Sprocket
Aeg maha 60
12.02.2008 22:37:22
| Vedas.
26 |
EvilKatarn
diivanilill
12.02.2008 22:42:21
Mitte vähe. Minu oma hoiti 3 nädalat ja siis anti 2006 alguse oma :/
A see-eest sain Forza 2 tasuta
ja viva pinata
81 |
erick
13.02.2008 00:53:08
Mass Effect Coming to PC in May
Though Mass Effect had its fair share of problems, it was still an excellent game. Many of our readers, however, clamored for a PC release. Well, it's coming and sooner then we thought. EA and Bioware have announced that the space opera epic Mass Effect is coming to PCs in a refined form this May, including the following changes:
* Optimized controls designed specifically for the PC.
* High resolution visuals: Mass Effect for the PC features highly detailed textures, characters and environments.
* Fully customizable controls: PC gamers can re-map the control scheme any way they like.
* Run & Gun Control: Players can assign biotic powers or skills to 'hot keys' allowing them to play Mass Effect with a heavier focus on action.
* New decryption mini-game.
* New inventory screen GUI and functionality: The enhanced inventory system makes it easier for players to equip and modify their weapons and armor.
It's possible the PC version will be in every way superior to the 360 version, especially in light of those changes. Full hot key mapping, a better interface, and better performance are three improvements that would answer most of the major criticisms against the title. I guess that EA ownership has its benefits after all.
Specs have yet to be announced, but we'll be keeping our eye out for more information. |
X360 exclusive?
96 |
Roost
13.02.2008 09:42:04
Minu meelest on see normaalne, et nii hea mäng nagu Mass Effect(pole küll ise kahjuks mänginud) tuleb lõpuks ka PC'le. See ei tohiks enam mingi üllatus olla et bioware mäng tuleb ka PC'le. Igal juhul jääb see konsooli exclusive'ks. Kas sa oled kade, kuna ME on juba õige mitu kuud X360'l ja tuleb PC'le alles mais?
btw sa oled esimene PC fanboy keda ma tean.
| Kommentaarid: 11 loe/lisa |
erick
13.02.2008 10:25:04
| Roost kirjutas: |
btw sa oled esimene PC fanboy keda ma tean.  |
Tegelikult on üllatus ja veel milline. Bioware keeldus kommenteerimast igasuguseid kavatsusi seda mängu PC-le välja lasta. X360 omanikud muidugi ei jõudnud toona seda exclusive'it piisavalt kiita. Eriti on mul meeles amddude'i seisukoht:
Mitte alati.. Iga uue konsooligeneratsiooni tulekuga vaatate, et vau, konsoolidel on nii äge graafika.. seda oli näha nii PS2 kui ka X360 tulekuga... pikka aega polnud teil midagi vastu pakkuda.
Ning ka nüüd saate mängudena kamaluga sitta... Mass Effecti ei näe te elusees ja ka Assassins Creedi saate alles veebruaris.. Aga ära liiga kurvasta .) Crysisele tuleb küllalt mode, mida senikaua mängida |
EDIT: Tegelikult ma trollisin veidi, sest võimalus oli lihtsalt liiga hea. Ma lähen nüüd ära. Carry on.
96 |
vabarna
13.02.2008 10:37:18
| Hea eputrilla oled sa ikka.
| Kommentaarid: 14 loe/lisa |
14 |
erick
13.02.2008 11:04:32
Ma olengi internetis väiklane inimene, what can I say
96 |
Ravenclaw
13.02.2008 12:38:31
raha meeldib kõigile ju siis lihtsalt keegi tegi piisavalt hea pakkumise et tasus see litsents (või kuidas iganes neid mängu õigusi nimetatakse) ka PC peale müüa.
| Kommentaarid: 30 loe/lisa |
29 |
sLg00
13.02.2008 14:20:38
heh, see pole tegelikult eriline üllatus. jade empire ja kotor olid ju ka x360 exclusive esialgu
pronto
13.02.2008 17:10:50
Ja GoW ja vanasti ka Halod (mis tõsi küll tulid XBoxile välja). X360 peal on mäng ära elanud ja nüüd võetakse ka arvutimeeste käest papp ära. See on tavaline praktika ja ma ei imestaks, kui aasta pärast ka Halo3 arvutile tuleb. Aga keda see siis enam kotib? Erinevalt näiteks MGS4-st, mida üle aasta täiesti eksklusiivselt PS3-le saada ei ole.
_________________ Magento arendused |
| Kommentaarid: 7 loe/lisa |
Ravenclaw
14.02.2008 10:29:10
ekslusiivist rääkides ma ikka kuskil südame põhjas loodan et äkki Nintendo mehed Zelda litsentsi ka maha müüvad teistele konsoolidele kuigi see arvatavasti unistuseks vaid jääb. Lahendus on ka tegelt probleemile teada, tuleb soetada Nintendo Wii
29 |
EvilKatarn
diivanilill
14.02.2008 12:58:31
| henri kuule. Kui sa ühendad 360 monitori külge, siis kas sa paned heli arvutikõlarite taha või kodukino kõlarite taha?
81 |
pronto
14.02.2008 13:48:47
| Ravenclaw kirjutas: |
ekslusiivist rääkides ma ikka kuskil südame põhjas loodan et äkki Nintendo mehed Zelda litsentsi ka maha müüvad teistele konsoolidele kuigi see arvatavasti unistuseks vaid jääb. Lahendus on ka tegelt probleemile teada, tuleb soetada Nintendo Wii  |
See ei oleks ilma pretsedendita, the Philipsi CD-i konsoolile on Zelda ilmunud.. tõsi, seda peetakse läbi aegade kõige sitemaks Zelda mänguks ning Nintendo üritab seda maha vaikida. Mul on see mäng muide olemas -- tõenäoliselt on tegu kõige haruldasema Zelda-ga ever. Samas on see loomulikult äärmiselt ebatõenäoline -- peamiselt sellepärast, et Nintendo on eelkõige ikkagi tarkvarafirma, mis toodab seadmeid peamiselt oma tarkvara läbimüügi tõstmiseks (n.ö. loob ise omale turu).
henri200
14.02.2008 14:54:12
amddude, eem. Mul on nii, et on mingi Dragon'i VGA kaabel vist. Siis sealt tuleb kaks otsa välja (üks punane teine valge, RCA out on vist selle nimi), siis need toppisin RCA IN'i sisse (eraldi kaabel selline, sain oomipoest) ja selle kaabli lõpus on see default kõlari auk vms. mille saad arvutisse jne panna, sinna otsa ostsin sellise mis muudaks selle sisendiks ja sinna sisse panin kõrvaklapid . Segane jutt tiba aga jah, ma ei tea kuidas arvutikõlareid sinna saad panna kuna neil tavaliselt rohkem juhtmeid.
Kui abi vaja vms, lisa msn-i (profiil).
| Kommentaarid: 62 loe/lisa |
59 |
14.02.2008 15:22:20
| eelmise helikaardiga vähemasti (ALC650 realteki oma) rikkus see xboxi heli ära automängudes (heli ei püsinud enam sünkroonis kahe kanali vahel ning tekkis resonants)
| Kommentaarid: 85 loe/lisa |
1dumbpcuser
14.02.2008 17:12:16
| henri200 kirjutas: |
Kui abi vaja vms, lisa msn-i (profiil). |
Mul logitech x230-l oli see üleminek kaasas(2RCA emased -> 3,5mm emane). 5.1 arvutikõlaritega on jah vist teema see, et XBOX ei anna välja analoog surroundi(5.1), vaid ainult digitaalset läbi optilise spdif. Mõnedel 5.1 kõlaritel on mingi süsteem, mis üritab stereot 5.1-ks muuta, aga see minu arvates kahtlane asi...
mikk36, mis helikaart siia puutub? Lasid heli arvutist läbi? Kui on stereoheli vaja, siis üleminek ja saab kasutada nii 2.0, 2.1 arvutikõlareid kui ka kõrvaklappe.
_________________ M: MSI B660M MORTAR |
97 |
14.02.2008 17:59:16
1dumbpcuser, jah, saab otse kõlaritesse, hetkel teengi nii
aga tüütu on kõlarite tagant kitsikusest vahetada seda pidevalt arvuti ja xboxi vahet
henri200
14.02.2008 18:03:30
| Endal pole olnud jah kokkupuudet kõlarite ühendamisega, kuna ainult kõrvaklape kasutanud.
59 |
14.02.2008 18:47:01
niih, proovisin uue emaplaadiga ära
Realteki HD 883 kiip peal sellel ning heli on täiesti puhas line in'i kaudu
kusjuures logitechi X-540'e matrix mode oskab täitsa asiselt 5 kanalit tekitada kahest nii (vähemasti forza2's)
ex6
14.02.2008 18:49:21
Kellel soov oma mängukollektsiooni täiendata, soovitan vaadata linki minu signatuuris. ja nagu signatuuris kirjas - võib pakkuda ka vahetusvariante...
Vot selline pakkumine siis täna minu poolt...
| Kommentaarid: 65 loe/lisa |
54 |
EvilKatarn
diivanilill
14.02.2008 19:04:54
| Täna mängime?
81 |
14.02.2008 20:01:17
| amddude kirjutas: |
| Täna mängime? |
ma oleks käpp küll
313 |
14.02.2008 20:15:08
| vabalt
EvilKatarn
diivanilill
14.02.2008 20:18:00
Ma olen siis varvas.
Kus on Velsa?
81 |
14.02.2008 21:35:31
velsaaa, uuu
skeptik, tule sisse
