valat
03.09.2006 19:07:12
Uus mälu + vana mälu = aeglane |
Lugu siis selline...ostsin arvutile mälu juurde 2x512 MB Corsair DDRAM XMS3200 PC3200 400MHz 512MB DIMM CL2.0 DDR (2-3-3-6) Black arvutile, mis on profiilis.
Enne oli arvutis veel 2x PC2700 Kingstonid 256 MB-sed
Emaplaadil on Dual Channel tugi ja kui kõik ramid sisse sai pandud kukkus 3D mark 01 skoor märgatavalt.
siin väiksed testi tulemused:
Test--------------------------------- 2x512 + 2x256-------- 2x512---------2x256
Car Chase - Low Detail----------- 172,9 FPS -------------181,1------ ---178,8
Car Chase - High Detail----------- 57,1 FPS----------------61,7-----------60,2
Dragothic - Low Detail -------------257,8 FPS--------------272,8----------267,3
Dragothic - High Detail------------ 141,1 FPS-------------- 149,2----------146,4
Lobby - Low Detail----------------- 166,6 FPS-------------- 181-------------173,6
Lobby - High Detail---------------- 73,4 FPS--------------- 80,4-------------77,1
Nature------------------------------ 88,7 FPS--------------- 88,9-------------88,8
Fill rate (single texturing)--------- 1625,7 Mtexels/s------ 1625,7----------1628,1
Fill rate (multi texturing)---------- 3930,9 Mtexels/s------ 3930,9----------3930,9
High Polygon count (1 light)------ 83,4 Mtriangles/s------83,9-------------84,1
High Polygon count (8 lights)----- 16,7 Mtriangles/s------15---------------15,2
Environment Bump Mapping------ 171,1 FPS-------------- 169,3------------169,1
DOT3 Bump Mapping-------------- 249,7 FPS-------------- 250,7------------250,4
Vertex Shader--------------------- 179,7 FPS-------------- 185,8------------183
Pixel Shader----------------------- 201,3 FPS-------------- 210,8------------205,4
Advanced Pixel Shader----------- 287,2 FPS-------------- 287,3------------287,4
Point Spirites----------------------- 34,2 Mspirites/s--------34,2-------------34,3
Overall------------------------------ 13181-------------------13953-----------13647
Sai ka ET (Enemy Territorys) timedemo tehtud ja tulemused ikka allamäge
2x512MB Crosshair XMS3200 Black: 125,54 FPS
2x256MB Kingston PC2700 : 121,02 FPS
2x512Crosshair + 2x256Kingston: 113,8 FPS
Prose kellad hetkel 18x150 MHz = 2700MHz
mälu timingud 2,5-3-3-7
Oskab keegi hüva nõu anda, kuidas mõlemad mälud Dual Channelis tööle saada?
_________________ Mix minna otse, kui saab tiiruga?
Tasuta lõunad on siiski olemas |
Marie
03.09.2006 19:57:52
Uus + vana mälu = aeglane |
Arvatavasti hakkasid mälud tööle T2 peal ja madalamal MHz_l, ASRock oskab sellist BIOSt teha mis enamikel juhtudel jääb arvuti tööle ka siis kui mingi seade on vale ja paneb automaatselt ise mingid madalamad seaded millega arvuti on veel suuteline käivituma, muidugi kui seaded on väga piiri lähedased jookseb ka ASRocki emaplaat kooma ja arvuti ei käivitu
| Kommentaarid: 83 loe/lisa |
74 |
valat
03.09.2006 21:27:04
Et siis ASRocki peal ei saagi seda tööle we?...
Biose updatesin ka just, see ka ei aidanud...
Kus neid T1 T2 timinguid seada saab?
Everestis näitab timinguid 2,5-3-3-7 ja 166Mhz, see mis biosis olema peaks, ei ole naq madalam.
Troll
03.09.2006 21:33:35
Jäta sisse ainult uued 2x512MB Corsairid. Seni kuni kasutad neid koos vanade PC2700 mäludega, töötavad ka uued aeglasemal kiirusel.
_________________ TÜMPA, TÜMPA...EEST ÄRA, TROLL TULEB!!! |
121 |
valat
03.09.2006 22:06:34
nii et ei saa mingi valemiga neid koos tööle panna...nii et nad kiiremini töötaks ma mõtlen...?
yoyoo
03.09.2006 23:11:14
| kas mul muudab pc2100 mälu pc3200 mälu aeglasemaks? Nagu et see töötab ka pc2100 peal?
| Kommentaarid: 30 loe/lisa |
04.09.2006 00:54:34
yoyoo, kõik mälud töötavad alati ühe kella peal, sinu puhul siis PC2100 (kuna SPD ei tohiks lubada kiiremini jooksutada, kui just ise ei sunni)
samas endal jooksevad ühes kastis ilusasti PC2100 ja PC2700 koos PC2700 peal ning veel default timingutega (ei ole lõdvendatud PC2100 mälu jaoks), mälud on nonamed
| Kommentaarid: 85 loe/lisa |
Matrix75
04.09.2006 07:47:32
Endal olid Asuse emmega 2x256mb(pc2700/cl2,5) ja 2x256mb(pc3200/cl2,5) sees ja toimisid dualis. Ainult kumma paari ühe mälu panin esimesse pesasse selle järgi valis emme teistele mäludele kiiruse. Oli vist nii ei mäleta enam . Aga saab ka biosist jõuga settinguid muuta. Iseasi kas aeglasemad mälud kannatavad kiiremaid settinguid! Endal kannatasid .
| valat kirjutas: |
| nii et ei saa mingi valemiga neid koos tööle panna..? |
Ei usu, et need Kingstoni(333Mhz/oletan, et cl2,5) suudaksid selle emmega toimida nende Corsairi(400Mhz/cl2) mälude kiirustel. Parimal juhul saad mälud käima kui paned biosist 400mhz/cl2,5 või siis 333mhz/cl2 pealt. Soovitan viimast. Pane ainult Kingstonid sisse, biosist u300mhz/cl2 pealt ja järjest tõstad mälude kiirusi kuni nad vigadega toimivad. Siis 5-10mhz lahjemaks ja lisad teised mälud. Vigasid kontrollid Memtestiga.
Iseasi, kas ASRocki(VIA kiviga) emme võimaldab üldse seda teha? Ja mälud paarid pane ühte värvi pesadesse.
| Kommentaarid: 321 loe/lisa |
241 |
-vodafone-
04.09.2006 07:53:33
| yoyoo kirjutas: |
| kas mul muudab pc2100 mälu pc3200 mälu aeglasemaks? Nagu et see töötab ka pc2100 peal? |
Jah
217 |
valat
04.09.2006 07:54:09
ASRocki biosis saab ´kiirusteks ainult 133, 166 ja 200mhz panna...rohkem ta miskipärast ei võimalda
Matrix75
04.09.2006 08:38:05
Arvata võib, et ei lase peenelt panna mhz mäludele . Võid siis proovida 166(333)/cl2 pealt või 200(400)/cl2,5 pealt. Kui memtestiga toimivad veatult saad jätta nii kui ei pole eriti midagi teha. Kui proovides enam pilti ette ei võta saad kiiremate mäludega tagasi muuta!
Parem kasuta Trolli soovitust.
241 |
ranel
04.09.2006 15:58:01
peaks laskma küll, mingi mälu sobivust tuli muuta mälu kellade all olevas reas ja siis paned 400 mhz peale. Niimodi ei pea sa hakkama arvutit klokkima
Võin ka eksida
165 |
Viilutaja
12.09.2006 08:52:31
vabandan, et kirjutan sinu teemase, kuid küsiksin ühte asja, kas mälu toimib siis ka dual süsteemis kui, on üks komplekt 2x256 Corsair pc3200 cl2.0 mälusi ja teine komplekt mingi muu firma mälusid kuid ka cl 2,0 ja 2 x 256 pc3200? Et siis kokku oleks 4x 256 = 1GB.
_________________ Parim kodukino projektor müügis: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11768241#11768241 |
| Kommentaarid: 226 loe/lisa |
196 |
12.09.2006 12:46:33
toimib
üldjuhul toimib ka siis, kui kõik 4 on erinevad
Viilutaja
196 |
12.09.2006 23:25:24
suurt vahet pole, mõttekam oleks 512x2, saad teise 2x512 veel otsa lükata
