praegune kellaaeg 04.08.2025 09:32:19
raitzr
24.09.2007 22:53:02
Probleem uue prosega |
Emaplaat A7N8X Deluxe ,oli prose Duron 1 GHz ,sai nüüd ostetud AMD Athelon 2500+ axmh2500fqq4c
Käima pannes 600 mhz Mobile AMD Athelon. Bios-is cpu external frequency 100Mhz ,settingud Auto peal,Agressive.
Kui panna seal cpu external frequency 200mhz,cpu frequency multiple 9X on olema 1.8GHz aga siis näitab Unknown CPU ja arvuti ka vahepeal tõrgub.Jumper sai ka emaplaadil ringi tõstetud. Kas mingi muu nipp kuidas see korralikult käima saada. Siin sarnast teemat foorumist ei leidnud.
CPU Properties:
CPU Type Mobile AMD Athlon XP
CPU Alias Barton
CPU Stepping A2
CPUID CPU Name Mobile AMD Athl
CPUID Revision 000006A0h
CPU Speed:
CPU Clock 601.30 MHz
CPU Multiplier 6.0x
CPU FSB 100.22 MHz
CPU Cache:
L1 Code Cache 64 KB
L1 Data Cache 64 KB
L2 Cache 512 KB (On-Die, Full-Speed)
CPU
CPU Properties:
CPU Type Mobile AMD Athlon XP, 600 MHz (6 x 100)
CPU Alias Barton
CPU Stepping A2
Instruction Set x86, MMX, 3DNow!, SSE
L1 Code Cache 64 KB
L1 Data Cache 64 KB
CPU Manufacturer:
Company Name Advanced Micro Devices, Inc.
Product Information http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118,00.html
CPU Utilization:
CPU #1 0 %
CPUID
CPUID Properties:
CPUID Manufacturer AuthenticAMD
Extended CPUID Revision 000007A0h
Platform ID CBh (Socket A)
IA CPU Serial Number Unknown
HTT / CMP Units 0 / 0
Instruction Set:
64-bit x86 Extension (AMD64, EM64T) Not Supported
Alternate Instruction Set Not Supported
AMD 3DNow! Supported
AMD 3DNow! Professional Supported
AMD Enhanced 3DNow! Supported
AMD Extended MMX Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Not Supported
IA SSE 3 Not Supported
CLFLUSH Instruction Not Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
MONITOR / MWAIT Instruction Not Supported
RDTSCP Instruction Not Supported
SYSCALL / SYSRET Instruction Supported
SYSENTER / SYSEXIT Instruction Supported
VIA FEMMS Instruction Not Supported
Security Features:
Advanced Cryptography Engine (ACE) Not Supported
Data Execution Prevention (DEP, NX, EDB) Not Supported
Hardware Random Number Generator (RNG) Not Supported
Montgomery Multiplier & Hash Engine Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features:
Automatic Clock Control Not Supported
Enhanced Halt State (C1E) Not Supported
Enhanced SpeedStep Technology (EIST, ESS) Not Supported
Frequency ID Control Supported
LongRun Not Supported
LongRun Table Interface Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Not Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Supported
Thermal Monitor 1 Not Supported
Thermal Monitor 2 Not Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Supported
CPUID Features:
36-bit Page Size Extension Supported
Address Region Registers (ARR) Not Supported
CPL Qualified Debug Store Not Supported
Debug Trace Store Not Supported
Debugging Extension Supported
Fast Save & Restore Supported
Hyper-Threading Technology (HTT) Not Supported
L1 Context ID Not Supported
Local APIC On Chip Supported
Machine Check Architecture (MCA) Supported
Machine Check Exception (MCE) Supported
Memory Configuration Registers (MCR) Not Supported
Memory Type Range Registers (MTRR) Supported
Model Specific Registers (MSR) Supported
Page Attribute Table (PAT) Supported
Page Global Extension Supported
Page Size Extension (PSE) Supported
Pending Break Event Not Supported
Physical Address Extension (PAE) Supported
Secure Virtual Machine Extensions (Pacifica) Not Supported
Self-Snoop Not Supported
Time Stamp Counter (TSC) Supported
Virtual Machine Extensions (Vanderpool) Not Supported
Virtual Mode Extension Supported
viimati muutis raitzr 24.09.2007 23:16:07, muudetud 1 kord |
Kommentaarid: 14 loe/lisa |
raido357
24.09.2007 23:00:15
Bios update ?
Kommentaarid: 78 loe/lisa |
raitzr
24.09.2007 23:03:20
raido357 kirjutas: |
Bios update ? |
pole teinud ,kas sellest oleks kasu ,ning kuidas see käib?
Minttunator
25.09.2007 08:46:18
Kui prose on mobost uuem, siis võivad BIOSiga ebakõlad tekkida küll. Step-by-step õpetuse BIOSi flashimise kohta peaksid oma emaplaadi manualist leidma. Jõudu!
Kommentaarid: 3 loe/lisa |
raitzr
25.09.2007 10:22:57
panin bisosis nagu manualis öeldud aga vahepeal tõmbab arvuti kinni kui 1.8ghz peal.
Kas voolu võib ka vähe olla 1.6v
Marie
25.09.2007 11:32:59
Re: Probleem uue prosega |
raitzr kirjutas: |
Käima pannes 600 MHz Mobile AMD Athelon. Bios-is cpu external frequency 100Mhz ,settingud Auto peal,Agressive.
Kui panna seal cpu external frequency 200mhz,cpu frequency multiple 9X on olema 1.8GHz aga siis näitab Unknown CPU ja arvuti ka vahepeal tõrgub.Jumper sai ka emaplaadil ringi tõstetud......
cpu frequency multiple peab 11 olema ja see cpu external frequency 166, pinge võid protsessoril kohe 1,65V peale panna, kui protsessoril hea jahutus on ja arvuti stabiilselt õigel kiirusel tööle oled saanud siis võid cpu external frequency 200 peale viia, ah ja tegelikult AMD Mobile 2500+ cpu external frequency on 133 ja õieti peaks cpu frequency multiple olema hoopiski 13,5 kuid enamus emaplaate seda ei võimalda ja siiani on kõik AMD Mobile 2500+ tööle saadud 11x166, kuni 12,5x166 1,65V >>> XP 2500+ Barton Overcloking
Kommentaarid: 83 loe/lisa |
74 |
oswald
Kommentaarid: 15 loe/lisa |
15 |
Marie
25.09.2007 12:29:36
BIOS_i uuendamisest küll AMD XP 2500+ Mobile Barton puhul abi ei tõuse, AMD XP 2500+ Mobile Barton on siiski sülearvuti protsessor mis pole lauaarvutites töötamiseks ette nähtud, lauaarvutites kasutatakse AMD XP 2500+ Mobile Bartoni just väga heade ülekiirendamis omaduste tõttu, kordaja on AMD XP 2500+ Mobileel lahtine mistõttu lauaarvutisse pannes hakkab tööle kõige madalamal astmel mida emaplaat võimaldab, tavaliselt on see 6x nii juhtus ka siin teemas, endal on olnud ka selline emaplaat millel kordajat fikseerida polnud võimalik ja siis oli ikka väga masendav olukord kus suurt üle 1,0GHz tööle teist ei saanud, normaalse kordajat lukustada võimaldava emaplaadi puhul on AMD XP 2500+ Mobile Barton üks parimaid, kui mitte parim protsessor mis soc A_le kunagi toodetud.
74 |
raitzr
25.09.2007 20:21:32
Hetkel käib töötab laitmatult 11X166 1.8 GHz 1.65V
tänud kõigile kes vastasid
lisa lemmikuks |
