riaak
14.04.2008 21:12:25
PlatoonSgtElias kirjutas: |
Kõige parem review selle mängu kohta, mingi kasutaja gamespotis kirjutas: |
Muidugi et AC on täielik pask kui kõik asjad üritad pingsalt ära teha. Võtke asja rahulikult ning tehke asja lõbu ja huviga ning mäng ise muutub kordades nauditavamaks.
Kõiki torne ei pea ju läbi ronima ning inimeste päästmine on kah suht savi.
_________________ ¯\_(ツ)_/¯ |
Kommentaarid: 119 loe/lisa |
105 |
striker13
14.04.2008 21:17:42
minu arust neid tüüpe tappa on lahe, tuleb mingi 10 venda peale ja siis ükshaaval lööd mõõga kõhtu neile.
_________________ Sarcasm is just one of the many services I offer to people who ask stupid questions. |
Kommentaarid: 95 loe/lisa |
90 |
Player16
14.04.2008 21:29:40
mul on üks probleem, et ma ei leia assassinsi save game file üles . Tahaks need üles leida, kus need asuvad kas keegi teab?
riaak
14.04.2008 21:33:07
xp - C:\Documents and Settings\Administrator\ - kasutaja nimi -\Ubisoft\Assassin's Creed\Saved Games
vista - C:\Users\ - kasutaja nimi - \AppData\Roaming\Ubisoft\Assassin's Creed\Saved Games
kaustad võivad olla varjatud!
105 |
rycyve
15.04.2008 08:20:39
tsitaat: |
Not too much to say, game looks good, especially on a PC but it is very repetitive, after the first city or two you have already experienced everything the game has to offer, you repeat the same missions over and over, rescue civilians about 7 or 8 times, climb about 7 or 8 towers, then go complete the plot portion which means watching a cutscene, stab the guy, and go hide, repeat ad nauseum.
It seems another case of a game dumbed down for console gamers where simplicity and flash are all its got, sadly by reading the reviews thats all it takes for most people.
Again, dont believe the hype, if you are looking for a sandbox type game with lots to do, this is not it.
graphically its pretty good but there isnt much in the way of interesting, after walking the city for an hour or two it wears off, climbing is so stupid easy and obvious look every third house has a ladder against it, and a crane on top, amazing |
Mingi analoogne kiunumine oli ka Crysise puhul
Kommentaarid: 98 loe/lisa |
81 |
angel
15.04.2008 08:42:31
peab täiesti paika ning sellest lõpmatuseni igalpool vatratud et copy paste on parim käsk
aga jah: kuidagi omamoodi fun on ringi joosta mööda katuseid ja kõigile nuga anda... võitlus süsteem on sutsu liiga titekas aga vähemalt näeb hea välja.
Kommentaarid: 175 loe/lisa |
157 |
MONX33
15.04.2008 09:34:59
Mul tekkis lihtsalt huvi kuna mul praegu monitor garantiis ja suht igav et millega seda mängite, klaveri või gamepadiga?
Player16
15.04.2008 10:36:49
"xp - C:\Documents and Settings\Administrator\ - kasutaja nimi -\Ubisoft\Assassin's Creed\Saved Games
kaustad võivad olla varjatud!"
Otsisin aga ei leidnud neid. Äkki on need varjatud, kuidas saaks neid näha?
15.04.2008 10:47:38
Player16 kirjutas: |
Otsisin aga ei leidnud neid. Äkki on need varjatud, kuidas saaks neid näha? |
Xp all pole kindel aga Vista all: Control Panel-Personalize-Folder Options ja 2 linnunkest eest vajalikel asjadel,et kaustad nähtavaks muuta.
Kommentaarid: 92 loe/lisa |
prtv
15.04.2008 14:39:48
MONX33 kirjutas: |
Mul tekkis lihtsalt huvi kuna mul praegu monitor garantiis ja suht igav et millega seda mängite, klaveri või gamepadiga? |
Klaver+hiir
_________________ |
Kommentaarid: 82 loe/lisa |
73 |
monty11
15.04.2008 15:03:58
No vingujaid on olemas iga mängu puhul ja selle jaoks ei pea minema GameSpoti vaid neid leiab piisavalt ka HVst.
Esiteks ei saa sellist kriitikat tõsiselt võtta kui tüüp ei valgusta isegi oma mängueelistusi.
Tõsisemalt võib võtta inimesi, kes on mängu pikisilmi oodanud (ja pole seda algusest saati maha teinud) ja lootnud ning kui mäng välja tuleb, siis on pettunud. Hetkel tundub, et kommentaarid on pigem vastupidised ja endistele kriitikutele läheb ka asi peale.
Kõige arusaamatumad on tegelased, kes käivad sellise mängu foorumis, mis on neile vastukarva juba idee eostamisest saati ja virisevad. Kas postituste arvu eest antakse auhindu? Mulle C&C eriti ei istu ja ma ei lähe ka selle mängu foorumisse
_________________ Both the universe and stupidity are infinite. I'm not so sure about the former. - A. Einstein
Tule ja kiika minu fotomaailma. |
Kommentaarid: 4 loe/lisa |
symmi
15.04.2008 18:25:18
neljandas memorys olen aga nüüd saan kuidagi igasse linna minna aga seal pole midagi teha?! keegi oskab öelda mida tegema peab??
Kommentaarid: 27 loe/lisa |
25 |
prtv
15.04.2008 18:26:26
symmi, Damascuses Rich District
_________________ |
73 |
angel
15.04.2008 18:44:58
kui mitte peerugi teha ei ole siis korda eelnevaid tegevusi ehk siis iga kord roni kusagile torni otsa ja vaata ringi (E tähte vms pressi) kui "uus torn" (raske vahet teha kuna nad kõik suht ühesugused, ainult mingi paar eri torni mudelit on üldse) siis saad teada kuhu edasi minema pead. Kui vana siis otsi kusagil kaugemal asuv torn ülesse.
ise sain igatahes nõnda edasi.
157 |
prtv
15.04.2008 18:48:29
angel, Tab nupp (default) manab ette kaardi kust saab vaadata mis objectived on täitmata
_________________ |
73 |
Cheetah
15.04.2008 22:29:35
Ja näitab ka torne, mis on läbi käimata.
Kommentaarid: 91 loe/lisa |
84 |
riaak
15.04.2008 23:43:20
XP all on Explorer -> Tools -> Folder options
Paned linnukese show hidden files and folders'i ja hide protected bla bla ette.
105 |
Ahf
16.04.2008 09:46:59
Kas eelnevalt pickpocketist on juttu olnud?
kuidas suvalisi inimesi tühjaks teha? Ma ei saa neid ju "sihikule" võttagi.
Kommentaarid: 57 loe/lisa |
54 |
antikondor
16.04.2008 10:43:34
pickpocketida saad ainult infi enne targeti ründamist ja viskenugasi linnas liikuvatelt kaabakatelt
_________________ Olen jah muusika suhtes elitaarne sitapea
000 WHILE hangover
001 drink beer |
Kommentaarid: 48 loe/lisa |
45 |
Ahf
16.04.2008 11:01:14
Ok.
Kuidas jalgu puruks lüüa ? Unustasin ennist küsida.
54 |
16.04.2008 13:35:11
random counterattack.
_________________ - londiste
Kommentaarid: 241 loe/lisa |
215 |
Minttunator
16.04.2008 14:01:41
Minu isiklikud paari tunni põhjal tekkinud muljed:
+Mööda maju turnimine on igavesti lahe.
+Stoori tundub kaasahaarav.
+Tegelaste liigutused on üsna loomulikud.
+Graafiliselt näeb kena välja, kui AA peale force'ida.
+Performance profiilimasinal üllatavalt sujuv, netist loetud QQ põhjal ootasin palju hullemat.
-AA tuleb jõuga peale lükata, mängu sees sellist võimalust ei näinud. Ilma AA'ta on suht kole.
-Forced widescreen (=mustad ribad ekraaniservas) sucks balls.
-Võitlus on liiga lihtsakoeline, vastased rumalad.
-'Blend' tundub kergelt totter, eriti ratsutades - mingi keskmise kiirusega traavimine ärgitab töllid mõõkadega hoobilt kannule, aga natuke aeglasemalt sõitmine ei tekita absoluutselt kahtlust?
-Control scheme tundub vähemalt hetkel päris kohmakas, st on tunda, et tegu ikkagi konsoolipelaga.
-LONG ASS UNSKIPPABLE CUTSCENES! Tore muidugi, et mängul stoori ka on, aga kui ma tahan näiteks asja esimest korda proovides lihtsalt kiirelt natuke actionit näha, kuid pean selle asemel 20 minutit tutoriali tegema ja videot vaatama, mida SKIPPIDA EI SAA, OMGWTFBBQ, siis ajab ikka vihale küll.
Yahtzee revüü ka sellele asjale, kui ma seda veel linkinud pole - üldiselt temaga nõus, vähemalt senise mulje põhjal ei ole halb mäng, aga ootasin siiski enamat. Eks näis, kas ta ennast lõpupoole kordama ka hakkab, nagu lugeda on, ja kuidas stoori edasi areneb.
Kommentaarid: 3 loe/lisa |
16.04.2008 14:44:26
1) linnadevaheline tatsamine ja ka mäest alla tatsamine lõppes pmst memory block 3 ära. kuidagi märkamatult, aga just siis kui hakkas tüütuks minema.
2) sidequestidest on vaja teha kaks per linnaosa. mitte just eriti raske. (mis tuletab meelde, on keegi selle võimalikult vähese violencega ka proovinud ära teha?)
3) cutscened on mõnevõrra tüütud neh, see teise viewpointi teema on imo sama rõve kui unskippable olemine. eriti xkastis, kus sellega achievement seotud on (irw).
4) aa on mängus sees ka pealelükatav, ilmselt dx10 req.
5) forced widescreen seebiks.
6) võitlus on imo väga asjalikult lahendatud. speedkill ehk siis counterattack omab. ma lihtsalt puhtfüüsiliselt ei viitsiks muidu kakelda, liiga twitchy on.
7) blend... noh hobusega liiklemisel on müstiline, miks ja kuidas seda vaja, käies on väga lahe.
8) control scheme võiks vähe rohkem pc kanti hoida pc variandil.
9) performance on vägev, profiilimasinal rõõmsalt fps 30+ kanti 1600x1200 kõik peal mis mängu seest panna annab (aa ei ole viitsinud otsida, seega seda pole)
10) graafilises osas, kurat mulle ronimine meeldib. kuidas tüüp jalad-käed õigetesse õõnsustesse asetab etc.
kes ootas rpg-d või puhast sandboxi, siis edu neile. algusest peale räägiti tegelikult sellest, mis praeguseks olemas on.
mida tegelikult tahaks, oleks tõesti hitmani stiilis planeerimine mõrvimise osas. kõik 6 investigation questi ära tehes saab väga palju infot, aga reaalne assassination lõpeb ikka sellega, et cutscene, blablabla ja town alert + miljon rätipead/ristisõdalast/prantslast sul hetkega kallal. isegi siis kui stealthkill sai tüübile tettu. :/
215 |
Ahf
16.04.2008 20:18:48
Kellelgi probleeme Jerusalemma sisenemisel ei ole olnud ?
Mul lööb errori ette ja mäng kinni...polegi veel sisse saanud...
54 |
omgwtf
16.04.2008 20:38:56
Ahf,
Nu tegemist ilmselt sul piraga "nuked" versiooniga Sellega sa ei saagi sinna..
Kommentaarid: 155 loe/lisa |
137 |
