s4nder
09.11.2007 14:59:44
Acti lõpetamisel tuleb videoklipp ja "Act 1 Finished" kiri näiteks ekraanile suurelt. Ei tea, kuidas ta suutis maha magada selle.
Kommentaarid: 8 loe/lisa |
foxx_
09.11.2007 15:16:13
Ma kusagilt rebisin ka kaardi (ei mäleta enam kustkohast) ning sellel ära näidatud kenasti kuidas need ACT'id paiknevad.
Riputasin selle kaardi ka üles, kellelgi äkki hea vaadata: Siin
Kommentaarid: 5 loe/lisa |
Metsjeesus
09.11.2007 21:26:22
Guardian miskit head on? Eng betas ei muljetanud yleliia ja 14 SP evoker on nagu ta on.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
Kommentaarid: 108 loe/lisa |
94 |
Reimo005
10.11.2007 03:44:24
Lvl. 14 ja viskas kopa ette. Hakkas korduma liialt ja vabadust pole piisavalt. See ka nõme et kõik varustus on klassitsi piiratud, võiks mingi loogika olla mille järgi erinevat armorit piirata. Püksid võiksid minna ju kõigile jalga ja kiiver samamoodi pähe.
Kommentaarid: 12 loe/lisa |
12 |
Scart
11.11.2007 02:19:09
Sometime today, they also changed the cancellation policy and didn't tell anyone. When someone went to cancel thier subscription that was for a month that they opened over the weekend, there was a message now that if they cancel thier subscription that they lose all subscriber priveleges immediately. So that means if someone signs up for a subscription today for a month, and then tomorrow decides that the they dont' feel it's worth the subscription for the following month and cancels, they lose the month that they already paid for right away and FSS just keeps the money. Any threads opened that question this are promptly locked and deleted.
Kommentaarid: 119 loe/lisa |
101 |
Sakurai
11.11.2007 15:20:09
Scart kirjutas: |
Sometime today, they also changed the cancellation policy and didn't tell anyone. When someone went to cancel thier subscription that was for a month that they opened over the weekend, there was a message now that if they cancel thier subscription that they lose all subscriber priveleges immediately. So that means if someone signs up for a subscription today for a month, and then tomorrow decides that the they dont' feel it's worth the subscription for the following month and cancels, they lose the month that they already paid for right away and FSS just keeps the money. Any threads opened that question this are promptly locked and deleted. |
hahah
Kommentaarid: 33 loe/lisa |
Paganarh
11.11.2007 16:13:14
nuh, peab ütlema et pärast patche on Hellgate hoopis midagi muud. selline olekski pidanud retail versioon olema.
graafika korras (nüüd on isegi täitsa kena!), luksumisi pole (ainult jaamades aga see on poh), muusika justkui lülituks tihedamini sisse- pole enam niipalju seda nõmedat vaikust jnejne kümme erinevat pisiasja.
ajan aga oma lvl 21 marksmani edasi.
ainuke jama mis tekkis, on et pre-patch charil (sellsamal marksmanil) kadusid pärast patchi minigamed ära (see korja-loodi-tapa-midagi-siis-saad-järsku-nänni-mängud). uutel charidel mis tekitan, on olemas. mitte midagi väga hullu kuid jälle üks kamasaamise võimalus vähem...
Kommentaarid: 15 loe/lisa |
dsg
11.11.2007 16:46:22
kuda see mp seal on siis , kõik koos või nagu diablos?
Kommentaarid: 23 loe/lisa |
23 |
s4nder
11.11.2007 21:05:24
Nagu Guild Warsis - jaamades on rohkem rahvast koos, jaamadest väljas võideldakse väiksemate gruppidena.
.asd
11.11.2007 22:39:48
Kas engineeril saavad korraga drone, rocket bot ja bomber bot väljas olla?
Kas marksmanil on parem pvm'iks rapid firel või critical chancel & stancedel põhinev build? Ning sniper stancesse üle ühe punkti pole mõtet panna?
Kumb on summoneril parem tank - carnagor või warper?
Mis buildiga evoker oleks parim pvm?
Ei teagi kellega alustada, kui kord mängu saan. Huvi pakuvad cabalistid ja hunterid, kuigi templarid tunduvad ka asjalikud.
Kommentaarid: 1 loe/lisa |
Metsjeesus
11.11.2007 23:12:20
Ma toksin nüüd SPs Guardianiga ja päris pro on. Elusid hunnik, defence hunnik, tapab mühinal jne.
Evokeri puhul jääb sul punne piisavalt ikka, et omada eri skille.
94 |
Paganarh
11.11.2007 23:55:39
.asd kirjutas: |
Kas marksmanil on parem pvm'iks rapid firel või critical chancel & stancedel põhinev build? Ning sniper stancesse üle ühe punkti pole mõtet panna? |
crit build parem imho. täitsa kahju nendest kolmest punktist mis rapid fire alla olen pannud
snaiprisse 1 punn piisab. puhtalt sniperdada saab kahjuks suht vähe ja sniper stances paigal kaua ei istu, penaltid. samas pärast patchi enam snaiper nii hullult ei agro, niiet seda saab jälle kasutada. head relva lihtsalt raske leida.
tactical stance, beacon ja ricochetid + võimalikult palju kuule per min pritsiv relv (tavaliselt siis mingi bulletbased) ja crit aktiveerubki pidevalt.
tulemus on carnage väga hea meel et marksmani valisin, mõnus char
granaati ja napalm strike julgen ka mitte soovitada. alguses sai neid kasutatud aga nüüd (lvl 23) pole enam mõtet- dam ei jõua järgi
Auron
12.11.2007 12:03:07
Ise kahh marksman, sain ommiku pelades oma esimese unique rifle'i Üldiselt jahh, suvalised madinad eriti rasked ei ole ja seal nö. on see snaipimine rohkem fun, raskemates oludes (a'la miski eriti kapp boss ja ilge hunnik muid loomi) aga snaipaga suurt miskit ei tee. Iseenesest mulle meeldib grenade launcher - saab kaugele lasta, on splash efektiga area dämm ja samas veel raisad põlevad ning saavad lisadämmi. Aeg ajalt kipuvad olema vastased kes millelegi on immune või praktiliselt immune siis on vähemalt paari erinevat relva vaja. Lambihetkel ongi näpus 5 slotiga elektripüss mis sigakiirelt laseb ja grenade launcher.
Kommentaarid: 152 loe/lisa |
129 |
Paganarh
12.11.2007 12:51:06
korralik granaadiheitja või rokkit launcher on must have. vahest lihtsat on vaja mingil portsul vastastel jalgealuse kuumaks ajada. enal ongi enamvähem tüüp-layout: F1 - rifle; F2 - grenade/rocket launcher; F3 - sniper
relv igaks elujuhtumiks
Metsjeesus
12.11.2007 13:29:15
SPs saab ka normalit läbi teha? Miskit bossi ka seal on või need legendary vm elukad aeg-ajalt ongi siis "need" ? Eks ma käin techsmiti peas ära ja siis kommenteerin, kuidas oli noid maha lüüa Guardianiga, seni on see char küll suht ulme olnud Oma esimene saast uniik mõõk ka saadud.
94 |
Paganarh
12.11.2007 16:28:26
bossud on nagu bossud peavad olema. legendaryd on ikka tavalised minioonid. ühe bossu just lõpetasin london toweris. ei spoili
täpsusta seda guardiani "ulme" kommentaari- liiga tegija või nõrk?
.asd
12.11.2007 18:18:24
Küsimus mängijatele: Kust te mängu ostsite?
Metsjeesus
12.11.2007 19:13:53
Paganarh, korralik tegija ütleks mina. Otseselt ulmeline pole, aga tugev on ta küll, olen lvl 14 ja kohad, mis olid Evokeriga rasked on Guardianiga nagu koll ikka. Nimelt saab hästi kombotada, evoker sakkis selles osas. Ootan siis ka oma esimese bossu ära, siiamaani ongi need kuldse nimega "lordid" aint. Tahaks, et head nänni ka kukuks juba.
Peale Legendary tuleb mis aste ? Tean, et Uniq on 5 tärni, aga huvitabki, et mis on 4 ja kas on ka 6seid.
94 |
Scart
12.11.2007 20:53:00
.asd kirjutas: |
Küsimus mängijatele: Kust te mängu ostsite? |
EA Downloader ning enne seda külastus @ EA Store.
After its unsteady launch throughout western territories, Flagship's Hellgate: London now appears to cause problems for Asian gamers as well. The so-called Patch0, used to address various issues in Asian Hellgate, requires a complete character wipe. For that reason, they'll be offering a months worth of free subscription time.
101 |
s4nder
12.11.2007 22:45:55
Metsjeesus kirjutas: |
Peale Legendary tuleb mis aste ? Tean, et Uniq on 5 tärni, aga huvitabki, et mis on 4 ja kas on ka 6seid. |
Unique peakski praegu parim olema.
Ma olen oma summoneriga lvl 26 praegu, act 5 keskel kuskil. Üsna tugev, umbes sõbra engineeriga võrdne. Warper+force (ja ka muud) elementalid on build ja warper laseb isegi kuldse kirjaga vastaseid ühe lasuga.
Auron
13.11.2007 11:49:01
6'seid ei usu kuna unique on nö. über, 4 tärniga on vist epic. Samas on unique asjad olnud suht pettumus - on ikka liialt nõrgad arvestades kui haruldased nad on.
129 |
Paganarh
13.11.2007 13:22:14
luudiga on üldse nii et suht raskelt tuleb kätte. peab ikka päris lucky olema et leida häid relvi. armor on enamvähem.
nii ongi et vahest tuleb ette võtta "shoppingspree"- teed stationist exit, läed mängu tagasi, vaatad sepistaja ning kaupmehe üle ja kui midagi pole siis exit ja repeat
eile "jahtisin" endale sedamoodi ca poole tunniga korraliku snaipri + modid. nüri, kuid vahest ei jää midagi üle kui ainult legendaarne hernepüss käes on.
a nüüd korralik +16% dam ja 7 modslotti (ning nendest tulenevad boonused). enamus kolle on ühepaugumehed
Metsjeesus
13.11.2007 15:01:29
Ei saa aru, aint et mis see relval kohe näidatav muutuja on. Dami ta lööb vist ikka seda, mis descriptioni alt leiab...
94 |
Paganarh
13.11.2007 15:35:53
see number on lihtsalt relva reiting võimidagi- et mida kõrgem nummer seda ägedam nagu on. paljud ajavad seda segi mingi damminumbriga mida see tegelikult pole. reaalse dammi saab jah, alles siis kui descriptionit vaatad
codemaster
13.11.2007 15:44:13
kuskilt tutvustusest lugesin/kuulsin, et see number aitab mängijal kiirelt otsusta kumb relv parem on seega jah nagu mingi reiting või nii.
Kommentaarid: 2 loe/lisa |
