Ezh
06.05.2008 01:54:12
Kaspersky 2009 final - täiesti uus põlvkond! Arvamused? |
Ma teen uue teema, kuna nüüd see ei ole enam alpha/beta, kuid Technical Release.
Kaspersky-l on väljas täiesti uus põlvkond - versioon 2009 (8.0). Kauplustesse ilmub see versioon ainult suve lõpus, kuid tehnisel on ta juba olemas.
Versioon on MEGAkiire! Sisaldab palju-palju uusi tehnoloogiaid ja kasutajaliidest.
Alla laadida saab siit:
ftp://ftp.kaspersky.ee/beta/2009/TR/
Beeta alla on see pandud kuna see ei ole veel ametlikult väljas. Samuti asub seal "Release Notes".
Sobib aktiveerimiskood 7.0 versioonist.
On oodatud arvamused vanadelt ja uuetelt kasutajatelt. Kui tekib mingi probleeme või leiate vead kirjutage siia.
Põhilised täiustused(inglise keeles)
- NEW: HIPS (http://en.wikipedia.org/wiki/Intrusion-prevention_system)
- NEW: Whitelisting Technology (whitelisting certain programs to automatically allow Kaspersky to decide whether an application can connect to the internet and perform specific activity... less user intervention and more user friendly... less popups and requests from PDM and firewall.
- NEW: Scanning of Vulnerabilities in installed programs (so you can update them to prevent the programs being "exploited" and malware being installed on your computer via them)
- NEW: Advanced Reporting Capabilities (more in depth reports of activity of your programs and more statistics)
- NEW: Virtual Keyboard (to prevent keyloggets logging keys, good to use when entering personal details/passwords)
- NEW: Database of malicious URLs (Alerting users about prolific malware hosting websites)
- NEW:System Restore Wizard (Help fix damage caused to the computer after an infection; restoring functionality)
- NEW: GUI
- IMPROVED: Speed of overall product components (More efficient and faster scanning and will not slow computer down as much as previous versions thanks to the rebuilt/improved antivirus engine.
- Enhanced PDM
- Improved Heuristics
- New Packer Detection (suspicious packer and multi-packer)
Kommentaarid: 7 loe/lisa |
06.05.2008 16:41:19
katsu olla, palju neid kaspersky teemasid siin olema peab?
_________________ - londiste
Kommentaarid: 241 loe/lisa |
215 |
Ezh
06.05.2008 16:54:04
See oli beeta. Nüüd on juba täis versioon. Kas ise oled juba proovinud?
tsihh
13.05.2008 15:37:53
Peal olnud u nädala ja kiirem tundub küll eelnevatest olema (KAV). Üks probleem ka siiani välja tulnud: nimelt paneb , peale Kaspersky installli, messenger (8.5.1302.1018) end suvalisel ajal kinni kui kella juures oleva ikooni peale minna. Event Viewer ühtegi viga ei näita, kui messenger uuesti käivitada, siis töötab jälle probleemideta kuni mingi ajani.
Kommentaarid: 59 loe/lisa |
58 |
Ezh
13.05.2008 15:49:32
OK. Panen kirja KL-le.
15.05.2008 09:18:14
Re: Kaspersky 2009 final - täiesti uus põlvkond! Arvamused? |
Ezh kirjutas: |
Versioon on MEGAkiire! |
väga tehniline väide
oleks siis vähemasti miskeid võrdlusgraafikuidki...
Kommentaarid: 85 loe/lisa |
Kommentaarid: 1141 loe/lisa |
721 |
Ezh
721 |
lehm2
15.05.2008 21:27:48
Miilised eelised on siis Nod32 ees ?
_________________ Piilu siia, progreja!
Vajad abi Node.JS-ga ?
Võta ühendust ! |
Kommentaarid: 15 loe/lisa |
Lord Ami
15.05.2008 21:38:25
lehm2 kirjutas: |
Miilised eelised on siis Nod32 ees ? |
Virtual Keyboard
Proactive defense module uute viiruste jaoks(sama teeb ka heuristika)
Kaspersky uuendused on mahukamad
vaata
http://www.kaspersky.com/viruswatch3 (ekraani resolutsioon peab olema suhteliselt suur selle vaatamiseks)
Viimase 24h jooksul on lisatud ca 3000 uut viirust.
Nod-il vastu
http://www.nod32.ee/uuendused
Kommentaarid: 57 loe/lisa |
52 |
Ezh
16.05.2008 01:00:05
lehm2, proovi ise ära. Aga oota järgmise nädala - ilmub uuendus (laaditakse automaatselt alla) mõne parandustega.
17.05.2008 19:03:22
Ezh: Kas see uus ja finaalvariant ka Safe Modes ja Command Promptis kah suudab joosta ja moodsate Boot-viiruste ja Boot-Spyde olemasolu kontrollida ning neid tõrjuda.
Kommentaarid: 284 loe/lisa |
211 |
Kaemka
18.05.2008 18:27:51
Mul näiteks sööb 33MB mälut (KIS 7 sõi 50MB). Praegu olen rahul sellega 8)
_________________ GSM Service: Ost-Kodeerimine-Tarkvara uuendamine-Remont-Vahetus
SAT-TV Süsteemide hooldus, paigaldus, seadmed.
M:533333*5, 51999*99, 533000*0 |
Kommentaarid: 333 loe/lisa |
263 |
Ezh
18.05.2008 19:46:19
Ezh: Kui Sul on masinas Boot-viirus või Boot-Spy, siis Windowsi tavatöötamise ajal Sa neid viiruseid mälust maha tappa ei saa. Vaid mälus istuv Boot-viirus nakatab esimesena tema poole pöörduva viirusetõrje. Need viirused on rünnatavad ainult kas Command promptis või siis Safe Modes.
Kummaline, et viirusetõrjeprogrammi tootja pole midagi kuulnud kõige moodsamatest viirustest - väga veider. Seda enam, et Boot-viiruseid kirjutatakse maailmas juba pikki aastaid ja iga aastaga järjest rohkem...
Näitena võib tuua Avasti, millel on Command Promptis töötav skänner sisse ehitatud ammu ammu. Nii, et siin pole midagi uut.
211 |
Ezh
19.05.2008 16:47:15
tahanteada, kas saad ühte seda viiruse nimetus ütelda?
Kui sul jookseb AV Windows täis reziimis, siis ta avastab seda boot viirused kohe kui nad salvestatakse diskile ja ei anda mällu laadida ja Safe modis sind midagi ei ähvarda. Aga igaks juhuks tahaks mingi viiruse nimetuse kuulda.
Uuendus:
tahanteada, Kaspersky 2009 saab seda Boot-viirus ja Boot-Spy koda ka tava reziimis hakkama. Näiteks Backdoor.Win32.Sinowal ta tapab mälus ja pärast kustutab ka fail ise.
pajakas
Ezh
22.05.2008 17:36:39
On väljas 2009 versiooni uuendus "a". Seda laaditakse ja installitatakse automaatselt uuendustega alla. Nüüd peab paistma versiooniks: 8.0.0.357a
vahelduvool
24.05.2008 18:41:47
Kas sellele on ka eesti keelset oleams?
Kommentaarid: 43 loe/lisa |
37 |
maxsimiljo
24.05.2008 18:44:48
Vista all töötab asi ilusti?
Kommentaarid: 28 loe/lisa |
28 |
Lord Ami
24.05.2008 23:35:02
kikas kirjutas: |
Kas sellele on ka eesti keelset oleams? |
Hetkel veel ei ole.Tuleb suvel, kui programm ametlikult väljas/valmis on.
maxsimiljo kirjutas: |
Vista all töötab asi ilusti? |
Niipalju kui mina olen foorumitest lugenud, töötab hästi.
52 |
sakunne
27.05.2008 13:29:23
Hehhee:
The requested URL could not be retrieved
The requested URL:
http://foorum.hinnavaatlus.ee/viewtopic.
php?t=84566&postdays=0&postorder=asc&
start=1000
Is forbidden by Parental Control
Reason: Heuristic analysis
Generated:
Tue May 27 12:19:06 2008
Kaspersky Internet Security 2009 |
Ja nii ka mõnel muul lehel - samas päris maha ei tahaks keerata, siis pole kasu asjast eriti, vist
_________________ Kuna ei pruugi õigel ajal foorumisse sattuda:
SMS: 5051598 [võõraid tel. ei vasta]
Email sakunne@seenior.ee |
Kommentaarid: 77 loe/lisa |
69 |
Lord Ami
27.05.2008 13:45:32
sakunne kirjutas: |
Hehhee:
The requested URL:
start=1000
Generated:
Ja nii ka mõnel muul lehel - samas päris maha ei tahaks keerata, siis pole kasu asjast eriti, vist  |
Eks ta ole jah veits buggine ma arvan
http://parental.kaspersky.fr/
52 |
Ezh
28.05.2008 00:08:47
sakunne, peab nüüd korras olema. Kui leiate sama proogleem mingi lehega, andke teada.
Tänud.
