sõnum ![Teata moderaatorile Teata moderaatorile](./images/icon_move_w.gif) |
RassK
![RassK RassK](https://foorum.hinnavaatlus.ee/images/avatars/upload/39a932224d66008d67e1a74c808c85a6.png)
15.05.2008 18:49:24
AMD laseb RV770 välja 18-ndal juunil |
link :: VR-Zone
VR-Zone kirjutas: |
AMD has just confirmed the marketing name for RV770 yesterday which is no surprise to anyone, the Radeon HD 4800 series. RV770PRO is Radeon HD 4850, RV770XT is Radeon HD 4870 and R700 is Radeon HD 4870 X2. AMD will be shipping RV770 GPUs to AIB by end of this month and you can expect different card designs from the manufacturers at launch. AMD is set to launch the Radeon HD 4850 on June 18th and it is definitely a hard one with retail availability on the same day. Radeon HD 4870, however, will be launched a week later on June 25th with retail availability in July due to GDDR5 availability. Radeon HD 4870 X2 will come later in Q3. As for the clocks, we won't be revealing them yet but the RV770XT core clock is not going anywhere above 800MHz.
Kuuldavasti siis tuleb neid 4xx0 seeria kaarte rohkem, kuid ainult 48x0 on RV770.
Muude allikate väitel peaks tulema siis need kaardid:
HD 4870X2
HD 4870
HD 4850
HD 4670
HD 4650
HD 4470
HD 4450
HD 46x0 seeria ja 44x0 seeria kaardid on siis veel omakorda teiste RV'dega (madalamad)
Kommentaarid: 112 loe/lisa |
![](./images/komment/img_10_1.gif) ![](./images/komment/img_10_0.gif) ![](./images/komment/img_10_2.gif) |
98 |
![](templates/HinnaVaatlus/imagesHV/spacer.gif) |
SurfData
![SurfData SurfData](https://foorum.hinnavaatlus.ee/images/avatars/upload/5c55717e37906583cefeff94970b781a.png)
15.05.2008 20:45:25
DDR5??? Nvidia pole vist DDR4 kasutades ühtegi kaarti vist teinud, AMD läheb juba DDR5 peale. Aga eks tuleb ootama jääda mis sellest saab
Kommentaarid: 84 loe/lisa |
74 |
High-Q
![High-Q High-Q](https://foorum.hinnavaatlus.ee/images/avatars/upload/ed610b53744153796e234a434724ed8d.jpg)
16.05.2008 12:05:58
nv pole gddr4 teed läinud seetõttu, et gddr4 ei omanud voolutarbimise eelist gddr3-me ees, samuti loobuti kõrgema mälu siseviiteaegade (latency), üsna väikse taktierinevuse ning oluliselt kangema sisseostuhinna tõttu. lisaks oli gddr4 levik ja tootmine piiratud.
väidetavalt gddr5 parandab need gddr4 vead, st samsung juba toodab neid mõislikus hulgas, samuti on eelised kõrgema takti ning mõistliku voolutarbe juures.
igivanal gddr3-l oli lihtsalt hea tasakaal: odav hind, massiline levik ja hea jõudlus. miks rikkuda hästi töötavat asja?
kõige huvitavamad kaardid on muidugi 4870 ja 4850 (need siis peaks olema hd 3850 loogilised järglased). Kui suudetakse enamvähem hoida nende hetke turuhinda, parandada ilma AA/AF mängude jõudlust kasvõi 25%, aga kaotada olulise jõudlusekao AA/AF kasutuamisel, siis võivad ju päris pädevad kaardid tulla.
Kommentaarid: 107 loe/lisa |
97 |
libe
kvaliteetne mees
![libe libe](https://foorum.hinnavaatlus.ee/images/avatars/upload/72a9ca22075894b8de356b71160d9842.jpg)
17.05.2008 17:41:26
4870x2 kõlab huvitavalt
peab ainult korpust vahetama
_________________ ☠ |
Kommentaarid: 82 loe/lisa |
RassK
18.05.2008 14:20:12
Mõndadel andmetel on:
HD 4870 32% kiirem kui 8800GT, 22% kiirem kui 9800GTX ja 12% kiirem kui HD 4850.
Ning HD 4850 20% kiirem kui 8800GT ja 10% kiirem kui 9800GTX.
Kui sedasi edasi peaks minema, siis peaks HD 4870X2'st tulema 10-15% kiirem kaart kui 9800GX2.
viimati muutis RassK 31.05.2008 12:10:59, muudetud 1 kord |
98 |
djkiller
![djkiller djkiller](https://foorum.hinnavaatlus.ee/images/avatars/upload/0c17024f29f8505346361a86e68b6ce0.jpg)
18.05.2008 14:26:45
LOODAME
Kommentaarid: 222 loe/lisa |
201 |
excalibur
![excalibur excalibur](https://foorum.hinnavaatlus.ee/images/avatars/upload/51537a403f6dba68a2fc62f54e076316.jpg)
19.05.2008 19:46:17
eestisse jõuab 18september. pakun
Kommentaarid: 314 loe/lisa |
260 |
![Tomorrow Tomorrow](https://foorum.hinnavaatlus.ee/files/me3_667.jpg)
20.05.2008 14:58:08
excalibur kirjutas: |
eestisse jõuab 18september. pakun |
Nice guess .Sa Eesti riigieelarvet ei taha kokku panna?
Kommentaarid: 89 loe/lisa |
79 |
Elof
![Elof Elof](https://foorum.hinnavaatlus.ee/images/avatars/upload/2a809c6b81292a38cb10772356710964.png)
20.05.2008 15:06:11
krusu70 kirjutas: |
HD 4870 32% kiirem kui 8800GT, 22% kiirem kui 9800GTX ja 12% kiirem kui HD 3850.
Ning HD 3850 20% kiirem kui 8800GT ja 10% kiirem kui 9800GTX.
Kui sedasi edasi peaks minema, siis peaks HD 4870X2'st tulema 10-15% kiirem kaart kui 9800GX2. |
Kuna 8800GT on parasjagu kiirem kui HD3850 siis selle võrdluse tulemuseks saab absurde kinnise ringi, mõlemad kaardid on kiirmad kui kumbki neist.
4850?
Kui see punaseks värvitud number õige, siis ilmselt ka võrdlus 4870 on 12% kiirem kui 4850, mitte 3850.
Kommentaarid: 212 loe/lisa |
175 |
Pihv
![Pihv Pihv](https://foorum.hinnavaatlus.ee/images/avatars/upload/f745274eac69d00b54f1914fd9125804.jpg)
28.05.2008 16:30:03
Nii palju kui mina tean olevat oodata juba juuni lõpp, juuli algus.
Kommentaarid: 100 loe/lisa |
93 |
noxton
![noxton noxton](https://foorum.hinnavaatlus.ee/images/avatars/upload/ce36e5dae7aa0cec9c70ad176c525b11.gif)
29.05.2008 22:13:11
peab siis veel kannatama kaardi vahetusega hea uudis!
Kommentaarid: 186 loe/lisa |
169 |
RassK
31.05.2008 12:10:35
Elof, tänan tähelepanu pööramast
98 |
siLc
01.06.2008 00:48:55
krusu70 kirjutas: |
Ning HD 4850 20% kiirem kui 8800GT ja 10% kiirem kui 9800GTX. |
Kui siis nii on, siis võib kord üle pika aja ka punase laagri kaart mu õuele (kasti tulla) 8800GT asemele
Kommentaarid: 194 loe/lisa |
183 |
05.06.2008 15:51:23
79 |
