praegune kellaaeg 01.10.2025 08:57:58
Marx
23.05.2008 22:21:50
xhtlm w3c valitaator |
kuidas kirjutada sellist koodi nagu if(x>10 && x<100){.........} ,mis läbiks w3c valitaatori, kuidas tuleks kirjutada && (and) , <,<=
Funktsioonid töötavad aga ei läbi valitaatorit
AMD
23.05.2008 22:25:15
Javascript pane eraldi faili
_________________ From now on, the forum is owned by AMD.That means that you are NO LONGER allowed to talk about, or even mention *ntel. |
Kommentaarid: 335 loe/lisa |
145 :: |
12 |
Marx
23.05.2008 22:35:11
On pandud selliste tagide vahel
<script type="text/javascript">
function wpiir(sag,g,pk){
if(sag>=10 && sag <400){
var wp=2;
var r=Math.sqrt((pk*Math.pow(10,(g/10)))/(4*pi*wp));
return(r);}
else if (sag>=400 && sag < 2000 ){
var wp=sag/200;
return(r);}
else if (sag>=2000 ){
var wp=10;
return(r);}
</script>
Firefly
23.05.2008 22:51:54
Marx, kommenteeri JS välja
Kommentaarid: 151 loe/lisa |
141 |
Traf
23.05.2008 22:53:47
Ehk siis
<script type="text/javascript"><!--
var wp=2;
return(r);}
var wp=sag/200;
return(r);}
var wp=10;
return(r);}
--></script> |
Kommentaarid: 49 loe/lisa |
48 |
Marx
23.05.2008 23:53:22
pole inimest pole probleemi
pole koodi pole probleemi
mõned read validaatorilt
Line 54, Column 18: character "&" is the first character of a delimiter but occurred as data.
else if (sag>=400 && sag < 2000 ){✉
This message may appear in several cases:
You tried to include the "<" character in your page: you should escape it as "<"
You used an unescaped ampersand "&": this may be valid in some contexts, but it is recommended to use "&", which is always safe.
Another possibility is that you forgot to close quotes in a previous tag.
Line 54, Column 19: character "&" is the first character of a delimiter but occurred as data.
Line 54, Column 25: character "<" is the first character of a delimiter but occurred as data.
Firefly
23.05.2008 23:58:25
Marx, ega see ei tähenda, et JS ei töötaks kui sa ta üleval poole mainituna välja kommenteerid, lihtsalt lollid brauserid ei näe siis seda, mis ei oskaks nagunii seda kasutada.
141 |
Marx
24.05.2008 00:35:06
Tore lugu küll ja töötabki, ise küll selle peale poleks tulnud
Tänud
lisa lemmikuks |
