praegune kellaaeg 06.10.2026 18:36:46
bantid
18.05.2008 22:03:22
Phpbb thehumanizer120 Install |
Äkki keegi kirjutaks algusest peale, kuidas seda installida foorumile külge. Oleks väga abi vaja.
_________________ Kasutatud arvutivaruosade e-pood www.arvutiromula.ee |
113 |
maremark
23.05.2008 22:24:49
mod? õpetuse järgi ikka:
## MOD Title: The humanizer
## MOD Author: Underhill < webmaster@underhill.de > (N/A) http://www.underhill.de/?language=english
## MOD Description: Changes the register form to prevent spam bots by a simple individual question
## MOD Version: 1.2.0
## Installation Level: easy
## Installation Time: 5 minutes
## Files To Edit:
## includes/usercp_register.php
## templates/subSilver/profile_add_body.tpl
## language/lang_english/lang_main.php
## Included Files: N/A
## License: http://opensource.org/licenses/gpl-license.php GNU General Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes:
## Do not use the example question within this MOD. Only your own individual question will be save!
## This modification was built for use with the phpBB template "subSilver"
## Screenshot: http://www.underhill.de/downloads/phpbb2mods/thehumanizer.png
## Download: http://www.underhill.de/downloads/phpbb2mods/thehumanizer.txt
## MOD History:
## 2007-07-14 - Version 1.2.0
## - Changed to individual question
## 2006-12-31 - Version 1.1.1
## - Removed HTML comment
## - Successfully tested with phpBB 2.0.22
## - Changed Author Notes
## 2006-08-26 - Version 1.1.0
## - Added dynamic attribute to confuse spam bots
## - Changed access value to prevent spam bot guessing
## 2006-07-17 - Version 1.0.5
## - Added notes for a frequent install problem
## - Added forgotten history entry for version 1.0.4
## - Fixed more little spelling errors
## 2006-06-11 - Version 1.0.4
## - Successfully tested with phpBB 2.0.21
## - Fixed little spelling errors
## 2006-04-29 - Version 1.0.3
## - MOD Syntax changes for the phpBB MOD Database
## 2006-04-19 - Version 1.0.2
## - Fixed bug with mode=editprofile (Markus Wandel and fanrpg)
## - Fixed some little problems with spelling and usability
## 2006-04-18 - Version 1.0.1
## - MOD Syntax changes for the phpBB.de MOD Database
## 2006-04-17 - Version 1.0.0
## - Final-Version
## - Successfully tested with EasyMOD beta (0.3.0)
## 2006-04-14 - Version 0.0.1
## - BETA-Version
## - Built and successfully tested with phpBB 2.0.20
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
#-----[ DIY INSTRUCTIONS ]------------------------------------------------------
#-----[ OPEN ]------------------------------------------------------------------
#-----[ FIND ]------------------------------------------------------------------
# NOTE - This is a partial match, the whole line on a fresh phpBB installation looks like this:
# validate_optional_fields($icq, $aim, $msn, $yim, $website, $location, $occupation, $interests, $signature);
#-----[ AFTER, ADD ]------------------------------------------------------------
# NOTE - Not "INLINE AFTER, ADD"! - Add this after the whole line like:
// The humanizer MOD
$humanizer_attribute = md5(($board_config['board_startdate'] + $board_config['board_timezone']) * $board_config['avatar_filesize']);
$ruhuman = isset($HTTP_POST_VARS[$humanizer_attribute]) ? $HTTP_POST_VARS[$humanizer_attribute] : '';
$ruhuman = trim(htmlspecialchars($ruhuman));
if ($board_config['enable_confirm'] && $mode == 'register')
#-----[ BEFORE, ADD ]-----------------------------------------------------------
$humanizer_answers = $lang['humanizer_answers'];
if (!in_array(strtolower($ruhuman), $humanizer_answers) && $mode == 'register')
$error = TRUE;
$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Are_u_human_wrong'];
if ( ($mode == 'register') || ($board_config['allow_namechange']) )
if ( $mode == 'register' )
$template->assign_block_vars('switch_register', array());
'SIGNATURE' => str_replace('<br />', "\n", $signature),
'HUMANIZER' => stripslashes($ruhuman),
'L_EMAIL_ADDRESS' => $lang['Email_address'],
'L_ARE_U_HUMAN' => $lang['Are_u_human'],
'L_ARE_U_HUMAN_EXPLAIN' => $lang['Are_u_human_explain'],
'S_ALLOW_AVATAR_UPLOAD' => $board_config['allow_avatar_upload'],
'S_HUMANIZER_ATTRIBUTE' => $humanizer_attribute,
<!-- END switch_confirm -->
<!-- BEGIN switch_register -->
<tr>
<td class="row1"><span class="gen">{L_ARE_U_HUMAN} *</span><br /><span class="gensmall">{L_ARE_U_HUMAN_EXPLAIN}</span></td>
<td class="row2">
<input type="text" name="{S_HUMANIZER_ATTRIBUTE}" class="post" style="width: 100px" size="10" maxlength="15" value="{HUMANIZER}" />
</td>
</tr>
<!-- END switch_register -->
$lang['Are_u_human'] = 'Are you human?';
$lang['Are_u_human_explain'] = 'Sorry, but this stupid question shall keep away the bots from this forum. Please type your answer in the following text field.';
$lang['Are_u_human_wrong'] = 'Sorry, but the "humanizer" question must be answered correctly.';
// possible humanizer answers - only use this syntax:
$lang['humanizer_answers'] = array('yes', 'jes', 'yo');
#-----[ SAVE/CLOSE ALL FILES ]--------------------------------------------------
# EoM |
| Kommentaarid: 25 loe/lisa |
24 |
