mcaff
10.10.2007 15:08:27
Selge tänud
Kommentaarid: 130 loe/lisa |
104 |
minake
10.10.2007 16:20:59
m6tlesin, et viskan siia osadele yhe kommentaari netist mis crysise kohta on tehtud 2kki osad kodanikud saavad siit endale vajalikku infi oma masina vastavuse kohta:
tsitaat: |
Ive played the betas for a while and Ive tested some of the hardware that I have on hand, and without a proper time demo heres the basic results..
X2 3800 at 2.6 with 2gb ddr500 and Core 2 e6300 at 3.0 with 3gb ddr2 800 both with XP
1920x1200 high detail - HD2900PRO 512 or 8800GTS 640 were very playable, the 8800 felt smoother but the 8800 was not able to play at any higher AA settings than the HD2900. Both cards had lows in the 20-25 range and highs in the 50s, most often FRAPS reported numbers in the 30-45 range, it was very playable. Neither card was able to really go beyond 2x AA without seeing dips into lag. The 8800GTS 320 was playable at these settings, but seemed to become limited by the 320mb of ram very quickly.
The HD2900XT 512 vs 8800GTX was much the same situation but the GTX seemed faster, I dont have a 1gb XT to see the impact of the graphics memory on this game, but if the numbers between the GTS 320 and GTS 640 are any indication, this game is a beast when it comes to sucking down graphics memory. 1gb XT/PRO will likely be nice choices because of this limitation and their price range. The XT 512 was playable with 4x AA, but numbers were lower than the GTX at the same setting. Neither card was what I would call playable at 8x AA.
1600x1200 medium/high detail - Much the same case with the above but certainly a bit smoother. A better match for the GTS 320 but I would still recommend a combination of medium/high setings. SLI or Crossfire 7900 series or x1900 series would probably just as playable as the GTS 320. Overclocking the GTS 320 from 520/1600 to 620/1950 improved the smoothness of the game play, but did not bring it up to the numbers the 640 had been dealing.
1280x1024 medium/high detail - 7900GT and 7900GTX tested, didnt have an x1900 series on hand to test. Both were playable, more so with the core 2 than the X2 though. The difference between the two cards was not drastic and the GT was more so at home at medium with a few settings on low (ie shader detail), and the GTX was certainly more playable. Based on the typical numbers with the 7900 vs x1900 series I would certainly say the x1900 series is going to perform better, but as I said, I dont have one on hand to test. The 512mb cards seem to be the ones to have so for those with the 512mb versions of the GT would seem to be better off. AA was not friendly to the 7900 series and really had an impact on performance.
I dont have any midrange series (HD2600/x1600 or 7600/8500/8600) so I cant have any numbers for those but based on the high end I would say 1024x768 or 1280x1024 would be playable on the upper midrange series, perhaps even with higher detail than the older 7 series. It is kinda hard to compare the older high end to the newer midrange based on the numbers I tested because though the newer architectures are much more adapt to this type of game, they are quite limited compared to the 8800 and hd2900 series so its something I'd rather not speculate on.
The core 2 system was faster than the x2 system (no surprise?) but the video card is still gunna be the bottom line at higher resolutions and details. Dont have any quads to test just yet..or single cores..but 2gb of ram would be my suggestion for XP and 3gb for vista.
The weakest configuration I could put together was somewhat playable. It used a 2.2 newcastle 754 Athlon64, 768mb of DDR400, and a 9600xt. 800x600 on low with texture detail at medium, or 1024x768 with all lows was playable but often dipped into the low teens, average fraps numbers were low 20s. Any gamer would not call this playable at all, but for those of you who think these new fangled parts out today are too expensive, you could probably play the game.
The HD2900 series and 8800 series all scored "medium" detail settings by default by clicking the "optimal settings" button at 1920x1200. "optimal settings" button also defaulted to flat medium on 1600x1200. But I wouldnt say thats the best indication as even 1024x768 optimal settings were medium. It would seem the highest detail settings are reserved for SLI/Crossfire set ups.
But given the beta only contains 1 level to test I wouldnt say these recommendations are set in stone, larger levels contain more detail, but on this level (Power Struggle) in a full 32 man server, they stand pretty well. A slower server with player numbers in the teens or low 20s are not an issue, but a 32 man server with so many vehicles, explosions, and level details its a matter of fine tuning your specific systems and perhaps overclocking your cards. 256mb cards beware, even higher end cards (like the 256mb x1900xt). 512mb+ cards are recommended but remember a highend card with less memory will still be faster than a midrange card with a lot of memory.
I would definitely recommend 8800 or HD2900 series for serious gamers, but people who are more interested in the single player aspect than the multiplayer will probably get by just fine with x1900 series or even 7900 series.
2gb of ram is a must, and I would probably suggest 3gb for vista as well, but I never actually did compare XP 2gb vs XP 3gb now that I think of it.. 1GB is playable but not as smooth, 768 mb on the low end machine I tested was slower than the same machine with 1gb. 512mb was not tested, with 512mb sticks costing $20 used or even $30-$35 retail...you shouldnt have any trouble running at least 1gb.
XP vs Vista was not really tested as the beta was DX9 only so Vista was not really worth trying for its DX10 numbers.
*edit*
Oh and note this game on low looks like farcry
by Ravenas (October 10th - 4:54 AM) - Reply |
allikas: http://www.techpowerup.com/?41711
Kommentaarid: 162 loe/lisa |
137 |
omgwtf
10.10.2007 16:35:24
Krt DX9 ikka rohkemaks suuteline kui neil piltidel välja toodud
Kommentaarid: 155 loe/lisa |
137 |
Nokia
Serverid.ee
10.10.2007 17:42:15
Mis seal mängus vaata see snaipri moodi relv on, et kas sellele silencerit ei saagi otsa panna? ostsin küll Rifle Silencer jne.. aga ei lase midagi teha nagu. Sihiku saab küll peale.
_________________ Web3 | ERC721A |
Kommentaarid: 44 loe/lisa |
43 |
Firefly
10.10.2007 17:47:30
Nokia kirjutas: |
Mis seal mängus vaata see snaipri moodi relv on, et kas sellele silencerit ei saagi otsa panna? ostsin küll Rifle Silencer jne.. aga ei lase midagi teha nagu. Sihiku saab küll peale. |
Parem ongi kui ei saa, muidu saaksid sa salaja kuskil snaipida
Kommentaarid: 151 loe/lisa |
141 |
10.10.2007 17:59:59
Nokia kirjutas: |
Sa mõtled Precision Rifle ja/või Gauss Rifle?.Mõnes mõttes on see loogiline,et neile ei saa summutit otsa panna aga teisest küljest võiks ju see valik olemas olla(vähemalt fullis).Endale meeldibki eriti SP FPS-e niimoodi mängida,et kui vähegi võimalik siis koristan vaenlased ära ilma lärmi tegemata ja kui vähegi võimalik siis kaugelt sniperdades .
...Samas MP-d mängin hoopis niimoodi,et ajan niipalju pappi kokku,et tank osta ja siis hakkan järjest kõmmutama face to face
Kommentaarid: 92 loe/lisa |
Illu
Kommentaarid: 5 loe/lisa |
rycyve
10.10.2007 19:57:40
Kas multiplayeris saab very highi ka või?
Kommentaarid: 98 loe/lisa |
81 |
Nu
10.10.2007 19:59:31
Illu kirjutas: |
Crysis pildid setingutel LOW,MID,HIGH,VERY HIGH
esimesed 3 on siis dx9 ja vh dx10
_________________ DO you want it.. And if you had it would you flaunt it...
ss |
Kommentaarid: 177 loe/lisa |
157 |
Stabby
10.10.2007 20:01:29
Need lingid on katki ju. mul viskab mingi 404 forbidden vms.
Et mul ei ole mingit permissionit .
Kommentaarid: 34 loe/lisa |
34 |
Nu
157 |
Erik_Est
10.10.2007 20:12:26
Ehh mul si..ad silmad dx 9 high ja dx 10 very on minujaoks ühesugused....
Kommentaarid: 41 loe/lisa |
34 |
Lotharius
rallisibul
10.10.2007 21:04:08
heh kasvõi vaata neid väikseid kive maas selle suure rahnu kõrval, seal küll vahe sees.
Kommentaarid: 123 loe/lisa |
115 |
NATAS999
10.10.2007 21:23:15
päike paistab kah kenam, see, umm, volumetric lightning või sun waves või mis iganes see asi on seal
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik |
39 |
10.10.2007 21:33:30
rycyve kirjutas: |
Kas multiplayeris saab very highi ka või? |
Ei.See on MP-s nö Greyed Out
rycyve
10.10.2007 21:37:44
Tomorrow selge siis.
81 |
mannatera
10.10.2007 21:48:38
ma saaksin testida 1920x1200 resoga, mul on e6600@3.2 ja gf8800 GTS640, kui ainult saaksin mingi tip'i kuidas seda betat testida
hästi ta selle resoga max settingutel igatahes ei jookse
kas eestlased betas mingeid kokkusaamisi kah korraldavad?
Kommentaarid: 24 loe/lisa |
19 |
10.10.2007 21:53:57
mannatera kirjutas: |
kas eestlased betas mingeid kokkusaamisi kah korraldavad? |
Hetkel pole veel juhust olnud aga kui inimesed tahavad siis miks mitte .Hetkel muidugi see jama,et eraldi servut ei saa teha.Siis saaks teha mingi passwordiga kaitstud HV servu kus AHV-d tuld annavad .
BTW:Mul uus avatar(pole veel lõplik...tänud kasutaja punktiir )
mannatera
10.10.2007 21:54:10
tomorrow kirjutas: |
Hetkel pole veel juhust olnud aga kui inimesed tahavad siis miks mitte .Hetkel muidugi see jama,et eraldi servut ei saa teha.Siis saaks teha mingi passwordiga kaitstud HV servu kus AHV-d tuld annavad . |
hehe see oleks jah lahe, kahju tõesti et ei saa aga samas võiks ju mingi aja kokku leppida ja mingi servu numbri välja valida?
19 |
Stabby
10.10.2007 22:34:55
Kui mõelda Crysise videomälu kasutusele, siis praegu võiks küll videomälu overclokkimine olemas olla Aga tegelikult rohkem kui 1280x1024 ei mängi kah..
34 |
10.10.2007 22:42:09
Stabby kirjutas: |
Kui mõelda Crysise videomälu kasutusele, siis praegu võiks küll videomälu overclokkimine olemas olla |
Ja kas siis pole?
symmi
10.10.2007 22:43:13
Stabby kirjutas: |
Ja kas siis pole?  |
ju ta arvas et nagu mälu mahu suurendamist nt. 320mb @ 1.2gb vms
Kommentaarid: 27 loe/lisa |
25 |
WäntWõll
make.believe
10.10.2007 22:45:53
Kämpimise kokkutuleku võiks teah küll,kasutaja Wanawoll nagu ikka
Hetkel vaatan Die hard 4,niiet miski paari tunni prast võiks mingi low ping servus kokku saada(endal ping 62)
Kommentaarid: 374 loe/lisa |
300 |
10.10.2007 22:50:04
symmi kirjutas: |
Stabby kirjutas: |
Ja kas siis pole?  |
ju ta arvas et nagu mälu mahu suurendamist nt. 320mb @ 1.2gb vms  |
Njah osta pilet Aasiasse ja näppa mõned kiibid Hynix-i tehasest.Kodus joodad kaardile külge ja olemas .
Ega jah CryTek-i ametlikes soovitustes soovitati jah minimaalselt 256MB ja soovituslik 512-640MB.Eks videomälu kasutusele mõjub vast AA kõige rohkem.
dreamx kirjutas: |
Hetkel vaatan Die hard 4,niiet miski paari tunni prast võiks mingi low ping servus kokku saada(endal ping 62)  |
Mina olen küll täna out taolisel juhul .Sellinne peavalu,et issand halasta
MarekSäde
10.10.2007 23:17:45
mina sain aru piltidelt, et dx10 mängijatel on rohkem ja kaugemalt näha loodus jms. Eks on pisierinevusi ka aga see oli põhiline. Kui nüüd kaugelt vastane ka näha on siis on dx9 kasutajal eelis, sest sellel on vähem varjavat võsa ja ta näeb vastast ennem, kui dx10 kasutaja
Kommentaarid: 68 loe/lisa |
66 |
