marli1
23.03.2008 08:54:17
My Documents stardib automaatselt |
Probleem nimelt selles et My Documents kaust avaneb arvuti käivitumisel ise.
Startup listis aga ei paista seda olevat- kuidas teha nii et see kaust ise ei avaneks?
| Kommentaarid: 40 loe/lisa |
40 |
kännuämmelg
23.03.2008 08:58:05
kas run>msconfig>startup kah ei räägi midagi Sinu dokumentidest?
seljuhul kahtlustan mingit ussi
205 |
marli1
23.03.2008 09:04:04
| Täpselt nii- ei mingit vihjet My Doc kaustale seal listis..
40 |
Porno Parm
mugavuspagulane
23.03.2008 09:51:42
Click Start then Run and type msconfig in the "Run" box...click "Ok". Click on the "Startup" tab". Look in the startup list and remove the check from the box next to EXPLORER.EXE, click "Apply" then "Ok". Restart your computer. Upon restart, you may get a Selective Startup dialog box...if you do, check the box in the lower left corner of the window and click "Ok".
parem jah kui mingi kogenum user selle teeb su eest igaks juhuks
kuigi pole eriti raske
variant B vist tõhusam
The answer is a corrupted registry entry.
Run regedit and navigate to:
HKLM/SOFTWARE/Microsoft/Windows NT/CurrentVersion/Winlogon
In there there should be a value (on right hand side of screen) called Userinit.
The data for this value is probably something similar to:
C:\windows\system32\userinit.exe,C:\windows\system32\userinit.exe,
If you do see a duplicated string in there similar to the above - simply double click on the Userinit value and edit the data so as to delete everything to the right of the first comma (,). In the case above you would leave only:
Exit registry edit and reboot. No more My Documents!
| Kommentaarid: 66 loe/lisa |
6 :: |
47 |
marli1
23.03.2008 15:38:05
Thanks Karm Laks, Option B oli minumeelest lihtsaim variant- ja mis peamine toimis : " No more My Documents!"
40 |
