Paganarh
13.07.2005 08:48:42
Supreme Commander |
Hea uudis kõikidele vanakestele kes fännasid Total Annihilation'it või siis lihtsalt RTS zhanri kummardajatele.
Nimelt selline firma nigu Gas Powered Games teeb hr Chris Taylor'i käe all uut mängu Supreme Commander. Põhimõtteliselt võib seda nimetada Total Annihilation II'ks.
Ei hakka mingeid quote ja featuresid välja tooma, keda huvitab lugege ise - gamespot preview
imo aasta parim uudis
| Kommentaarid: 15 loe/lisa |
Ho Ho
13.07.2005 10:11:34
banaanitants
Polegi ammu ühtki korralikku RTS'i olnud, SC/TA ja väikeste mööndustega WC3 olid minu arvates viimased. Ehk sellest tuleb midagi sama asjalikku,
Senikaua võib aega veeta TASpring'i mängides
http://taspring.clan-sy.com/
Kahjuks vist hetkel küll kodukas maas kuid paari pilti saab vaadata siit
http://www.flipcode.com/cgi-bin/fcarticles.cgi?show=65371
[edit]
Link veidi rohkemale infole:
http://archive.gamespy.com/landing/supremecom/
Paremad palad esialgsest artiklist
"You gotta have nukes!" Taylor chortles, selecting the nuclear option and clicking his mouse near a naval fleet. Assuming a nuclear missile isn't intercepted by anti-missile systems, the devastation it causes is unreal. The epicenter vaporizes what seems like miles of terrain in a single brilliant flash, and then the shockwaves radiate out. The first one is brutal, but stronger units can survive the rushing arc -- fast units can even escape the blast. The second, slower-moving shockwave creeps along devouring nearly everything in its path, creating tsunami waves at sea and scorching a ring of earth on land. In the center of the devastation the expected mushroom cloud slowly rises -- soon to be followed by many more if your opponent retaliates in kind. When several nukes go off at once (and Taylor demonstrated this by gleefully blowing up most of the planet), the effects are cumulative -- for several seconds you almost couldn't see the map amidst the white-hot glow of a dozen miniature suns.
Nobody ever said war was pretty. No, wait, on second thought, we're saying it -- it looks awesome.
Here's what that means: when a tank rolls over a hill in Supreme Commander and fires its cannon at a moving target, it's not an instant hit. The trajectory of the shell is computed as it whirls through the air. Hitting a moving target from a moving platform is hard -- the AI might not be able to compensate, especially if the target suddenly switches direction or vaults in the air. For this reason, tanks may not be the best choice against fast targets (as opposed to a vehicle that fires lasers or guns.) They also work better when stationary. This isn't because the designers are futzing with numbers behind the scenes: It simply how tanks work.
Interestingly, Supreme Commander plans to offer cooperative play within the single-player campaign. This is a great feature that's long overdue: you and a friend can both tackle the plot together. There are three separate single-player campaigns, one for each faction. Several different missions will take place on each planet, and the base you build for one mission on a planet will carry over to the next mission -- that should speed up the action considerably.
86 |
Tuletegija
13.07.2005 19:53:52
Screenide, infi ja mängu looja tausta järgi järeldades on midagi tõsiselt head tulemas.
_________________ Rolling Thunder |
| Kommentaarid: 28 loe/lisa |
26 |
Ho Ho
01.03.2006 15:05:16
link :: http://supcom.strategyplanet.gamespy.com/gallery.php?mode=album&id=1
19 uut pildikest. Päris kenake näeb välja
86 |
Paganarh
Ho Ho
11.05.2006 09:18:42
heh, 2x19" CRT peal saab seda vist päris lõbus mängida olema
86 |
Paganarh
18.05.2006 07:40:45
| E3 video värisev ja s**a kvaliteediga kuid mina sain oma kaifi kätte
Cyberlord
18.05.2006 07:57:59
Eluaeg rts sõber olnud ja tundub, et siit võib täitsa midagi head tulla
| Kommentaarid: 546 loe/lisa |
449 |
One
18.05.2006 16:01:00
julm andmine - seda võiks täitsa pelada
728 |
Killhoven
OC`er
02.06.2006 09:51:53
seda värki ootan ma küll suure huviga
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
| Kommentaarid: 408 loe/lisa |
351 |
laevus
02.06.2006 19:01:37
Võimas. Artiklis mainiti, et menüü saab panna kas ekraani alumisse äärde või külje peale, et näiteks widescreen monitoriga rohkem mänguvälja näha. Huvitav, kas tulevikus on selline funktsioon mängudel enesestmõistetav?
| Kommentaarid: 10 loe/lisa |
10 |
Paganarh
04.08.2006 09:14:24
Gamespot avaldas esimese artikli Supreme Commander'i "rassidest" ja ajaloost.
Mõnus lugemine, mulle meeldib kui mängu tausta peale mõeldakse
Mingi aja jooksul järgnevad ka ülejäänud kahe osapoole kirjeldused.
[EDIT:]
Ilmus järgmine artikkel kahe UEF planeedi ning tegelase taustakirjeldustega
[EDIT2:]
Jätkab UEF mõningate unitite ja ehitiste tutvustamisega
[EDIT3:]
jätkan siis selle postituse updatemist
Küberneetilise, rassi- Cybran'ite taustalugu
[EDIT4:]
kolmanda ja viimase poole kirjeldus ning ajalugu. Aeon Illuminate - rahvas kes on nii rahumeelne et on valmis selle nimel teisi maha nottima
mutabor
| Kommentaarid: 24 loe/lisa |
22 |
Paganarh
08.09.2006 11:54:31
| closed beta algab varsti. loositakse välja nende vahel kes tellivad ametlikku newsletterit
Scart
23.10.2006 09:51:58
| Nonii, Fileplanet jagab beetat ning nagu võiksi arvata - tublid äkkerid on selle juba lahti murdnud ja LANimäng täiesti kättesaadav peaaegu kõigi üksustega. Kes tahab rohkem teada, otsib ise.
101 |
Mastersas
01.11.2006 20:09:31
Beta 2.7 intallitud ja töötab.
väga massive mäng ja vajab väga MASSIVE arvutit et pelada.
hetkel saan ainult 1 CPU vastu pelada (2 arvuti vastu pelades võtab m6nusalt lagima ja peab pelama kiirusega -4 siis käib sujuvalt ja seda Easy AI vastu )
kuna kaart on suur ja korraga liigub liiga palju tegelasi ringi.... jällegi kui LANis pelada siis jookseb mugavalt (kuna pole AI-d) 8)
peab mainima et armeed saab ehitada up to 50 000 units aga selleks on vaja ikka väga korraliku OC arvutit.
Üks parimaid takilisi pelasid mida kunagi pelanud
kui kellelgi see veel olemas siis keegi v6iks öelda kuidas keerata kaamerat, ise ei ole veel sellest trikist jagu saanud
vaadake video http://www.gamespot.com/pc/strategy/supremecommander/index.html?q=suppreme%20commander 8)
EDIT: NÕUDED
CPU P4 1800mhz min. (soovitav 3200mhz või k6rgem, Intel Core 2 Duo)
RAM 512mb min. (soovitav 2000mb)
VGA X800XT, 6800Ultra or Higher
imelik et nad Core 2 Duo Rõhutasid
| Kommentaarid: 203 loe/lisa |
153 |
Noname
01.11.2006 23:35:23
oioi seda mängu ootaks küll
_________________ "Olukord on sitt, aga see on meie tuleviku väetis." - Lennart Meri
"Edu on kehv õpetaja. See ahvatleb tarku inimesi mõtlema, et nad ei saagi kaotada" - B. Gates |
| Kommentaarid: 371 loe/lisa |
321 |
Mastersas
02.11.2006 00:06:11
mis sa seda enam ootad pela seda juba
me siin juba sõpradega teeme seda üle interneti Virtual Lanis 8)
153 |
Noname
02.11.2006 23:53:49
panin beta kiskuma, ons hea?
321 |
Mastersas
08.11.2006 22:46:34
Liiga Hea et Tõsi olla.
AI on veica bugine, kipub natuke palju ehitama (ja liigne ehitamine ja massiline taktikaline ryndamine kurnab prose .... Easy AI tundub kuidagi liiga raske
Arvestage et kui mängite AI vastu siis see kisub m6nusalt mängu aeglasemaks, soovitav on pelada LANis v6i siis üle interneti Virtual LAN-is.
http://www.hamachi.cc/download/
Keegi pelada viitsib 1v1 vmt ??
153 |
ModiKomP
| Kommentaarid: 12 loe/lisa |
12 |
Mario153
28.12.2006 13:16:21
| ModiKomP kirjutas: |
| Kust tirida saab kasvõi demo |
Sama küsimus.
| Kommentaarid: 56 loe/lisa |
50 |
EvilKatarn
diivanilill
28.12.2006 19:08:30
Demo pole.. küll aga ole beta vahva... saab zoomida nii välja et tekib 2D pilt mis näitab kelle sõjaväed jne asjad on kus ja sisse zoomides on mõnus motion blur ja see transitsioon 2Dst 3Dsse näeb välja nagu 2D polekski olnud... mängu ennast aga mängida ei saand
81 |
Mario153
28.12.2006 20:15:10
Aga kust beta saab
50 |
Mastersas
29.12.2006 00:14:35
tuleb tõmmata beta tester versioon, see tuleb siis teha 1.27v + tuleb t6mmata lisa vidinaid et saada tööle Skrimish ja Lan. Nüüd peaks isegi saama pelada 1.30v mis pidi palju mugavamalt ja paremini jooksma. Peab mainima et mul jäi Protsessor piduriks, Soovitav on Core 2 duo, beta-ga tuli selline soovitus kaasa.
Muide kui pelada LANis siis on prose kyllaga (AI kurnab massiivselt prose)
kas keegi on juba suutnud proovida LANis 50 000 units VS 50 000 ?
ise olen LANis suutnud sõdida 1500 units vs 1500 units, siis kisub asi väga pingeliseks
153 |
