uus teema   vasta Vaidlused »  Võitlustanner »  wPrime- multithreaded bencmark märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, ... 9, 10, 11  järgmine
Markx
Markx
sõnum 10.12.2006 01:34:00 vasta tsitaadiga
wPrime 32M - 55,719 sec
http://www.tsa.planet.ee/wPrime.JPG
Kommentaarid: 92 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
Anti
sõnum 10.12.2006 03:51:15 vasta tsitaadiga
Intel Celeron M 420 1,6GHz
512MB DDR533
107,922
AJ
AJ
sõnum 11.12.2006 15:22:41 vasta tsitaadiga
wPrime 32M 158,953 sec
ivar43
sõnum 12.12.2006 06:53:15 vasta tsitaadiga
w-Prime v.1.28
skoorid
32MB (speed Test) - 31,906 sec
1024MB (stability Test)- 1016,563 sec
/ 12-12-2006 / 4:08 /
CPU Found: CPU0
Name: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+
Speed: 2640 MHz
L2 Cache: 512 KB
CPU Found: CPU1
Speed: 2639 MHz
L2 Cache: 0 KB
? millegi pärast Everest näitab CPU x2 5000+
aga tegelt on AMD x2 4600+ / ( mitte AM2)
everest info :
CPU Properties
CPU Type DualCore AMD Athlon 64 X2 5000+
CPU Alias Manchester
CPU Stepping BH-E4
CPUID CPU Name AMD Athlon(tm) 64 X2 Dual Core Processor 4600+
CPUID Revision 00020FB1h
CPU Speed
CPU Clock 2640.0 MHz (original: 2400 MHz, overclock: 10%)
CPU Multiplier 12.0x
CPU FSB 220.0 MHz (original: 200 MHz, overclock: 10%)
Memory Bus 220.0 MHz
DRAM:FSB Ratio CPU/12
CPU Cache
L1 Code Cache 64 KB per core (Parity)
L1 Data Cache 64 KB per core (ECC)
L2 Cache 512 KB per core (On-Die, ECC, Full-Speed)
Motherboard Properties
Motherboard Name Asus A8N32-SLI Deluxe
Chipset Properties
Motherboard Chipset nVIDIA nForce4 SLI X16, AMD Hammer
Memory Timings 3-3-3-8 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
SPD Memory Modules
DIMM1: Corsair CMX512-3200C2 512 MB PC3200 DDR SDRAM
(3.0-3-3-8 @ 200 MHz)
(2.5-3-3-7 @ 166 MHz)
(2.0-2-2-6 @ 133 MHz)
DIMM2: Corsair CMX512-3200C2 512 MB PC3200 DDR SDRAM
rewer
rewer
sõnum 12.12.2006 15:15:50 vasta tsitaadiga
32M
39,046 sec
X2 3800+@2200MHz
Kommentaarid: 1302 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 919
1dumbpcuser
sõnum 12.12.2006 15:55:15 vasta tsitaadiga
32M: 49,563 sek
1024M: 1564,062sek
Ordi läppariga (GL30): T2400, 1GB DDR2-533MHz, 7600Go, 120 Gb
M: Gigabyte B650M-DS3H
Kommentaarid: 100 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
antikondor
antikondor
sõnum 15.12.2006 18:18:53 vasta tsitaadiga
Sai ome uut opteron 165 piinatud veidi.
9x311 1.4v
Mälud 200 mhz 2.5-3-3-7
Aeg 30,375 sec
http://www.hwbot.org/result.do?resultId=562639
Olen jah muusika suhtes elitaarne sitapea
000 WHILE hangover
001 drink beer
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 45
okas5
sõnum 15.12.2006 20:41:48 vasta tsitaadiga
Celeron 2.66 GHz, 256 mb pc2700 ram. 130,969 sec thumbs_up.gif icon_lol.gif icon_lol.gif
Võtan suurtes kogustes tagastamata laenu ja muid vidinaid. Kõik pakkumised PSi thumbs_up.gif
Kommentaarid: 11 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 6
rewer
rewer
sõnum 15.12.2006 23:18:11 vasta tsitaadiga
kodulehelt ei leidnud- win98-ga vist ei tööta?
WäntWõll
make.believe
WäntWõll
sõnum 16.12.2006 00:15:57 vasta tsitaadiga
Opteron 144 SingleCore @ 3012mhz
2x512 ram 2.5,3,3,3 @ DDR430mhz
Asus A8n-SLI Premium
http://www.hwbot.org/compare.do?resultId=562690
PS. võtsin vabaduse ja liitusin HWBot-is HinnaVaatluse Teamiga.
hashi
sõnum 16.12.2006 00:24:05 vasta tsitaadiga
P4 2,8GHz HT
1GB PC3200 DDR 2,5-3-3-7
101,15 sec
Seniks...
Hashi
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 30
SirVorkars
SirVorkars
sõnum 16.12.2006 01:53:57 vasta tsitaadiga
x2 3800+
ja aeg 41,859
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 1 :: 3 :: 56
CoiL
CoiL
sõnum 16.12.2006 02:24:16 vasta tsitaadiga
dreamx kirjutas:
päris hea skoor ju 1core kohta beer_yum.gif PS! oleks tore kui Jaan HV wPrime tabelit uuendaks.
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
okas5
sõnum 16.12.2006 03:58:55 vasta tsitaadiga
Sõbra AMD Turion 1.6ghz, 1gb ram läpakas pani mu 2.4 kellule pika puuga icon_biggrin.gif
Läpakal 55,219 sec
WäntWõll
make.believe
WäntWõll
sõnum 16.12.2006 04:13:26 vasta tsitaadiga
60,047 sec
Opteron 144 SingleCore @ 3066mhz
2x512 ram 2.5,3,3,6 @ DDR439mhz
Mingi hetk proovin veel(asi on põhimõttes juba)
http://www.hwbot.org/compare.do?resultId=562733
ivar43
sõnum 16.12.2006 07:15:00 vasta tsitaadiga
sai veits seadeidid muudetud, teised m2lud prooviks ja juba tuli -8 kymnendiku alla icon_smile.gif
uus skoor 31,202 sec
uued seaded .
CPU Found: CPU0
Speed: 2700 MHz
L2 Cache: 512 KB
CPU Found: CPU1
Speed: 2699 MHz
L2 Cache: 0 KB
CPU Speed
CPU Clock 2700.0 MHz (original: 2400 MHz, overclock: 13%)
CPU Multiplier 9.0x
CPU FSB 300.0 MHz (original: 200 MHz, overclock: 50%)
Memory Bus 192.9 MHz
DRAM:FSB Ratio CPU/14
SPD Memory Modules
DIMM1: OCZ OCZ4001024DCGEVX-K 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz)
DIMM2: OCZ OCZ4001024DCGEVX-K 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz)
okas5
sõnum 16.12.2006 09:14:08 vasta tsitaadiga
AMD Turion 64 x2, 1gb ram sain nüüd 54.672
Edit:
tõstsin celeroni 1.1ghz, mälud sama = 178,998 seci. 100mhz kiirem ja 20 sec kohe tulemus paranes icon_biggrin.gif
Edit: Näppisin celeroni mäludega ka midagi, sai seki alla thumbs_up.gif
Edit:
Hardi
Hardi
sõnum 16.12.2006 09:35:15 vasta tsitaadiga
Celeron 2.4 @ ~3.2GHz
512MB DDR PC3200 2.5-3-3-7 200mhz
94.828 sec
Kommentaarid: 82 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 68
rewer
rewer
sõnum 16.12.2006 13:19:48 vasta tsitaadiga
3000+ winchester@1980MHz 87.062
Celeron 466MHz soc370 449.417
win98 all tööle ei saanud.
Rutz
sõnum 16.12.2006 14:17:50 vasta tsitaadiga
Rutz kirjutas:
Celeron M 360J (C0) @1873MHz (14x133) 1,28v
Asus P4GPL-X + Asus CT-479
2x256MB Winbond BH5 200Mhz 2-2-2-5-2
92,296 sec
Celeron M 360J (C0) @2342MHz (14x167) 1,35v
2x256MB Winbond BH5 167Mhz 2-2-2-5-2
73,859 sec
Kommentaarid: 401 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 345
ebuprofen
ebuprofen
sõnum 16.12.2006 14:39:49 vasta tsitaadiga
AMD X2 3800+@2722MHz (s939 BOX jahutus icon_biggrin.gif )
DDR 2x512MB 181MHz 2-2-2-5
Asus A8N SLI Deluxe
33.078
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 67
antikondor
antikondor
sõnum 17.12.2006 13:20:15 vasta tsitaadiga
Sei siis veel paarkümment megahertsu prosest välja pigistatud ning tulemus lõpuks alla 30 sekundi.
http://www.hwbot.org/compare.do?resultId=562862
29.77 sec
000 WHILE hangover
001 drink beer
ranel
sõnum 18.12.2006 10:54:47 vasta tsitaadiga
sai ka natuke proovitud, aga mitte veel räige klokiga. Aga vaadake, mida ütleb see wPrime ja mida ütleb cpuz prose kiiruse kohta. Muidu on veel see, et kui ma sätin kahe tuuma peale, siis ma võidan ca 0.1sec. icon_rolleyes.gif
CPU:AMD Athlon™ XP Thorton 2400+@2631mhz
MOBO:Epox 8RDA+ rev1.1
MEM Dualis:2xCorsair 3200xl (2.2.2.5) 256Mb@175 (2-2-2-2)
Jaan
sõnum 18.12.2006 23:55:53 vasta tsitaadiga
edetabel nüüd esimesel lehel.
viimati muutis Jaan 19.12.2006 01:02:41, muudetud 1 kord
Kommentaarid: 143 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 123
ceemic
24/7@kalal
ceemic
sõnum 19.12.2006 00:39:43 vasta tsitaadiga
Opteron144@3277MHz
2*512MB@273MHz@2-2-2-5 1T
51.640sek 8)
uus teema   vasta Vaidlused »  Võitlustanner »  wPrime- multithreaded bencmark mine lehele eelmine  1, 2, 3, ... 9, 10, 11  järgmine
