03.06.2007 21:25:14
Auzentech X-Fi Prelude 7.1 Arutelu |
Siia ainult pealkirjas mainitud kaardiga seotud küsimused/probleemid/lahendused/info/arutelu jne
Ametlik Koduleht: http://www.auzentech.com/site/products/x-fi_prelude.php
Tehnilised andmed:
*24-bit Analog-to-Digital conversion of analog inputs at 96kHz sample rate
*24-bit Digital-to-Analog conversion of digital sources at 96kHz to analog
7.1 speaker output
*24-bit Digital-to-Analog conversion of stereo digital sources at 192kHz to
stereo output
*16-bit to 24-bit recording sampling rates: 8, 11.025, 16, 22.05, 24, 32,
44.1, 48 and 96kHz
*ASIO 2.0 support at 16-bit/44.1kHz, 16-bit/48kHz, 24-bit/44.1kHz
*24-bit/48kHz and 24-bit/96kHz with direct monitoring.
*Enhanced SoundFont support of up to 24-bit resolution
*64MB of X-RAM
Põhikomponendid:
*Creative X-Fi CA20K audio processor
*One AKM AK-5394 super high performance 192kHz 24-bit ADC for analog input
*Four AKM AK-4396 192kHz 24-bit advanced multi-bit DAC for analog output
*64Mbytes of memory for audio processing
*High fidelity audio OP-Amps for analog input and output(OPA2134 SOIC)
*Front L/R output OP-Amp is replaceable by end-user(National LM4562 SOIC Opamp)
*Dual mode S/PDIF receiver and transmitter
IO Ühendusvõimalused:
*One 3.5mm MIC input connector in rear panel
*One 3.5mm line input connector in rear panel
*One 4-pin AUX connector on board
*Four 3.5mm 8 channel line output connectors in rear panel
(FL/FR/C/SW/RL/RR/RSL/RSR)
*One S/PDIF combo input connector in rear panel for receiving either coaxial
or optical digital
*One S/PDIF combo output connector in rear panel for transmitting either
coaxial or optical digital
44.1, 48 and 96kHz
*One 10-pin front panel connector on board for MIC input and headphone
support
*One 40-pin digital extension header on board to support AD-Link and other
digital functionality
Saadavus:
Järgneval lehel on list online kauplustest erinevates maailmajagudes kes müüvad Auzentech-i helikaarte.
http://www.auzentech.com/site/where/where.php
Hind:
Hind:~2000-3000 Eesti krooni
Retail hind on $175.99.
Ülevaated:
http://www.guru3d.com/article/sound/456/
http://www.xtremesystems.org/forums/showthread.php?s=ca8dfb585c3c97de16ce681bde3db9c4&t=157615
http://www.elitebastards.com/cms/index.php?option=com_content&task=view&id=456&Itemid=27
http://techgage.com/article/auzentech_x-fi_prelude/
http://www.overclock3d.net/reviews.php?/audio/auzentech_x-fi_prelude_7_1_sound_card/1
Viimati muudetud 29.06.07:Lisatud retail boxi pilt ja paar kommentaari hinna ja saadavuse kohta.
Viimati muudetud 30.06.07:Lisatud teksti ametlikult kodulehelt
Viimati muudetud 01.07.07:Lisatud veel üks preorder koht(tänud kasutaja yb228a).
Viimati muudetud 11.08.07:Muudetud retail boxi ja kaardi enda pilt olemaks kooskõlas tootmisversiooni omadega.Ühtlasi uuendatud infot saadavuse kohta
Viimati muudetud 01.09.07:Lisatud ostukohti kus peaks olema kaardi reaalne saadavus(aka=In Stock USA & EU)
Viimati muudetud 28.11.07:Muudetud kogu esimese posti ülesehitust ja täpsustatud/eemaldatud/uuendatud erinevaid kaardi kohta käivaid andmeid.
Viimati muudetud 06.02.09:Eemaldatud mittetoimiv pilt ja korrigeeritud hinnavahemikku
Täiustan teemat vastavalt sellele kuna uut infot tuleb ja kuna vajadust on.Kõikidest vigadest/ebatäpsustest esimeses postis anda mulle teada PS teel.
viimati muutis Tomorrow 06.02.2009 11:04:24, muudetud 14 korda |
| Kommentaarid: 92 loe/lisa |
koristaja
03.06.2007 21:51:35
Re: Auzentech X-Fi Prelude 7.1 Arutelu |
| tomorrow kirjutas: |
| [... Tehnilised andmed:... Põhikomponendid: ... IO Ühendusvõimalused: |
juhul kui tehnilised andmed eriti midagi ei ütle ...
millisele kasutajale see kaart suunatud?
milline kõlarikomplekt oleks optimaalne?
kas see HIND on seda väärt, mida selle raha eest saab, tarkvara, laienduspaneel, pult?
kas võrdluseks sobiks CREATIVE SB X-FI XTREME MUSIC BULK (OX-s näiteks), kui musa loomine teemaks?
ühesõnaga, jälgin teemat ...
03.06.2007 22:54:29
| koristaja kirjutas: |
| millisele kasutajale see kaart suunatud? |
Kui varem on helikaardid jagunenud(üldistades) 2 klassi:Mänguritele(mängud) ja Audiofiilidele(muusika loomine,filmide vaatamine,muusika kuulamine jne)...siis see konkreetne kaart sobib pmst mõlemale kuna tal on X-Fi audio protsessor mis on hetke parim mängude jaoks kuna võimaldab EAX efekte jne.Samas on tal ka featuurid mida enamasti leiab ainult audiofiilidele mõeldud kaartidelt.Teisisõnu on võetud parim mõlemast maailmast .
| milline kõlarikomplekt oleks optimaalne? |
See on väga subjektiivne aga ise eelistaksin Creative toodangut selle kaardi puhul kuna iialgi ei või teada kuidas X-Fi audio protsessor nt Logitechi kõlaritele heli ette annab(X-Fi+Logitech on mõnedel kasutajatel esinenud väikesi probleeme).Konkreetset komplekti on raske soovitada aga soovitan vaadata 5.1 ja 7.1 heli pakkuvate komplektide poole .
| kas see HIND on seda väärt, mida selle raha eest saab, tarkvara, laienduspaneel, pult? |
Lisade kohta ei oska hetkel öelda kuna kaasasolevaid asju pole veel avalikustatud.Paljalt riistvara põhjal hindan,et kaart on oma hinda väärt .
| kas võrdluseks sobiks CREATIVE SB X-FI XTREME MUSIC BULK (OX-s näiteks), kui musa loomine teemaks? |
Ei.Seda väga lihtsal põhjusel:X-Fi kaardid on mõeldud ennekõike mängimiseks mitte muusika loomiseks...ja siin tulebki mängu X-Fi Prelude...see peaks olema(vähemalt loodame )kaart mis rahuldab nii mängurit(EAX,X-RAM jne) ja Audiofiili(kõrge kvaliteediga opampid ja teised komponenid parema heli jaoks).
CnZ
04.06.2007 12:40:00
kas sellega mingit i/o boksi tuleb ka kaasa?
hetkeste x-fi'dega on minimaalne helivahe erinev vaid elite prol, huvitav kuidas see siis konkureerib helikvaliteedi suhtes?
edit: no loodame, et siis tulevad head opampid sellel
aga m$ tahab Vistaga ju põhimõtteliselt EAXi välja suretada tänu hardware audio layeri eemaldamise tõttu, mille tõttu creative peab siis oma alchemy projekti arendama kogu aeg. cmr dirt kasutab eax5 näiteks - huvitav, kas dirt Vista all vajab ka alchemyt või on neil mingi teistsorti bypass juba sisse ehitatud?
| Kommentaarid: 14 loe/lisa |
07.06.2007 18:18:01
| CnZ kirjutas: |
| aga m$ tahab Vistaga ju põhimõtteliselt EAXi välja suretada tänu hardware audio layeri eemaldamise tõttu, mille tõttu creative peab siis oma alchemy projekti arendama kogu aeg. cmr dirt kasutab eax5 näiteks - huvitav, kas dirt Vista all vajab ka alchemyt või on neil mingi teistsorti bypass juba sisse ehitatud? |
Pole ise uurinud aga kuna sa ütled,et CMR Dirt kasutab EAX 5.0 ,siis jah...selleks,et saada täie rauaga toetatud EAX-i läheb selle mängu jaoks Vista all vaja Alchemy-t .
Btw:Microsoft ei taha EAX välja suretada ...lihtsalt keegi jahupea leidis,et audio processingu lükkamine CPU peale suurendab süsteemi stabiilsust .Samas fakt jääb faktiks...mitte ükski üldine asi ei suuda kunagi asendada spets asja(e. CPU ei suuda asendada Helikaarti ...audio processingu kui sellise suudab see ära teha aga kus on CPU-l OpAmp-d jms asjad? ).
NATAS999
07.06.2007 20:15:18
cpul polegi opakaid vaja, dacid ja opakad ikka helikaardil. prose ülesandeks on siis "aint" nende effektide arvutamine vms. Põmst nagu 3d markis need cpu testid . Helikaart antud juhul ei pea muud tegema kui digihäälest analooghääle tegema. Aga jah, kui ikka arvutataske täpselt doppleri efekte ja igast kajasid jne, siis prosel ikka suht kole tegemine nende häälte, füüsika, ai ja krt teab mis asjadega veel Süsteemi stabiilsust ehk tõesti parandab (hmm, microsoft ja stabiilsus ... ... :LOL: haha hea nali ) aga perfoormants saab kannatada selle all.
| Kommentaarid: 41 loe/lisa |
39 |
Terror
19.06.2007 11:58:25
| LM4562 opamp (dip8) tuleb front channelisse ning ülejäänud kanalitesse opa2134 (soic-8)
91 |
s4nder
29.06.2007 23:59:20
| Huvi pärast küsin, et kust need väljalaskekuupäevad pärit on? Kodulehel pole selle kohta eriti midagi, viimati oli juuni lõpust juttu.
| Kommentaarid: 8 loe/lisa |
30.06.2007 11:10:59
| s4nder kirjutas: |
| Huvi pärast küsin, et kust need väljalaskekuupäevad pärit on? Kodulehel pole selle kohta eriti midagi, viimati oli juuni lõpust juttu. |
Väljalaskekuupäev on võetud Overclokers.co.uk järgi .Aasia väljalaskekuupäev peaks tegelikult olema kõige varasem kuna kõigi eelduste kohaselt valmistatakse kaarte kas Taiwanis või Lõuna Koreas.Järgmisena peaks kaart jõudma Euroopasse ja viimasena USA-sse .Uuendan väljalaskekuupäevi kui uut infot tuleb
Herr Kurm
30.06.2007 11:42:24
lihtsalt keegi jahupea leidis,et audio processingu lükkamine CPU peale suurendab süsteemi stabiilsust  |
mingi jahupea arvas et DRM on jube hea asi.
_________________ -logod, firmaidentiteet, küljendamine, flash-
-portfolio- |
| Kommentaarid: 25 loe/lisa |
19 |
Zonerman
30.06.2007 11:49:51
Nii aga kuidas on selle kaardi softi tugi Vista all. Hetke X-FI kaardid pole 100% ära kasutatavad Vista all kui Winxp's. Creative on suht mannetu Vista suppordiga. Kaardi karbil võiks olla juba logo Designed for Vista. Teadupärast Vista ei toeta EAX'i!!!
_________________ Sõim ja räuskamine läheb SIIA |
| Kommentaarid: 68 loe/lisa |
67 |
30.06.2007 12:08:13
| Zonerman kirjutas: |
| Nii aga kuidas on selle kaardi softi tugi Vista all. Hetke X-FI kaardid pole 100% ära kasutatavad Vista all kui Winxp's. Creative on suht mannetu Vista suppordiga. Kaardi karbil võiks olla juba logo Designed for Vista. Teadupärast Vista ei toeta EAX'i!!! |
Alguses puuduvad selle kaardiga Vista all järgmised featuurid:
*Dolby® Digital Live
*DTS® Interactive
*DTS NEO:PC
Need featuurid peaks olemas olema Q4 2007-->Q1 2008.
Driverite tugi üldiselt peaks tulema parem kui Creative-l .Mis EAX puutub,siis tõenäoliselt on ALchemy kasutatav ka selle kaardiga.OpenAL toimib muidugi mõista by def riistvaraliselt Vista peal ja ALchemy võimaldab EAX samuti kasutada seega suuri probleeme ei tohiks tekkida
Flavius
118 |
NATAS999
01.07.2007 12:45:45
Pole nagu uurinud helikaardivärki, aga kas auzen toodangut eestis kah leidub, või peab selle kaardi saamiseks tellima kuskilt? HV hinnakirjas pole nagu auzenit märgand, aint creative ja maudio jne. Siis veel spdif ühendus, kodukal nägin siukest värki et coax auku topitakse miski adapter, mis teeb coaxist optilise sealt kah midagi kaduma läheb või tekivad kaod kehvema poolse coax kaabliga?
Veel tekitab huvi see kella süsteem, x-fi teemas vist tuli jutuks kella küpsis. Põmst tekitab muret see, et mul sellel ressiiveril, mille taha arvut läheb, ja kui ressiiveril on kehvapoolne kell, siis kuidas selle vahetamisega lood on? Ja kas on üldse mõtet, et kui palju see tavakuulajale ära on kuulda, kui kellad päris sünkroonis ei jookse vms.
39 |
Terror
01.07.2007 14:06:06
x-plosion (odavam kaart) oli kunagi modikomp's saada, kuid x-meridian ning tulevane prelude vaevalt Eestisse jõuavad.
Kui on odavamapolne resiiver, siis usun, et tegu pole mitte ainult kellas vaid ka kogu ülejäänud kupatuses. Nii digi kui ka analoogahelas. Võid ju proovida korralikust allikast analoogsignaali lasta ning võrrelda seda digisignaali sisselaskmisega. Kui palju seda kuulda on oleneb kuulajast ning tehnikast. mõni hindab helitehnikat selle järgi mitmendale korusele ta muusikat kuulda on - tahan öelda, et igaleühele käivad asjad omamoodi ning vastuse peab sageli ise leidma.
91 |
NATAS999
01.07.2007 14:12:43
| Damn, ok, eks siis peab vist krieitivi peale jääma, ei viitsi mingi netist tellimisega n****ma hakata. Ja siis see xfi kaart ära tuunida vastavalt.
39 |
yb228a
| Kommentaarid: 231 loe/lisa |
192 |
Terror
15.07.2007 15:49:08
"Naised saunas" rääkisid, et kuu lõpuks peaks asja lettidel näha olema.
91 |
NATAS999
15.07.2007 21:23:08
| nad seal seda ka rääkisid, et kas eestis olevatele lettidele kah tuleb?
39 |
Terror
16.07.2007 09:45:02
| NATAS999 kirjutas: |
| nad seal seda ka rääkisid, et kas eestis olevatele lettidele kah tuleb? |
Kuna keegi praegu Eestis Auzeni tooteid ei müü, siis praeguse seisuga ma küll ei näe, et see siia banaanivabrikusse jõuaks 8) , kuid alati saab ju piiri tagant tellida. Kogemuste puudumisel võin ka abi pakkuda selles osas.
91 |
naips
25.07.2007 18:21:34
yb228a räägi kuidas kaar on ja mis sul seal taga on?
| Kommentaarid: 16 loe/lisa |
14 |
yb228a
26.07.2007 00:17:06
| naips kirjutas: |
| yb228a räägi kuidas kaar on ja mis sul seal taga on? |
Mis ma ikka oskan öelda. Audigy2 pealt üle minnes on muusika poole pealt sound tunduvalt mahlasem. Koos Sennheiser HD-595 klappidega lausa nauditav. Viimaste draivudega toimib Vista all ka 5+. Muusika kuulamiseks vägagi hea kaart. Samas kui rõhk rohkem mängudel siis vast ootaks X-Fi Prelude ära.
192 |
s4nder
31.07.2007 18:03:12
Nonii, juuli viimane päev käes ja helikaardist pole kipu ega kõppu. Tahaksin juba käpad taha saada sellele
yb228a
02.08.2007 23:34:26
Neil kipub jah uute toodete turgu laskmisega vähe rohkem aega minema kui algselt lubavad. X-Tension DIN lisakaardiga võttis ikka päris pikalt aega. Tundub, et Coming Soon on neil lemmik sõna kombinatsioon
192 |
s4nder
26.08.2007 10:53:23
| Uus press release siiski kinnitas, et testimine on läbi ja toomine on alanud. Seekord lubatakse väljalaset augusti esimeses pooles, eks näis, millal seda Eestisse on võimalik hakata tellima.
yb228a
26.08.2007 14:18:15
| Tundub, et Dataplaneetal asi saadaval hinnaga 199 EURi
192 |
PiXel
02.09.2007 11:54:30
| Selle hind pidi olema vist 200$, nii et kaart peaks varsti veel natuke odavam saama
| Kommentaarid: 182 loe/lisa |
170 |
PiXel
02.09.2007 13:34:31
| jup, aga 200$<199EUR. See oli mu postituse mõte
170 |
vallo
02.09.2007 14:35:32
| PiXel kirjutas: |
| jup, aga 200$<199EUR. See oli mu postituse mõte |
Ma ei tea miks, aga üsna tihti juhtub, et hinnad on pandud kursiga $=EUR
Ühesõnaga eurooplasi kooritakse.
66 |
Andrus Luht
itimees.ee
318 |
PiXel
04.09.2007 19:45:41
| Tahaks mingisugust review't ka näha, kuid ilmselt pole seda veel kuskil üleval. Vr-zones on pildid küll väljas, kuid mingeid teste pole. Tahaks näha, kuidas näitab kaart ennast X-Fi Elite Pro võrdlemisel
170 |
excalibur
05.09.2007 18:53:56
| elite proga pole ju võrdlust
262 |
Terror
05.09.2007 19:01:06
| Küll varsti ka mõni asjalikum ülevaade ilmub, need kaks esimest on küll parajad käkid tglt.
91 |
05.09.2007 19:26:34
| excalibur kirjutas: |
| elite proga pole ju võrdlust |
Ja mis sul seda Elite Pro võrdlust nii hirmsasti vaja on? .Selge see,et Elite Pro pole Audio jaoks parim vaid on mõeldud rohkem mängimiseks.See X-Meridian vs X-Fi Prelude võrldus hoolitseb juba audio osa eest ja mis mängudesse puutub siis on selge,et kuna Prelude põhineb suuresti samadel põhikomponentidel(sound processor,x-ram jne) siis ei saagi mingit väga kõrget vahet tekkida .Samas tundub review-de järgi,et Prelude on mängudes ikkagi parem 8) .
excalibur
05.09.2007 19:32:02
| ma sellellepärast küsisin, et keegi lubas võrdlust (aga seal polnud) muidu on mul savi
262 |
s4nder
11.10.2007 21:55:44
Kas keegi on selle kaardi juba ostnud ka? Dataplaneetast tundub hetkel otsas olevat, saatsin neile ikkagi meili, et kas üldse Eestisse saadavad. Pillipood.ee hinnakirjas seda pole, kuigi nad saaksid ka ehk välismaalt tellida. Ebay-s olevad poed toimetavad kauba kohale ainult Inglismaale.
Edit: vastus dataplaneetast:
Hello,
yes we can sell to foreign customers. We have sold couple of cards to Estonia, and the shipping cost has been about 25 (we are using Finnish Post). Currently we only have proforma invoice. We will send it to customers e-mail in pdf-format. After we have received the payment we will ship product and send a tracking code. Currently we don't have any soundcards in our stock but we are accepting pre-orders. After we receive enough orders we will make order to Auzentech.
Best regards,
Jari / Dataplaneetta.fi |
Kas keegi oskab selgitada, mida proforma invoice peaks tähendama? Invoice on arve küll, aga väljend kui selline on tundmatu mu jaoks. Siiani olen välismaalt Paypali või krediitkaardiga asju ostnud.
georgots
11.10.2007 22:06:29
PROFORMA INVOICE:
A Proforma Invoice (Proforma) is an official price quote, a step up from a published price list that allows the customer to present the Proforma Invoice to their Accounting Department and to arrange a prepayment procedure. It is most commonly requested by customers pre-paying orders via bank money transfer before shipping an order. It is used by customers to formalize the terms of sale (price, shipping, F.O.B. location, shipping date, etc.) and properly allocate and/or transfer the funds needed for the purchase.
| Kommentaarid: 10 loe/lisa |
9 |
Andrus Luht
itimees.ee
318 |
s4nder
11.10.2007 22:43:38
| Eks kui mitu inimest tellib, saab rutem see vajalik arv tellimusi täis küll. Siiski, mida reaalselt tegema peab, et see raha dataplaneetani jõuaks proforma invoice'i nõuete järgi? Kas nad ise suhtlevad pangaga ja raha kantakse automaatselt üle, või peab ise kandma kuidagi? Oeh, miks inimesed ei võiks lihtsalt Paypali ülekandeid vastu võtta.
Andrus Luht
itimees.ee
318 |
yb228a
17.10.2007 02:55:32
| s4nder kirjutas: |
| Siiski, mida reaalselt tegema peab, et see raha dataplaneetani jõuaks proforma invoice'i nõuete järgi? Kas nad ise suhtlevad pangaga ja raha kantakse automaatselt üle, või peab ise kandma kuidagi? Oeh, miks inimesed ei võiks lihtsalt Paypali ülekandeid vastu võtta. |
Pmst. siis Eesti keeli nad saadavad sulle mailiga tavalise arve kus on konto nr, IBAN ja muu selline. Sina lihtsalt maksad arve ära ja kõik. Teed pangast välismakse. Soovitavalt Sampo pangast kuna Dataplanetal on Soomes Sampos arve. Tuleb odavam.
192 |
s4nder
25.10.2007 18:01:38
| Tellisin kaardi ebay kaudu Itaaliast ja täna jõudis kohale. Eriti palju veel kuulanud pole, aga vahe X-Fi Xtrememusicuga on sees. Erinevates lauludes on edasiminek vaevumärgatavast üsna jahmatamapanevani. Üldiselt on kõik puhtam ja kirkam, bass on mõnevõrra prominentsem. Muidugi võib see kõik olla ka platseebo kõrgete ootuste tõttu, aga eks pikemaajaline kuulamine teeb asja selgemaks. 2900.- krooni täiesti väärt.
naips
25.10.2007 22:43:12
Oled sa ikka kindel ,et on seda väärt? Selle raha eest saab Revolution 7.1 ja jääb üle..
14 |
s4nder
26.10.2007 00:46:06
| Prelude'il on parem helikvaliteet ja ka X-Fi tuum mängude jaoks. Kõik on solid-state kondensaatorid, defaultis juba LM4562 op-amp front kanalis, DACid ja ADC-d vastavate tegijate high end. See on põhimõtteliselt X-Meridian paremate komponentide ja X-Fi tuumaga. Raske uskuda, et M-Audiol oleks eeliseid, kui kaarti kasutada vaid heli kuulamiseks, mitte salvestamiseks. Pealegi ei saaks seda mängudes kasutada, mis on minu jaoks tähtis.
