madness
21.08.2006 21:47:05
| Linnapea kirjutas: |
no kui see uus bf tuleb sellise grafaga välja nagu need pildid siis ma söön oma mütsi ära  |
kui ta ju alles järgmise aasta lõpu poole tuleb, siis mine tea
Crysis ju samasugune, või paremgi..ja juba aasta alguses tuleb.
E: Vilets tõlge siis sellest teatest Dice lehel
Digital illusion's launches new title - Battlefield: Baths Company
Digital illusion's CE Ltd (publ) 2006-08-21
Today, digital illusion's was presented (DICE) new title Battlefield: Asked Company for Xbox360 and PlayStation 3. Battlefield: Baths Company is planned to be released during 2007 and is an of the previous utannonserade titles as not been named.
Battlefield: Baths Company is an entirely new and independent playing in Battlefield-serien that uses itself of Frostbite, DICE: s entirely new own developed playing engine. The playing contains a cinematisk singel-player-del loaded with adventure feeling and dark humour as never earlier been experienced in Battlefield-serien.
in a playing world that is first ear bar to 90% so is the possibilities infinite - the kind field to be changed all the time and forces the players to always to change tactic. says man Magnus Troedsson, Senior Producer for Battlefield: Baths Company
More information about pc - and PSP-versionerna will be presented at a latter occasion.
The Internet address to Battlefield-seriens information side is http://battlefield.ea.com.
For further information contact:
John Hargelid, information responsible, 08-658 78 00
E-mail: press@dice.se |
| Kommentaarid: 13 loe/lisa |
inc
21.08.2006 22:03:28
Peale serveri crashi sai klani servus rahvast oodatud.. Hakkas igav ja otsisime endale tegevust.
| Kommentaarid: 65 loe/lisa |
62 |
Cander
22.08.2006 21:11:15
2 väikest küsimust siis - medicu 1. unlockitud relvaga selline jama, et alguses kui Fire nuppu peal hoian, valab järjest kuule. Aga vahest on vaja iga kuuli jaoks eraldi klõpsida Fire nuppu. WTF ?
2 - 1on1 osad vennad hüppavad nagu pikali ja teevad siis ümber oma telje veel ühe tiiru..kuidas see veel võimalik on ?
| Kommentaarid: 39 loe/lisa |
34 |
Lordlesta
22.08.2006 21:20:09
esimese küsimuse vastus siis, kui sul relv on käes ja sa vajutad uuesti sama relva peale, siis vahetab ta kas auto, burst või single peale.
ehk siis kui sul on single ja tahad auto peale tagasi panna vajuta uuesti relva peale.
teisest küsimusest ei saanud ma hästi aru
| Kommentaarid: 31 loe/lisa |
rixk
22.08.2006 21:37:15
| Cander kirjutas: |
2 - 1on1 osad vennad hüppavad nagu pikali ja teevad siis ümber oma telje veel ühe tiiru..kuidas see veel võimalik on ? |
See on lihtsalt animatsioon, kui külje peale liikudes pikali viskad. Sina teed ka seda, ainult ise ei näe.
| Kommentaarid: 35 loe/lisa |
Cander
22.08.2006 22:19:12
tohoh..see krdi "animatsioon" on palju 1on1 ära si**unud.. nimelt mul tavak saand, et 1on1 ma tavaliselt tapan püsti..ja ei liigu ning lasen hullu laadungi kuule otse vastasele pooled küll lähevad mööda, aga nohjah .. on juhtunud ka nii, et kui näen vastast kusagil peidus ja endal juhuslikul on "lifesaveri värgid" käes, siis sprindin, hüppan ja siis maandun kõhuli otse vastase peale, kellele siis okiteraapiat teen
34 |
-N!gHtY-
22.08.2006 22:59:42
Lase kükakil vi kõhuli , sihi rohkem, kasuta paarikuuliseid või ühekuuliseid valanguid...
inc
23.08.2006 00:59:38
| Kas keegi mingit 24/7 normaalse pingiga Ghost Towni serverit ei tea?
62 |
sotamees
23.08.2006 05:16:25
Küsiks mõned asjad.
Mul bf2, kas ma pean seda uuendama ka? muidu servudes saan mängitud aga mu mängija rank ega play time, most played vehicle jne ei lähe suuremaks, miks nii? tahaks ikka saada ranke ka. (medaleid jne) olen miu korda saanud kulda aga mitte midagi ei rank all ei tõuse!
Kas ta automaatselt uptade ei tee?
| Kommentaarid: 34 loe/lisa |
34 |
MarekSäde
23.08.2006 06:24:00
| sotamees kirjutas: |
Küsiks mõned asjad.
Kas ta automaatselt uptade ei tee? |
Mängid ikka ranked serverites?
| Kommentaarid: 68 loe/lisa |
66 |
sotamees
23.08.2006 07:06:57
Eip. Otsisin netist neid, leidsin , panin IP ja ütleb 2 asja, kas vigane IP või error netiga, aga kui mängin tava servusid siis kõik OK
andke üks rank servu ip ma proovin kas töötab!, andke selline milles olete ise mänginud.
34 |
rixk
23.08.2006 07:12:32
| Autoupdate-t pole. Otsi netist viimane patch(hetkel 1.3, lähiajal peaks 1.4 välja tulema) tõmba ära ja installi. Aga miks sa netist otsid? Mängu sees on ju otsing olemas.
sotamees
23.08.2006 07:57:35
Pole ühtegi rank servutkõik tavalised.
Äkki annad lingi et ma mingit paska ei tiri endale
34 |
kuriloom
23.08.2006 08:23:27
| Mängust seest paned serveri otsingu filtriks et otsiks ainult "ranked" servereid ja "same mod" ka, siis need serverid mis kuvatakse ongi kõik ranked.
33 |
sotamees
23.08.2006 09:15:48
| Nüüd peaks asi korras olema, kohe installin pach 1,3 ka ära ja siis räägin mis saab, ma aravn 200h play time pole üldse suur!
34 |
rixk
sotamees
23.08.2006 10:01:55
Et siis see 178mb mille tirisin v1.3 pole mõtet-
Jama tekkis, ütleb et vähe ruumi kuigi mul 40GP vaba ruumi aga teisel kettal 800MB. ta ei lase valida kuhu installida, mida nüüd teha? Ei ole valikuvõimalust kuhu installida, pachida, tahab automaatselt panna c kettale
Mitte midagi ei saa teah! miks ei ole SAVE AS? Ühesõnaga jääb see 600.- siis asjata ja viskame samahea kui prügikasti
Ma löön kohe bf2 originaal plaadi pooleks!
34 |
kuriloom
23.08.2006 10:05:50
patchitakse ju mängu, selle panid paika juba mängu installides.
parem tõmba jah full patch 1.3.
ning hakka aga sõdima
33 |
sotamees
23.08.2006 10:12:45
MA EI SAA JU SEDA INSTALLIDA KUNA SEAL EI OLE SAVE AS JA TA TAHAB PANNA AUTOMAATSELT C KETTALE KUS VABA RUUMI 800MB ; JA TAHAB SAADA 1,6GB....
Kust mina pean teadma mida see freaky arvuti teha tahab. peaks ja mängi pachima aga mingi c ketas low space c ketas low space!!1111
34 |
Valdars
23.08.2006 10:23:20
| Kui downloadimisel probleem, siis proovi parema kliki menüüst save link as. Aga kui patchi installimisel ei saa kohta valida, siis see installitakse automaatselt BF2 juurde.
| Kommentaarid: 47 loe/lisa |
44 |
sotamees
23.08.2006 10:47:08
Aga ta ei installi bf2 juurde, ütleb aina et low disk space, )= kohe varsti on see 400mb tiritud, siis näeb mis saab
34 |
sushimees
23.08.2006 11:26:29
| Kas on mõtet osta BF2 või oodata ära BF 2142 ja vaadata, kuhu rahvas siirdub?
Cander
23.08.2006 11:47:02
| sulle oleks loomulikult parim osta mõlemad, aga noh, kellel see rahakott kannatab, kellel mitte..
34 |
inc
23.08.2006 12:05:27
| sushimees kirjutas: |
| Kas on mõtet osta BF2 või oodata ära BF 2142 ja vaadata, kuhu rahvas siirdub? |
Eks sa ise tead kumb sulle rohkem meeldib: kas tulevik või tänapäev.
| inc kirjutas: |
| Kas keegi mingit 24/7 normaalse pingiga Ghost Towni serverit ei tea? |
62 |
kuriloom
23.08.2006 13:33:40
Kavatsen ka veidi rahapeale mängimist proovida, tegin end http://www.prizefight.com kasutajaks,
on keegi ehk ka rahapeale mänginud juba? võimalik et seal on jubedad mängurid koos ja mind ei võetagi, aga eks näis, proovida võib.
kui keegi veel joinida tahab siis ma saadaks kutse, saame mõlemad 5 naela kontole juurde.
33 |
