WäntWõll
make.believe
31.01.2008 13:56:37
Is this the world's most expensive desktop PC? |
link :: Zeus Shows Off $750,000 PC
This could well be the most overpriced expensive commercial computer ever to be launched: the Zeus Jupiter. The computers case is made of solid platinum embedded with diamonds which have been arranged to mimic astrological constellations. However, given that the PC has a price tag of ¥80,000,000 (just over $750,000) youll be disappointed to hear that its powered by a 3GHz Intel E6850 CPU, 2GB 667MHz DDR2 RAM, a 1TB hard drive, a dual Blu-ray/HD DVD drive and a 256MB GeForce 8400GS. Yes, thats one of NVIDIAs entry level graphics cards. Of course, if thats just out of your price range you could always go for Jupiters little brother Mars, which has the same specs but with gold instead of platinum. That sells for a mere ¥60,000,000 which is just under $565,000.
Modiatele vähe mõtlemisruumi ja ka silmailu,rahast siinkohal ei räägiks
Panin hinnad õigeks
viimati muutis WäntWõll 31.01.2008 14:23:06, muudetud 1 kord |
300 |
DonNiger
31.01.2008 14:03:38
116 |
Marduuhin
108 |
CoiL
31.01.2008 14:12:56
| Marduuhin kirjutas: |
Kole.  |
Sama siinpool. Sellise käki eest ei maksaks ma ka siis kui miljardär oleksin
| Kommentaarid: 95 loe/lisa |
83 |
WäntWõll
make.believe
31.01.2008 14:13:01
Kus on öeldud et see asi peab olema ilus
Kuigi heledam on täitsa nunnu 8)
Usun et tähtsad on muud väärtused
300 |
Subu
31.01.2008 14:16:58
| wanawoll kirjutas: |
Usun et tähtsad on muud väärtused  |
noh, tänapäeval on peenise suurendamiseks ju operatsioon leiutatud?
| Kommentaarid: 60 loe/lisa |
56 |
31.01.2008 14:20:15
esimeses postis on viga. hind peab olema 80 000 000 ja 60 000 000 jaapani jeeni.
mida tõestab ka tootja koduleht: http://www.pc-zeus.com/bto/bto-jewelry-spec1.html
_________________ "a rental car, three cheeseburgers and a head start."
viimati muutis SKG 31.01.2008 14:20:33, muudetud 1 kord |
313 |
WäntWõll
make.believe
31.01.2008 14:26:20
| Subu kirjutas: |
noh, tänapäeval on peenise suurendamiseks ju operatsioon leiutatud? |
Opereeritud peenist sa vaevalt 24" molli taga hoiad ja MSN-is istud 8)
300 |
DonNiger
31.01.2008 15:28:24
Sellesse kesta oleks normaalne vesijahutust paigutada. Kui üritaks õige DREMEL'iga sinna radika jaoks auke sisse lõigata Kullast kesta veel aga plaatinast
Ja kui sul kodus laua all oleks 10 kg kulda, siis tahaks näha seda, kes ütleb - KOLE
116 |
CoiL
31.01.2008 16:01:27
mina ütlen KOLE Ei ole kunagi kulda jms. väärisvärki ületähtsustanud. Kui ma sellise kasti saaksin (ise kindlasti ei ostaks seda) siis müüksin ka kohe maha (koos selle suht saasta rauaga) ning ostaks korraliku raali
83 |
RassK
31.01.2008 17:26:16
kuusepuu alla sobiks või jõuludel aknale... arvutiks ei sobi
105 |
AJ
01.02.2008 11:02:57
Maksku palju tahes, koledaks jääb see asi ikkagi.
| Kommentaarid: 37 loe/lisa |
36 |
WäntWõll
make.believe
01.02.2008 11:04:54
Eks ta ole ikka nende asjadega nii,mida elusees isegi unes ei saa endale lubada
300 |
AJ
01.02.2008 11:08:28
Isegi kui mul oleks pappi nagu pudru ei ostaks ma sellist. Asja mõte näib olevat selles, et saaks kiidelda oma kalli kastiga.
36 |
WäntWõll
make.believe
01.02.2008 11:13:40
Eks ikka nati eputada ka aga peamine on ainulaadsus(nii toode),sama nagu vanad kuldavad oma masinaid üle ja alles kuskil näitas mingi õiparuni audit mis oli üle hõbetatud
300 |
DonNiger
01.02.2008 11:40:18
Sadam'mil olid kullast püstolid
116 |
Karvased
01.02.2008 11:55:05
| Niiet tegemist ei ole siiski kalleima arvutiga - vaid kalleima korpusega. Komponendid suht suvalt sisse visatud.
Auron
01.02.2008 12:14:45
| Ei meeldi mulle sellised nö. feigilt ülespushitud kallid asjad. Samahästi võiks suvalise codegen'i kasti võtta, panna mingi tseleroni sisse aga power nupuks modiks mingi 100 karaadise teemanti ja kasti hinnaks mingi 27 milli taala.
133 |
