uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Nokia 5500 märgi kõik teemad loetuks
mine lehele 1, 2, 3  järgmine
Karr000
sõnum 16.05.2006 22:43:46 Nokia 5500 vasta tsitaadiga
Netis ringi vaadates jäi silma midagi uut ja kahtlemata väga huvitavat - Nokia 5500. Plaanitav release date on Q3 2006
Nagu numbergi ütleb, on see järg põrutuskindlale Nokia seeriale, eelkäijatele 5210, 5100 ning 5140(i)
Telefon ise on suhteliselt kole (nagu kõik eelnevad 5-seeria Nokiad), kuid näitajad juba on midagi. Nimelt pole tegu mitte Series 40 telefoniga, vaid Symbian 60 smaartfööniga.
mobilegazette.com kirjutas:
Get past the strange looks, and at first glance the Nokia 5500 Sport looks pretty conventional. It weighs a shade over 100 grams, has a 208x208 pixel display in 262,000 colours, a 2 megapixel digital camera, multimedia player, Bluetooth and expandable memory using microSD cards.
In fact, at first glance you'd be forgiven for thinking that this was a tweaked Nokia 6230i - but one of the surprising things about the Nokia 5500 Sport is that it's a Symbian S60 Smartphone, rather than the normal Series 40 device you'd expect to see in a handset of this type.
It's the first S60 device we've seen with a 208x208 pixel panel, and at 103 grams we're pretty sure that it's Nokia's lightest S60 device to date. The 208x208 pixel panels to date have been pretty small, but it does appear that the 5500 Sport has a physically larger panel than the 6230i.
And on top of that, there's a FM radio, flashlight and 3D sensor that includes a simple "screen tap" function for ease of use while in sport mode. Physically, the 5500 Sport is a tri-band 900/1800/1900 handset with GPRS and EDGE data, measuring 107x34x16mm. Talktime is 2-4 hours with up to 11 days standby time. All of this is wrapped in a stainless steel chassis with a spash and dust resistant case with rubber grips.
:::Mobile-review.com ülevaade:::
viimati muutis Karr000 27.05.2006 13:51:16, muudetud 3 korda
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 88
Sixten
sõnum 16.05.2006 22:45:17 vasta tsitaadiga
Kommentaarid: 87 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 76
Puuriit
Puuriit
sõnum 17.05.2006 15:02:59 vasta tsitaadiga
Välimust on sel siiski kõvasti rohkem kui eelkäijatel, kuid arvatavasti teeb tänu funktsionaalsusele kahjuks ka kerge hüppe hinnaklassis. icon_confused.gif
Kommentaarid: 90 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 88
Karr000
sõnum 27.05.2006 13:52:22 vasta tsitaadiga
Nüüd tegi www.mobile-review.com telefonist ka korraliku ülevaate, täitsa asjalik masin tundub. Puudu on vaid korralik kaamera autofookuse ja välguga.
kaupz
kaupz
sõnum 07.07.2006 10:22:25 vasta tsitaadiga
ei no, kui 5210 või 5100 või 5140 välja tulid, siis oli ka hind vist mingi 4700,-
loota võib et klahvid on paremad sellel 5500 kui 5140 omad.
ise kasutasin 5210 ühe aasta ja 5100 saab kohe 2a. 5140 jätan aga vahele(bt ja mp3 netu ja kaamera on jama)
ja mis sellel välimusel viga on? klahvid on kenasti servast servani, mitte nii nagu 5120 ja 5140 jooksevad alla kokku.
siemens m75 oli vahepeal ka suht koht asjalik variant vahepeal.
aga see 5500 tasub turule tuua küll nokial.
taskulamp ka endiselt küljes thumbs_up.gif kuigi oleks võinud kaamera kõrval olla nii nagu SE aparaatidel
siin siis ülevaade inglise keeles.
http://www.mobile-review.com/review/nokia-5500-en.shtml
"The most elementary form of pedometer is a 3D-sensor detecting number of steps made."
sammulugeja? miks 3D ? et loeb ükskõik mis asendis? hmm
O: VW T2 Hipibussi Transporter T2a VolksWagen T1 või Vana Põrnika
Kommentaarid: 86 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 78
Karr000
sõnum 07.07.2006 13:12:27 vasta tsitaadiga
Väga pimedas ruumis saab ehk siiski taskulambi abil natukene paremaid pilte..
kaupz
kaupz
sõnum 11.08.2006 09:39:55 vasta tsitaadiga
Karr000 kirjutas:
seda küll, aga näiteks se w800i on lamp otse objektiivi kohal, siis ikka valgustad konkreetselt seda mida pildistad.
muidugi kui ainult lampi kasutada siis mugavam kui seal otsas on.
edit:
emt lehel hind üleval 4790,-
http://mobiiltelefonid.emt.ee/body.php?op=phones&PID=376
konkurent oleks 6233 mis on 3G aga ilma symbianita, teagi kumb kasulikum valik on ...
Caveman
Caveman
sõnum 23.09.2006 18:45:51 vasta tsitaadiga
Praegu uurin seda telefoni, esimene mulje: UIMANE.
Tõsiselt kohe, nagu mingi vana Siemens oleks.
Muidu see tava-sport-muusika režiimi vahetamine on muidugi tore (OK nupu ümber olev plaadike hakkab siis roheliselt või punaselt helendama), sammuloendaja on ka huvitav mänguasi (telefoni koha peal üles-alla liigutades näitab muide isegi jooksmise kiirust icon_biggrin.gif ), aga vaevalt et keegi sellega väga pikalt jamada viitsib.
Üldiselt on telefon kõvasti sümpaatsem kui 5100 või 5140i (5210 on siiamaani minu lemmik), nii et 4K hinna juures on täitsa arvestatav asjandus, kui vastupidavust taga ajada.
Eriti lahe asi on muidugi tagakaane kinnitus, mis käib sõna otseses mõttes lukku, kõige parem on "vinti" keerada mündiga.
Aga jah, see Symbian on suht jama lahendus IMO, samas mõne jaoks muidugi suurim pluss. icon_rolleyes.gif
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 4 :: 10 :: 41
kaupz
kaupz
sõnum 02.10.2006 10:42:13 vasta tsitaadiga
kas symbiani menüü kujundusi on mitu tehase softis?
on siis tõest nii uimane nagu 6210 oli kunagi...
Caveman
Caveman
sõnum 03.10.2006 14:15:16 vasta tsitaadiga
S60 on üks opsys ja see on sama kujundusega ikka kogu aeg, aga 5500 on mõnevõrra uimasem kui teised (kuigi ega ükski erilise kiirusega ei hiilga).
ffw
sõnum 03.10.2006 14:33:42 vasta tsitaadiga
Caveman kirjutas:
mul kuskilt meeles et n91(oli vist see muusika telefon) omas ikoonide suhtes teistsugust asetus kui muudel.
EDIT: http://www.gsmarena.com/nokia_n91-review-81p3.php ikoonide asetus jah 3x3 mitte 3x4
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 52
kaupz
kaupz
sõnum 03.10.2006 14:57:17 vasta tsitaadiga
seda symbiani siis maha keerata ei anna?
vilesid kinni et kiirem oleks? värvid jms...
ps. kui keegi tahab maha müüa seda aeglast telefoni, siis olen avatud pakkumistele.
on kuskil esinduses aparaat saadaval ka näppimiseks?
mitte kummist dummy, vaid toimiv õige aparaat ikka.
viimati muutis kaupz 03.10.2006 15:00:07, muudetud 1 kord
ffw
sõnum 03.10.2006 15:00:01 vasta tsitaadiga
kaupz kirjutas:
paned vähem värvilise teema, hoiad vähem programme töös korraga, siis on nii kiire kui ta olla saab icon_biggrin.gif. symbiani keerad maha=arvuti ilma OP systeemita.
kaupz
kaupz
sõnum 03.10.2006 15:04:09 vasta tsitaadiga
aga miks mitu "programmi" korraga jooksma peaks?
lihtsalt tavalise "telefoni programmi" puhul on ka täiesti uimps?
Caveman
Caveman
sõnum 07.10.2006 17:16:47 vasta tsitaadiga
No näppida võid enamustes TELE2 esindustes, EMT ja Elisa kohta ei oska öelda.
Telefon ei ole "täiesti uimps", aga kiireks ei saa teda kuidagi nimetada.
Praegu uurin E50-t - mulje on sama. Ei midagi katastroofilist, aga häirib.
striker13
striker13
sõnum 08.10.2006 11:58:52 vasta tsitaadiga
minule see asjandus küll meeldib icon_biggrin.gif ainult mulle meeldiks "võimsam" kaamera
Sarcasm is just one of the many services I offer to people who ask stupid questions.
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 90
kaupz
kaupz
sõnum 09.10.2006 22:48:30 vasta tsitaadiga
e50 olen korra katsunud. ei old kõige hullem.
kas 5500 kaamera ei ole 2mp?
kui ka oli siis fotoka 2mp kõrvuti teda ikka ei pane, valgusjõudlus jms.
häda pärast mingi situatsiooni jäädvustab, aga ei asenda ka väikest taskufotokat ixust näiteks.
edit:
miskid uued mudelid tulemas, liugurklapiga 5200 ja 5300
aga kas on siis ka tugeva korpusega ...
http://europe.nokia.com/A4199012
Caveman
Caveman
sõnum 14.10.2006 18:00:55 vasta tsitaadiga
Ma nüüd ei saa päris hästi aru, kust sa järeldad, et need peaks olema tugevdatud korpusega? Tegu on puhtalt noortele suunatud muusikatelefonidega.
PS: kaamera on 2MP
PPS: Kui siin leidub keegi, keda 18-kuuline leping suure ja hirmuäratava TELE2-ga ei muserda, siis selle telefoni saab kampaania korras osta 1440 krooni eest.
kaupz
kaupz
sõnum 14.10.2006 18:31:01 vasta tsitaadiga
ok my bad, jäi kuidagi tunne et 5210 5100 5140 5500 kuigi vahepeal oli 5510 mingi mängimise telefon ja vanasti oli 5110 ja ....
küsisin magistrali emt-s täna asja katsuda.
aga need "Triipud otsa" nupud ja ülemised nupud kuidagi kehvalt vajutatavad icon_sad.gif
pildi pealt tundub raskem, aga peale raami muu ikka plast ja suht kerge.
tele2 puhul hirmutab see olematu levi "pole levi pole arvet, näeme siis räägime"
muidu oleks okas, Extra200 ehk kuumaks miinimum 200,- kõneminut 1,75 ehk siis 114min saab/peab vähemalt rääkima.
praegu diil99 ja läheb ka ikka üle 100 minuti, nii et mingi 85,- maksaks ikka rohkem kui extra200 rääkida 85x18=1530,- ja telefon ise 1440 on kokku 2970
mida on küll vähem kui ilma lepinguta 3750,- osta kuskilt. hammas on verel. icon_confused.gif
tsarnevits
sõnum 22.10.2006 19:51:25 vasta tsitaadiga
tele2's telefone sirvides, panin tähele 5500 music edition , et kas see on täpselt sama telefon, lihtsalt suurema mälukaardiga ja ilusama korpusega thumbs_up.gif ?
r3nx
sõnum 22.10.2006 21:48:12 vasta tsitaadiga
tsarnevits kirjutas:
Jah, samad.
kaupz
kaupz
sõnum 05.11.2006 21:34:15 vasta tsitaadiga
r3nx kirjutas:
Jah, samad.
hmm, nokia.ee lehel on ainult see 5500 Music nähtaval, lihtsalt 5500 nagu ei olegi.
Music korpus on punakas-pruuni triibuga, aga kui telefoni omadusi vaatama hakkad siis jäävad valikusse ainult kollane ja must korpus thumbs_down.gif
kõrvaklapid või mitte miskit muud ei ole teisiti sellel musicul?
leidsin järgmise infi www.nokia.com europe regional lehelt.
et kaasas on 512mb kaart ja korpus vist ikka see punakas-pruun?
kuidas tarkvara uuendamise asi välja näeb?
kas saab päris ametlikult nokia.com lehelt laadida ja ise teha?
või kui väljamaalt uuena lepinguga ostetud kas eesti nokia garantii teeb ka asja ära tasuta?
.Scorps.
.Scorps.
sõnum 06.11.2006 22:54:20 vasta tsitaadiga
kaupz, Nokiatel saab tarkvara uuendada ainult hooldustes, garantiiajal tasuta.
Kommentaarid: 265 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 221
kaupz
kaupz
sõnum 06.11.2006 23:48:37 vasta tsitaadiga
no siis pean ilmaelu uurima, kus on veel peale kristiine-rle sellist tõsisemat nokia remondikohta?
mis paberit neil vaja on? väljamaa ostutsekki?
.Scorps.
.Scorps.
sõnum 07.11.2006 00:13:29 vasta tsitaadiga
kaupz kirjutas:
Kristiines enam hoolduskeskust ei ole icon_exclaim.gif Võid jätta suvalisse Elisa esindusse, sealt saadetakse edasi. Või siis ise viia, näiteks Sevartasse (asub kuskil Tondil).
Kahtlen, kas nad väljamaist garantiid tunnistavad, kuid mine tea, võid ju küsida.
uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Nokia 5500 mine lehele 1, 2, 3  järgmine
