uus teema   vasta Hinnavaatlus »  Multimeedia- ja helifoorum »  Joost™ märgi kõik teemad loetuks
mine lehele 1, 2, 3, 4, 5, 6, 7  järgmine
skulmars
sõnum 01.03.2007 07:54:40 Joost™ vasta tsitaadiga
Uus lelu Skype tegijatelt - Joost
What is Joost™?
Joost™ is a new way of watching TV on the internet, which uses new and established technologies to provide the best of both the internet and TV worlds. We're in the process of making it as TV-like as we can, with programmes, channels and adverts. You can also see some things that we think will enhance the TV experience: searching for programmes and channels, for example, as well as social features like chat. There are many more new features to come!
How does it work?
Joost™ uses secure peer-to-peer technology to stream programmes to your computer. Unlike other TV and video-based web applications, it does not require users to download any files to their computers or browse through complicated websites.
Joost™ uses the H.264/MPEG-4 AVC digital video codec standard as implemented by CoreCodec's CoreAVC
Windows System requirements - WINXP
Joost runs well on most modern PCs equipped with the latest updates to the Windows operating system. Recommended minimum specifications are as follows:
    * Windows XP Service Pack 2 with DirectX 9.0c
    * Pentium 4 processor, 1GHz
    * 512Mb or more RAM
    * A modern video card with DirectX support and at least 32Mb of VRAM
    * About 500 MB free disk space
    * The Joost software is a 10 MB download, expanding to 30-35 MB on disk. The remainder is used as a cache
    * Broadband/ADSL (1Mbit/s downstream, 512Kbit/s upstream recommended, although lower speeds may well work)
Mac OS X System requirements
Currently, Joost runs only on the latest Macintosh computers equipped with Intel processors. Recommended minimum specifications are as follows:
    * Any Intel-based Mac running OS X 10.4
    * 512Mb or more RAM
    * The Joost software is a 13 MB download, expanding to 30-35 MB on disk. The remainder is used as a cache
http://www.joost.com/FAQ.html
viimati muutis skulmars 16.04.2007 17:54:58, muudetud 14 korda
Kommentaarid: 213 loe/lisa Kasutajad arvavad:  :: 3 :: 1 :: 177
limp
limp
sõnum 01.03.2007 08:23:15 vasta tsitaadiga
ma regasin oi kui ammu, siiani pole mingit parooli saanud, uuesti regades ütleb, et mail on kasutuses, et olete waiting listis.
Ärgake lapsed, maailm on hädaohus
Windows keskkond on nagu li*s - kõik teda ke*ivad aga keegi teda ei armasta!
noxton
noxton
sõnum 01.03.2007 08:23:53 vasta tsitaadiga
Kommentaarid: 186 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 169
Motiv8
Motiv8
sõnum 01.03.2007 21:36:08 vasta tsitaadiga
viimati muutis Motiv8 01.03.2007 21:47:39, muudetud 1 kord
Kommentaarid: 17 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 13
trv
trv
sõnum 01.03.2007 21:41:55 vasta tsitaadiga
no ega ise ka kutsest ära ei ütleks.
tundub huvitav lahendus olevat, loodetavasti ikka peagi ka lõppkasutajateni jõuab
I need a break. I just tried to read 'Oxford' as a hexadecimal.
Kommentaarid: 139 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 126
noxton
noxton
sõnum 02.03.2007 14:04:06 vasta tsitaadiga
edith: Number of invitations you can send: 0
Vermon
Vermon
sõnum 02.03.2007 21:35:44 vasta tsitaadiga
Viimati kui lehte lugesin siis oli vähestele testijatele saadetud mäki versioon, seda siis ootaks eriti icon_biggrin.gif
Kommentaarid: 14 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 12
Mr.Brown
sõnum 03.03.2007 13:13:45 vasta tsitaadiga
Ma regasin, siis läks umbes kuu kui kutse tuli. Ebameeldiv üllatus on see, et Mac'i taga töötab ainult Intel-protsessoriga. Nii, et proovimata veel.
noxton
noxton
sõnum 03.03.2007 13:24:22 vasta tsitaadiga
ausalt öeldes suht mõttetu icon_biggrin.gif veel...usun, et läheb paremaks, tuleb uusi ja paremaid kanaleid jne.
Cert85
Cert85
sõnum 03.03.2007 14:25:22 vasta tsitaadiga
Vabandan kui millestki valesti aru sai, aga kui see interneti põhine TV, et mis ta siis nagu ka neti kiirust nõuab?
sõnum 03.03.2007 14:56:53 vasta tsitaadiga
Krt regasin kah juba ligi kuu aega tagasi ära vist(ei mäleta) ja siiani pole essugi icon_neutral.gif
Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
Youtube lisa vene jama eemaldamiseks:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=11745846#11745846
Motiv8
Motiv8
sõnum 03.03.2007 15:45:29 vasta tsitaadiga
noxton kirjutas:
Suht nóus, et midagi erilist seal vaadata pole, kui siis ainult National Geographicust dokke.
Lugesin, et Joostil on tehtud leping Viacomiga ja äkki sealt tuleb, midagi head varsti...
skulmars
sõnum 03.03.2007 16:15:06 vasta tsitaadiga
viimati tuli igastahes päris suur ports korraga
edit: never say never
viimati muutis skulmars 03.04.2007 19:01:19, muudetud 1 kord
artur-
artur-
sõnum 04.03.2007 19:37:06 vasta tsitaadiga
Sooviks ka kutset.
Mismoodi see kutsetevärk toimib üldse? st et kes neid saavad?
Kommentaarid: 82 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 72
skulmars
sõnum 04.03.2007 19:41:46 vasta tsitaadiga
artur- kirjutas:
We're gradually expanding our network, and we'd like you to invite new people to come and join in. Every once in a while you will receive tokens, enabling you to send invitations to friends, family or anyone else who you think will enjoy watching internet TV
Dijital
Dijital
sõnum 19.03.2007 10:28:30 vasta tsitaadiga
heh, viskasin juba silda, kui nägin Joosti kirja oma mailboksis. aga see oli ainult kiri, et mind pole veel unustatud ja kutse tuleb paari nädala pärast.
sõnum 19.03.2007 17:50:12 vasta tsitaadiga
Dijital kirjutas:
olen juba 2 taolist kirja saanud paaripäevaste vahedega
sõnum 20.03.2007 23:24:15 vasta tsitaadiga
Keegi võiks kutse tahtjatest mingi listi teha,et siis kui mõnel beta kasutajal mõned kutsed vabanevad oleks kerge kutset saata icon_wink.gif .List võiks olla selle alusel kuna on kutset küsitud ajaliselt(varem küsinud eespool) ja kasutajanime taga võiks olla ka lihtsuse huvide meiliaadress icon_wink.gif .Lihtsalt üks väike mõte...andke teada mida arvate 8) .
skulmars
sõnum 20.03.2007 23:26:06 vasta tsitaadiga
mina arvan, et kui mul on mõni kutse üle, siis ma küsin siin teemas mitte ei hakka mingit listi läbi kammima. postid "saatke mulle ka" on suht mõttetud imho icon_redface.gif
sõnum 20.03.2007 23:34:34 vasta tsitaadiga
skulmars kirjutas:
mina arvan, et kui mul on mõni kutse üle, siis ma küsin siin teemas mitte ei hakka mingit listi läbi kammima. :
Ja kui ütled,et sul on kutseid ,siis tuleb 20 posti stiilis "saada mulle kaa".Millepoolest see parem on,kui esimeses postis olev kutse tahtjate list icon_question.gif icon_smile.gif
skulmars kirjutas:
Sellepärast pakkusingi listi välja.Kes ikka viitsib siin postide vahel neid kutse tahtjaid ja meiliaadresse vaadata.List oleks IMO mugavam 8) .Kui keegi tahab kutset lisatakse ta lihtsalt esilehel olevasse listi.Kui keegi on kutse kätte saanud kustutatakse jälle listist ära jne icon_rolleyes.gif .
skulmars
sõnum 20.03.2007 23:37:32 vasta tsitaadiga
tomorrow kirjutas:
skulmars kirjutas:
skulmars kirjutas:
jumala eest, mis saaks selle vastu olla kui KEEGI tegeleda viitsib. siin on neid kutseid vähe targem jagada kui lihtsalt tuttavatele. samas pole JOOSTI näol hetkel tegu veel mingi eriti kasuliku jublakaga just...
artur-
artur-
sõnum 21.03.2007 00:03:10 vasta tsitaadiga
Järgmiseks teeme loosikasti. Tuleb kohale isik kes vaatab et sohki ei tehta ja siis kastist tõmmatakse kinnisilmi välja nimed kes endale kutse saavad thumbs_up.gif
Motiv8
Motiv8
sõnum 21.03.2007 07:58:37 vasta tsitaadiga
20/03/07: Last call for beta test on joost.com
We're reaching another big milestone this week. After months of testing with many thousands of users, we're ready to move Joost on to the next stage of its development.
In preparation for this we're closing down applications for the beta testing program on the website at the end of Thursday (GMT). Between this time and the public availability of Joost, access will be by invitation from beta testers only.
So this is last call to apply via the website!
The good news is, that everyone who applies before we close will get access to try out Joost within the next couple of weeks - how is that for a treat? icon_eek.gif)
As you can might imagine, this is a very exciting moment for us. A big thank you to everyone who has helped to bring us this far - and to the rest of you, we look forward to inviting you to try out Joost for yourself very soon.
noxton
noxton
sõnum 21.03.2007 13:21:48 vasta tsitaadiga
essu, kuidas neid kutseid juurde peaks tulema? mul koguaeg ''0''
Motiv8
Motiv8
sõnum 21.03.2007 15:43:46 vasta tsitaadiga
noxton kirjutas:
Sama siin, peab vist 24h joosti lahti hoidma...
uus teema   vasta Hinnavaatlus »  Multimeedia- ja helifoorum »  Joost™ mine lehele 1, 2, 3, 4, 5, 6, 7  järgmine
