uus teema   vasta Tarkvara »  Turvalisus »  Windows Vista SP1 märgi kõik teemad loetuks
Kalle
sõnum 22.01.2008 13:39:12 Windows Vista SP1 vasta tsitaadiga
Windows Vista SP1 sisaldab Dual EC-DRBG, mis on sinna lülitatud USA eriteenistute ja USA Rahvusliku Julgeoleku Agentuur (NSA) otsesel nõudmisel. Paljude ekspertide arvates sisaldab see backdoor'i, mis võimaldab eriteenistustel saada kätte arvutitest krüpteeritud andmeid. By default on see pärast installi disabled aga kes teab millal see hiljem mingi security patchiga kogemata enable olekusse satub icon_biggrin.gif
Andmed IT Channel News Briefs, Dec. 17:
Warning: NSA could exploit Vista SP1
A security expert is warning that Microsoft's Windows Vista Service Pack 1 will include a random-number generator that the federal government could use to crack encrypted data online. Researchers in August showed that the random-number generator, called Dual EC-DRBG, is based on a set of fixed numbers, which in turn are based on a secret set of fixed numbers. Author and blogger Bruce Schneier said if someone knows that secret set of numbers, he or she would be able to predict the random-number generator's outcomes and break any code encrypted by the generator. The National Security Agency pushed for Dual EC-DRBG to be included in the government's random-number generator standards, and someone from the NSA or an associated agency could know its secret numbers,
spikhoff
sõnum 22.01.2008 14:07:10 Re: Windows Vista SP1 vasta tsitaadiga
Kalle kirjutas:
Kus sa seda välja nüüd lugesid
Kommentaarid: 59 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 54
sõnum 22.01.2008 14:09:17 vasta tsitaadiga
Lingi võiks ka postitada, muidu jääb mulje nagu oleks tegu paranoiaga icon_exclaim.gif
M: Intel i5 4590 protsessorid
M: HP Elitedesk 800 G3 SFF
Kommentaarid: 750 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 563
sõnum 22.01.2008 14:21:40 vasta tsitaadiga
Mingid lingid leidsin
http://www.schneier.com/essay-198.html
http://www.schneier.com/blog/archives/2007/12/dual_ec_drbg_ad.html
HV-s ID-kaardiga autentimine
HV valuutakursid
mks
sõnum 24.01.2008 15:14:00 vasta tsitaadiga
Ja ma nüüd huvi pärast küsin kõigilt paranoikudelt - kui paljud kasutavad reaalselt windowsi enda krüpteerimissüsteemi?
Kommentaarid: 11 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 9
mks
sõnum 27.01.2008 20:06:53 vasta tsitaadiga
note1 kirjutas:
.. sellepärast et ei saanud oma xp'd teistega jagada.
linuxit saan.
go to someone who cares...
enivei, note1, sulle võiks lausa lõuapooliku tiitli anda siin ja ka muudes alamfoorumites aetava jutu põhjal... Vista aktiveerimissüsteem ei ole kohe kuidagi seotud selle random-number-generatoriga, seda võin sulle kinnitada icon_wink.gif
maatriks, tegelikult kontrollib natuke rohkem ikka icon_wink.gif väga palju riistvara muudad, võib ka uuesti aktiveerimist nõuda, samuti kui üritatakse kindlaid süsteemifaile mudida...
sakinaga
sõnum 27.01.2008 20:27:03 vasta tsitaadiga
mks kirjutas:
Seda küll, siin hakati juba rääkima pmst, et Bill teeb sulle formati vms icon_razz.gif
Kommentaarid: 164 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 155
HacaX
HacaX
sõnum 29.01.2008 01:56:55 vasta tsitaadiga
mks kirjutas:
Selle koha peal mainiks, et asi ei ole nii lihtne. Paistab olevat just tendents kodukootud numbrigeneraatorite asemel Winni enda API pakutavat lahendust kasutada (kuna sel teel säästetakse aega). Kui nüüd üks tolle pakutavatest algoritmidest on kahtlase turvalisusega ning, nagu Kalle pakkus, ta "kogemata" aktiveeritakse, siis on kõik seda lahendust kasutavad programmid ebaturvalised. Progel ei saa kuidagi kindlaks teha, et üks PRNG on teisega asendatud ja nii ei saa ka kasutaja asjast teada. Kuni võib-olla juba liialt hilja on.
Kokkuvõtlikult tähendab see seda, et vähemalt krüptimist sisaldavate programmide puhul ei pea nüüd mitte enam ainult seda jälgima millist šifreerimisalgoritmi nad kasutavad (umbmäärased "highly secure and secret algorithm" ja "government standard DES" vs AES ja Twofish+Serpent) vaid ka millist numbrigeneraatorit kasutavad (selle poole väljajätmine või Winni CryptoAPI vs näiteks Cryptlib või Fortuna).
IMO & GPLed
