uus teema   vasta Tarkvara »  Arvutimängude foorum »  Colin McRae: Dirt märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 37, 38, 39 ... 57, 58, 59  järgmine
epu[]
sõnum 17.06.2007 00:53:25 vasta tsitaadiga
Quote Codemasters foorumis:
t may not have anything to do with modified files. I've been playing the demo for weeks on xp and vista, both 32 bit and I've never heard the co-driver except after a crash when he tells you what's wrong with the car. That's with 100% stock files and an x-fi with the latest drivers. I only know that pacenotes exist because i've heard them when watching other people's videos.
It's exactly the same with the full version of the game... there simply are no pacenotes to be heard, even on rally stages. I've tried just about everything I could think of, software sound, direct3d, openal and all the possible settings for each, tried alchemy... nothing seems to make a difference. At one random point, an hour into playing the game (with no pacenotes)... in the middle of a stage, without changing any settings... the co-driver suddenly started talking and i had pacenotes for about a minute... After that (and before the stage was over) they stopped again and I've never ever heard them before or since. So if anyone has any tips on how to get them working I'd really appreciate it.
angel
angel
sõnum 17.06.2007 01:19:14 vasta tsitaadiga
ma ütleks et see mäng ei ole üldse PC peale sobiv... tundub rohkem xbox360 mäng olevat ja piixult porditud PC peale koos starforce kaitsega thumbs_up.gif
see seletaks ära miks nii jura fps enamus rahval on jms probleemid icon_rolleyes.gif
der hammer
der hammer
sõnum 17.06.2007 01:25:00 vasta tsitaadiga
angel kirjutas:
port on üpriski hea. Parem ,kui tavaliselt. Mäng jookseb ka enamusel väga kenasti. Suuremaid buge pole ka peale selle kaardilugeja mis kuigipalju ei sega mängu mängimist. Kindlasti lahendatakse see varsti patchiga.
Tere.
Kommentaarid: 148 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 130
estliiga
estliiga
sõnum 17.06.2007 01:33:35 vasta tsitaadiga
Ma ei saa aru kas codemaster pole aru saanud miks ta sellise käki kokku keeras, et rool ei tööta mängus õigesti, krt rooliga oleks teine fun seda mängida
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 56
angel
angel
sõnum 17.06.2007 01:34:37 vasta tsitaadiga
ei jookse ta midagi eriti häste... ja see probleemi hunnik mis nn "valitseb". ma ei tohiks küll seda öelda aga Codemasters pole ei tea mis ajast midagi head ja originaalselt ning toimivat asja välja suutnud lasta. Ja kardan et kui selle mängu nimi ei sisaldaks nime Colin McRae siis kannataks ka kõvasti müügi numbrid.
Aga eks näis mis sellest Dirt mängust saab ja kuda patchidega asja silutakse. Aga see kuramuse udune ja kahtlaste textuuridega graafika käib sutsu pinda (jah ma panin kõik high peale ja seisin autoga metsa vahel ja passisin graafikat... 20 fps i ei arvesta kuna sitt arvuti aga graafika "ilu" nägi kenasti ja uurida sai) ... gameplay paistab suht norm olevat (eriti kui AI sinu ees libaduse tõttu teelt välja paneb icon_lol.gif )
mõni konsooli omanik võiks parem rääkida kuidas mäng on ja kas probleeme esineb ning kui sujuvalt ja kenalt kogu see kupatus jookseb.
viimati muutis angel 17.06.2007 01:35:18, muudetud 1 kord
epu[]
sõnum 17.06.2007 01:35:00 vasta tsitaadiga
estliiga kirjutas:
Kui inimesed ei oska asja seadistada, siis see on nende enda mure. Rool on mõeldud seestvaate jaoks tavaliselt. icon_rolleyes.gif
estliiga
estliiga
sõnum 17.06.2007 01:39:22 vasta tsitaadiga
Palun pane rool tööle nagu RBRis. asi on sellels et rool jõuab hiljem järele ja kogenud RBRi mängija saab sellest näiteks kohe aru mis mäda on
angel
angel
sõnum 17.06.2007 01:41:57 vasta tsitaadiga
estliiga kirjutas:
aga kui auto sees oled ja rooli keerad. Kas siis auto sees olev rool töötab nagu sul rool laua peal? Ise olen rooliga mängides tavaliselt asja nõnda paika pannud et mängu sees olev rool on 100% täpselt sama moodi toimiv nagu minu käes olev rool. Ehk siis kui 1mm liigutan siis mängu sees ka see kajastub.
seda dirt i olen ainult gamepadiga tagunud ja eriti ei kurda... kuidagi järsk on aga ma ei viitsi seda ka seadistada icon_razz1.gif
Syncmahv
Syncmahv
sõnum 17.06.2007 01:42:55 vasta tsitaadiga
Proovisin nüüd ka klaveriga seda (ennem polnud kordagi) Asi kõvasti tuimem ning mulle tundub et isegi klaviatuur jääb pööramisega maha icon_lol.gif icon_lol.gif
estliiga
estliiga
sõnum 17.06.2007 09:36:00 vasta tsitaadiga
Seal jäävad kõik asjad pööramisega maha ja, mis kasu mul on kui ma vaatan seest vaataes rooli ma ju tunnetan mida see auto teel teeb, muidu vaataseime eest vaates rattaid ja need jäid küll mingi 1 sekk taha
windsurfer
windsurfer
sõnum 17.06.2007 10:45:47 vasta tsitaadiga
estliiga kirjutas:
Rool uimab kohutavalt, default settingud võiksid ikka sellises mängus nagu Dirt ometigi korras olla. Minul ei ole sellist probleemi esinenud rooliga et peab ise seadeid hakkama käppima vaid on kohe alguses töötanud niii nagu vaja. icon_lol.gif
Aga vähemalt saab need settingud manuaalselt paika pannna... icon_rolleyes.gif
Kommentaarid: 42 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 39
Stabby
sõnum 17.06.2007 11:15:46 vasta tsitaadiga
Endal on siis hetkel käimas Tier 8, seega lõpp väga kaugel ei ole (kokku on 11 Tier-i).
Vaatasin kah, et eile co-driverit ei olnud, kuid äkki täna oli ta ilusti autos sees.
weasel
weasel
sõnum 17.06.2007 11:47:35 vasta tsitaadiga
Mis tasemega te neid sõite teete karjääris muidu?
PSN: weaselEST
libe
kvaliteetne mees
libe
sõnum 17.06.2007 11:48:06 vasta tsitaadiga
üritan pro'ga, aga teen vast mediumiga
its2cold
sõnum 17.06.2007 11:56:27 vasta tsitaadiga
Pro Am on minule paraja raskusastmega.
Kommentaarid: 196 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 173
weasel
weasel
sõnum 17.06.2007 11:57:16 vasta tsitaadiga
Ja kas te võidate siis veenvalt või peate vahel mitu korda proovima?
PSN: weaselEST
its2cold
sõnum 17.06.2007 12:03:59 vasta tsitaadiga
Suurem osa ikka võidan kohe esimesel katsel. Umbes iga viiendat sõitu proovin uuesti.
epu[]
sõnum 17.06.2007 12:50:47 vasta tsitaadiga
Pro tasemel algusest peale sõitnud ja igas tieris umbes 2 sõitu mida peab uuesti proovima. Eriti hull on nende sõitudega mis haigelt lagivad.
Siin põhimõtteliselt allpool kirjas, et kui teil ikka masin nõrk, siis pole mõtet rooliga mängida kah. http://community.codemasters.com/forum/showthread.php?t=187810
Muide see co-driveri probleem tundub millegipärast olevad just paljudel Ida-Eurooplastel icon_lol.gif
j22lind
sõnum 17.06.2007 13:02:11 vasta tsitaadiga
epu[] kirjutas:
Ega sa teinud vihjet Markko kohta kohta? See oleks labane
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 3
Syncmahv
Syncmahv
sõnum 17.06.2007 13:22:45 vasta tsitaadiga
Mul oli 5 pool tieri tehtud kõik Pro tasemel... Kõigeenam vihkasin neid Offroad sõita kuna need olid kõige raskemad, neid sai ikka päris mitu korda uuesti tehtud... teised sõidud olid suht savid.
der hammer
der hammer
sõnum 17.06.2007 13:36:42 vasta tsitaadiga
angel kirjutas:
Kuidas ei jookse ? Mida sa tahad new gen graafikalt ? Et Geforce 2 mehed seda mängida saaks ?
7800GTX. 2 aastat vana kaart jooksutab väga hea graafikaga mängu 1280x1024 ,medium ja 2 multisampling.
Need on täiesti arvestatavad graafika settingud ja võib öelda ,et mängust saab kogu mõnu kätte. icon_rolleyes.gif
Tere.
libe
kvaliteetne mees
libe
sõnum 17.06.2007 13:41:30 vasta tsitaadiga
nüüd kus lõpuks sõitmisega alustasin, siis panin tähele, et rohkem nutsu saada, tasub ka need rookied ja amateurid ilusti järjest kõik läbi sõita
kuna kui sõita kohe pro peal ennast esimeseks, siis ülejäänu eest saab kõvasti vähem pappi
anyway mul jookseb ultra 1280x960 multisampling 4x ja 16xAF 37-42fps, aga kuna märkasin, et videomälu kasutab ta rohkem kui mul on, siis panin high peale, lisaks pole ka olulist vahet high ja ultra vahel icon_razz.gif
Crz
sõnum 17.06.2007 14:17:28 vasta tsitaadiga
libe kirjutas:
kui tohib küsida siis mis programmiga sa seda videomälu kasutust vaatad
Kommentaarid: 90 loe/lisa Kasutajad arvavad:  :: 10 :: 5 :: 60
JediMihkel
JediMihkel
sõnum 17.06.2007 14:19:34 vasta tsitaadiga
huvitaks ka, tahaks näha palju sellest 512 mb näiteks uutemate mängude puhul raisus on.
Kommentaarid: 42 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 38
G80
G80
sõnum 17.06.2007 14:42:34 vasta tsitaadiga
Crz kirjutas:
libe kirjutas:
Rivaturneriga vist sai kuidagi.
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Colin McRae: Dirt mine lehele eelmine  1, 2, 3 ... 37, 38, 39 ... 57, 58, 59  järgmine
