Mart352
01.06.2003 21:44:44
Ma leidsin Codemasters-i koduleheküljelt Minimum system requirements-i, mille minu masin peaks nagu täitma ja directX 9 on peal. Demo aga tööle ei lähe. Oskab keegi öelda milles probleem on.
Veateateks saan, et Your craphics card does not meet the minimum system specifications for this game. Kas asi võib olla selles, et tõmbasin demo gameland.ee-st. Seal on faili suuruseks 121 MB kuid Codemasters-i kodulehel on see 92,5 MB.
Min sys requirements
Processor - Pentium 3 700mhz / Athlon 700mhz
RAM - 128Mb
Graphics Card - Rage 128 32Mb / TNT2 32Mb / G400 32Mb
Sound Card - SoundBlaster compatible
Operating System - Windows 98, ME, 2000 or XP
DirectX - DirectX 8.1b
Minu masina konf
_________________ Imperfection is perfect |
| Kommentaarid: 54 loe/lisa |
51 |
01.06.2003 21:48:37
põhjusi võib ju olla mitu...mul ka gamelandi fail, aga töötab...proovi leida uued video draiverid, keera kinni taustal töötavad programmid, abiks võib olla ka restardi tegemine
| Kommentaarid: 94 loe/lisa |
81 |
01.06.2003 21:50:47
| Mart352 kirjutas: |
RAM - 128Mb
Minu masina konf
sa oled ju välja toonud Pro Race Driver 'i system requirementsi
Pro Race Driver > PC > Demos > Single Player Demo
Title > Single Player Demo
Date Uploaded > 27th February 2003
Description > This demo includes one test drive at Brands Hatch in the Proton Satria and a race at Sears Point in a Supra against a full field of Euro Tour cars.
Technical Description > Minimum system requirements
RAM - 128Mb
Recommended system requirements
Processor - Pentium 4 2ghz / AthlonXP 2000+
RAM - 512Mb
Graphics Card - GeForce 3 Ti 500 64mb
Sound Card - SoundBlaster Audigy
Operating System - Windows XP
81 |
OskarR89
01.06.2003 21:56:44
Colin McRae 3e omad on siis
(i) Minimum Requirements
- Windows 98SE/ME/2000/XP
- DirectX 9
- Pentium III or Athlon at 750Mhz
- 128Mb RAM
- Supported 32Mb Graphics Card
- DirectX 9 Compatible Sound Card
(ii) Recommended Requirements
- DirectX 9
- Pentium 3/4 or Athlon at 1.4Ghz
- 512Mb RAM
- Supported 64Mb Graphics Card
139 |
Mart352
01.06.2003 22:05:08
Olen jah, täna vist liiga kaua arvuti taga istunud.
Õige leht on siin
Seal on fail 119 MB suur, vist sellepärast, et zipiga kokku pakitud.
Aga sellejärgi peaks ta ikkagi tööle minema.
Kas TNT 2 m 64 32 MB jääb ka selle rea tähenduse alla. Supported 32Mb Graphics Card
51 |
Zoig
01.06.2003 22:26:16
| malcom kirjutas: |
tõsijutt minu juustul(p2 350mhz) on kõik maha keeratud ja sis mäng jookseb küll
siis peaks ka minul ju minema!!! sul tõrgub ka vä |
esimesed 2 korda tõksis, edasi on juba suht sujuvalt jooksnud, aga jama on heliga, nimelt ennem sõites heli ei ole kui replay on 1/2 peale mängitud
| Kommentaarid: 48 loe/lisa |
44 |
OskarR89
01.06.2003 22:33:14
(iii) Supported Graphics Cards
ATI Radeon 8500LE, 8500, 9000 Pro, 9500 Pro, 9700 Pro
Matrox Parhelia
nVidia nForce 1 & 2, GeForce, GeForce 2, GeForce 3, GeForce 4
SiS Xabre 400
sinu kaarti siin kirjas ei ole!! Selleks sul ei lähegi
139 |
yek
01.06.2003 22:43:36
mul on aga ikka ei lähe tööle (geforce2 mx200)
stalcer_x
| Kommentaarid: 28 loe/lisa |
Tuhkur
01.06.2003 23:02:14
hmm... abiks siis demo ära tirida(kehvema yhenduse puhul 3h max) ja lugeda readme vms läbi.
oleks siis mõni readme ka demoga kaasas oleks hästi...
Matrox Parhelia
SiS Xabre 400
minu kaart on seal näiteks kirjas...aga pilt ikkagi vigane...
_________________ ____________________ |
| Kommentaarid: 10 loe/lisa |
Mart
01.06.2003 23:32:55
Proovisin siis kah mängu demo lõpuks ära. IMO graafika on päris hea, aga see juhitavus on küll halb või on põhjus lihtsalt selles, et ma ei teagi tegelt, kuidas ralli auto käituma peaks.
yek
01.06.2003 23:33:14
| sain korda...aga üks väike probleem veel et need ajad mis ma seal välja sõidan ei klapi...sekund seal on umbes pärismaailmas 2 ja pool sekki vms aga muidu mäng jookseb puhtalt!!!
traks
304 |
madest
02.06.2003 03:01:09
| voltc kirjutas: |
gtosse saab nii, et regad ja t6mmad proge  |
trrr mul on väike küss miks se GTO nii segast peksab
mul juuser on sel "madest"
aga Colin'is plyer on nagu mad ja siis koguaeg kui submitin viskab accounti useri mad i peale nagu m2ngus ??
ja ükski tulemus pole yles läinud....
Tuttaval oli samas nii et isegi sama user ja player iga tulemused yles ei läinud ....
kas GTO l mingi kala ??
| Kommentaarid: 13 loe/lisa |
VeixES
02.06.2003 07:50:54
eee.... kala jah. ma ka ei saand algul submittida. aga abiks double-click selle ikooni peal all nurgas ja siis vahetada initsiaalid õige nime vastu ja siis submittida ajad
_________________ Tule ja arutle mobiilsidest, võrkude kaardistamisest, tehnoloogiast, telefonidest ja operaatoritest http://t.me/cellmappereesti |
| Kommentaarid: 36 loe/lisa |
madest
02.06.2003 08:59:18
| [veix] kirjutas: |
eee.... kala jah. ma ka ei saand algul submittida. aga abiks double-click selle ikooni peal all nurgas ja siis vahetada initsiaalid õige nime vastu ja siis submittida ajad  |
ma räägin et muudan ära no ja submitin aga ei lähe
ja kui võtan selle "Reload" nupuga uued ajad logist(või kust iganes), muudab ta jälle nime ära
Tuhkur
02.06.2003 10:46:11
no ma teen samamoodi ja kõik on ok...algul on seal nimi kolme tähega...siis panen aga oma GTO sisselogimis nime ja kõik on ok...
One
02.06.2003 15:03:57
mai saa aru mix siia mingi 10x neid minimum system spec-se toodud on? ma andsin need ju juba mingil teisel v6i kolmandal lehel, yhes6naga inimesed lugege teema algusest l6puni l2bi
728 |
yek
02.06.2003 18:52:40
| mh...mul selline mure et see aeg mis seal kõrval käeb see käib aegluubi(see sekund mis seal on on umbes päriselus 2 ja pool sekki) et kui keegi teab mis viga on siis öelgu...PS mäng jooxeb muidu puhtalt
kukimuki
03.06.2003 00:24:56
| Huvitav, kas mängu kakkumisel mängib siiski rolli see,et mul on 256 RAM -mis on min.nõudeks,aga soovitav on siiski 512.Muud nõuded peaks olema kuhjaga täidetud.Nii kui UK rajal heinabrikettide vahele ja metsa jõuan hakkab üks kuradi tõmblemine pihta.
Valta
03.06.2003 09:49:00
Väga kahtlane tundus see demo mulle, ainuke normaalne asi oli Auto detailid ja damage .
Doc Cannibal
03.06.2003 09:57:06
njah..sai ka ise seda pela proovitud. graafika on normaalne, kuid mitte midagi erilist. auto detailid on suht hästi isegi tehtud. juhitavus on asfaldil küll pisut "vesine" kuid seda põhjustab ilmselt default setting, mida fullis kindlalt võrreldes cmr2 veel arendatud on. rajad tundusid ka suht huvitavad, kuna endale meeldivadki just sellised kitsad ja käänulised rajalõigud. ühesõnaga jään fuli ootama
| Kommentaarid: 20 loe/lisa |
20 |
IceUul
Sinu Ema
03.06.2003 11:51:36
Ikka väga kehva arengu on see läbi teinud, juhitavus on jälle selline libe arcade, kuigi cmr2 omaga ei oska võrrelda, kuid tundub sama tüüpi olevat, ainult auto pidamine on tunduvalt halvem.
Samuti ei ole suudetud puid ikka korda teha, mingusugused puu pildid on tee äärtes ja 100-ga vastu pisikest 2d põõsast sõites on sama efekt nagu sõidaks vastu betoon seina. Mängu tegijad on vist omal ajal füüsika tundidest poppi teinud, sest auto füüsilisest käitumisest tee ja objektide suhtes ei ole neil õrna aimugi. See viga on esindatud muide kõikides codemasteri automängudes.
Muidu tundub norm mäng olevat, juhitavusega saab hakkama, graafika on kah kena ja auto näeb hea välja ning läheb ilusti katki. Suurima pettumuse valmistas mulle aga mängu mängimine rooliga, kui cmr2-s oli rooliga sõitmine täiesti reaalne (nagu ikka päris autoga), siis siin tundus nagu rattad ei puudutaks üldse maad, roolil mingit vastujõudu pole. Samuti on julm delay sees, mis muudab mängimise rooliga võimatuks.
Panex 5-st punnist hinde 3
| Kommentaarid: 218 loe/lisa |
187 |
@cer
03.06.2003 12:39:51
Lasin ka oma näpud käiku. Alguses tundus asi hull, juhitavust nagu polnudki olla. Eriti käitus auto imelikult kurvides, võimatu oli sõita Inglismaa rajal metsavahelisel lõigul. Võtsin siis graafikat veidi maha, draw distance panin 10-elt 7-mele ja Z Dephi võtsin 24-lt 16-mele. Ennäe imet, kas tegu on vigase demo versiooniga või minu arvuti (eeskätt videokaardi) kapriisidega, auto juhitavus muutus ebaloogiliste muudatuste tõttu palju paremaks. Auto käitub nüüd kurvides palju rahulikumalt ja jaapani rajal libisemisel ei ole enam sellist ebanormaalset kohest külje ette-viskamist.
Graafika ise on korralik (pettumuse valmistasid puud ja pealtvaatjad, kes tundusid täpselt samasugused nagu cmr2-es), eriti meeldis auto enda graafika. Auto katki minevus on ka hea. Muideks mul endal õnnestus mingi nipiga parem-esiratas alt ära saada. Sai ka rooliga proovitud mängu (peale graafika muutmist) ja jällegi ei oska öelda, kas viga minu arvutis, aga täiesti tore oli sõita.
Full versioonilt ootaks rohkem ja loodan, et nad ka mõned vead ära parandavad. Kas kohe full versiooniga või mõne hilisema patchiga. Kuna mäng on sisuliselt vananenud, siis loodan ka, et lastakse välja patch (nagu cmr2 2002 autod), mis tooksid rajale selle aasta masinad.
Annaks 5-st punktist hinde 3,5. Arenguruumi jagub veel.
_________________ Muudab see maailma... ilmselt mitte. |
Tuhkur
03.06.2003 13:38:08
erinevalt cmr2'est ei ole cmr3'es enam default setingut...mäng paneb ise enamvähem parima setingu paika...vähemalt täisversioonis on küll nii...kui soovi oli siis võisid ise ka miskit ära muuta...
ja üks asi veel ,et kui nüüd võistlust sõidad ja sõitude vahepeal auto parandamiseks läheb...siis parandab mäng jällegi ise vajalikumad asjad ära...erinevalt cmr2'est kus tuli ise parandada seda mida tahtsid...
