WäntWõll
make.believe
07.06.2007 23:51:18
Ilmunud uus versioon tuntud programmist Ad-Aware |
Ilmunud siis uus versioon kõigile teda tundud pahalaste otsijast ja eemaldajast
Ad-Aware 2007 Free
Laeb all Siit
Süsteemi nõuded on suht taagsihoidlikud,niiet peaks sobima paljudele.
Pentium 600 MHz or faster
RAM Operating system + minimum 50 MB (100 MB recommended)
50 MB free hard disk space
Operating Systems: Windows 2000 (Pro and Server), Windows Server 2003, Windows XP (Home and Pro)
Web Browsers: Internet Explorer (version 5.5 or higher), Firefox (version 1.5 or higher), Opera (version 9 or higher) |
Kurb on muidugi jällegist Vista kasutajate saatus.
Väidetavalt varsti peaks ka Vista tugi saabuma
Head kasutamist
Täiendav info kodukalt
300 |
Mario.
07.06.2007 23:58:16
aga mis ta parem on kui eelmine osa, update teevad ka eelmised niiet nimekiri peaks sama olema, järelikult eemaldab ka sama.
ad-aware nõuded võivad küll olla see 600mhz, kuid vaene masin, asi tõmbab ikka suhteliselt kooma prose.
professional kärab veel...
6 :: |
217 |
WäntWõll
make.believe
08.06.2007 00:07:21
MarioA., Kuna huvi tundsid sii uut ikka on(loodan et tõlget pole vaja)
What's New in Ad-Aware 2007 Free?
Redesigned Engine Benefit from superior program flexibility and more accurate scanning methods with all-new program architecture.
Improved Code Sequence Identification (CSI) Technology Boost your privacy protection with precise detection of embedded malware, including known and emerging threats.
Incremental Definition File Updates Save precious time and resources with smaller update files resulting in faster download times.
TrackSweep - Control privacy by erasing tracks left behind while surfing the Web on Internet Explorer, Firefox, and Opera, with one easy click.
Multiple Browser Support Choose Internet Explorer, Firefox, or Opera with expanded browser support.
New Straightforward User Interface Effortlessly maneuver the complexities of malware detection and removal with our new user-friendly interface. |
Eks lase vanaga kast läbi ja proovi uuega järgi,äkki jäi midagi veel
Teema oli lihtsalt valgustamiseks ja kui sulle midagi uut ei ole siis kommentaarid on liigsed,onju
300 |
08.06.2007 10:49:02
Opera tugi on positiivne nähtud. Pole kindel, kas eelmisel versioonil see oli? 50 MB vaba kettaruumi on küll suht palju, kui võrrelda teisi sama eesmärgiga programme. Isegi enamus viirusetõrje programme ei võta nii palju (tean, et see pole tänapäeva gigabaidistes ketastes palju, aga siiski harjumatu).
_________________ M: HP Elitedesk 800 G3 SFF
M: HP Elitedesk Mini 800 G2 35W |
| Kommentaarid: 765 loe/lisa |
571 |
riaak
08.06.2007 13:46:13
Eelmine ver oli 4.5MB, see on 17MB
Kiirus tundus olevat sama ja kumbki ei leidnud nagu tavaliselt midagi.
_________________ ¯\_(ツ)_/¯ |
105 |
Marie
27.06.2007 19:55:19
Katsetasin ka Ad-Aware 2007 ära, vaike seadetes ei leidnud midagi, siis tegin täis otsingu ja seda tegema ta jäigi, võttes kasutusele mõlemad C2D tuumad ja koormates arvutit hullu moodi, peale neljatunnist töötamist tahtsin seda Ad-Aware 2007 sulgeda, ei allunud, päris programmi sulgemisel aga jätkas endiselt tööd peidetult.
Sulgesin arvuti ja uuel käivitamisel kustutasin selle meeletut ressursi nõudva Ad-Aware 2007, rohkem pole kunagi isu seda Ad-Aware 2007 katsetada
| Kommentaarid: 83 loe/lisa |
74 |
AJ
27.06.2007 20:08:55
Minul töötab ilusti ja on natuke kiirem kui vana variant
| Kommentaarid: 37 loe/lisa |
36 |
Marie
27.06.2007 20:16:13
| AJ kirjutas: |
Minul töötab ilusti ja on natuke kiirem kui vana variant  |
Sa peale esimest vaike otsingu midagi muud ka oled proovinud ja programmi töötamise ajal protsessori kasutust kontrollinud, töötab loomulikult ilusti, proovi töötamist poolelt töölt katkestada
74 |
Märt.
28.06.2007 07:11:54
| Marie kirjutas: |
Sa peale esimest vaike otsingu midagi muud ka oled proovinud ja programmi töötamise ajal protsessori kasutust kontrollinud, töötab loomulikult ilusti, proovi töötamist poolelt töölt katkestada |
Huvitav, endal küll andis, ei viitsinud argipäeva õhtul full scanni testida lõpuni...
| Kommentaarid: 29 loe/lisa |
23 |
28.06.2007 11:12:12
Uus kipub "pooma küll", eriti kui on suured failid (filmid jms) läbi skännida.
Seetõttu soovitan soojalt kasutada alternatiivina AVG tasuta Spy-otsijat ja Skännerit. leiab need, mida Ad-Aware ei suuda leida
211 |
AJ
28.06.2007 11:36:13
| Marie kirjutas: |
| AJ kirjutas: |
Paaril korral jõudis prose kasutus 50%-ni aga üle ei läinud ja poole scanni peal katkestamine ei valmistanud migit probleemi.
36 |
sakunne
04.07.2007 14:57:13
Ressurssi matsutab nigu loom
Vana küll tegi ka
Mingi nali - poole skänni peal teatas, et peab katkestama, kuna internetiühendust pole - ja katkestaski full skänni - tõbrik
Service error: 6000 has occurred.
Description: Lost connection with
Ad-Aware service.
Terminating gracefully ... |
Hakka aga otsast peale
_________________ Kuna ei pruugi õigel ajal foorumisse sattuda:
SMS: 5051598 [võõraid tel. ei vasta]
Email sakunne@seenior.ee |
| Kommentaarid: 77 loe/lisa |
69 |
Risto40
04.07.2007 15:12:54
| kasutsain ka korra uut versiooni. panin tähele, et kui programm sulgeda, siis vaikimisi jääb see ikka tööle ( taskmanageris näitab, et programm ikka töötab). seetõttu panin vanema versiooni arvutisse tagasi, kuna ei taha, et see progr. koguaeg (vaikimisi) töötaks.
Hiid
04.07.2007 15:26:19
Torufoorumis kirjutati et see pidi tohutu kräpp olema.
ei soovitata kellelegi kasutamiseks.
| Tegu on totaalse kräpiga, seega hoidke palun kaugemale sellest versioonist. Kõhklejatel soovitan lugeda erinevatest foorumitest hinnanguid selle asja kohta. Kurb, et Lavasoft pika nuputamise peeale sellise käki kokku keeras |
_________________ Hapud viinamarjad
viimati muutis Hiid 04.07.2007 15:30:25, muudetud 1 kord |
| Kommentaarid: 665 loe/lisa |
512 |
Karvased
04.07.2007 15:28:11
| panin tähele, et kui programm sulgeda, siis vaikimisi jääb see ikka tööle ( taskmanageris näitab, et programm ikka töötab). |
äkki saab seda kuskil settingutes timmida ? on keegi proovind ?
üldjuhul peaks uus asi ikka parem olema
marco
04.07.2007 16:08:05
Smart ja full scan mõlemad tehtud ja kahepale kokku kahekümne viie minutiga. CPU hüppas kõigerohkem 20% peale.
Kuna pole kaua aega pahalasi masinas olnud, siis kasulikkuse kohapealt ei oska hinnangut anda. Leidis, nagu tavaliselt, mõned küpsised.
_________________ Does "genuine" mean "with the real bugs"? |
| Kommentaarid: 9 loe/lisa |
9 |
nuhk
08.07.2007 10:44:26
| Ma ei leidnud vana versiooni ees mitte mingeid eeliseid. Lisaks suur nagu elajas, ettearvamatu nagu vene valitsus... - seda värki ma rohem kuskile peale ei pane ja teile ka ei soovita.
| Kommentaarid: 8 loe/lisa |
LP
10.07.2007 20:02:05
| Mina jään oma vanale Ad-Aware SE'le kindlaks...
