
39 |
melofan
21.06.2008 13:13:44
| Duke Nukes on väljakud. Aga vot Doomi sai nii ammu mängitud, et võibolla tõesti avarusi ma ei mäleta, vaid koridorid kummitavad peas, heas mõttes kummitavad 8)
G80
26.06.2008 20:04:20
| heretic666 kirjutas: |
KillerXP, jah, pean nõustuma, et Doom 3 on üks üksikuid mänge, mis tõesti oskab ehmatada. Eriti kui mingi uks tuleb lahti ja siis Imp kargab BÖÖ sulle sülle. Tahaks juba screene näha  |
Ojaa, need heli+ valgus efektid ja siis tuleb kuskilt koll välja.
Ainuke mäng, mida pelades tõusis vererõhk 200 peale, ikka jubedalt ehmatas.
Imo oli ikka Doom 3 palju ägedam, kui Far Cry.
210 |
mutabor
26.06.2008 22:46:03
miskipärast mina harjusin doom3 ehmatustega suht ruttu ära ja oli kuidagi ette aimatav kust kapist järjekordne koll välja kukub...
viimaste ehmatavate mängude seas minu jaoks oli The Suffering 1 ja 2, mõnusalt poeb naha alla, selline haige mäng... tegelikult mitte nii väga ehmatas isegi vaid koguaeg hoidis vastiku ja samas mõnusa pinge all.
selles nimekirjas doom3 on kuuendal kohal:
http://www.youtube.com/watch?v=TJI5dzl8GTE
22 |
Aah
26.06.2008 23:42:01
| Doom 3 oli väga hea kui mõningad asjad välja jätta. Doom4 on väga oodatud mäng minu poolt, vähemalt hetkel.
| Kommentaarid: 21 loe/lisa |
21 |
313 |
KillerXP
28.06.2008 16:27:16
huvitav kas siin on miskine vandenõu ps3 vastu või milles asi... just vaatasin Red alert 3 gameplay videot ja seal karjuti ka et x360 ja pc
93 |
v2hja
60 |
piimaPAKK
28.06.2008 20:22:21
| KillerXP kirjutas: |
huvitav kas siin on miskine vandenõu ps3 vastu või milles asi... just vaatasin Red alert 3 gameplay videot ja seal karjuti ka et x360 ja pc  |
Niipalju kui mäletan, siis ID rääkis Rage kohta mingit juttu, et nad saavad compileda Win, Mac, X360 ja PS3 versiooni samast muutmata sourcest.
Seega ei näe miks nad peaksid D4ga muud moodi talitama, kui just MS papiga ei lehvita või D3 ajast pole mingit pikemaajalist lepingut all.
28.06.2008 20:45:38
Xbox 360-le on odavam ja lihtsam mänge teha, samuti on installbase suurem, kuhu neid hiljem müüa. ja no loe seda ka, DOOM-i looja John Carmack isiklikult
http://www.gamepro.com/news.cfm?article_id=93630
PC/Xbox 360 mänge on tegelikult väga palju. PC/PS3 omi nagu ei teagi, aga eks mõni võibolla on ka.
313 |
d3t
28.06.2008 20:59:15
Kui asi on PC peal siis pole nagu vahet, ei tekita küll mingit halba tunnet. Nutta tuleks siis kui oleks Xbox Exlusiiv.
Ma ei tea, tahaks sellelt mängult Crysisest paremat graafikat
_________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
| Kommentaarid: 85 loe/lisa |
72 |
28.06.2008 21:50:10
| d3t kirjutas: |
Ma ei tea, tahaks sellelt mängult Crysisest paremat graafikat  |
enne pead ainult sellise video muretsema, mis Crysist veaks
313 |
d3t
28.06.2008 21:59:16
Skeptik, täitsa olemas ju
72 |
28.06.2008 22:34:36
| d3t kirjutas: |
Skeptik, täitsa olemas ju  |
profiilis olev 8600GT? mispidi sa sellega Crysise eye candy-t näed? ja juba tahad veel paremat
313 |
G80
28.06.2008 22:45:42
| d3t kirjutas: |
Näita kaarti, mis veab 2560x1600+Very High+4XAA ning üks AVG 60FPS.
Ma arvan, et selle näitamiseks läheb 1-2aastat.
210 |
heretic666
28.06.2008 22:49:13
| Kas mänge peab ilmtingimata mängima 2560 resul olenemata mis tollides LCD sul on või ?
d3t
28.06.2008 23:22:44
Skeptik, ega mu monitor ei võimalda üle 1280 reso ju Ning selle resoga polegi eriti vingemat kaarti vaja ju
72 |
KillerXP
28.06.2008 23:55:33
| d3t kirjutas: |
Skeptik, ega mu monitor ei võimalda üle 1280 reso ju Ning selle resoga polegi eriti vingemat kaarti vaja ju  |
no mul on endal ka 8600gt all ja no sellest pole miskit asja crysise mängimisel - low-medium seaded ja reso ka veel alla võetud, vist oli 800x600 peale või oli 1024x768... ei mäleta enam....
ok jah tõesit ta low-medium jookseb aga miskit silmailu vägapalju sa ei saa...
93 |
d3t
28.06.2008 23:58:34
KillerXP, medium/high on mul ja stabiilne 30+ fps
72 |
KillerXP
29.06.2008 00:00:58
| d3t kirjutas: |
KillerXP, medium/high on mul ja stabiilne 30+ fps  |
hmm ma millegipärast usun, et vahepeal kiskus vägagi alla... ma üritasin just püsivalt kõrget fpsi saavutada, olenemata palju objekte ekraanil oli.
93 |
29.06.2008 02:34:52
| d3t kirjutas: |
sel juhul pole sa ju Crysise tippu näinudki ja juba tahad paremat
313 |
tonism
29.06.2008 03:38:38
| veel üks crysise thread?
Heineken
29.06.2008 03:56:32
Ma isegi ei teadnud , et Doom 4 välja kuulutatud , kuni seda teemat nägin , veel üks mäng , mida tasub oodata... ja ilmselt peab oma aastakese ootama .
Ja sellega , et Doom peabki koridorites olema , nõustun täielikult .
Doom 3-e sai alguses pelatud sellise arvutiga , mis vaevaliselt madalatel settingutel jooksutas ( sama arvuti mis profiilis , aga FX5200 ja 512MB RAMi , oleks vast aeg uus masin muretseda ) .
Loodan , et Doom 4 nõudlikum , kui Crysis ei ole , või kui on siis vastav raud kah väljas .
23 |
d3t
29.06.2008 14:13:19
Skeptik, ütle veel seda paar korda. Varsti tulebki kätte aeg mil kogu masina välja vahetan
72 |
UB
29.06.2008 20:29:15
| Muidugi tahaks näha ilu täies hiilguses, aga kui mängutavus kannatab sisu puudumise kallal, siis on küll paha. Doom 3s üritati põnevust lisada nende koodide otsimisega, mis tähendas aga taustaks meeletult mõttetu materjali läbikuulamist. See küll eriti mängitavusele kaasa ei aidanud. Loodetavasti on järgmises osas asjad lahendatud mingi tegevuse läbitegemisega, mitte mingite failide läbilappamisega.
39 |
30.06.2008 00:40:49
| G80 kirjutas: |
| d3t kirjutas: |
Ma arvan, et selle näitamiseks läheb 1-2aastat.  |
cpu-bound. triple-sli gtx280 sai 38fps, 2 kaarti said 35fps, 1 sai 18fps.
x360 on otsapidi directx ja ilmselt ka osa samu development toole.
217 |
