roostevaba
19.12.2007 10:34:27
| MiXeR kirjutas: |
Peab ka vist logitechilt hiirt nuruma hakkama. Cruise down nupp lõpetas töötamise täielikult ja nüüd ka left click keberneerib.
Mul on see kõige sitem, et serial number, part number jms kraam on hiire alt ära kulunud.  |
mul oli sama teema.
alt oli ära hõõrutud, siis pingutasin silmi ja asju, et midagi välja lugeda. minu meelest nendel oli suva see number, sest tegin põhjast ka pilti, et ära oli hõõrdunud...
_________________ White Powwa! |
161 |
Hive
19.12.2007 16:54:01
Dear Mr. Kaldoja,
Thank you for contacting Logitech's Electronic Technical Support.
I am sorry to learn that the battery charge of the Logitech MX1000 Laser mouse is not lasting long.
The MX1000 Laser mouse is provided with non-replaceable rechargeable Lithium ion batteries which on complete charge should last approximately 14 days.
If the charge of the mouse is not lasting even after a complete charge, then the mouse could be defective. Please contact your point of purchase for an exchange during the warranty period.
If you are not able to return the device to the point of purchase, please write back to me with the following details.
1. The M/N: of the product (Model Number).
2. The S/N or PID: of the product (Serial Number or PID Number).
3. The P/N: of the product (Part Number).
4. Your Full Postal Address, area zip code, city, country & daytime Telephone Number.
5. Dealer Name, Address & Telephone Number.
6. The reason dealer did not exchange the product.
7. Purchase Date.
8. Results of charging the mouse completely.
Should you have any other queries, please do not hesitate to write back to me.
If you have any additional questions regarding your product, please feel free to visit our website at http://www.Logitech.com
Kind Regards,
Shreenand B.
Logitech Europe SA
European Customer Support
Pean poodi viima või saan kuidagi valetada ?
Äkki kirjutan,et vanaisa ostis jõuludeks aga vanaisa suri ära ja ma ei tea kust ta ostis selle ?
| Kommentaarid: 6 loe/lisa |
Lotharius
rallisibul
19.12.2007 17:03:46
Siin ju selgelt öeldud, et kui pood ei vaheta, siis saadad neile need küsitud andmed ja saad nendelt.
117 |
Mihkel.
19.12.2007 17:08:13
| Huvitav kas karbil on need kirjas? Teoreetiliselt peaks olema ikka.
| Kommentaarid: 92 loe/lisa |
roostevaba
20.12.2007 09:07:01
| MiXeR kirjutas: |
| Huvitav kas karbil on need kirjas? Teoreetiliselt peaks olema ikka. |
need on hiire põhjas kirjas
161 |
Hive
20.12.2007 11:25:27
| roostevaba kirjutas: |
| MiXeR kirjutas: |
need on hiire põhjas kirjas  |
Kui natuke eelnvaid poste uuriksid , siis ta ütles seal,et tal hiire alt ära kulunud
Aga ise mõtlen kas viitsin hakata seda k-arvutisalongi viima , või valetan mingi jama kokku ?
Lotharius
rallisibul
20.12.2007 11:36:58
Mida sul valetada on vaja? Kaua sul see hiir on olnud? Kui üle aasta, siis saadetakse sind K-salongist kukele ja tuled sama targalt tagasi. Seal öeldud selgelt, et kui ei vahetata poes, siis saata neile enda andmed ja tuleb sealt hiir. Ja kui on nõutud põhjust, miks poes ei vahetata, siis kirjutad, et üle aastaste toodete puhul OU Klisseran (K-arvutid) ei teosta garantii korras vahetust.
117 |
Hive
20.12.2007 13:18:58
On küll üle aasta
arm2004
20.12.2007 16:21:04
ma pean 3-da jaanuarini ootama, siis peaks oma MX5000 ka saama välja vahetatud põhimõtteliselt oleks ka Eestis garantiisse võetud, aga sellega kaasneks igasugune edasi-tagasi (saarelt mandrile ja vastupidi) saatmine, mille kulud läheks minu taskust. mul lihtsam asjad ära lõhkuda ja pilt meilida
kusjuures hiire lollused ja laadimised kannatab ära, aga klaver andis lambist saba. seega õigustatult küsin uut, ei ole lihtsalt külma tegemise peal väljas
97 |
Mihkel.
20.12.2007 16:23:25
| Saab keegi omanik öelda kas hiire all ja vastuvõtja all olevad S/N, M/N ja P/N kattuvad? Hiire klaveri komplektil ei kattunud, aga äkki ainult hiirel kattub?
20.12.2007 17:03:37
| aga kas peaksid kattuma ?
| Kommentaarid: 85 loe/lisa |
Hive
20.12.2007 17:11:06
| MiXeR kirjutas: |
| Saab keegi omanik öelda kas hiire all ja vastuvõtja all olevad S/N, M/N ja P/N kattuvad? Hiire klaveri komplektil ei kattunud, aga äkki ainult hiirel kattub? |
ei kattu.
roostevaba
20.12.2007 17:24:34
| MiXeR kirjutas: |
mul ka mitte:)
161 |
Mihkel.
20.12.2007 17:27:42
| mikk36 kirjutas: |
| aga kas peaksid kattuma ? |
Eino ma nagu lootsin.
Aga kui ei kattu, siis peab vist hiire laiaks lööma või usb kaabli ära lõikama.
roostevaba
20.12.2007 17:32:21
| MiXeR kirjutas: |
| mikk36 kirjutas: |
Aga kui ei kattu, siis peab vist hiire laiaks lööma või usb kaabli ära lõikama.  |
ma saatsin neile usb otsa, mis arvutisse läheb
161 |
Hive
23.12.2007 17:23:25
Dear Mr. Kaldoja,
I thank you for getting back with the information.
I am glad to inform you that, I am shipping you a new Logitech MX1000 Cordless mouse for your existing defective cordless mouse, free of cost.
Once you get the new cordless mouse, I request you to cut the power supply plug and USB and PS/2 receiver plugs of the old cordless mouse and pack them in an envelope and send it to the following address:
Logitech Service Center
c/o Sykes Enterprises
ID 071223-000145
Roffhausener Landstrasse 18d
26419 Schortens
Germany
We need the above-mentioned part to close your case. You will be receiving the cordless mouse within 15 days. You do not have to confirm receipt of this e-mail.
Should you have any further questions, do not hesitate to get back to me.
If you have any additional questions regarding your product, please feel free to visit our website at http://www.logitech.com
Kind Regards,
Anees Ur Rahman
Logitech Europe SA
roostevaba
24.12.2007 13:54:44
| Hive kirjutas: |
Dear Mr. Kaldoja,
ID 071223-000145
26419 Schortens
Germany
Kind Regards,
Anees Ur Rahman
Logitech Europe SA
European Customer Support |
Paju õnne siis
161 |
Hive
24.12.2007 14:50:04
Hea jõulukingitus
Refused
25.12.2007 10:22:08
Ka mulle tuli täna kiri, et 10 päeva jooksul peaks uus hiir saabuma koos jõuluõnnitlustega
92 |
roostevaba
25.12.2007 11:58:42
nad ikka seal logitechis päris lihtsalt jagavad neid uusi hiiri. Päris üllatus tegelt...
161 |
sakinaga
25.12.2007 12:41:54
| nad ikka seal logitechis päris lihtsalt jagavad neid uusi hiiri. Päris üllatus tegelt... |
Samas, kui paljud inimesed oskavad seda üldse küsida?
154 |
25.12.2007 13:21:20
| maatriks kirjutas: |
Samas, kui paljud inimesed oskavad seda üldse küsida? |
ja kui paljudel on vaja vahetada üldse arvestades nende kogutoodangut ?
btw, oskab keegi kiirelt öelda et kui kaua tallinna kaubamaja garantiid annab ?
kui 1a, siis saadan ka neile pildi enda hiirest (pole küll MX1000, aga siiski)
Hive
25.12.2007 14:03:13
| See tuleb postkontorisse ja siis pean sinna järgi minema ?
roostevaba
25.12.2007 14:59:17
| Hive kirjutas: |
| See tuleb postkontorisse ja siis pean sinna järgi minema ? |
Saadetakse koju.
Ja maatriks, no eestist on küll viimaksel ajal palju vahetamispalveid sinna laekunud
161 |
Mihkel.
26.12.2007 19:33:59
Mulle pandi ka nüüd uus hiir teele. Piisas kui kirjutasin vastuvõtja alt numbrid.
