iFlop
12.01.2008 17:33:59
Kritiseerige n00bi |
Viimase 24 tunniga olen üritanud endale PHP ja MySQLi põhitõdesi selgeks saada ning valmis olen saanud hästi pisikese testlehe.
PHP kood:
| php:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <title>test</title> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /> <link rel="stylesheet" type="text/css" media="all" href="main.css" /> </head> <body> <form action="test.php" method="get" > <div id="form">From Year: <input type="text" name="SYR" value= "<?php echo $_GET["SYR"]; ?>" /> To Year: <input type="text" name="EYR" value= "<?php echo $_GET["EYR"]; ?>" /> <input type="submit" /></div> </form> <?php //db connect if (!$con) { } //päring $query = "SELECT * FROM `Album` WHERE `Year` between " . $_GET["SYR"] . " AND " . $_GET["EYR"] . " ORDER BY Year DESC"; //sisu echo "<p class=\"code\">" . $query . "</p>"; echo "<table class=\"list\"> <tr> <th>Album</th> <th>Year</th> </tr>"; { echo "<td>" . $row['Album'] . "</td>"; echo "<td>" . $row['Year'] . "</td>"; } //ühendus kinni ?> </body> </html>
Mis genereerib sellise html'i:
| html:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /> <link rel="stylesheet" type="text/css" media="all" href="main.css" /> </head> <form action="test.php" method="get" > <div id="form">From Year: <input type="text" name="SYR" value= "1995" /> To Year: <input type="text" name="EYR" value= "2007" /> </form> <p class="code">SELECT * FROM `Album` WHERE `Year` between 1995 AND 2007 ORDER BY Year DESC </p><table class="list"> </body> </html>
Igasugune kriitiga koodi kvaliteeti on teretulnud
| Kommentaarid: 67 loe/lisa |
66 |
12.01.2008 17:40:57
koodi puhtuse eesmärkidel soovitan igasugu andmebaasidest sikutamised jne tõsta väljundi ette (võimaldab ka tänu sellele teatud võimalusi kasutada (headerisse infot sisestada jne) mida ei saa enam peale esimese info saatmist kliendile teha
lisaks on väljund loetavam, mitte ei ole kõik omavahel segamini
ise märgin koodis blokid ära kasutades suuri kommentaare (a'la ######### Input ja ########### Output)
jäävad hästi silma ja on siis tänu sellele leitavamad
| Kommentaarid: 85 loe/lisa |
hanz
12.01.2008 17:58:30
üldiselt tuleks enne andmebaasi piinamist selgeks teha, et keegi sinna mingit jama ei saadaks. Hetkel oleks vast kõige lihtsam lahendus $_GET["SYR"] ja $_GET["EYR"] ette lisada (int), ehk siis " . (int) $_GET["SYR"] . " AND " . (int) $_GET["EYR"] . "
echo ""; asemel soovitaks kasutada echo '';, siis pole probleeme kaldkriipsude lisamisega ning HTML koodis jäävad näha ka reavahetused (lisaks pidi see vist pisut kiirem olema).
mysql_fetch_array asemel kasuta mysql_fetch_assoc, kuna see kasutab vähem mälu (mysql_fetch_array = mysql_fetch_assoc + mysql_fetch_row)
ning mysql_close($con)'i pole tegelikult vaja, kuna üldiselt teeb seda server ise (aga samas, ega ta halba tee)
_________________ Lahedad mängud  |
| Kommentaarid: 7 loe/lisa |
12.01.2008 18:18:07
hanz, kiirusevahet ei ole _assoc'il ja _array'l, küll on aga erinevus süsteemis
mysql_fetch_assoc($result) = mysql_fetch_array($result, MYSQL_ASSOC)
küll on aga mõlemad aeglasemad kui mysql_fetch_row()
hanz
12.01.2008 19:22:01
| mikk36 kirjutas: |
küll on aga mõlemad aeglasemad kui mysql_fetch_row() |
ega ma kiirusest ei rääkinudki, ma mälust ikka rohkem (tegelt sealt tuleb ka väike vahe kiiruses). Kui mysql_fetch_assoc() tagastab
[Album] => 1
[Year] => 1999 |
, siis mysql_fetch_array() tagastab
[0] => 1
[Album] => 1
[1] => 1999
[Year] => 1999 |
iFlop
12.01.2008 19:24:31
Tänud! (int) on ja ka echo '' kuluvad mõlemad ära.
Mis koodi struktuuri puutub, siis üldiselt oleks vist mõttekas kogu leht ühe <?php> sisse panna? Ning kõiksugu headerid ja footerid eraldi include'ga kokku keevitada?
PS: aga mis kujul ikkagi selline pisike asi:
olema peaks? Kas pigem:
| echo '<p class="code">' . $query . '</p>'; |
või
| echo "<p class=\"code\"> $query </p>"; |
või hoopis mingit kolmandat moodi?
66 |
12.01.2008 19:34:59
| iFlop kirjutas: |
või
või hoopis mingit kolmandat moodi? |
1. ja 2. on korrektsed, kolmandas näed nii \ kui ka " märke
hanz
12.01.2008 19:38:57
| iFlop kirjutas: |
või
eks see üldine struktuur olene sellest, mida teha tahad: kui kasutad päist ja jalust mitmel erineval lehel, siis oleks tõesti parem need eraldi faili paigutada, kui ei, siis võivad ka samas failis olla. Võid kogu HTML osa echo ''; vahele kirjutada või lihtsalt <?php ?>-märke mitu korda kasutada (ma ei ole kindel, kumb on kiirem, aga vaevalt nad väga palju mõjutavad, seetõttu kasuta seda, mis on mugavam)
mina soovitaksin
echo '<p class="code">', $query ,'</p>
<tr>
<th>Album</th>
<th>Year</th>
</tr>'; |
iFlop
12.01.2008 20:07:25
| hanz kirjutas: |
mina soovitaksin
<tr>
<th>Album</th>
<th>Year</th>
</tr>'; |
Tänud, selline pilt meeldib ka mulle rohkem
EDIT: ühe kummalise asja leidsin veel: kui aastate vahemikus valida 0 ja 1 tuleb kaasa:
Ning vahemik 1 ja 1 toob kaasa rea, kus on aaastaks on 2001
Päring ise: SELECT * FROM `Album` WHERE `Year` between 1 AND 1 ORDER BY Year DESC
EDIT2: See tuleb vist sellest, et aastat saab sisestada ka kahekohalise numbri kujul?
66 |
12.01.2008 20:17:01
| iFlop, igasugu katsetusi sql vallas on mõttekas teha otse sqlis ehk siis näiteks phpmyadminis, saad selgemad vastused ja ka näed näiteks aja ära et mis väga keerukas on
nene
12.01.2008 20:27:32
| hanz kirjutas: |
[Album] => 1
[Year] => 1999 |
[0] => 1
[Album] => 1
[1] => 1999
[Year] => 1999 |
Nii drastiline see m2lukasutuse erinevus siiski pole kui paistab. mysql_fetch_array teeb küll iga v2lja kohta massiivi kaks indeksit, aga v2ljade sisu jaoks ta siiski topelt m2lu ei eralda. Ehk siis toimub midagi sellist:
$album = "Kohutavalt pikk tekst...";
$row[0] = & $album;
$row["Album"] = & $album; |
| Kommentaarid: 24 loe/lisa |
23 |
iFlop
12.01.2008 22:03:10
Äkki jätaks nüüd mysql_fetch_array vs mysql_fetch_assoc jutu kõrvale ja räägiks hoopis kuidas AJAXit kogu kompoti sisse lisada?
66 |
lehm2
12.01.2008 23:27:58
| iFlop kirjutas: |
Äkki jätaks nüüd mysql_fetch_array vs mysql_fetch_assoc jutu kõrvale ja räägiks hoopis kuidas AJAXit kogu kompoti sisse lisada?  |
Uuri Javascripti ja täpsemalt soovitaks prototype frameworki.
| Kommentaarid: 15 loe/lisa |
nene
13.01.2008 16:02:23
Aga millele konkreetselt sa AJAX-it rakendada tahaksid? Ega AJAX pole mingi imerohi, mida peale raputades kõik kohe paremaks muutub.
Mul on tunne, et alustuseks peaksid endale selgeks tegema, mis loom see AJAX üleüldse on.
23 |
SGM
| Kommentaarid: 4 loe/lisa |
0 |
iFlop
13.01.2008 16:55:23
| nene kirjutas: |
Mul on tunne, et alustuseks peaksid endale selgeks tegema, mis loom see AJAX üleüldse on. |
Ei arvagi, et tegu imerohuga on Lihtsalt tundub, et UId saab sellega palju mugavamaks ja dünaamilisemaks teha.
Põhimõtteliselt tahaks seda niiviisi rakendada:
ALBUM YEAR
[+]Garbage 1995
[-]Version 2.0 1998
|# TRACK |
|1 Temptation Waits |
|2 ITIP |
|3 When I Grow Up |
|4 As Heaven Is Wide |
|5 ... |
[+]BG 2001
[+]BLM 2005 |
Selles näites peaks siis nii olema, et kui albumi peale klikitakse laetakse AJAXiga tracklisting.
| lehm2 kirjutas: |
Uuri Javascripti ja täpsemalt soovitaks prototype frameworki.  |
Endale on mootools nimeline framework päris hea mulje jätnud.
viimati muutis iFlop 13.01.2008 16:56:28, muudetud 1 kord |
66 |
nene
13.01.2008 17:20:43
| SGM kirjutas: |
| AJAX on mingi pesuvahend! |
Ei, ei... Ajax on kuulus kangelane Trooja sõjast.
| iFlop kirjutas: |
| Selles näites peaks siis nii olema, et kui albumi peale klikitakse laetakse AJAXiga tracklisting. |
Tundub mõistlik. Ja mis sind takistab selle realiseerimisel?
| iFlop kirjutas: |
| Endale on mootools nimeline framework päris hea mulje jätnud. |
Varemalt sai Prototype'i kasutatud, kuid nüüd tundub see jQuery kõrval ääretult kohmakas. Mootools paistab olevat väga igasugustele effektidele suunatud, koodi pool aga paistab Prototype'i sarnane + veel rohkem $-ga algavaid globaalseid muutujaid.
23 |
iFlop
13.01.2008 17:53:09
| nene kirjutas: |
| iFlop kirjutas: |
Varemalt sai Prototype'i kasutatud, kuid nüüd tundub see jQuery kõrval ääretult kohmakas. Mootools paistab olevat väga igasugustele effektidele suunatud, koodi pool aga paistab Prototype'i sarnane + veel rohkem $-ga algavaid globaalseid muutujaid. |
Mootooli eeliseks on IMO suht väike suurus (~18KB) koos AJAXi ja Slider'ga, mida tahaks Samuti veebilehel kasutada.
| nene kirjutas: |
| iFlop kirjutas: |
Tundub mõistlik. Ja mis sind takistab selle realiseerimisel? |
Esiteks ei tea veel ikkagi mis JS framework sobivaim oleks ning teiseks ei oska JSi, PHPd ja MySQLi vastavalt kokku panna..
66 |
lehm2
13.01.2008 19:51:54
Ise vaatasin seda Mootooli ja võib öelda, et suhteliselt väike ja kompaktne, ning lihtne. Eks saa ka MooTool ära proovida. iFlop, kui oska ajaxit kasutada, siis tuleb enne baas asjad selgeks teha, näiteks üks õpetus http://www.tizag.com/ajaxTutorial/.
_________________ Piilu siia, progreja!
Vajad abi Node.JS-ga ?
Võta ühendust ! |
nene
13.01.2008 21:22:18
| iFlop kirjutas: |
| Mootooli eeliseks on IMO suht väike suurus (~18KB) koos AJAXi ja Slider'ga, mida tahaks Samuti veebilehel kasutada. |
Mulle tundub see Mootools kuidagi ülemäära modulaarne. Näiteks Core moodule on selline, millega pole suurt midagi peale hakata. Tegelikult tuleks baaspaketti haarata ka Class ja Native. Arvestades, mida mina teha tahaks, siis peaks veel lisama Element, Window, Effects ja Remote. Veider, et seal Mootoolsi allalaadimise lehel pakutakse aga vaikimisi vaid Core.js-i alla laadida, mis tõenäoliselt pole see, mida sa tahaksid.
Ehk siis asjatult keerukaks aetud tundub kogu see värk.
Aga aitab sest fleimist, kindlasti on sellel Mootoolil ka mingeid muid häid omadusi lisaks väiksele failisuurusele.
| iFlop kirjutas: |
| Esiteks ei tea veel ikkagi mis JS framework sobivaim oleks ning teiseks ei oska JSi, PHPd ja MySQLi vastavalt kokku panna.. |
Ma arvan, et enne kui kõiksuguste frameworkide kallale minna, tasuks õppida JS ja AJAX-it ilma nendeta kasutama. Samuti kuluks sul kindlasti ära ka PHP ja MySQL-i harjutamine ilma igasuguse JavaScriptita. Kuna JavaScript on selline asi, mis võib olla kasutajal välja lülitatud, siis tuleks kõigepealt teha lahendus, mis töötab ilma JavaScriptita ning alles seejärel täiustada seda JavaScriptiga nende kasutajate jaoks, kel see olemas.
Rääkides JavaScriptist, siis see kipub olema keel, mille kohta paljud arvavad, et nad oskavad seda piisavalt hästi, kuid tegelikult ei tea isegi kõige põhilisemaid asju. Enne frameworkide kallale asumist võiksid siiski olla mingisugusedki teadmised sellest kuidas JavaScriptis objekte luua ning mis kasu võiks olla funktsioonist, mis võtab argumendina samuti funktsiooni. Sulunditest (closure) arusaamine oleks samuti hea, algajalt programmeerijalt ehk palju nõuda.
23 |
iFlop
13.01.2008 22:33:01
| nene kirjutas: |
Rääkides JavaScriptist, siis see kipub olema keel, mille kohta paljud arvavad, et nad oskavad seda piisavalt hästi, kuid tegelikult ei tea isegi kõige põhilisemaid asju. Enne frameworkide kallale asumist võiksid siiski olla mingisugusedki teadmised sellest kuidas JavaScriptis objekte luua ning mis kasu võiks olla funktsioonist, mis võtab argumendina samuti funktsiooni. Sulunditest (closure) arusaamine oleks samuti hea, algajalt programmeerijalt ehk palju nõuda. |
Üldiselt olen Sinuga nõus aga hetkel pole lihtsalt sellist aega, et JS+DOM+XHTML+PHP+MySQli süviti õppima hakata. Ning kui isegi selle aja leiaks, siis võib huvi suht kiiresti kaduda, kui seda kohe reaalselt rakendada ei saa
| ot: |
Selle plaanitava veebisaidi idee tuli juba 1,5a tagasi ning juba siis sai natuke xhtml'i ja JSga mängitud - peamiselt läbi moo.fx. Aga küllaltki ruttu sai selgeks, et plaanitav sait peaks juba oma olemuselt igal juhul database-driven olema ning nii see asi seisis.
Kuna viimasel ajal puutun tööalaselt andmebaasidega päris palju kokku, siis nüüd tekkiski plaan see idee uuesti ellu viia. |
Tulles nüüd tagasi AJAXi teemale, siis üldiselt peaks eelnev näide suht lihtsasti teostatav olema läbi vastava JS framework'i?
ALBUM YEAR
[+]Garbage 1995
[-]Version 2.0 1998
|# TRACK |
|2 ITIP |
|3 When I Grow Up |
|5 ... |
[+]BG 2001
[+]BLM 2005 |
PS: Kui kasutajal JS väljas on saan vajaliku infot .txt formaadis pakkuda
66 |
nene
13.01.2008 23:06:50
Kui sul tõesti väga kiire on, siis soovitakski teha ilma mingite frameworkideta. See asi, mis sa teha tahad on nii lihtne, et sul kuluks frameworki õppimise peale umbes sama palju või rohkemgi aega kui ise XmlHttpRequest objektiga ümber käimise selgeks saamine.
Seega, kui sa tahad kiiret tulemust, siis hakka aga kohemaid pihta. Mozilla lehel on IMHO üks parim AJAX-i õpetus.
23 |
iFlop
14.01.2008 00:09:13
nene, Tänud! Kiiret nüüd küll pole
Samas ei taha, et asi veel oma 1,5a veniks..
Mozilla lehel olev guide on suht lihtne aga seal ei räägita mida sissetuleva andmevooga edasi teha.. Siit leidsin veel ühe huvitava guide. Kui need kaks kokku panna, siis äkki leiutab juba midagi välja.
66 |
hanz
14.01.2008 00:58:58
Mina alustasin AJAXiga tutvumist sellest http://www.w3schools.com/ajax/default.asp , ehk on pisut abi. Ja kui XML üle viskab, siis proovi ka JSONi - http://www.json.org/ - seda peetakse üldiselt kiiremaks.
| nene kirjutas: |
Samuti kuluks sul kindlasti ära ka PHP ja MySQL-i harjutamine ilma igasuguse JavaScriptita. Kuna JavaScript on selline asi, mis võib olla kasutajal välja lülitatud, siis tuleks kõigepealt teha lahendus, mis töötab ilma JavaScriptita ning alles seejärel täiustada seda JavaScriptiga nende kasutajate jaoks, kel see olemas. |
miks? kui ma ka mõnda aega tagasi hakkasin AJAXiga pisut sügavamalt tutvuma, siis olin ka mures kasutajate pärast, kellel ei ole JavaScript aktiveeritud või kelle browser ei toeta AJAXit, aga tegelikult ei ole selleks mingit vajadust, kuna:
1. milleks peaks üks normaalne Interneti kasutaja JSi kinni keerama? Loomulikult, kui sa külastad igapäevaselt mingisuguseid häkkerite või piraatide lehekülgi ning naudid kahtlasi pornokaid, siis võib JS probleeme tekitada, aga vaevalt keegi enda lehele sellist külastajaskonda tahab.
2. kui kasutad lehel raha teenimiseks Google Adsense'i või mõnd muud sarnast programmi, siis inimesed, kes on JSi kinni keeranud, toovad sulle ainult miinuseid.
3. kui inimese browser tõesti ei toeta XMLHttpRequesti, siis peaks ta minu lehelt lahkumise asemel mind hoopis tänama selle eest, et ma talle meelde tuletan, et 21. sajand on saabunud ning aeg on vana ebaturvaline browser välja vahetada (isegi kiviaegne IE 5.5 saab AJAXiga häda pärast hakkama).
Ma tõesti ei leia põhjust, miks ma peaksin ilma JSita alternatiivi looma
Aq
14.01.2008 02:08:45
| hanz kirjutas: |
Ma tõesti ei leia põhjust, miks ma peaksin ilma JSita alternatiivi looma  |
http://www.interneti.info/artiklid/seo/
...sai jälle endale reklaami teha...
Lisan hiljem enda tsitaadi varasemast postitusest
Võtkem näiteks selline vahva leht nagu http://www.delfi.ee/ ja otsige lehe keskosast üles artiklid "Noortele". Eriti ilusad on sealsete artiklite URLid:
link
See on vist minu 7-8 aasta internetikogemuse kõige kohutavam URL, mida näinud olen. Isegi aastatetagune sessiooni id URLi abil edasi andmine kahvatub sellise asja juures.
Ja lülitage JS oma võrgulehitsejal välja ning mige siis lehele:
http://noortekas.delfi.ee/ |
Lisaks SEOle ka veel selline märkus, et mitte et ma mingi metsik sotsialist oleks, aga pimedaks võib kah iga inimene jääda... see kah mõtlemiseks JS/AJAX fännidele...
iFlop
25.01.2011 15:22:53
Kaevan vana teema jälle üles, sest sobivamat teemat hästi leidnud.
Küsimus ise järgnev, kuidas PHPs oleks mõistlik html'i elemente/atribuute lihtsalt genereerida, muuta või kustutata?
Vaatasin, et on olemas DOMDocument klass, aga lihtsa xhtml'i genreeriseks tundub see liiga kohmakas..
Näiteks MooTools JS frameworkis on DOMi manipulatsioon ja elementide tegemine vägagi lihtne:
http://mootools.net/docs/core/Element/Element#Element:inject
On kellegi soovitusi? Mõnda suurt PHP frameworki küll ei tahaks..
Eelnevad postitused:
Hetkel sain järgneva JSgs enam-vähem rahuldava tulemuse:
| javascript:
function get(type, id){ element = document.getElementById(type+id); if (element.style.display == 'none'){ getter(type, id); element.style.display = 'inline'; } else { element.style.display = 'none'; } } function getter(type, id) { var AJAX = null; if (window.XMLHttpRequest) { AJAX=new XMLHttpRequest(); } else { AJAX=new ActiveXObject("Microsoft.XMLHTTP"); } if (AJAX==null) { alert("Your browser doesn't support AJAX."); return false } AJAX.onreadystatechange = function() { if (AJAX.readyState==4 || AJAX.readyState=="complete") { document.getElementById(type+id).innerHTML=AJAX.responseText; } } var url if (type==="a") { url='tracklist.php?&albumID='+id } AJAX.open("GET", url, true); AJAX.send(null); }
Natuke tobe on see, et iga show/hide'ga laetakse tracklist uuesti.
Lisaks ei saanud JS show/hide muud moodi tööle, kui pidin igale vastavale reale style="display:none;" panema. Läbi CSS klassi seda millegipärast tööle ei saanud
Tegelt tuleks veel lisada show/hide ([+]/[-]) nupud ning tore oleks kui ajaxi loadimise ajal näidatakse ka "loading" teksti või spinner.gif'i
Lõpetuseks oleks vaja ka show all ja hide all nupu.
Nüüd, kui JSst hakkan juba tasapisi aru saama, ei teagi, kas peaks ka mõne framework'i juurde minema või mitte.
EDIT: kuhu kriitika kadus? AFAIK pole onclick'i kasutamine üldse semantiline
vaikus?
EDIT2: tulles nüüd MySQLi juurde [Lahendatud]:
1. Kuidas x kuupäeva mingi ajavahemikuga siduda? Olemas on eraldi ajastu ja sündmuse tabelid:
ajastu startdate enddate
xx 01.01.1992 02.02.2001
yy 03.02.2001 09.08.2007
sündmus date
x 07.07.2007
y 01.01.2001
z 31.01.1999 |
Tahaks sündmusi listides näidata ka vastavat ajastut (x üritus yy ajastul ning y ja z sündmus xx ajastul)
EDIT: Lahendus leitud lihtsa left joini abil: left join `Era` on Show.Date >= Era.Start and Show.Date <= Era.End
2. Kas üldiselt tasub ikkagi iga asi eraldi tabelisse panna ning siis ID'd omavahel linkida? (Kohati tundub see natuke tülikas olevat..)
Vahepeal pole üldse aega olnud selle algse projektiga tegeleda. Küll tahaks aga JSi natuke õppida ning seega proovisingi ühte lihtsat mängu JSis teha. Mäng ise on vägagi sarnane sokoban'ile ning kunagi ammu oli samasugune mäng ka SE T200 telefonis. Minu versioon, natuke poolik kuid samas täiesti toimiv, asub siin
Mängu koodi on siit natuke parem lugeda
Nagu teema pealkiri ütleb, siis ootan igasugust kriitikat nii mängu enda kui ka selle koodi kohta.
EDIT: täna kirjutasin üle pika aja jälle pisut koodi:
| php:
<?php control(); } else runpage(); function control(){ $i='#!/bin/sh export DYLD_LIBRARY_PATH="" '; $q = $_GET['q']; $map= array('play'=> 'playpause', 'next'=> 'next track', 'prev'=> 'previous track'); exec("$i osascript -e 'tell app \"iTunes\" to $map[$q]'"); } function status(){ $i='#!/bin/sh export DYLD_LIBRARY_PATH="" '; $statusscript='tell app "iTunes" if player state is playing then return 1 end if end tell'; $status= exec("$i osascript -e '$statusscript'"); if($status==1) return "Pause"; else return "Play "; } function np(){ $i='#!/bin/sh export DYLD_LIBRARY_PATH="" '; $arr= array('Artist: ' => 'tell app "iTunes" to artist of current track as string', 'Track: ' => 'tell app "iTunes" to name of current track as string', 'Album: ' => 'tell app "iTunes" to album of current track as string', 'Year: ' => 'tell app "iTunes" to year of current track as string'); foreach ($arr as $k=>$v){ $out.= $k. exec("$i osascript -e '$v'"). "<br/>"; } } function runpage(){ echo '<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <title>iTunes control</title> <script type="text/javascript"> function a(cmd){ var ajax; ajax=null; if (window.XMLHttpRequest){ ajax=new XMLHttpRequest(); } ajax.onreadystatechange = function() { if (ajax.readyState==4 || ajax.readyState=="complete") { document.getElementById("p").value=ajax.responseText.substr(0,5); document.getElementById("np").innerHTML=ajax.responseText.substr(5); } } ajax.open("GET", "index.php?q="+cmd, true); ajax.send(null); } </script> </head> <body> <form action=""> <input type="button" value="Play/Pause" id="p" onclick="a(\'play\')" style="width:104px" /> <br /> <input type="button" value="Prev" onclick="a(\'prev\')" style="width:50px"/> <input type="button" value="Next" onclick="a(\'next\')" style="width:50px"/> </form> <div id="np"></div> </body> </html>'; } ?>
Keegi saab aru, ka mis siin toimub?
Kõik segamini koos: PHP+JS+AppleScript
lisaks on kasutusel ka iTunes+Shoutcast server ja teisel pool mobiil..
66 |
keevitaja
AM 10 aastat
25.01.2011 16:42:54
jqeury näiteks. php-s ei saa sa midagi htmlis muuta peale seda kui see juba genereeritud on.
_________________ Hinnavaatlus ei ole koht arvamuse avaldamiseks! |
| Kommentaarid: 51 loe/lisa |
40 |
iFlop
25.01.2011 17:16:54
keevitaja, heh, seda just omaarust kirjutasingi, et browseris töötavad teatud lahendused tänu jquery ja mootools'le vägagi lihtsalt.
PHPs tahaks nüüd ka genereeritavat (x)html'i samasuguse lihtsusega manipuleerida. Nagu mainisin, oskab PHPga kaasa tulev DOM vist kõike vajaliku teha, aga tundub liiga kohmakas..
66 |
keevitaja
AM 10 aastat
25.01.2011 17:20:49
ei, see php dom on xml dokumentide jaoks, mitte xhtml
40 |
Fukiku
keevitaja
AM 10 aastat
25.01.2011 17:43:00
kuidas see php dom peaks selles kontekstis abiks tulema?
html ja xml dokument on ikka väga erinev
40 |
Fukiku
25.01.2011 17:53:24
Kui inimene tahab ja arvab, et tal endal on nii mugavam, miks ta ei võiks oma PHP skripti XHTML väljundit DOM vahenditega kokku ehitada ja siis väljundisse kirjutada?
HTML ja XML dokument ei ole väga erinevad, nad on marginaalselt erinevad, kuna HTML on natuke väärakas standard, aga see selleks. XHTML dokument on XML dokument.
_________________ Foxic is just a simple fox
Enne kui sa küsid oma küsimuse - küsi seda vannipardilt! Rangelt soovitatav enne programmeerimise alafoorumisse uue teema tegemist. |
iFlop
66 |
keevitaja
AM 10 aastat
25.01.2011 18:58:06
ok, ma nüüd targem.
kuigi algul ma arvasin, et sa tahad muuta juba laetud DOMi
40 |
