EvilKatarn
diivanilill
12.05.2007 19:52:14
Kellel Wii Sportsi veel ei ole?
On keegi?
Uhhuuu!!
Kõik kellel pole Wii Sportsi mingu sinna ritta...
*rohutirtsu laul*
81 |
Primary
Aeg maha 60
12.05.2007 20:50:01
| 2ra ole ebaviisakas-spammer amduud :d wiiga netis
| Kommentaarid: 39 loe/lisa |
24 :: |
EvilKatarn
diivanilill
12.05.2007 21:03:54
| Point oli selles, et Wii sports on IGA Wiiga kaasa pakendatud.. seda ei pea/saa juurde osta.. juhul, kui sa Jaapanis ei ela.. või elad sa Jaapanis?
81 |
Primary
Aeg maha 60
12.05.2007 23:39:01
Ma sain aru küll mida m6tlesid aga ma ei viitsinud sell neetud wiiga typeda aga peale tunnist duckhunti ple see enam probleem...point selles ,et myyakse bundle pakke kus ei ole sportsi :\
www.wiiplayable.com
24 :: |
EvilKatarn
diivanilill
81 |
Primary
Aeg maha 60
13.05.2007 16:22:54
Nonii Wii ownerid . Avastasin ,et just lasti välja viimane versioon progrest mis laseb sul mängida backupe ilma modchipita Kes palub see saab
24 :: |
Koppel^^
13.05.2007 16:27:12
| Jaaa nägin ühte tuti netis,raske nata...
EvilKatarn
diivanilill
13.05.2007 16:29:58
| Primary, oled kindel? Kõiki backupe?
81 |
Primary
Aeg maha 60
13.05.2007 16:37:15
ISEGI KÕIKI REGIOONE Hehe. Lähen linki kopima! Asjal on konks ka ikka
Edit:
Nautige (Link)
viimati muutis Primary 13.05.2007 16:39:03, muudetud 1 kord |
24 :: |
Koppel^^
13.05.2007 16:38:47
| Pead mulle ütlema... :*
Primary
Aeg maha 60
13.05.2007 16:42:13
Omg :/ sa eriti ähmi täis postitasin JUST ja 1sek pärast uus postitus, wtf Okei...vajuta lingile!
File Description
AloneTrio has announced that WabModCheap has finally reached its final version. While this is welcome news for Wii owners, it also serves as AloneTrio's last release for the Wii. According to him, he won't be working on WABModCheap anymore as it now has all the features he needed.
WabModCheap is a program that lets Wii owners load backups without actually installing a mod chip on their consoles. All you have to do to run it is to connect your Wii to your PC using parallel cables (4 wire Wii side) K0NKS. For more installation and usage instructions, please see the readme file included in the download.
Version 3.0 of WabModCheap still doesn't use hardcoded sync values since Wii syncing generally depends a lot on you parallel port speeds. One last thing, Alone Trio also says that you will sometimes need to turn your Wii off anf on again before re-using WABModCheap. Remember, read the readme file more more info. |
KOPPEL MIS TUTORIALI SA NETIS NÄGID? Mulle käib hetkel see Parallel line ajule :/ hakkan kõiki juhtmeid proovima ?
24 :: |
Koppel^^
13.05.2007 16:44:32
| Hmm raske asi.
Primary
Aeg maha 60
13.05.2007 16:47:07
| Pärast seda kui Koppel mulle selgeks tegi milline ajun**s see on :/ ... tellin parem modchipi 700eek eest.
24 :: |
metz
15.05.2007 08:51:35
| hea proge jah, lasin kah otse RCA otsast splittisin signaali kaolmeks nii et sain kõik värvid kätte, siis keerasin need otse viibrisse kus nad moodustasid vikerkaare, ning seejärel ühendasin fiibrile juba ülikiire firewire, vola oligi paralleel kaabel olemas. mängud jooksevad mis mühinal. aga kui omal niipalju nutti ei ole siis tuleb ikka õige kaabel tellida. ise sooviks seda component juhet aga ei oska tellida ei ole kogemusi tellimisega, vist peab ikka selle kah ise tegema, selleks ju vaja vist see paralleel kaabel enne fiibrit uuesti lahti võtta.
DODONPACHI
| Kommentaarid: 23 loe/lisa |
22 |
Rihostern
16.05.2007 13:34:04
MUl selline küssa , et kuidas saada Wii-ga internetti kolama ? Opera peaks toetama ja seda peaks saama sealt wii shop centerist vms a mul ütleb et see on unavailable
| Kommentaarid: 9 loe/lisa |
9 |
thomaz
16.05.2007 13:42:27
| Rihostern kirjutas: |
MUl selline küssa , et kuidas saada Wii-ga internetti kolama ? Opera peaks toetama ja seda peaks saama sealt wii shop centerist vms a mul ütleb et see on unavailable  |
Shopata saad, aga browser-it ei saa tirida?
_________________ NC |
| Kommentaarid: 87 loe/lisa |
83 |
juurastaja
16.05.2007 13:43:26
Sul on kindlasti kodumaaks pandud Eesti, muuda ära ja pane UK.
| Kommentaarid: 31 loe/lisa |
30 |
EvilKatarn
diivanilill
16.05.2007 14:21:32
| Kas kellegi teise arust ei näe Harry Potter&TOotP imelikul viisil hea välja?
81 |
Primary
Aeg maha 60
16.05.2007 15:54:35
| Pange kodumaaks Finland kes ei saa browserit tõmmata ... UK sobib ka. Amduud mitu Wii mängu sul on? :/
24 :: |
EvilKatarn
diivanilill
16.05.2007 16:07:21
| Ainult Twilight Princess.. mis siis?
81 |
Primary
Aeg maha 60
16.05.2007 18:04:14
| Eem on see hea mäng? On tal graafika Sportsist palju üle?
24 :: |
EvilKatarn
diivanilill
16.05.2007 18:07:51
Zelda teemaarenduse ja pildikese leiad siit...
Enamuse arust on see väga hea mäng... graafika kohta ei oska väga öelda.. suht erinevad stiilid siiski
Mulle väga ei meeldinud :/ IMO üks halvimaid Zeldasi üldse.. parem tiri Ocarina of Time (N64) Virtual Consolest...
81 |
Twar
16.05.2007 18:08:22
Mäng on vägagi hea. Võin kinnitada et graafika on (isikliku arvamuse kohaselt) palju hämmastamapanevam ja mängu stiil (minu jaoks) väga huvitav. Kui oled enne Zeldat mänginud, siis must-have. Kui mitte, siis võiks alustada...
Ei aga mulle meeldib.
_________________ SSBB FC: 0645-7287-8522. |
Flacko
Joonistusmaniakk!
17.05.2007 06:55:47
| Ootan juba pikisilmi, kui Charged välja tuleb, et ära osta.
| Kommentaarid: 199 loe/lisa |
166 |
