uus teema   vasta Tarkvara »  Turvalisus »  Tulemüüri install ja seadistamine märgi kõik teemad loetuks
sakunne
sakunne
sõnum 27.10.2007 18:44:46 Tulemüüri install ja seadistamine vasta tsitaadiga
Paneks siia teemasse igasugu nõuanded nendele, kelle jaoks Windooza tulemüürist väheks kipub jääma - seega potentsiaalselt kõigile icon_wink.gif
Niisiis, toote koju uue arvuti, pakite lahti, panete juhtmed/kablad/karvad külge ja ... STOPP
Samm #1: Esmasel sisselülitamisel hoolitse, et arvutil puuduks igasugune pääs mistahes võrku
Samm #2: Installeeri TULEMÜÜR - Comodo, Zone Alarn, SygatePF(minu varasem lemmik, a'läksin Comodo'le üle)
Samm #3: otsi tulemüüri seadistustes koht, kust saad keelata igasugu võrguliikluse kuni TM'i ülesjooksmiseni
Samm #4: tekita "Packet Filtering Rules" ehk "Advanced Rules":
1. "Generic Host Process for Win32 services trying to act as a server.....application. svchost.exe"
to block communications with the Internet on these ports (both TCP and UDP, both incoming and outgoing): 135, 137, 138, 139, 445, 5000.
Allow for now svchost.exe to "act as a server" and ask ZA to remember your option.
http://www.annoyances.org/exec/forum/winxp/t1116095044
2. svchost.exe lubatud pordid 53,67,68,80,443
Application: C:\Windows\system32\svchost.exe
Parent: C:\Windows\system32\services.exe
Protocol: UDP/TCP
Direction: In/out
Source Ports: 53,67,68,80,443
http://forums.comodo.com/help/sychostexe-t11762.0.html
Kui keegi tahab internetti
1. Fail "tcsd_win32.exe" healane v pahalane
Description: File tcsd_win32.exe is located in a subfolder of "C:\Program Files". The file size on Windows XP is 180224 bytes.
The program has no file description. The program is not visible. tcsd_win32.exe is not a Windows system file. The application uses ports to connect to LAN or Internet. You can uninstall this program in the control panel. Therefore the technical security rating is 59% dangerous.
Important: Some malware camouflage themselves as tcsd_win32.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the tcsd_win32.exe process on your pc whether it is pest. We recommend Security Task Manager for verifying your computer's security. It is one of the Top Download Picks of 2005 of The Washington Post and PC World.
http://www.file.net/process/tcsd_win32.exe.html
Kuna ei pruugi õigel ajal foorumisse sattuda:
SMS: 5051598 [võõraid tel. ei vasta]
Email sakunne@seenior.ee
viimati muutis sakunne 27.10.2007 19:01:35, muudetud 5 korda
Kommentaarid: 77 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 69
Dijital
Dijital
sõnum 27.10.2007 18:55:41 vasta tsitaadiga
ot:
voh, loodan asjalikku teemat sellest. omalgi asjad pole päris selged, et mis netti lubada ja mis mitte. just winni serviiside koha pealt. kui puhtale ilma igasugu programmideta vinnile kaabli sappa lükkad, siis on seal kohe tuhat serviisi, mis netti küsivad. ehk siia tulevadki näpunäited mis peab netti saama ja kuhu porti ning mis pole oluline.
HacaX
HacaX
sõnum 28.10.2007 13:10:03 vasta tsitaadiga
Üks Outposti konfiõpetusest silmahakanud nõuanne: Winni DNS client kinni keerata. Sel teel jääb tulemüüri märk igast programmist mis aadressile vastavat IPd küsib (vist oli see ka ainus võimalus kuidas DNSikaudu lekkimist ära hoida).
Et võrk üldse toimiks tuleks seetõttu teha uus reegel, mis lubaks pöördumist UDP ja TCP porti 53. Kõige parem kui oleks kui reeglis oleks ka siht-IP paika pandud, täpsemalt siis ametliku DNS serveri oma (NATi taga olijatel vastavalt NATiva seadme IP, kes otse netijuhtme taga istuvad neil ISPi käest saadavad DNSiserverid), nii jääb ära DNSiärandamise võimalus. Ning edaspidi iga programmi puhul mis tohib võrku kasutada antud reegel aktiveerida.
IMO & GPLed
Muhkel
Muhkel
sõnum 10.11.2007 12:24:32 Re: Tulemüüri install ja seadistamine vasta tsitaadiga
sakunne kirjutas:
Paneks siia teemasse igasugu nõuanded nendele, kelle jaoks Windooza tulemüürist väheks kipub jääma - seega potentsiaalselt kõigile icon_wink.gif ...
Mulle küll XP SP1 tulemüürist väheks ei jää! Kui ise mingit solki ei käivita, töötab samakindlalt kui mistahes teine "korralik" tulemüür. Pordid lahti, masin 24/7 sees juba aastaid. Ükski onlinescanner ei näita ühtki lahtist porti.
Ja kõige parem on asja juures see, et ta ei küsi ühegi programmi jaoks luba! Enamus tavakasutajatest tambib ju iga ettehüppava tulemüüri akna peale pikalt mõtlemata yes! Kui installid mingi suurema ja keerulisema softijupi, mis esimese käivituse järel sult 10 korda mingite täiesti mittemidagiütlevate failinimede kohta küsib, siis tahaks näha tavakasutajat, kes enne yes! vajutamist uuriks täpselt järgi, mis fail ja kus kaustas asub ning mida teeb. Ikka klõps ja rahu majas. Küll näinud neid kasutajaid, kes täiesti järjekindlalt pressivad seni yes-nuppu, kuni programm käima läheb, teadmata isegi, mida küsitakse!
Kunagi proovisin isegi paari "klassikalist" tulemüüri, ei viitsind minagi neid exe-sid taga hakata ajama. Ja kus on siis garantii, et sul ühtegi pahavaralast internetti pole lubatud?
Pika ja lolli jutu lõpetuseks lisan, et SP1-e tulemüür piirab vaid sissetulevat liiklust. Väljaminev liiklus on "tihendi" enda otsustada/klõpsutada - mida käivitad, seda ka saad icon_razz1.gif
Kurda kõigile oma rasket saatust... ning sa näed enda ümber ainult rõõmsaid inimesi.
ints0000
sõnum 13.11.2007 00:30:02 vasta tsitaadiga
Ehk keegi oskab ka öelda, mida Comodo firewall pro-s muuta, et ta elioni digiTV pildi läbi laseks VLC playeri jaoks?
Praegu saan seda vaadata ainult nii, et firewalli komponent: Network Monitor on väljalülitatud asendis.
sakunne
sakunne
sõnum 14.11.2007 10:05:42 vasta tsitaadiga
ints0000 kirjutas:
Ehk keegi oskab ka öelda, mida Comodo firewall pro-s muuta, et ta elioni digiTV pildi läbi laseks VLC playeri jaoks? Praegu saan seda vaadata ainult nii, et firewalli komponent: Network Monitor on väljalülitatud asendis.
Vaata, mis sul 'Network Monitoris' blökitud on? Lisa 'Application Monitori' VLC Player - muud esialgu ei oska soovitada icon_sad.gif
Muhkel kirjutas:
... Mulle küll XP SP1 tulemüürist väheks ei jää! Kui ise mingit solki ei käivita, töötab samakindlalt kui mistahes teine "korralik" tulemüür ...
Tulemüür piirab ainult sissetulevat liiklust ja seda XP FW teebki, nn. 'korralikele' on lisatud veel igasugu vidinaid ja reeglite kirjutamise võimalus, vt eespool.
Muhkel kirjutas:
... Pordid lahti, masin 24/7 sees juba aastaid. Ükski onlinescanner ei näita ühtki lahtist porti ...
Muhkel kirjutas:
... Ja kõige parem on asja juures see, et ta ei küsi ühegi programmi jaoks luba! ...
Luba küsitakse kahel juhul:
1. Kui vaja käivitada mõni protsess - nt. 'Component Monitor' Comodo's
2. Kui mõni rakendus tahab intrnetti minna. nt. 'Application Monitor' samas
Esimesel juhul, jah, ehk pole vaja tavakasutajal teada mis täpselt toimub, küll aga peaks isegi puruloll kasutaja omama ülevaadet, millised rakendused tema arvutis internetti pääseda püüavad.
Näide: mingi saatanlik vägi meelitas mind alla laadima 'QuickTimeInstaller.exe' - ja pange tähele ainult alla laadima, mitte käivitama - ja voila, äkki vaatan: mingi 'Bonjour' on minu arvutisse pesa teinud ning tahab internetti ühenduda icon_evil.gif
Niisiis teeme mõisted selgeks:
1. Tulemüür - Firewall (Comodo's 'Network Control') - piirab ainult sissetulevat liiklust, milleks tal on omad nn 'packet filtering rules', te ei küsi midagi ja teda ei huvita, mis arvutis toimub ega arvutist väljaminev liiklus, näited: XP FireWall, GhostWall/ http://www.ghostsecurity.com/ghostwall/
2. Rakenduste kontroll (Comodo's 'Application Control') - kontrollib seda, milliste rakendustel lubatakse internetis suhelda
3. Protsessi kontroll (Comodo's 'Process Control') - kontroll igasugu protsesside ja harude algatamise üle
4. Registri kontroll (Spybot S&D' 'Tea Timer') - redistrimuudatuste lubamine/keelamine
Need neli asja annavad kasutajale täieliku kontrolli arvutis toimuva üle ja kui kaks viimast on ehk tõesti tavaksutajale veidi keerulised, siis kaks esimest on küll nn MUST HAVE ja mittekasutaja süüdistagu iseennast icon_evil.gif
ints0000
sõnum 14.11.2007 11:09:24 vasta tsitaadiga
Seal ei ole ühtegi asja plokitud. Selles nimekirjas on ainult 6 lubatud asja(IP out, IP in, TCP/UDP IN/OUT, ICMP OUT, ICMP IN, ICMP IN, IP OUT).
Ja otseselt programmi seal lubada/keelata ei saa. Saab teha uue reegli: Allow/block ja siis veel nõuab parameetreid: protocol, direction, source ip, destination ip, source port, destination port. Proovisin sinna midagi tekitada, kuid ei hakanud tööle, panin igale poole seal, et kõike lubab icon_confused.gif
ThedEviL
ThedEviL
sõnum 14.11.2007 11:14:34 vasta tsitaadiga
Kõige parem tulemüür: (kahujks töötab esialgu ainult kaabliga ühenduse puhul)
Tellid internetist polüetüleenoksiidi ning segad 10g 1l bensiiniga.
Määrid saadud tatiga võrgukaabli kokku. Kui tundub et pätid ründavad, süütad võrgukaabli. See desinfitseerib kõik ära ja pätid enam ei kiusa.
Alternatiivselt on wifi tulemüür natukene aeglasema toimega, sest tavaliselt ei saada tikuga ruuterile pihta, kuna ei viitsita tagumenti toolilt leviteerida. Siinkohal jõuavad pätid su pornokogu läbi sirvida, enne kui desinfitseerimine toimub
AJ
AJ
sõnum 14.11.2007 11:41:39 vasta tsitaadiga
ThedEviL kirjutas:
ThedEviL
ThedEviL
sõnum 14.11.2007 11:48:28 vasta tsitaadiga
juhe võib olla pistikkusse kinni jäänud ning sa ei saa õigel ajal juhet kätte. Lisaks võib pätt kaabli sisse jääda ning kui sa selle seina tagasi pistad, lipsab pätt su arvutisse ja saadab su kallima alasti pildid netti ülesse.
sakunne
sakunne
sõnum 14.11.2007 11:58:45 vasta tsitaadiga
ints0000 kirjutas:
...Ja otseselt programmi seal lubada/keelata ei saa. ...
Loe uuesti:
Sakunne kirjutas:
Comodo -> 'Security' tab -> Application Monitor -> +Add -->Application/ParentApplication - Browse
ints0000
sõnum 14.11.2007 12:09:07 vasta tsitaadiga
sakunne
sakunne
sõnum 14.11.2007 15:32:31 vasta tsitaadiga
Uuri järele, mis porti eliontv tahab ja tee see lahti.
Väga õpetlik: Comodol on esimene 'Network Control Rule'(NCR) TCP/UDP - OUT - kõik pordid lahti, seda suunda kontrollib 'Application Control', IN aga vaikimisi kõik pordid kinni - lahtitegemiseks kirjuta uus NCR, ära ainult kõiki porte lahti tee icon_wink.gif
Kui miski ei aita, küsi comodo support foorumist.
ints0000
sõnum 14.11.2007 21:27:59 vasta tsitaadiga
Kirjutasin uue reegli, kus kõik pordid on lahti, kuid ikka kui network monitor on "on" asendis, siis pilti ei näita icon_confused.gif
sõnum 14.11.2007 21:37:41 vasta tsitaadiga
Kuhu sa selle uue Network Monitor-i reegli paigutasid? Monitor loeb reegleid ülalt alla ja kui sinu kirjutatud reeglist kõrgemal on mõni muu reegel, mis sinu oma kasutuks muudab, siis see sinu reegel ongi kasutu.
Näiteks saab seal olemasolevaid reegelid väga lihtsalt välja lülitada neid lihtsalt vaikimisi kõige alumisest, nn "Block & Log" reeglist allapoole nihutades.
sakunne kirjutatud kirjeldus Comodost on muidu väga hea ja ülevaatlik, paraku jäi seal silma kriipima üks väike viga:
sakunne kirjutas:
Nimelt "huvitab" Comodo Network Monitor-i vägagi ka väljaminev liiklus, aga paraku on vaikimisi kõige ülemiseks reegliks seal
ALLOW TCP or UDP OUT FROM IP [Any] TO IP [Any] WHERE SOURCE PORT IS [Any] AND DESTINATION PORT IS [Any]
(see võib konfimise käigus olla ka allapoole nihkunud, nt. "surub" seda allapoole Trusted Zone tsoonide lisamine)
ja see reegel lubab masinast välja kogu selle soga, mida programmid välja pritsivad ilma igasuguse piiranguta. Ainsaks piirajaks on sel juhul Application Monitor-is igale "pritsile" (so programmile) kehtestatud reeglid.
Kui see "allow all out" reegel välja lülitada (nihutada allapoole "Block & Log" reeglit), siis pääseb välja vaid liiklus, mida lubavad ülejäänud "Out" reeglid. Kui selliseid reegelid ei ole, siis midagi välja ei pääsegi, k-a DNS ja DHCP päringud - iga tüüpi liiklusele võib siis luua vastavad oma reeglid.
viimati muutis Dogbert 14.11.2007 21:58:11, muudetud 2 korda
ints0000
sõnum 14.11.2007 21:43:07 vasta tsitaadiga
Ei aita ka see, et uus reegel esimeseks panna. Tegin sellise reegli:allow TCP/UDP IN/OUT, source ANY, destination ANY.
sõnum 14.11.2007 21:57:33 vasta tsitaadiga
ints0000 kirjutas:
ja pordid on ka ANY?
Sel juhul blokeerib miski muu. Sa näed ju toimuvat Activity aknas. Connections all on olemasolevad ühendused ja Logs aknas hoiatused ja alarmid - näiteks kui midagi tõesti blokeeritakse, siis peaks see seal näha olema.
Muhkel
Muhkel
sõnum 14.11.2007 21:59:21 vasta tsitaadiga
sakunne kirjutas:
Muhkel kirjutas:
Ühendusel pordid avatud, arvutil portskänneriga kontrollides pordid Stealth Mode's, ehk siis väljast vaadatuna suletud.
Ju sa said ikkagi aru...
sõnum 14.11.2007 22:04:36 vasta tsitaadiga
Muhkel kirjutas:
sakunne kirjutas:
Muhkel kirjutas:
NATtiva ruuteri taga on see ju normaalne nähtus.
ints0000
sõnum 14.11.2007 22:14:17 vasta tsitaadiga
Pordid kaa. Nüüd proovisin, kui VLC töötab ja siis network monitor sisse lülitada, pilt hangub ja sinna log tabelisse tuleb punane hoiatus:
"DDOS Attack (UDP Flood)....The Firewall has swiched to EMERGENCY mode"
Hoiatajaks ikka network monitor.
sõnum 14.11.2007 22:33:52 vasta tsitaadiga
Ma kahtlustasin juba enne, et Comodo peab VLC suurt UDP pakettide voogu DDOS rünnakuks. Sellepärast logi vaadata soovitasin.
Nüüd ava Security -> Advanced -> Advanced Attack Detection and Prevention [Configure] -> Intrusion Detection
Suurenda "UDP Flood" all "Traffic Rate" kastis olevat arvu. Ma ei tea kui palju, aga pane seal olevale "100"-le üks null otsa ja proovi siis.
Muide, seda kõigilt kõigile lubavat reeglit ma ei soovita sellisel kujul säilitada - see muudab ülejäänud reeglid mõttetuks. Muuda protokoll UDP-ks, liikluse suund "IN"-iks, pane source kohale allika IP aadress ja source port-iks port, millelt allikas VLC striimi välja pritsib. Aga seda tee alles siis, kui sellest DDOS-i blokist lahti oled saanud.
ints0000
sõnum 14.11.2007 22:51:27 vasta tsitaadiga
Panin selle 2000(rohkem ei lasknud) ei aidanud, ikka pilt hangub, kuid LOG-i ta ei viska seda punast hoiatust icon_sad.gif
connectioni alt kaob VLC kohe ära kui network monitor ON panna
sõnum 14.11.2007 23:11:59 vasta tsitaadiga
Siis pane sealt "UDP Flood" alt "Duration" lühemaks, "1" on väikseim võimalik number.
Lisaks võib sama dialoogiakna teiselt sakilt "Miscellaneous" võtta "linnukesed" maha kõigilt ridadelt peale esimese (esimene võiks olla).
Muhkel
Muhkel
sõnum 14.11.2007 23:15:56 vasta tsitaadiga
Dogbert kirjutas:
Muhkel kirjutas:
sakunne kirjutas:
Muhkel kirjutas:
Mul pole ju ruuterit, masinal on välisvõrgu IP.
ints0000
sõnum 14.11.2007 23:19:00 vasta tsitaadiga
duration 1 ja ka sealt teisest menüüst sai linnukesed ära, ikka ei tööta. Ühtegi hoiatust ei viska, kuid VLC ühendus kaob kohe minema sealt log alt kui network monitor sisse lülitada.
sõnum 14.11.2007 23:42:58 vasta tsitaadiga
Muhkel kirjutas:
Ah, ma ei lugenud su esimest posti, vabandust! XP tulemüür blokib sissetulevaid ühendusi täiesti edukalt. Selle vastu ei vaidle keegi.
Probleemid tekivad täpsemate reeglite kehtestamisel ja/või juba masinasse siginenud pahalastelt väljuva traffic-u peatamisega (pahalased oskavad kenasti endale ise XP tulemüüri augu teha, nagu iga asjalik programm või kasutaja seda teha oskab).
ints0000, võimalik, et leidsid Comodost uue probleemi või puuduse - ma pole ise veel Comodoga masinas VLC-ga mingit videostriimi vaadata üritanud, nii et pole sellega kokku puutunud.
Tõenäoliselt oleks põhjust Comodo kasutajatoe poole või foorumisse pöörduda. Esmapilgul seal VLC kohta teemasid ei kohanud, aga kolmetäheline otsing pole kuigi usaldusväärne, kuigi see seal isegi töötab.
VLC foorumis esimese otsinguga jälle comodot ei leidnud... ei oskagi rohkem muud soovitada, et kui Comodo ei sobi, siis ürita mõne muu tulemüüriga.
Võibolla leian homme tööl mahti VLC-ga striimi vastuvõtmist Comodoga masinas ise katsetada, aga see on kahtlasevõitu.
sakunne
sakunne
sõnum 14.11.2007 23:48:10 vasta tsitaadiga
Dogbert kirjutas:
...sakunne kirjutatud kirjeldus Comodost on muidu väga hea ja ülevaatlik, paraku jäi seal silma kriipima üks väike viga:
sakunne kirjutas:
njah, märkasin ise ka seda, a'ei jõudnud parandada - Dogbert sai enne jaole icon_biggrin.gif
Tegel't on Comodo'ga vist siuke lugu, et vaikimisi on kogu väljaminev liiklus antud 'Application Managerile' manaagerdada.
Kui AM nüüd välja lülitada ja see esimene reegel ära kustutada ja igale väljujale oma reegel kirjutada saaks enamvähem klassikalise tulemüüri.
Tundub, et GhostWall on miskit sellist pole veel jõudnud proovida, kuna Comodo on masinas, küll aga proovisin sama firma 'AppDefener' ja 'RegDefender' varsti hakkan tütre läpakat tegema ja panen sinna GhostWalli peale - siis saan täpsemalt rääkida.
ints0000
sõnum 19.11.2007 17:28:20 vasta tsitaadiga
vahetasin comodo zone alarmi vastu ja nüüd näen ka VLC -ga digitv-d.
sakunne
sakunne
sõnum 01.12.2007 02:03:42 vasta tsitaadiga
ints0000 kirjutas:
ints0000
sõnum 03.12.2007 14:10:05 vasta tsitaadiga
comodo ei lase digitv-d läbi- see on viga. kõik sai ju max seadistatud, kuid kui network monitor töötab pilti ei näita ikka.
urmas97
sõnum 04.12.2007 00:50:08 vasta tsitaadiga
ints0000 kirjutas:
Tahtsin isegi Comodo tulemüüri all Digi-Tv-d vaadata, aga mitte miski ei toiminud. Näppisin mitu õhtut igasuguseid seadeid, lugesin palju teemasid Comodo foorumist, kuid mitte miski ei aita. Mulle tundub, et tegemist tulemüüri tarkvara veaga. Kui keegi kunagi tööle saab, siis võiks teada anda!
sõnum 04.12.2007 01:43:46 vasta tsitaadiga
urmas97 kirjutas:
Oli see Comodo v2.x või uus v3?
Tsitrus
sõnum 04.12.2007 01:54:00 vasta tsitaadiga
Igatahes Comodo v3 lahendas selle VLC probleemi. Vähemalt minul. icon_smile.gif
America is the only country that went from barbarism to decadence without civilization in between.
sõnum 04.12.2007 09:11:54 vasta tsitaadiga
Tsitrus kirjutas:
v2.x testisin päev-paar enne v3 ilmumist (mitte küll digiTV-ga, vaid lihtsalt VLC video striimimist ühest masinast teise) ja sellel oli tõepoolest mingi kala, võin seda kinnitada.
sakunne
sakunne
sõnum 04.12.2007 13:58:57 vasta tsitaadiga
Dogbert kirjutas:
Tsitrus kirjutas:
Anna sellest kalast Comodo meestele teada - parandavad ära äkki - hea FW muidu ju, parem, kui ZA igaljuhul icon_neutral.gif
ints0000
sõnum 04.12.2007 15:24:51 vasta tsitaadiga
Kui uuemas versioonis viga parandatud, siis on ju hästi icon_smile.gif . Proovin kaa siis v3-e
sõnum 06.12.2007 14:54:50 vasta tsitaadiga
sakunne kirjutas:
Anna sellest kalast Comodo meestele teada...
Killerwave
Killerwave
sõnum 07.12.2007 14:53:24 vasta tsitaadiga
Kas on võimalik kuidagi WINxpSP2 tulemüüris icon_razz.gif kah porte kinni panna, probleem just SMPT mail server pordiga?
sõnum 07.12.2007 21:26:40 vasta tsitaadiga
Killerwave kirjutas:
Mis probleem? Mis mõttes "kinni panna"? Väga umbmääraselt formuleeritud küsimus. Kui vastata sama umbmääraselt, siis on vastus "jah".
Kui vastata pikemalt, siis:
Vaikimisi ongi SMTP port kinni. Kui keski/miski* pole seda seestpoolt avanud, siis ta ongi kinni. Paraku oskab iga enesest lugupidav programm, sh ka viirus XP tulemüüri auke teha.
___________________________
*keski/miski - sihilik õigekirjaviga icon_wink.gif
Killerwave
Killerwave
sõnum 08.12.2007 13:58:44 vasta tsitaadiga
Sa said tõenäoliselt aru küll mille probleem oli aga see selleks.
Kinni ta ongi aga online scanner väitis et pahalastele nähtav. Seega ära peita vb.
Lihtsalt kas ma peaks tegema selles suhtes või võtma asja rahulikult ning jätma selle pordi nii nagu ta on?
Muhkel
Muhkel
sõnum 08.12.2007 15:12:17 vasta tsitaadiga
Minuarust näitavad erinevad online portskännerid erinevat tulemust. Mõni ütleb, et on kõik stealth, kuigi osa porte lahti, mõni teine aga näitab avatud pordid ära...
Siiani pole sissetungiprobleeme siiski olnud.
ints0000
sõnum 09.12.2007 20:42:28 vasta tsitaadiga
Nüüd siis jälle comodo peal tagasi. V3 laseb digitv läbi ja esialgu mingeid probleeme ei märganud icon_biggrin.gif
