uus teema   vasta Raud »  Protsessorid »  Veidi "ionic wind" nimelisest prosejahutustulevikust märgi kõik teemad loetuks
anubis
anubis
sõnum 16.08.2007 10:10:53 Veidi "ionic wind" nimelisest prosejahutustulevikust vasta tsitaadiga
äärmiselt paljulubav tehnoloogia
Harnessing ionic winds to accelerate charged air between high-voltage electrodes can enhance a chip's heat-transfer coefficient by 250 percent, according to Purdue University (West Lafayette, Ind.). Its chip-sized ionic wind engine prototype, funded by Intel Corp., works by overcoming the "no-slip" effect that ordinarily keeps the air molecules nearest the chip surface relatively stationary.
"We get a 250 percent improvement in heat-transfer coefficient; however, the challenge is to achieve the cooling enhancement we have shown at lower operating voltages," said Suresh Garimella, an engineering professor at Purdue. "The key challenges ahead are ensuring that we can operate at lower voltages, and making sure we have a robust electrode design."
For the prototype demonstration, tiny electrodes were placed 10 millimeters apart, on either side of a chip, and thousands of volts were applied to them. The positive electrode was a wire that ran across the anode side of the chip, while several negatively charged cathode electrodes emitted electrons to charge the air from the other side of the chip. In these tests, a chip cooled to 140 degrees Fahrenheit by a traditional fan was further cooled to 95 degrees Fahrenheit with the use of the ionic wind engine.
link
CoiL
CoiL
sõnum 16.08.2007 14:38:19 vasta tsitaadiga
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
One
sõnum 16.08.2007 14:40:39 vasta tsitaadiga
jälle üks asi mis kunagi turule ei tule..
Le Inc
Le Inc
sõnum 18.08.2007 22:33:01 vasta tsitaadiga
Huvitav kui palju energiat kulub nende "ioonide" liigutamiseks!?
heretic666
heretic666
sõnum 19.08.2007 09:38:28 vasta tsitaadiga
Njah, vee soojusjuhtivusega ei anna võrreldagi (vesijahutuse kasuks).
Ho Ho
Ho Ho
sõnum 19.08.2007 10:54:01 vasta tsitaadiga
Kas mitte samast asjast polnud ka eelmine aasta mingi uudis? Siis väideti et see pidavat tavalised ventilaatorid üsna kiiresti välja vahetama icon_razz.gif
heretic666
heretic666
sõnum 20.08.2007 23:39:56 vasta tsitaadiga
Ho Ho kirjutas:
Ähmaselt mäletan ma ka seda loba, et see uus süsteem vahetab kõik tavacoolerid välja.
anubis
anubis
sõnum 21.08.2007 09:41:35 vasta tsitaadiga
Ega ta väljavahetamisele rõhu, pigem sellele, et suurem hulk soojusenergiat CPU juurest kiiresti eemale juhtida - olemasolevat jahutust aidata.
Ordinarily the "no-slip" effect in air flow keeps the air molecules closest to a surface increasingly stationary, thereby inhibiting thermal transfer. However, if ionic wind engines could be integrated in arrays on the backside of chips, then normal cooling fans would become more than double their efficiency because air near the surface of chips would no longer be stationary.
sõnum 21.08.2007 09:50:11 vasta tsitaadiga
heretic666 kirjutas:
mis ajast on vesi hea soojusjuht? vesi on väga suure soojusmahutavusega aga mitte hea juht.
mõõdeti energiahulka, mida on vaja 1ühiku aine temperatuuri tõstmiseks 1 kraadi võrra.
heretic666
heretic666
sõnum 21.08.2007 11:13:29 vasta tsitaadiga
Nii et kui see jahutus tuleb välja, on siis watercooling history või ?
See energiahulk oli kalor, noh igatahes my bad selle vee kohta.
sõnum 27.08.2007 19:21:57 vasta tsitaadiga
Mnjah, kui need jahutused tõepoolest lõpuks müügile ilmuvad, siis tuleb edaspidi olla ülimalt ettevaatlik soovitustega à-la "katsu näpuga radikat" icon_rolleyes.gif
Auron
Auron
sõnum 27.08.2007 19:34:28 vasta tsitaadiga
Päh mingi samalaadne pläma nagu see hiitpaipides ringlev liquid metal teema oli mingi eelmine aasta mis pidi vendid mõttetuks muutma ja sigaefektiivne olema. Igast kemo tumo füsio pläplä asjad võivad küll toimida teoreetiliselt kuskil kaboris aga kui nende tootmine, energiaga varustamine ja hooldamine on liialt keerukas ning kallis siis tegu mõttetu asjaga. Samahästi võiks teoreetiliselt väita, et spets laseriga (äää äätom leiser kuuling) annaks prose kastis -273C külmutada, et siis hää klokkida ja pedemarke jooksutada vms. icon_biggrin.gif aga reaalselt ju sellist asja kellelegi ei satu.
anubis
anubis
sõnum 28.08.2007 11:38:58 vasta tsitaadiga
..Its chip-sized ionic wind engine prototype, funded by Intel Corp., works by overcoming the "no-slip" effect that ordinarily keeps the air molecules nearest the chip surface relatively stationary...l
Intel niisama raha tuulde ei loobi..
sõnum 28.08.2007 13:41:57 vasta tsitaadiga
tegemist võiks olla rakendusega, mis muutub vajalikuks näiteks olukorras, kus ei ole keskkonda, kuhu soojust eraldada.
Ho Ho
Ho Ho
sõnum 28.08.2007 13:52:39 vasta tsitaadiga
Minu arusaamist mööda see tehnoloogia lihtsalt tõstab harilike õhkjahutuste efektiivsust. Soe õhk tuleb kusagile ikkagi ära juhtida. Olukorras, kus pole võimalik soojusenergiat ära juhtida/teisele kujule muundada tekib lihtsalt ülekuumenemine. Pole olemas vahendeid, mis suletud keskkonnas soojusenergiat lihtsalt ära kaotaksid icon_smile.gif
anubis
anubis
sõnum 23.05.2009 10:57:10 vasta tsitaadiga
Dailytech
Holy thread revival Batman!!!
