Labukana
02.02.2008 12:20:15
| Flacko kirjutas: |
| Jalutaja kirjutas: |
| Arcade mängud on seotud kõvaketta ja ostja gamertagiga, mitte konsooliga. See, kes ostab ei jää millestki ilma. Kaotavad need, kes said vanal kõvakettal olevaid teiste mänge mängida. |
Aa tore. A kui mu xbox <b>piix</b> läheb, siis ma saan uuesti tõmmata need eks? Sest gamertagis on kirjas et olen need ostnud. Ei tahaks küll kaotada oma 26 arkaad mängu, mis ma olen ostnud ja tasuta saanud (Hexic 2, Carcassonne,Undetrow) |
dno kas uuesti tirida saab aga vist kõvaketas oleks soovitatav alles hoida? right?
edit: vist ikka pole nii, pidavat vist uuesti tirida saama, aga kui ketta alles hoiad ja offline'is näitab et trial mängud siis peaks vist nii tegutsema:
"Im really sorry that youre having a problem on your Xbox console. I understand that when you repaired or exchanged your Xbox 360 console, you can no longer access previously downloaded premium content when they are not connected to Xbox LIVE.
If after you repair your Xbox 360 console, make sure that you have been recovering your gamertag on Xbox Live.
If you have try to access previously downloaded premium content when you are not connected to Xbox Live, please follow these steps:
1. In the Xbox Live section of the Xbox Dashboard, select Xbox Live Marketplace, and then press the A button.
2. Select Games, and then press the A button.
3. Select All Game Downloads, and then press the A button.
4. Select the game from the master list that you cannot play offline, and then press the A button.
5. Select the row that has a check mark next to Full Game (name of the selected game), and then press the A button.
6. Select Download Again, and then press the A button.
If you gone through all the troubleshooting steps and still it does not work, please call our support line and ask the phone support representative to escalate your call. "
That should cover it... |
| Kommentaarid: 32 loe/lisa |
30 |
EvilKatarn
diivanilill
02.02.2008 12:36:34
Mis möla? :O
Gamertagiga on mängud seotud muidugi. Minu Carcassonne oli eelmise 360 peal ja see läks nässu. Sain uuele uuesti tirida.
80 |
Jalutaja
02.02.2008 16:33:47
| Flacko kirjutas: |
Aa tore. A kui mu xbox <b>piix</b> läheb, siis ma saan uuesti tõmmata need eks? |
Kui box piixu läheb, siis tuleb lihtsalt kõvaketas alles hoida. Ei mingit uuesti tõmbamiste jama. Kui aga keegi kuskilt ketast nõudma hakkab, tuleb rahulikult see isik piixu saata.
| Kommentaarid: 4 loe/lisa |
02.02.2008 16:46:51
| Stabby kirjutas: |
| Ma võiks ka Forza 2-hte pelada. |
mulle tulid täna sõbrantsid külla ja hõivasid Guitar Hero III multiplayeri, seega ma ei tea, kas löögile saangi
_________________ MÜÜA: PlayStation 3 Slim 160GB (UUS) |
313 |
EvilKatarn
diivanilill
02.02.2008 16:57:30
| Mulle võiks ka tüdrukud külla tulla ja Halo 3 mängida :,(
80 |
EvilKatarn
diivanilill
02.02.2008 17:15:32
Tegin gearsi serveri.
GT on EvilKatarn ja palun tulge, joinige.
80 |
Alvaaro
02.02.2008 18:06:05
Krt ma ennem ei saanud joinida aga täna õdakul võiks veel teha.
| Kommentaarid: 217 loe/lisa |
182 |
EvilKatarn
diivanilill
02.02.2008 18:08:26
| Kurat võiks rohkem rahvast kokku saada. >:( Kahekesi on igav.
80 |
Olaf
02.02.2008 18:14:55
Teie võrgus mängimise kohta ..
Te võiksite selliseid asju ehk MSN'is või kusagil jutukas rääkida ja siia vaid "kutse mängule" teha.
Kuidagi imelik on vaadata ja lugeda siit sellist hülgemöla.
| Kommentaarid: 81 loe/lisa |
75 |
EvilKatarn
diivanilill
80 |
ilwe2
02.02.2008 19:50:40
forzat mängiks minagi, aega täna suht kogu aeg...
gt teravkahvel - lisage, kui forza mängijad olete...
02.02.2008 19:58:58
ürituste foorum on võrgumänguteemade jaoks
| Kommentaarid: 85 loe/lisa |
volts333
02.02.2008 20:12:53
järgmine nädal joinin teiega:D see nädalavahetus ei saa 8)
_________________ don't click this link... |
| Kommentaarid: 80 loe/lisa |
72 |
EvilKatarn
diivanilill
02.02.2008 20:32:39
Joinid millega? Mitte kui midagi ei toimu
80 |
Anti
02.02.2008 20:59:00
amddude, sul muud pole siis teha ve, kui ainult xboxi mängida?
240 |
henri200
02.02.2008 21:13:29
Milleks siis veel xbox on
| Kommentaarid: 62 loe/lisa |
59 |
Anti
02.02.2008 21:14:39
| Mismõttes?
240 |
henri200
02.02.2008 21:16:43
| No ega see tolmukoguja pole
59 |
EvilKatarn
diivanilill
02.02.2008 21:30:26
| velsa kirjutas: |
amddude, sul muud pole siis teha ve, kui ainult xboxi mängida?  |
Mängin PCl doomi vää?
80 |
Anti
02.02.2008 21:32:59
Küsisin sellepärast, et terve ilusa laupäevase päeva sa iga tunni aja tagant küsid, kas midagi mängid tahab keegi. ega ma paha pärast vms.
240 |
EvilKatarn
diivanilill
02.02.2008 21:36:56
Ilus? Mul igakord kui oli plaanis õue minna hakkas jälle õues mingit ebamäärast paska alla tulema süngest tumehallist taevast.
Ja nädalavahetus ongi mul broneeritud mängimiseks. Nädala sees muu pasaga vaja tegeleda.
80 |
Stabby
02.02.2008 21:39:35
| OT: mis sellel hallil taeval viga on? Just mõnus olla, tekitab sellise hea tunde vms.
| Kommentaarid: 34 loe/lisa |
34 |
Flacko
Joonistusmaniakk!
03.02.2008 00:30:39
Jajah, eriti nüüd kui selline tuul on ja elektrikatkestused on...
_________________ Flacko, the nutty weasel who loves blue cheese, Blyth's Reed Warblers, Thrush Nightingales and Devin Townsend! |
| Kommentaarid: 199 loe/lisa |
166 |
ny21k
03.02.2008 00:36:58
Katkestus oli jah, hea et box ei töödand. Eelmise tormi katkestuse ajal oli sees ja sellest läks ta Veidike oma ajudega segi. See eest telekas vajus ära
| Kommentaarid: 9 loe/lisa |
xtr
03.02.2008 01:52:07
Re: X360 pilti ei ole HDMI'ga LCD taga. |
| xtr kirjutas: |
Juhtus mulle koju X360 Arcade. Ainult tavaline AV kaabel koos SCART-üleminekuga kaasas. Vana väikse teleka peal oli ikka jama mängida, niisiis vedasin koju ka monitori, 24" LG L245WP-BN, millel on HDMI sisend. Ostsin Ordist suvalise 3m HDMI kaabli ja mõtlesin, et nüüd on kõik tore, aga mida ei ole, on pilt monitoris, isegi siis mitte, kui õige sisend valida . Proovinud olen veel niipalju, et VGA kaudu saan läpaka pildi monitori, Xbox tavalise teleka taga näitab pilti nagu ennegi, Xbox monitori taga ei võta ka siis pilti ette, kui Xbox'i ekraaniseadetele reset teha, ei tule pilti ka AV kaabli samaaegsel külgepanekul(telekat/kõlareid seal taga polnud). Huvitav, mida ma valesti teen või olen valesti aru saanud, äkki ei peagi töötama või peab originaaljuhtme ostma? |
Any ideas?
_________________ M: Magic Mouse + Keyboard, MX Master 3S
M: Ryzen 1700X/16GB DDR4/1TB SSD/650W Gold
M: 2021 MacBook Pro 14 M1/16/500/SWE |
| Kommentaarid: 326 loe/lisa |
270 |
