libe
kvaliteetne mees
10.07.2007 21:47:53
ok siksisin natukene selle speedtouchi modemiga ja sain targemaks ja nüüd on pmst kõik nagad mul punaste nimedega ja lag'i pmst ei ole 8)
Go to Start, Run and type cmd
Then type telnet 192.168.1.254 and press Enter
Enter your username and password (by default both are set to "admin" on the Home Hub)
Then type the following exactly as shown below and press Enter after typing the 0
connection bind application=CONE(UDP) port=0
Then type "saveall" (without the invered commas) to save the config changes
Type exit to quit
Go to the Home Hub web interface and restart the router
I don't know whether this works with the BT Home Hub as although similar he firmware might be significantly different to the 780 firmware for this function not to work, but I would be interested in feedback.
There is another CLI command which might also help and this one will disable the intrusion detection system on a 780, but may also work on the Home Hub
Again when you have telnetted to the router (see above), type the following
ids config state disabled -> Press Enter
saveall -> Press Enter |
Think I've found the solution
Telnet to the BT Home Hub (instructions as given above)
Enter the following:
connection appconfig application=CONE(UDP) timeout=0
saveall |
_________________ ☠
viimati muutis libe 10.07.2007 22:28:10, muudetud 1 kord |
| Kommentaarid: 82 loe/lisa |
monty11
10.07.2007 22:02:58
Nii tark mees, tõlgi nüüd ära, mida ":connection bind application=CONE(UDP) port=0" täpselt teeb ja mis on default seadistus, et vajadusel tagasi panna kui see äkitsi oluline on? ...port=1?
_________________ Both the universe and stupidity are infinite. I'm not so sure about the former. - A. Einstein
Tule ja kiika minu fotomaailma. |
| Kommentaarid: 4 loe/lisa |
libe
kvaliteetne mees
10.07.2007 22:29:00
| monty11 kirjutas: |
| Nii tark mees, tõlgi nüüd ära, mida ":connection bind application=CONE(UDP) port=0" täpselt teeb ja mis on default seadistus, et vajadusel tagasi panna kui see äkitsi oluline on? ...port=1? |
ära minu käest küsi
kui midagi pärast tööle ei hakka, siis ma helistan elisa tehnikule ja lasen tal ruuteri paika panna
ise aga loen seni raamatut 8)
_________________ ☠ |
Stabby
10.07.2007 22:32:02
Umh, räigelt ajate isu peale online's sõitmisega... Kui juba singleplayeris on päris huvitav cruisida, siis arvatavasti onlines veel lahedam, eks?
Kui ostan, siis ostaks k-salongist (ei ole just tellija tüüp, hint: andrico)
Et siis, endal kah speedtouch 780 ja ikkagi, kuidas see lagiga üldiselt lugu on?
Kõige rohkem kardangi seda, et teised lihtsalt hüppavad ringi ja sellist sujuvust pole.
Üleval pool antud õpetusega on see, et võibolla keeran midagi tuksi
| Kommentaarid: 35 loe/lisa |
libe
kvaliteetne mees
10.07.2007 22:42:45
| Stabby kirjutas: |
Üleval pool antud õpetusega on see, et võibolla keeran midagi tuksi  |
nu mina tegin üksühele ja lahmisin need kolm rida sisse
ja kui enne kasutaja hensiga üksteist ei leidnudki ja kõik vennad peaaegu ekraanil hüppasid, siis nüüd polegi peale seda enam lag'i näinud
omavaheline sõit on täiesti tiptop
hens
10.07.2007 22:42:52
| Stabby kirjutas: |
Mängisime Libega.Päris okei oli mingit hüppamist ega jama peale suurt libe modemi kruttimist:)
| Kommentaarid: 31 loe/lisa |
24 |
11.07.2007 02:55:18
| libe kirjutas: |
nägin onlines mapil mingit venda, kelle kohta ütles car not yet downloaded  |
Xbox-il näitas samamoodi kui inimene polnud seda autot omale allalaadinud... siit võib järeldada siis mida
võibolla PC-le ka mingid masinad juba allalaetavad või siis paremad pojad saavad neid kuskil juba testida...
samas vahest viskab seda ka siis, kui TDU mänguserver jamab.
313 |
weasel
| Kommentaarid: 38 loe/lisa |
libe
kvaliteetne mees
11.07.2007 14:18:44
sain pagani zondaga 415km/h sisse
ühtlasi proovin selle patchi ka vast ära
11.07.2007 14:19:51
| sel Zondal on lahe mootorihääl imho
313 |
weasel
11.07.2007 14:28:53
| libe kirjutas: |
ühtlasi proovin selle patchi ka vast ära  |
Anna siis teada, siis otsustan, kas proovin ka homme ära. Ja homme teeme onlines ka sõitu (kui töötab peale patchimist )
_________________ PSN: weaselEST |
hentz
11.07.2007 14:35:54
| Tänud, sain ka selle online tööle lõpuks...
| Kommentaarid: 423 loe/lisa |
9 :: |
341 |
libe
kvaliteetne mees
11.07.2007 14:54:49
| weasel kirjutas: |
| libe kirjutas: |
Anna siis teada, siis otsustan, kas proovin ka homme ära. Ja homme teeme onlines ka sõitu (kui töötab peale patchimist ) |
autod on igatahes olemas, muud ma ei oska kommenteerida
aa see, kui kellelegi meeldib traffic'uta sõita, siis mäng ei lase enam seda trikki kasutada
ja neile kes lootsid, et skyline saab 1000HP ja 300kmh@13s tuunida
nüüd on õnneks 3 masinat E klassis, millega võidu ajada GTO, R34 ja RS4
monty11
11.07.2007 14:55:50
Ise ootan küll ametliku patchini.
See vähemalt hea, et paar normaalset autot juurde tuli ... muidugi mina pole veel aru saanud, et mis värk Lexusega on. Enne mängu väljatulemist oli video juba olemas. Pood ka kaardil, kuid autost ei kõssugi. Sama RUFi ja muude markidega, mis kõik kohe meelde ei tule.
Kuidas sai keegi loota, et Skyline'i saab 1000 hepaseks tuunida?
viimati muutis monty11 11.07.2007 15:00:50, muudetud 1 kord |
11.07.2007 15:01:17
libe, vaatan sul roolis oleks nagu ülikond seljas. must pinstak ja valge krae paistab
seesama RS4 Quattro Saloon peaks parim Audi olema seal mängus ja kiirenduses teeb paljudele kõrgema klassi ühesillaveolistele ilusti ära
mootori hääl suhteliselt vaikne. S6 undab palju rohkem
313 |
libe
kvaliteetne mees
11.07.2007 15:30:13
| Skeptik kirjutas: |
mootori hääl suhteliselt vaikne. S6 undab palju rohkem |
rs'iga pole veel ringile jõudnud, kuid ühega seal juba mõõtu võtsin
skyline tundus ringil mõnusalt käituvat
| monty11 kirjutas: |
| Kuidas sai keegi loota, et Skyline'i saab 1000 hepaseks tuunida? |
igasugu hulle on olemas
http://www.youtube.com/watch?v=Q8kCsDDUZpA
YouTube - 1400hp Nissan Skyline GTR
http://www.youtube.com/watch?v=VQoQhDXeT_I
YouTube - Nissan Skyline 1300 Hp Top Speed Runs
softis
11.07.2007 15:37:42
Ega TDU mingi über underground street tuner ei ole ju.
Ikka normaalsuse piiridesse jäädud.
| Kommentaarid: 21 loe/lisa |
21 |
mario20031
11.07.2007 16:01:36
nothing important
viimati muutis mario20031 19.08.2012 04:58:15, muudetud 1 kord |
| Kommentaarid: 15 loe/lisa |
libe
kvaliteetne mees
11.07.2007 16:03:52
| mario20031 kirjutas: |
| libe kirjutas: |
aa see, kui kellelegi meeldib traffic'uta sõita, siis mäng ei lase enam seda trikki kasutada |
kuidas ei saa,mina mängisin ilma trafficuta nüüd installisin ka selle mitteametliku uuenduse ära ja mängin ilma trafficuta samamoodi edasi...kaks lemmikut nagu naksti juures,aga see top speed on sellel skylinel ja rs4'l ebareaalne 3.tuuningpaketiga nagu ka AMG mersudel...need peaksid ikka 300km/h küündima |
mul automaatselt viskas teate connection lost, muidugi sõltub kuidas sul traffic eemaldatud oli
nimelt ta kontrollib traffic kausta ja failide suurusi seal kaustas
piisas, et igal failil esimene bit ümber muuta ja probleem lahenes
hentz
11.07.2007 16:06:46
softis, ons see hea või halb?
9 :: |
341 |
libe
kvaliteetne mees
11.07.2007 17:26:16
lüpsin mingit naga skylinega, tollel oli alfa competicione vms 300/4,2 skyline 275/4,5
kiirendused olid mul kõvasti paremad
igatahes tüübil oli räme uudishimu, mis autoga tegu 8)
jungleman
11.07.2007 17:28:07
| imho see Audi rs4 näeb küll väga sobiv välja selle mängu jaoks, siuke ikk muskel.
| Kommentaarid: 70 loe/lisa |
62 |
monty11
11.07.2007 18:11:26
Pakun, et kui patch ametlikult välja tuleb, siis on tänavatel enamasti ainult RS4 ja Skyline sõitmas
softis
11.07.2007 18:40:19
| hentz kirjutas: |
softis, ons see hea või halb?  |
Hea ikka.
Märjaks võib ennast Undergroundiga ajada.
21 |
flameas
11.07.2007 19:13:25
Keegi oskab öelda, kuidas saaks mängu "installitud" nii, et seda ei peaks installima. Nimelt kopeerisin mängu enne formatit copy pastega teisele kettale. Peale Wini re-installi arvab arvuti , et mäng ei ole installitud ning patchi peale ei saa panna. Kindlasti peitub võti kuskil regystris, aga kuidas täpsemalt? DVD lugeja on endaga võrdlemisi
| Kommentaarid: 91 loe/lisa |
81 |
