EvilKatarn
diivanilill
10.02.2007 21:17:37
[Wii] The Legend of Zelda: Twilight Princess |
Kuna digitala failib Nintendo osakonnas võtan ma mujalt kirjelduse.
| Gamespot kirjutas: |
| Like most other Zelda games, Twilight Princess is a retelling of the same basic tale, though this one is not without its twists. There's a princess named Zelda, a land called Hyrule, and a world that's on the verge of destruction if you don't do something to save it. In this installment, there's a darkness creeping across the land, locking it in the eternal dusk of the twilight realm. You play as Link, a humble, pointy-eared boy who lives in a far-off village and herds goats for a living, yet he ends up getting involved in the conflict. The twilight that's infected the land is an alternate reality of sorts, serving as the game's equivalent of A Link to the Past's dark, alternate world, or in some cases, serving the same purposes as the adult Link/child Link differences in Ocarina. The difference here is that when you're in the twilight, you're transformed into a blue-eyed wolf. |
Ise olen siiamaani mänginud umbes 14 tundi ja väga meeldib... Hundiga osad on veidi tüütavad aga kui Linkiga ringi kargad dungeonides siis on mäng väga hea... Dungeonid on umbes 3-7x suuremad kui Ocarina of Times.
81 |
Godhand
16.02.2007 17:51:23
Kuna ma ise suurem Zelda-fänn ei ole, aga Wii peal midagi vaja mängida on, siis sai ka Twilight Princess ostetud. Hetkel olen täpselt niikaugel, et esimene hundiosa on läbi ja olen taas inimene. Peab mainima, et kuigi mäng on ilus, on ta siiani olnud igav. Võitlused ei ole mingit skilli vajanud, platformi-stiilis hüppamine toimub automaatselt ja peategelane jälle ei räägi.
Eks ajab parema seiklus-actionmängu puudumisel asja ära.
| Kommentaarid: 81 loe/lisa |
76 |
vabarna
17.02.2007 10:53:24
| Godhand kirjutas: |
| peategelane jälle ei räägi. |
WTF miinus see selline on? Kui mul on valida, kas peategelane pidevalt väljastab nätsunäriva surfari dialektis klieesid a la "I will avenge my father's death!" (nagu enamikus JRPGdes) või on vait, siis mul ei ole küll raske seda valikut teha.
viimati muutis vabarna 17.02.2007 11:36:44, muudetud 1 kord |
| Kommentaarid: 14 loe/lisa |
14 |
EvilKatarn
diivanilill
17.02.2007 10:55:36
| Aga kõik mängud kus peategelane ei räägi on flopid ju... Half-Life seeria on flop... KotOR jne... you get the point
81 |
17.02.2007 11:03:57
| amddude kirjutas: |
| Aga kõik mängud kus peategelane ei räägi on flopid ju... Half-Life seeria on flop... KotOR jne... you get the point |
Ei "geti" "pointi", seleta täpsemalt.
Ma pole Wii Zeldat mänginud, enda kogemused jäävad NESi ja SNESi peal olnud Zeldade aegadesse(+ üks Gameboy stiilis) ning mulle isiklikult meeldib just selline lakooniline joon, kus ise vaikselt liigud läbi keskkonna ja jälgid, mis sünnib, vajadusel tegutsed mitte ei loobi sõnu, ei jutusta. Las teised räägivad, sina oled tegude peal väljas. Täpselt sama ka Half-Life seeriaga(ja ka Quake 2/4'ga), kus tähtis osa on atmosfääri ülesehitamisel ja stoori jutustamisel. Kus sa ise tegutsed, vahepeal kuulad ning kõik ei tehta ette ära, ei nämmutata läbi. Ise peab fantaasiat omama.
Enamus vanakooli mänge olid sellised, kus teksti oli minimaalselt. Tegelikult maailm ja idee formuleerus su peas, ekraanil toimuv andis alguse, edasi pidid ise tegutsema.
147 |
EvilKatarn
diivanilill
17.02.2007 11:26:59
| Mark0, point on selless et mõndadel juhtudel teeb peategelase vaikimine mängu paremaks
81 |
Godhand
17.02.2007 12:01:15
| vabarna kirjutas: |
| Godhand kirjutas: |
WTF miinus see selline on? Kui mul on valida, kas peategelane pidevalt väljastab nätsunäriva surfari dialektis klieesid a la "I will avenge my father's death!" (nagu enamikus JRPGdes) või on vait, siis mul ei ole küll raske seda valikut teha.  |
Siis võiks Nintendo valida Linki hääle jaoks mõne nätsu vihkava surfari? Ma ei mõtlegi tegelikult häälenäitlemist, vaid kasvõi mingite kirjutatud dialoogide eksisteerimist, nagu juba kellegi poolt mainitud KotoRis. Zelda tahab ju RPG olla? Miks siis mitte lasta Linkil Midnaga ka suhelda, küsida, mis toimub, mitte lihtsalt lasta tal enda seljas ratsutada jne.
Küllap suunatakse kohe jälle minu pihta sarkastilise alatooniga postitusi, sest ma julgen mängu suhtes negatiivsemat hoiakut omada
Edit: Mõtelge kasvõi selliste mängude peale, nagu Vagrant Story, Final Fantasy, Tales of Phantasia, Splinter Cell, Conker's Bad Fur Day. Võtke sealt igasugune peategelase-poolne suhtlemine ära ja mis jääb järele? Igavus.
76 |
17.02.2007 12:34:38
| amddude kirjutas: |
| Mark0, point on selless et mõndadel juhtudel teeb peategelase vaikimine mängu paremaks |
Seda ma rääkisingi.
147 |
EvilKatarn
diivanilill
17.02.2007 12:59:15
Godhand, misajast üritab LoZ olla RPG? See on mulle küll uudis. Pigem on tegu Action Adventurega. RPG on mäng kus sa arendad (loe leveldad) oma tegelast ja paned mingeid erinevaid rüüsid selga, upgraded oma skille jne.
viimati muutis EvilKatarn 17.02.2007 13:31:27, muudetud 1 kord |
81 |
beastbeats
17.02.2007 13:10:08
Punkt amddude'le
M: Uus/pakendis Fjern Fjork Titanium Forked Spoon - 10€ |
| Kommentaarid: 366 loe/lisa |
282 |
Auron
17.02.2007 13:41:07
| amddude, ei ole RPG tingimata mäng kus sa leveldad, upgraded ja sitaks equt topid selga. RPG all üldisemalt mõistetakse mängu kus võtad ühe tegelase rolli kelle silmeläbi seletatakse lahti stoori. See kas saad vehkida triple dragon mõõgaga või kanda teemantrüüd pole esmajärguline.
133 |
EvilKatarn
diivanilill
17.02.2007 13:54:40
| Auron, saan su mõttest aru aga siis oleks ju ka FEAR RPG või mõni muu taoline mäng kus oled koguaeg 1 tegelane ja seletatakse stoorit. Mingisugune kindlam punkt peab ju olema mis teeks mängu RPGks ja minu poolest olgu see igalühel isiklik... näiteks Final Fantasy on raudselt RPG... sa leveldad, upgraded tegelast ja võitluses annad erinevaid commande... Lord of the Rings: Return of the King oleks Action RPG kuna ju arendad tegelast, õpetad trikke AGA mäng ise oma stiili poolest on action ju kuna kakled ja loobid mõõgaga vaenlastel piki lõusta nii et soolikaid lendab. Zelda jääb siiski minu jaoks, ükskõik mis platformil ta on, Action Adventureks kuna on actionit ja ka seiklust (pead leidma igast jubinaid ;Wind wakeris aga sõidad läbi pikki vahemaid saartel jne)ka GBA omadel on sama stiil... jooksed ringi, kütad karvastele perse vahele, otsid igasugu jubinaid jne...
81 |
Godhand
17.02.2007 20:12:20
Okei, mis iganes See kas ta on minu meelest RPG ja teiste meelest mitte ei muuda minu seisukohti mitte kuidagi. Lihtsalt minu arvates annaks Zeldale palju rohkem juurde see, kui peategelasel oleks mingi paremini edasi antud iseloom ja arvamused. TP-s ta lihtsalt noogutab/mühatab ja läheb vooluga kaasa. Arusaadavalt on tegu Zelda-sarja traditisiooniga, kuid ehk oleks aeg katsuda seda muuta?
76 |
EvilKatarn
diivanilill
17.02.2007 20:27:14
| Godhand, oehh... mängi edasi ja sa saad teada milline iseloom tal on. Pole vaja panna rääkima tegelast kellel poleks niguinii midagi tarka öelda... ja pealegi kui sa niiväga tahad näha kuidas Link räägib siis palun väga : http://youtube.com/watch?v=Q7g59KzZkY0
81 |
vabarna
18.02.2007 22:13:13
| Godhand kirjutas: |
Küllap suunatakse kohe jälle minu pihta sarkastilise alatooniga postitusi, sest ma julgen mängu suhtes negatiivsemat hoiakut omada  |
Kahju, et sa oma vestluskaaslastest juba ennetavalt nii halvasti arvad...
14 |
Auron
19.02.2007 10:04:27
| vabarna kirjutas: |
| Godhand kirjutas: |
Kahju, et sa oma vestluskaaslastest juba ennetavalt nii halvasti arvad... |
Mitte ennetavalt vaid eelnevast kogemusest.
133 |
Roberto57
21.03.2007 01:05:13
| Auron kirjutas: |
| vabarna kirjutas: |
| Godhand kirjutas: |
Mitte ennetavalt vaid eelnevast kogemusest. |
Jah, ikka leidub keegi kellele ei mahu pähe, et inimestel on erinevad maitsed ja soovid ja kui siis arvamus avalikkuse ette tuuakse saabki vaesekesest hoopis rünnakute ohver kuidas iganes ta ka vastu ei argumenteeriks. Kahjuks tavaline trend foorumites.
Flacko
Joonistusmaniakk!
21.03.2007 09:21:49
Damn, kuidas saab edasi sealt Vulkaani maailmast? Ma olen need 2 võtme tükki üles leidnud, aga edasi? Kus see 3lmas on?
Üks oli maadlemisea, nagu see Paks onu õpetas. Teine oli see, kus sa pidid selle värdja laavasse koguaeg viskama
_________________ Flacko, the nutty weasel who loves blue cheese, Blyth's Reed Warblers, Thrush Nightingales and Devin Townsend! |
| Kommentaarid: 199 loe/lisa |
166 |
terry
21.03.2007 09:34:40
| Flacko kirjutas: |
Üks oli maadlemisea, nagu see Paks onu õpetas. Teine oli see, kus sa pidid selle <b>piixu</b> laavasse koguaeg viskama |
Otsi Zelda Twilight Princess Official Guide. Piisavalt üldsõnaline, et mitte olla tüüpiline walkthrough ja samas piisavalt põhjalik, et mõnest tüütust kohast üle aidata.
| Kommentaarid: 6 loe/lisa |
EvilKatarn
diivanilill
81 |
Jim piim
21.03.2007 18:13:45
Kasutan ise ka seda õpetust ja olen väga rahul
keilakaz
31.03.2007 15:43:10
Ostsin koos wiiga ja tegin umbes 50 tunniga läbi..
Õpetus ainult heart piecede leidmiseks..
Soovitan kõigile kes pole veel mänginud.
Zelda on Action Adventure ja jääb kah selleks...
Ja ma ei taipa, mis värk on selle Voice actingu puudumise üle vinguda??
Tahate väga kuulata ebameeldivad ameeriklaste pealeloetud jura? Tekst on palju parem, raisata ruumi diskil sellise jura peale ning pärast saab VEEL ROHKEM vinguda kui asi halvasti välja kukkus. Mõttetu whine.
O
05.12.2008 20:29:09
Kellelgi üle pole toda mängu?
_________________ PS, kui teemades ei vasta |
| Kommentaarid: 76 loe/lisa |
69 |
