ossa
04.01.2007 14:00:26
Opteron 170 @ 2880 MHz
2*1024 pc 3200 @ 205 MHz (2,5-3-3-8)1T
Asus K8N-E
32MB=29,046 ja
@3040 MHz
32MB=27,562
| Kommentaarid: 20 loe/lisa |
20 |
HaVoC
05.01.2007 01:10:59
| HaVoC kirjutas: |
CPU: AM2 X2 4200+ (2200MHz)
2*1024MB DDR2 800 4-4-4-12 Corsair dual
Mobo: Asus M2N32-SLI Deluxe WiFI
Score
32M = 38.624 sec |
EDIT:
Väike kellamine X2 4200+ @ 2750MHz
Score
32M = 31.124 sec
Püüan saada parema jahutuse, ehk kannatab veel tõsta klokki.
_________________ http://s1.ee.bitefight.org/c.php?uid=28977
Kinnisidee -> www.kalonline.com |
| Kommentaarid: 7 loe/lisa |
toomasy
14.01.2007 17:48:09
CPU: Sempron 2500+ (1750MHz=166Mhz*10,5)
Mälu: 512MB 333MHz 2,5-3-3-7
Mobo: Asus A7V8X-X
tulemus = 116,843
Väike ülekiirendamine ja...
CPU: Sempron 2500@2131MHz (203*10,5)
tulemus = 80,796
| Kommentaarid: 40 loe/lisa |
39 |
23.01.2007 00:02:20
32M - 52,641 sec
Intel Core 2 Duo T5500 1,66Ghz FSB 667Mhz 2MB (Merom 65nm)
Apacer 2GB DDR2 RAM 667Mhz PC2-5300
profiili masinaga...
313 |
Chaza!
23.01.2007 21:01:02
32M- 48,968s
teine katse 48,53s
kolmas 48,062s
Intel(R) Core(TM)2 CPU T5600 @ 1.83GHz
COMPAL HGL3X
Mobile Intel Calistoga-G i945GM
1014 MB (DDR2-667 DDR2 SDRAM)
_________________ Linux - Future
1984 was not supposed to be instruction manual |
| Kommentaarid: 59 loe/lisa |
53 |
HaVoC
Alari A.
| Kommentaarid: 670 loe/lisa |
546 |
jarmo15
ebuprofen
04.03.2007 13:18:11
AMD X2 3800+@2805MHz (s939 BOX jahutus )
DDR 2x512MB 187MHz 2-2-2-5
Asus A8N SLI Deluxe
30.031
67 |
Chaza!
10.03.2007 20:55:14
C2D T5600 siis
53 |
Le Inc
10.03.2007 22:12:01
30,515 sekki.
CPU Found: CPU0
Name: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
Speed: 2772 MHz
L2 Cache: 512 KB
CPU Found: CPU1
Speed: 2771 MHz
L2 Cache: 0 KB
Kiirem kui rohkem kellatud Core 2 Duo 8)
| Kommentaarid: 56 loe/lisa |
54 |
DonNiger
10.03.2007 22:40:38
Jätan hetkel tulemuse enda teada, pärast muudan teksti ära
E: lihtsalt mälude katsetamiseks tulemuseks 25,109
E6700@3500 PC5400@700 Mhz, 4-3-3-4-2T
E2: 24,219 (8x450)
E6700@3600
PC5400@720 Mhz, 4-4-4-10-1T
E3: 24,141(10x360)
E6700@3600
PC5400@720 Mhz, 4-4-4-10-1T (synk)
viimati muutis DonNiger 11.03.2007 02:27:02, muudetud 4 korda |
116 |
WäntWõll
make.believe
10.03.2007 23:11:40
link :: 27.47 sec
OS Vista
Opteron 165 @ 2816
XMS TWINX1024-4400C25PT
A8N-SLI Premium
WD Raptor 36
Siia unustasin visata,test ise lastud 26/02/2007 22:01
300 |
rallitaja
11.03.2007 00:07:46
32 M - 70,124 sec
AMD Athlon 64 2800+ NewCastle @ 2404 MHz 1,5V
512 MB AM1 PC3200 @ 267 MHz 2.5-3-3-7 1T 2,7V
EPoX EP-8NPAJ
| Kommentaarid: 19 loe/lisa |
15 |
Jaan
11.03.2007 22:11:12
tabel esilehel uuendatud.
et ta liiga suur poleks jätsin ainult 15 esimest tulemust alles.
üks unustatud tulemus kah:
Intel E6700ES@ 490x10 (4,9GHz) 1,675V/LN2 -90 -100*C
Intel Bad Axe2 Vcore, Vmch modded, 1:1, Vmch=2,1V
2x512MB A-Data PC6400@DDR980 CL5-4-4-12/2,28V
wprime 32M- 17,812s
verification link , hwbot link
123 |
DonNiger
116 |
Jaan
11.03.2007 22:38:55
see on proge/hwbot-i bugi, tegelikult on asi ok.
Kui väga huvitab siis võid küsida proge looja käest:
Walter Eigner, walter_ ät_wprime.net
123 |
Kristoferr
216 |
antikondor
| Kommentaarid: 48 loe/lisa |
45 |
WäntWõll
make.believe
17.03.2007 15:53:58
Sul vist mälud panid reha aga cpu ise on päris hea lennuk
Proovi sirts madalama klokiga aga kangemate timmidega vaat mis tuleb
'Mul tekalt 26,xx ja aga pole aega saanud et uppida
kuigi klokk on 29xx+
OS on muidugi vista
300 |
antikondor
17.03.2007 16:10:00
Mälud ise 2x1gb ocz jurakad mis eriti kitsaid taiminguid ei taha, aga küll jõuab neid proovida. Muidu mälu klokk sel hetkel oli täitsa kena 272mhz 3-4-3-8
Edit: sai see 1024m test kah tehtud http://www.hwbot.org/compare.do?resultId=589490 . Tänaseks siis lõpetan benchimis, kahju et talvehooajal halvem mobo oli, muidu oleks vast isegi paremaid tulemusi saanud.
_________________ Olen jah muusika suhtes elitaarne sitapea
000 WHILE hangover
001 drink beer
viimati muutis antikondor 17.03.2007 16:37:07, muudetud 1 kord |
45 |
WäntWõll
make.believe
17.03.2007 16:35:56
ega jah sealt allapole pole vist minna
sebi endale mingid bh5 või tccd raketid
endal tccd raketid aga cpu paneb 2960 saba,veega nagu kannima ei hakka 24/7 sisteemiga
mälu on muidugi proovitud ja ddr306mhz on veel tegusad cpu aga nii ei arva
300 |
antikondor
17.03.2007 16:39:48
| dreamx kirjutas: |
mälu on muidugi proovitud ja ddr306mhz on veel tegusad cpu aga nii ei arva  |
Mälud peaks olema uccd kividega muidu ja 2-3-3-6 on 200mhz teinud küll, aga ei usu et see parem olekskui 272mhz nõrgematel ajastustel. Muidu pole mälusid kuigi palju testinud aga eks homme või esmaspäeval vaatan kas annab midagi rohkemat välja pigistada.
000 WHILE hangover
001 drink beer |
45 |
WäntWõll
make.believe
17.03.2007 16:50:39
Kuna see proge on mälu tundlik siis provi 2.8 cpu-ga aga mälu aja allapooole,ehk tekib mingi muutus
Kõige müstilisem on ,et kui hakkan peale pigistama siis number läheb(minul) järjest pissasemaks
300 |
antikondor
45 |
