01.12.2007 18:01:22
| Max Powers kirjutas: |
Siis ma ei näe seda foorumit üldse :-P
Sa ütled seda nii nagu tegemist oleks millegi halvaga :).
Jah, mul on see(ja paljud teised) foorumid peidetud.
147 |
Mario.
01.12.2007 18:04:52
Profiilist saad tervet foorumit ignoreerida.
Ma tahaks foorumite nimekirjas ikka näha. Lihtsalt nende hulgas ei taha näha:
vaata enda postitusi :: vaata vastamata postitusi
vaata postitusi alates viimasest külastusest :: vaata lugemata postitusi |
foorumise eiramisel ilmus ta minul ainult "vaata enda postitusi" all. Tanel ütles et tegeleb
6 :: |
217 |
ranel
01.12.2007 21:36:04
Miks mul vahepeal sellist jura ette viskab ?
= 4) && is_ie && is_win) { theSelection = document.selection.createRange().text; if (!theSelection) { txtarea.value += bbopen + bbclose; txtarea.focus(); return; } document.selection.createRange().text = bbopen + theSelection + bbclose; txtarea.focus(); return; } else if (txtarea.selectionEnd && (txtarea.selectionEnd - txtarea.selectionStart > 0)) { mozWrap(txtarea, bbopen, bbclose); return; } else { txtarea.value += bbopen + bbclose; txtarea.focus(); } storeCaret(txtarea); } function bbstyle(bbnumber) { var txtarea = document.post.message; txtarea.focus(); donotinsert = false; theSelection = false; bblast = 0; if (bbnumber == -1) { // Close all open tags & default button names while (bbcode[0]) { butnumber = arraypop(bbcode) - 1; txtarea.value += bbtags[butnumber + 1]; buttext = eval('document.post.addbbcode' + butnumber + '.value'); eval('document.post.addbbcode' + butnumber + '.value ="' + buttext.substr(0,(buttext.length - 1)) + '"'); } imageTag = false; // All tags are closed including image tags txtarea.focus(); return; } if ((clientVer >= 4) && is_ie && is_win) { theSelection = document.selection.createRange().text; // Get text selection if (theSelection) { // Add tags around selection document.selection.createRange().text = bbtags[bbnumber] + theSelection + bbtags[bbnumber+1]; txtarea.focus(); theSelection = ''; return; } } else if (txtarea.selectionEnd && (txtarea.selectionEnd - txtarea.selectionStart > 0)) { mozWrap(txtarea, bbtags[bbnumber], bbtags[bbnumber+1]); return; } // Find last occurance of an open tag the same as the one just clicked for (i = 0; i < bbcode.length; i++) { if (bbcode[i] == bbnumber+1) { bblast = i; donotinsert = true; } } if (donotinsert) { // Close all open tags up to the one just clicked & default button names while (bbcode[bblast]) { butnumber = arraypop(bbcode) - 1; txtarea.value += bbtags[butnumber + 1]; buttext = eval('document.post.addbbcode' + butnumber + '.value'); eval('document.post.addbbcode' + butnumber + '.value ="' + buttext.substr(0,(buttext.length - 1)) + '"'); imageTag = false; } txtarea.focus(); return; } else { // Open tags if (imageTag && (bbnumber != 14)) { // Close image tag before adding another txtarea.value += bbtags[15]; lastValue = arraypop(bbcode) - 1; // Remove the close image tag from the list document.post.addbbcode14.value = "Img"; // Return button back to normal state imageTag = false; } // Open tag txtarea.value += bbtags[bbnumber]; if ((bbnumber == 14) && (imageTag == false)) imageTag = 1; // Check to stop additional tags after an unclosed image tag arraypush(bbcode,bbnumber+1); eval('document.post.addbbcode'+bbnumber+'.value += "*"'); txtarea.focus(); return; } storeCaret(txtarea); } // From http://www.massless.org/mozedit/ function mozWrap(txtarea, open, close) { var selLength = txtarea.textLength; var selStart = txtarea.selectionStart; var selEnd = txtarea.selectionEnd; if (selEnd == 1 ||
165 |
7 :: |
362 |
ranel
01.12.2007 23:38:43
Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.11) Gecko/20071127 Firefox/2.0.0.11
see on, seadeid ei ole mina midagi muutnud
165 |
02.12.2007 18:21:27
| statistikas võiks nendel "baridel" ka src välja ära täita, hetkel on "<img src="" "
| Kommentaarid: 85 loe/lisa |
naaskel
jooda
04.12.2007 10:46:20
peale teenusepakkuja vahetamist olen hakanud liigagi tihti nägema teksti "Internet Explorer cannot display the webpage". refresh ja asi jälle korras aga miks ma pean refreshima, kui on olemas link "eelmine" või "vaidlused" jne
103 |
04.12.2007 10:59:21
| naaskel kirjutas: |
peale teenusepakkuja vahetamist olen hakanud liigagi tihti nägema teksti "Internet Explorer cannot display the webpage". refresh ja asi jälle korras aga miks ma pean refreshima, kui on olemas link "eelmine" või "vaidlused" jne  |
aeglasem nagu on jah HV viimasel ajal siiski
tanel, ka elisa link pole piisav ?
04.12.2007 11:04:01
Täpsustage palun ka enda ühenduskiirusi ja teenusepakkujaid ja mis teemadega konkreetselt?
Lingis ei tohiks probleem olla, vähemalt koduse Elisa ühenduse taga lippab HV ülikiirelt
EDIT: umbes nii "Leht loodi 0.1166 sekundiga (PHP: 90% - SQL: 10%) :: tehti 16 päringut 0.0121 sekundiga"
Kui üldse kuskilt aeglus tuleb, siis ehk andmebaasidest, mis vajaksid optimeerimist ja indekseerimist.
Samas ei seleta see seda, miks minul HVF kiirelt toimib.
_________________ Erakopeerimistasu tõstmise ettepaneku tagasilükkamine
7 :: |
362 |
ufo56
04.12.2007 11:08:22
Mul HV' sama kiire nagu varem oli. Pole vahet nagu. Digi TV ühendus on. Mingeid erroreid vms pole kordagi näinud
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
Mart352
| Kommentaarid: 54 loe/lisa |
51 |
naaskel
jooda
04.12.2007 11:11:09
ühegi teise lehega seda probleemi pole.
istun nö valitsuside otsas aga mis kiirused jne pole aimugi
kodus on elisa ühendus (see tasuta 5MB) ja ka seal esineb seda errorit
103 |
7 :: |
362 |
nuub
ufo56
04.12.2007 11:31:44
Äkki saab sinna mingi lihtsa küsimuse panna millele peab vastama ennem kommentaari saatmist.
Kommentaarid kustutasin ära
67 |
7 :: |
362 |
04.12.2007 11:43:22
| hmm, mul vast probleemi pole tundub, pigem asi suures koguses piltides, mis 8MB cache sisse ära ei mahu (mis panin brauserile testiks)
naaskel
jooda
04.12.2007 12:30:12
| Tanel kirjutas: |
nojah, täpsemate andmete puudumisel ei saa praegu küll midagi teha
Kas errorit annab HV või foorum? |
foorum
103 |
7 :: |
362 |
04.12.2007 12:39:41
| Tanel kirjutas: |
Erinevate arvutitega samas võrgus?
Kui tihti?
Kas lihtsalt lehekülg ei avane?
Mis teemad täpsemalt? |
Just tuli näiteks.
Pole võimalik ühendada
Firefox ei suuda luua ühendust serveriga aadressil foorum.hinnavaatlus.ee.
* Veebileht võib olla ajutiselt kättesaamatu või liialt hõivatud. Proovi mõne hetke pärast uuesti.
* Kui sa ei saa avada ühtegi lehte, siis kontrolli oma arvuti võrguühendust.
* Kui sinu arvuti või võrk on kaitstud tulemüüri või puhverserveri poolt, siis tee kindlaks, et Firefoxil on lubatud ligipääs internetile.
viimati muutis Dirty Harry 06.12.2007 17:35:20, muudetud 1 kord |
147 |
04.12.2007 12:53:37
Erinevate arvutitega, tööl-kodus, erinevate ühendustega (Elion, Lynx, Uninet) pole minul kunagi ühtegi veateadet peale selle mis vahest otsingul ilmneb...
| Kommentaarid: 94 loe/lisa |
81 |
8
04.12.2007 17:09:04
| Mul pole viimastel aegadel HV foorumiga mitte mingisuguseid tehnilisi probleeme enam täheldunud. Absoluutselt. Parem kui kunagi varem. Ning viimasel ajal olen ikka päris palju siin surfanud. Pealegi veel klikiaegse arvuti ja opsüsteemiga...
| Kommentaarid: 37 loe/lisa |
37 |
XYZ
04.12.2007 18:26:51
| 8 kirjutas: |
| Mul pole viimastel aegadel HV foorumiga mitte mingisuguseid tehnilisi probleeme enam täheldunud. Absoluutselt. Parem kui kunagi varem. Ning viimasel ajal olen ikka päris palju siin surfanud. Pealegi veel klikiaegse arvuti ja opsüsteemiga... |
Mida aeg edasi, seda parem selleks otstarbeks võibki klikiaegne arvuti ja tarkvara olla - neile ei hooli keegi pahalasi enam vorpida 8)
| Kommentaarid: 81 loe/lisa |
12 :: |
56 |
woozy
06.12.2007 00:54:00
Pole ju raske selle 8) smaili tagi ära vahetada, kasvõi või mis iganes... suht häiriv..
7)
8)
120 |
Mario.
06.12.2007 00:55:01
Msn fanatit
6 :: |
217 |
06.12.2007 00:57:44
| woozy kirjutas: |
7)
8) |
ommg, see smail oli juba enne msni aega tähistatud niimodi ja ma mappisin ka msnis endal selle ümber 8)
81 |
06.12.2007 17:35:56
| Tanel kirjutas: |
Kui tihti?
Just tuli näiteks.
147 |
ranel
07.12.2007 21:13:45
vahetevahel viskab sellise asja ette, kui oled kellegi profiilis käinud ja paned "vaata enda postitusi"
tsing leidis 119 vastet
Avaleht mine lehele 1, 2, 3, 4, 5 järgmine
Avaleht :: Firmad :: Viki :: Foorum :: Fotovõistlus :: Viited :: Reklaam :: Eripakkumised :: Virtuaalserverid :: Statistika :: Telekavad :: HV toote otsing
Eripakkumised STIILSED HP SÜLEARVUTID 12990.-
Ärifoorumi tasulised teemad HV jõululoos - HV lotopiletite müük kuni 15.12.2007, pott juba 33275 EEK 709 35427
ID-kaardiga autentimine ärifoorumites (muutused septembris ja 2008. a.!) 338 12769
HV logoga helkurvestid - avatud regamisvorm! 100 2884
HV MM KABE: "nääriprae turniir 2007" 172 3043
foorum teemasid autor vastuseid vaadatud viimane postitus
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: snap3
[ mine lehelemine lehele: 1, 2 ] 22.04.2004 12:40
MacAivar 49 3210 07.12.2007 17:47
jansadj vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: rannu15
[ mine lehelemine lehele: 1, 2, 3, 4 ] 14.06.2005 20:25
kaabakas 94 7180 07.12.2007 17:20
M!nA vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: Morillo
[ mine lehelemine lehele: 1, 2, 3, 4 ] 23.09.2003 09:40
bigmarx 85 2770 07.12.2007 16:31
Semmi vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: cdrom
[ mine lehelemine lehele: 1, 2, 3 ] 23.01.2006 21:54
Cyberlord 72 2981 07.12.2007 16:02
Ritsu82 vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: xaker
[ mine lehelemine lehele: 1, 2, 3, 4 ] 23.08.2003 09:04
RvD 99 4462 07.12.2007 13:44
al_z vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: Mõmm
[ mine lehelemine lehele: 1 ... 17, 18, 19 ] 27.08.2003 11:27
Nu 472 21817 07.12.2007 12:01
YRO vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: likoor
26.10.2006 18:02
OmmOs 13 1146 06.12.2007 21:35
mina777 vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: tennar
[ mine lehelemine lehele: 1, 2, 3 ] 30.04.2007 06:57
vindi 62 1993 06.12.2007 20:33
gogik vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: zarc
[ mine lehelemine lehele: 1 ... 4, 5, 6 ] 29.09.2003 18:23
muhvn 136 5698 06.12.2007 19:37
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: H_K
03.03.2005 20:37
Rastafari 22 1805 06.12.2007 16:50
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: huntermagic
[ mine lehelemine lehele: 1, 2 ] 04.06.2005 12:35
taurix 31 5508 06.12.2007 16:31
TarMoH vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: max86
18.03.2007 19:04
rainerz 19 690 05.12.2007 21:48
swodoo vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: RvD
[ mine lehelemine lehele: 1, 2 ] 22.08.2003 06:15
Nu 29 3439 05.12.2007 21:06
insekas vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: raunokr
[ mine lehelemine lehele: 1, 2 ] 23.10.2006 14:38
emmennpee 40 1037 05.12.2007 20:39
bob vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: Tanel
[ mine lehelemine lehele: 1 ... 9, 10, 11 ] 21.08.2003 16:17
Celeron 250 49613 05.12.2007 17:32
Gil-Harris vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: M!nA
[ mine lehelemine lehele: 1 ... 4, 5, 6 ] 29.06.2004 16:30
Magic 140 11312 05.12.2007 17:06
ranel vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: Anton
[ mine lehelemine lehele: 1, 2 ] 21.08.2003 18:15
MorroW 44 2863 05.12.2007 16:31
VR53 vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: oodi200
[ mine lehelemine lehele: 1, 2 ] 28.08.2005 19:26
Winterwind 31 901 05.12.2007 15:57
Rastafari vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: Archangel
02.09.2007 17:43
oodi200 5 162 05.12.2007 11:26
pip vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: ceemic
[ mine lehelemine lehele: 1 ... 6, 7, 8 ] 22.03.2005 14:14
neo 194 22056 05.12.2007 10:49
tools vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: nurro2
14.02.2006 17:46
ceemic 20 1082 04.12.2007 13:31
RagnarKahr vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: Oliver112
[ mine lehelemine lehele: 1, 2 ] 13.07.2004 19:10
Mirage 44 3757 03.12.2007 22:40
nmk vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: pennu
[ mine lehelemine lehele: 1, 2, 3 ] 24.08.2003 21:12
soodent 62 3740 03.12.2007 20:12
superior vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: k2nsa_hps
[ mine lehelemine lehele: 1, 2, 3 ] 31.10.2006 01:10
ferru 66 1655 02.12.2007 16:06
time123 vaata viimaseid postitusi
uued postitused puuduvad Kommentaarid kasutajatele Kommenteerimine: T2nel
[ mine lehelemine lehele: 1, 2, 3, 4 ] 07.10.2004 13:19
WipeOut 82 4001 02.12.2007 12:49
Turakaz vaata viimaseid postitusi
165 |
7 :: |
362 |
ceemic
24/7@kalal
322 |
08.12.2007 13:27:17
| Kas see on õige koht küsimaks, miks kanepi legaliseerimise teema lukku pandi?
147 |
Mart352
51 |
08.12.2007 16:01:51
| Miks ei sobi HVsse teema, kus arutatakse internetikasiinode üle?
147 |
7 :: |
362 |
08.12.2007 17:42:49
Aga kuidas teiste pahede üle tohib sellisel juhul rääkida? Autoteemas rullnokkadest, maailmalõputeemas saastamisest.
Üldiselt pole mõtet vastata, me teame mõlemad vastust ja need on retoorilised küsimused. Saab aega ja klaviatuuri kokku hoida.
viimati muutis Dirty Harry 08.12.2007 17:43:24, muudetud 1 kord |
147 |
7 :: |
362 |
zorten22
10.12.2007 10:40:43
| Miski suurem jama oli HV-ga...?
| Kommentaarid: 91 loe/lisa |
Mart352
10.12.2007 10:42:17
| zorten22 kirjutas: |
| Miski suurem jama oli HV-ga...? |
pmst 8 tundi oli maas öösel 01:00 kadus ära, ei saanud avalehele ega midagi
51 |
ufo56
10.12.2007 10:53:26
Kell 1 öösel oli küll foorum ju olemas, või krt ma ei käinud enam siin. Ei tea , minuarust oli öösel küll mingi kell ikka
67 |
Mart352
10.12.2007 11:10:26
| ufo56 kirjutas: |
| Kell 1 öösel oli küll foorum ju olemas, või krt ma ei käinud enam siin. Ei tea , minuarust oli öösel küll mingi kell ikka |
mitte täpselt kell 1 ei kadunud ära, 10 minutit pärast ühte on ööteemas viimane post, selle nägin eile ära lugeda ja siis oligi kõik. Praegugi sama post alles https://foorum.hinnavaatlus.ee/viewtopic.php?p=4061967#4061967
51 |
Max Powers
11.12.2007 15:16:46
Kuidagi aeglane on HV täna
182 |
ojapoiss
11.12.2007 15:17:45
Kuidagi aeglane on HV täna  |
Ei tunne küll... kala äkki sinu pool juhtme otsas?
| Kommentaarid: 65 loe/lisa |
51 |
Max Powers
11.12.2007 15:20:17
Ruuter.ee järgi 10.1 Mbit/sec on kiirus enam vähem ok hetkel.
Samas ehk tõesti ainult minu juhtmes viga
182 |
purexpure
11.12.2007 15:21:30
Endal kah hetkel välkkiire
| Kommentaarid: 58 loe/lisa |
47 |
ufo56
67 |
M00t
11.12.2007 17:59:45
mul on ka kiire, ainult siis on aeglane kui muusika või video mängib, siis on väga aeglane... Vista
| Kommentaarid: 77 loe/lisa |
73 |
11.12.2007 18:00:48
| lu1de kirjutas: |
mul on ka kiire, ainult siis on aeglane kui muusika või video mängib, siis on väga aeglane... Vista  |
Mis muusika sul foorumis mängib?
Winamp, WMP 11 ei mõjuta küll foorumis ringisiblimist mul
81 |
HA
11.12.2007 18:02:01
sama siin, kah "ideaalselt kiire"
| carlking kirjutas: |
Winamp, WMP 11 ei mõjuta küll foorumis ringisiblimist mul |
ta mõtles ilmselt et kui netist vaatab/kuulab midagi
või siis on tal mingi puss arvuti/windoosa peetis
121 |
M00t
11.12.2007 18:07:05
ikka WMP või ükskõik mis programm kust muusikat tulla saab ja tuleb.
kui need kinni panna siis on ok.
ma kuskilt kunagi pool aastat tagasi lugesin kuskilt ka et multimeedia mõjutab vistal neti kiirust
ka kui youtube töötab, siis on muidugi ka aeglasem...
73 |
Mart352
11.12.2007 21:17:19
3 aadressi, mida kaua laeb. Leht iseenesest oli alla laetud ja midagi puudu polnud.
google-analytics, mediaindex.ee, bencastricum.nl
Google kadus kiiresti ära aga teistega läheb tunduvalt kauem
Ilmselt nad mingi statistika kogumiseks.
See bencastricum.nl on ufo56, allkirjast pärit MSN staatuse kuvamiseks vmt. See pilt ongi ainus, mis laetud polnud ja http://www.bencastricum.nl on hetkel maas ka.
Opera ei lähe enamasti uue postituse juurde enne kui kõik vajalik tehtud. Kunagi kuskilt lugesin, et esc-i vajutamine pidi aitama aga ei mõju ka see.
Hiirega kerisin õige posituse juurde ja kui lõpuks suvatseb valmis saada, viskab õige posituse juurde
_________________ Imperfection is perfect |
51 |
