bbbb
20.01.2008 13:54:18
6. Does your son use Quake?
Quake is an online virtual reality used by hackers. It is a popular meeting place and training ground, where they discuss hacking and train in the use of various firearms.
8. Is your son obsessed with "Lunix"?
BSD, Lunix, Debian and Mandrake are all versions of an illegal hacker operation system, invented by a Soviet computer hacker named Linyos Torovoltos, before the Russians lost the Cold War.
Lunix is extremely dangerous software, and cannot be removed without destroying part of your hard disk surface.
eyelids
| Kommentaarid: 43 loe/lisa |
42 |
psydeblo
22.01.2008 08:26:29
| Congratulations, your dead body is worth $4325!
| Kommentaarid: 149 loe/lisa |
136 |
-m6mmik-
22.01.2008 08:55:29
4600. Tuleb hakata ootama dollari tõusu nüüd
| Kommentaarid: 19 loe/lisa |
17 |
Pingu911
22.01.2008 11:28:46
Congratulations, your dead body is worth $3650!
Doesn't that make you feel great?
weel this sucks
| Kommentaarid: 29 loe/lisa |
29 |
ZuluXE
22.01.2008 11:36:00
$4465
_________________ Vaata asukohta |
87 |
FurattoShutsuryoku
22.01.2008 13:12:16
| Congratulations, your dead body is worth $5675!
| Kommentaarid: 38 loe/lisa |
36 |
ajuNolk
121 |
mingivend
22.01.2008 13:48:50
viimati muutis mingivend 14.06.2014 09:12:47, muudetud 1 kord |
prtv
22.01.2008 13:49:44
ajuNolk, phun
Ärge vajutage seda linki
_________________ |
| Kommentaarid: 82 loe/lisa |
73 |
mks
22.01.2008 16:34:20
Congratulations, your dead body is worth $5465!
Jap, dollari tõus oleks tore...
| Kommentaarid: 11 loe/lisa |
9 |
eyelids
42 |
zorten22
| Kommentaarid: 91 loe/lisa |
-m6mmik-
24.01.2008 11:03:54
20tatikat
17 |
iguaan
24.01.2008 21:14:16
juba varegi juttu olnud et selliste värdjalike lehekülgedele pannakse hoiatus
ootan sind sinu klaviga enda juurde, et ctrl+alt+del teha, sest on-screen kyb pole see võimaik
| Kommentaarid: 84 loe/lisa |
72 |
2III7
24.01.2008 21:23:29
iguaan, mis sellel lehel siis viga on aint mingi video ja tekst
| Kommentaarid: 170 loe/lisa |
152 |
Ivoonu
24.01.2008 21:23:35
| iguaan kirjutas: |
ootan sind sinu klaviga enda juurde, et ctrl+alt+del teha, sest on-screen kyb pole see võimaik  |
Hiirega sai ka selle nuhtluse ära tappa. Täpsemalt Mozillas all taskbaris hiire parem klikk ja Maximize, lõpetas vähemalt tõmblemise ära. Kolmiku vajutamise asemel võib võtta ka lihtsalt hiirega Task manageri lahti ja tüütusele vesi peale lasta.
_________________ Esimese fotoaparaadiga pilti tehes tuli selle ees istuda 8 tundi. |
mks
24.01.2008 22:51:06
| iguaan kirjutas: |
kurat Tegin siis selle lehe lahti.... hakkasin kinni panema, tulid need messagebox'id ... ok, enter alla :d... messageboxid said otsa, aken sulgus ja enter jäi alla... viimane asi mida ma eelmises tabis tegin FFis, oli selle lingi klikkimine... nüüd oli enter jätkuvalt alla, avanes ~25 uut tabi selle lehega... siis läksin küll taskmanageri kallale...
Mina vistas sain küll On-screen klaveriga taskmanageri lahti... ctrl+shift+esc toimib ju väga ilusti...
9 |
ajuNolk
24.01.2008 23:46:19
kui ma hoiatuse oleks pannud, siis poleks ju asjal mõtet.
2III7, vaata IEga
121 |
2III7
24.01.2008 23:52:08
ajuNolk, IE-ga tulevad mul ainult need dialoogid (natuke enterit peal hoida ja kõik) ja operaga on ainult video
152 |
crypto
24.01.2008 23:55:23
2III7, opera on selles mõttes väga hea, et need igasugused ie-le mõeldud lehed ei taha operas nii tööle hakata kui vaja, st. ei saa kärna keerata eriti
_________________ 61. Logistikapataljoni võitleja |
| Kommentaarid: 42 loe/lisa |
37 |
lnxab
| Kommentaarid: 34 loe/lisa |
29 |
bbbb
artur-
| Kommentaarid: 83 loe/lisa |
73 |
jkddp
11.02.2008 20:01:27
ei maiiis uuuuuda.....
_________________ Kui vaja joonistada/saagida/hööveldada midagi, võib alati küsida  |
| Kommentaarid: 64 loe/lisa |
62 |
yodalr
11.02.2008 21:04:22
väga hea
_________________ kraater.ee |
jkddp
62 |
mks
11.02.2008 21:46:21
pole ka ime... see on ju järjekordne Villu "saada mulle e-kiri" Parveti projekt...
9 |
yodalr
12.02.2008 07:59:15
kõlab nagu mingi usu sekti tekst seal.
Log
12.02.2008 10:36:03
| Kui sa eile või täna deklaratsiooni täitsid, siis väga suure tõenäosusega sinu raha läks Tallinna loomaaeda, Mati Kaalule, eksootilise L-Carolina kukkurlooma ekspeditsiooniks, mida osaliselt toetab ka EL. |
| Kommentaarid: 113 loe/lisa |
103 |
Alari A.
12.02.2008 10:51:48
| Log kirjutas: |
seal on head naljad ikka krt.
mingi pool aastat tagasi saatis mul naine raseduse kohta lingi.
nalja sai vaat, et isegi rohkem
| Kommentaarid: 682 loe/lisa |
555 |
725 |
Shelby-SV
Jõulud On Läbi!
12.02.2008 17:29:32
seal all konsultantide pildid... kirke vilega prooviks seda kamasutra asja küll
| Kommentaarid: 63 loe/lisa |
55 |
jkddp
12.02.2008 20:53:41
aaga ta vist vedu ei võta, või tal juba järjekord.....
62 |
raul55
12.02.2008 22:10:38
| krusu70 kirjutas: |
www.pihi.net (vb juba mainitud) seal leidub ka mõningaid valjakaid lugusid
lihtsalt näide ka
Jootsin oma hamstrile 98% piiritust sisse, siis andsin talle kyynalt nuuskida,enne kui jõudsin midagi teha, põles puur maha (hamster naggu PLAHVATAS!!!)
koledad syymekad on... |
lihtsalt ei saanud seda sealt mainimata jätta  |
http://www.pihi.net/?mid=17348
| Kommentaarid: 27 loe/lisa |
24 |
crypto
12.02.2008 22:13:46
raul55, hea, aga korduvalt olnud
37 |
Max Powers
182 |
Taavi_R
166 |
Pimp
13.02.2008 18:53:00
see lasteaed ikka reivib rajult
_________________ PSN Taffinaff |
| Kommentaarid: 49 loe/lisa |
48 |
psydeblo
13.02.2008 18:53:42
| mina küll oma last ei julgeks sinna panna
136 |
Taavi_R
13.02.2008 19:43:43
Olge rahulikud. See ei ole veel midagi...
Vaadake neid...
Eralasteaed NABA
http://www.naba.ee/
Lehelt:
Kus Naba asub? Kuidas Nabasse saada? Kuidas saan lapse Nabasse registreerida?
Rühmade nimed:
Kuldse Draakoni Kuningriik
Vahva Võluri Vennaskond
Nabollo
Tähtsad Tähetargad
Päevitajad
Ma läheks PÄEVITAJATE rühma
_________________ raamatupidamine | laadakalender |
166 |
Taavi_R
166 |
RustyZ
13.02.2008 20:53:45
Nüüd siis teada, millisest Eesti lasteaiast DJ-d tulevad
_________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled) |
| Kommentaarid: 16 loe/lisa |
bbbb
psydeblo
17.02.2008 13:37:52
| mis siis sittumisel viga on? sulle ei meeldigi või?
136 |
punktiir
38 |
Shelby-SV
Jõulud On Läbi!
55 |
borru
| Kommentaarid: 13 loe/lisa |
crypto
19.02.2008 22:59:41
Shelby-SV, blääd, see sky foorum on põhimõtteliselt ju hijack'itud bottide poolt
37 |
Anna tooli
| Kommentaarid: 367 loe/lisa |
301 |
