Shelby-SV
Jõulud On Läbi!
25.11.2007 00:47:48
clicktoforyou.com probleem |
Tere,
tuttaval selline mure, et messenger jaotab poolele kontaktlistile seda aadressi. samas ta ise ei näe, et oleks mingeid teateid kellelegi saadetud.
on kellelgi kogemusi millega tegu ja kuidas lahti saada?
op.s vista
| Kommentaarid: 63 loe/lisa |
55 |
dexter666
25.11.2007 05:56:05
| sama probleem kummitab ennastki, pooled mu msni kontaktid saadavad mulle seda clickforyou.com pahna. Op nii Vista kui XP.
| Kommentaarid: 93 loe/lisa |
85 |
Lord Ami
| Kommentaarid: 57 loe/lisa |
52 |
monty11
27.11.2007 01:14:03
Kusjuures kõige omapärasem on see, et saatja ei tea saatmisest midagi.
_________________ Both the universe and stupidity are infinite. I'm not so sure about the former. - A. Einstein
Tule ja kiika minu fotomaailma. |
| Kommentaarid: 4 loe/lisa |
Laurikre
27.11.2007 01:27:29
Ms: http://www.microsoft.com/communities/newsgroups/en-us/default.aspx?dg=microsoft.public.msn.messenger&tid=4ffea43d-43c6-4eba-b9cf-1a1f196c40de&p=1
"i, I just wanted to put an update. It looks like the original http://www.clicktoforyou.com website has all of the sudden disappeared and now they have redirected the website to this site:
http://ad.jamster.com/landingpages/campaigns/int_o_flow/noselect_123/?adv_partner=0010&partner_var=477
BEWARE of future request of website that ask you to enter your account's user name and password. NEVER SHARE THAT INFORMATION!!!
I am positive the http://www.clicktoforyou.com website will reappear again with a different web address. For now it looks like they have obtained enough user names and password to do some damage. Good luck to all."
Ehk siis süsteem link saadab sind lehele kus pead sisestama oma msni kasutaja ja parooli.
Peale seda ta logib ise sisse ja saadab kõikidele sinu kontaktidele sinu kasutaja allt uusi huvitavaid lehti.
Laurikre:.
_________________ Need: Windows, .Net, Sharepoint, Exchange, Dynamics, Visual Studio, XNA, Expression, Silverlight, SQL and many other skills? Talk to me
Rohkem IT uudiseid iga päev BattleIT lehelt |
131 |
crypto
27.11.2007 01:32:55
samas seal lehel, terms of use:
We save your Passport username or password for further use of advertising from your MSN to your friendlist. You can change your password anytime to stop us sending messages these advertising messages.
_________________ 61. Logistikapataljoni võitleja |
| Kommentaarid: 42 loe/lisa |
37 |
paisutom
27.11.2007 16:42:23
lendasin sama probleemi otsa. kas parooli vahetusest piisab?
ceemic
24/7@kalal
27.11.2007 17:09:58
Täiesti haige, kui lollid võivad inimesed olla, kaasaarvatud mul elukaaslane, kes rõõmsalt seal lehel oma andmed sisestas
Saatsin ta ka siva parooli vahetama, ehk on abi
322 |
| Kommentaarid: 751 loe/lisa |
564 |
Shelby-SV
Jõulud On Läbi!
27.11.2007 18:03:44
vot, see ise sisse logimine seletab mu tuttava puhul nii mõndagi. ühel hetkel ta järsku kadus poole vestluse pealt ära, logis korraks uuesti sisse ja siis kohe veel korra. selle peale ta kurtis, et keegi oli tema useriga kuskilt mujalt sisse loginud. mõnda aega hiljem ütles ta, et kõik olid seda clickforyoud saanud. esialgu ei osanud ei mina ega tema seda sisselogimistega seostada.
ise uurides sattusin ma sama jutu peale mille Laurikre siia juba kopeeris.
aga küsimuse peale, kas sa sisestasid oma andmeid kuhugi vastas see tuttav tüdruk, et "muidugi mitte, ega ma nii blond ka pole..."
tuleb välja, et siiski on
55 |
Killer85
28.11.2007 12:47:56
| Mis sellel aadressil üldse oli? Mõned kontaktid jagavad ka seda linki, asi hakkab juba huvitama.
| Kommentaarid: 69 loe/lisa |
67 |
zzzzz
28.11.2007 12:58:15
| Killer85 kirjutas: |
| Mis sellel aadressil üldse oli? Mõned kontaktid jagavad ka seda linki, asi hakkab juba huvitama. |
Ooh noes, enam meie majas "blondiinid" seal andmeid sisestada ei saa.
Access to this web page is restricted at this time.
Internet access is only provided for business purposes. If you feel that a web site have been unnecessary blocked please contact your local help desk.
_________________ -puudub- |
| Kommentaarid: 20 loe/lisa |
19 |
Mart352
28.11.2007 13:10:22
Hetkel on selline teade
| Warning: mysql_connect(): Host 'root.blockdelete.com' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts' in /home/clickto/public_html/config.php on line 7 Host 'root.blockdelete.com' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts' |
Enne (laupäeval) oli Suurelt kiri Find out who's blocked you in MSN vmt, ei mäleta täpselt.
+ 2 lahtrit kuhu sai siis oma MSN-i aadressi ja salasõna loovutada
| Kommentaarid: 54 loe/lisa |
51 |
Ricard
| Kommentaarid: 6 loe/lisa |
