oravapoiss
04.06.2006 13:41:48
imho on see ikka HDR mitte bloom..
| Kommentaarid: 15 loe/lisa |
CnZ
04.06.2006 13:45:24
jep, see viimane on küll HDR, kuid see heledast ruumist tumedasse mineku valguse efekt on bloom.
btw, HDR on suht odavalt tehtud, kuna Alyxi relva peal pole jälgegi.. HDR on progetud ainult karakteri peale
| Kommentaarid: 14 loe/lisa |
madness
| Kommentaarid: 13 loe/lisa |
scarface
04.06.2006 14:29:28
se on kll HDR sul mul oli aint bloom sest HDR-i ei saand peale panna... ja polnd midagi sellist nagu sinu piltidel se HDR.
| Kommentaarid: 44 loe/lisa |
42 |
der hammer
04.06.2006 15:04:19
Õhtul kui saan mängu kätte teen samadest kohtadest HDRi toetava kaardiga pilte ja võrdleme
_________________ Tere. |
| Kommentaarid: 149 loe/lisa |
130 |
oravapoiss
04.06.2006 15:22:19
davai, saadame pildid ekspertiisi (steam) ja selgitame välja tõe!
RustyZ
04.06.2006 15:34:16
Õpime lugema:
http://www.bit-tech.net/gaming/2005/06/14/hl2_hdr_overview/1.html
HDR stands for High Dynamic Range, and is also sometimes referred to as High Dynamic Range Imagery (HDRI) or High Dynamic Range Rendering (HDRR). The Dynamic Range is the ratio of the largest value of a signal to the lowest measurable value. Current 16-bit integer-based formats use colour component values from 0 ("black") to 1 ("white"), but don't allow for what is known as "over-range" values, for example, a whiter-than-white highlight glinting off a piece of metal.
HDR facilitates the use of colour values way outside the normal range in an effort to produce a more realistic rendering of a typical 3D scene. If you have ever driven through a dark tunnel in your car, and then emerged out the other side into blazing sunshine, temporarily blinded by the difference in light levels - that oversaturation is one example of what is possible with HDR.
_________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled) |
| Kommentaarid: 16 loe/lisa |
madness
04.06.2006 15:42:33
kellele see suunatud oli ja mida sellega öelda tahtsid ?
teada ju, mis HDR on.
RustyZ
04.06.2006 16:48:28
| madness kirjutas: |
teada ju, mis HDR on. |
vaidlesite ju mis on HDR, et kas see nö bloom mida osad mehed siin näevad või mis, seal on täpselt kõik kirjas kui ingliskeelt oskad.
Mario153
04.06.2006 17:42:42
| Sai siis lõpuks läbi. Ega pani täitsa juba episode kahte ootama. Algul tundus ehmatavalt igav ja liiga ammendanud teema juba aga mida lõpu poole seda paremaks läks. Kujutan ette, et episode kaks on juba päris raju värk. Kahes peaks tegevus toimuma suurematel aladel linnast väljas ja kokku lastakse juba suuremad armeed 8)
| Kommentaarid: 56 loe/lisa |
50 |
zpeedy
04.06.2006 19:28:46
pani mind ka üle tükiaja arvutiga mängima. Natuke mängisin algust ja vana hea HL2 tuli meelde. EP2 teaserit vaadates jäi natuke suu lahti...cool.
PS: suura asi, kas on HDR või mitte. tundke mängust rõõmu
| Kommentaarid: 28 loe/lisa |
28 |
tolm
04.06.2006 19:33:30
sai kah just läbi taotud, algus oli tiba igavapoolne ja üldsegi kuidagi lühike oli kogu see värk, aga muidu suht tore. haigla oli mõnus rampage-zergimine :p
ep2 treiler tegi /droolmode :p
| Kommentaarid: 12 loe/lisa |
12 |
DoubleHelix
04.06.2006 19:53:35
Mõned pildid minupoolt... HDR on peal...
CLICK
| Kommentaarid: 39 loe/lisa |
38 |
UB
04.06.2006 20:56:17
Mäng oli tõesti lahe Ehk on see isegi hea, et ta mitmes osas välja lastakse, sest nii ei jõua kellelegi tüütuks muutuda. Veidi mängimist ja siis hakkavad kuud jälle venima
| Kommentaarid: 45 loe/lisa |
39 |
j22lind
04.06.2006 21:50:47
Ma usun, et episode 3-s näeb ka Gordoni kõrvaltvaates ära, see tähendab siis, et Alyxi silmade läbi tuleb kolmas osa
486
04.06.2006 22:11:56
Mina ei saa sellest hdr-ist aru jumalast nõme ju, iga maja oleks nagu prosektoriga valgustatud ja peale selle nad peegeldavad ka liiga palju valgust tagasi nagu oleksid klaasist või metallist aga tavaline krohv või kivisein ei tekita sellist peegeldust.
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
Ho Ho
04.06.2006 22:20:10
Kui kõik ei näeks nii jubedalt rõhutatud välja ei oleks ju näha et pildis on midagi muutunud (HDR kasutusse võetud). Ehk siis kui kasutajad näevad et pilt on metsikult üle/ala valgustatud siis nad teavad et tegu on HDR'iga ning kuuldu järgi arvavad et see on hea
87 |
lightbluefox
04.06.2006 22:25:30
| Kas episood 2s on ka need kommentaarid üle mäppide laiali jaotatud või oli see ainult ep1 , nagu mingiks tutuvustuseks vms?
44 |
der hammer
04.06.2006 22:46:55
Kas Episode 1 jaoks tavalist Half Life 2 on vaja ?
130 |
zpeedy
04.06.2006 22:48:10
| Totu user kirjutas: |
| Kas Episode 1 jaoks tavalist Half Life 2 on vaja ? |
õnneks ei ole...ma algul arvasin, et on, aga ei.
28 |
madness
05.06.2006 00:17:23
| 486 kirjutas: |
| Mina ei saa sellest hdr-ist aru jumalast nõme ju, iga maja oleks nagu prosektoriga valgustatud ja peale selle nad peegeldavad ka liiga palju valgust tagasi nagu oleksid klaasist või metallist aga tavaline krohv või kivisein ei tekita sellist peegeldust. |
ei ole üle valgustatud. ainult algul, kui pimedast nurgast pöörad vaate heledamasse kohta..siis vaikselt läheb tumedamaks.
kenam näeb välja küll, kui HL2 ilma HDRita
Ho Ho
05.06.2006 00:21:43
| madness kirjutas: |
| ainult algul, kui pimedast nurgast pöörad vaate heledamasse kohta..siis vaikselt läheb tumedamaks. |
Btw, kas keegi on seda efekti päriselus oma silmaga näinud? Ma ei pea silmas filme või fotosid vaid ikka oma ihusilmaga nähtut
87 |
madness
05.06.2006 00:29:53
Kinnisilmi liigud ringi ?
ei, tegelikult päriselus ei ole see üleminek nii kiire imo..aga siiski on olemas:p
Tbit
05.06.2006 00:41:25
päris sellisena ta küll välja ei näe aga idee on phm küll sama, sellist reaalset effekti on raske saavutada kuigi ma ütleks, et põhiviga on selles ajas mis kulub seal ühe valgusega ruumist teise minekul ümber "lülitumiseks", näiteks põikad korra pimedamasse kohta 5 sek ja siis valguse kätte oleks nagu mitu minutit pimedas olnud, sest inimese silm muutub nö passiivseks peale tükki aega alles teatud valguse käes olles. kui näiteks päeval päiksepaiste käest korra pimedasse kohta minna ja uuesti välja nii 5-10sek parast, taastub nägemine suht sekundite jooksul, kui aga kükitada pimedas oma minut paar siis ikka töllerdad oma pool minutit pool pimedana ringi.
sama asi ka näiteks päiksepaistelisel päeval mõnikord tuppa tulles võib koridoris romulrallit mängida, mitte essugi ei näe.
|OSTAN|-> T43 pikk jahutus |
230 |
Le Inc
05.06.2006 09:06:25
Episode 1 algus on küll sutsu sürr, aga ehk lõpu poole läheb paremaks. Ahjaa interaktiivsusest puudust ei tunne - naiskangelane Alyx muudkui lobiseb ja lobiseb .. (naisterahva asi ikkagi ).
Aga mäng jookseb hästi, oma komplektiga 1280x960 ja 6xAA & 16 AF ja alla 50 fps pole veel näinud. 1600x1200 kipub sutsu vist suureks jääma, aga ehk isegi veaks välja.
54 |
j22lind
06.06.2006 01:22:04
Tavai kirjeldage mängu, aga jah, ilma kellegi teise mänguelamust rikkumata. Tahaks väga teada, mis on mängus uut ja head, mis vajaks kohendamist ja mis on eriti nõme seal. Võrrelge Half Life 2 ja Half Life 2: Episode One omavahel, võiks tuua plusse ja miinuseid. See on ju mängufoorum
Aitäh.
UB
06.06.2006 07:29:35
Siin ei ole midagi kirjeldada, sest HL2 ja Episode One ei erine teineteisest väga palju. Järjes on sulle ainult üks lobamokk teele kaasa antud, kes ei vaja kunagi laskemoona ega esmaabi, vaatamata sellele, et tal eiole sellist kaitsvat ülikonda nagu peategelasel, seega võib päris paljud madinad tema hooleks jätta. Eriti just alguses kui laskemoonaga on kitsas käes. Kindlasti on leiutamist rohkem kui HL2s, kuid ei midagi kaelamurdvat, kuid ma usun, et aja peale on seda mängu kindlasti palju raskem mäbi teha kui seda HL2 puhul oli
39 |
Paganarh
06.06.2006 08:50:04
pole paha see EP1. vahepeal mõned kohad ajasid närvi aga polnd hullu.
aga selle HDR jutu peale- mulle meeldib kui on mõned kohad hästi kirkad ja eredad- tekitab mõnusa sooja suvepäeva tunde (oblivioni madistan kah HDR'iga)
06.06.2006 08:59:16
hl2e1 = ~3h telekavaatamise kõrvalt mängimist. pisut vähe seda. easyga seekord, proovisin algust normaliga ka aga ei hakanud oma närve rikkuma, raskem raskusaste oleks ilmselt kuskil 0,5h ajale otsa pannud anyway.
tagantjärele kirun, et kohe seda commentary mode peale ei keeranud, see paistis täitsa lahe olevat. teist korda selle pärast kohe järjest asja läbi jooksma hakata ei kavatse.
ahjaa, gravity gun sakib umbes kahesajaga. muidugi on vaja miski twist välja mõelda, et asi enam overpowered ei oleks. ehk siis lihtsalt läheb normaalseks tagasi ja kõik. lame. pluss siis muidugi see, et rämesuurt autovrakki saan tõsta või nügida aga ühtegi vastast ei saa.
_________________ - londiste
viimati muutis londiste 06.06.2006 16:47:40, muudetud 1 kord |
217 |
lightbluefox
06.06.2006 12:41:04
pelasin normaliga, aga jah, see lifti parandamise koht oli ikka lahe
Pimedas ringi kolada ja kui lõpus lift korda sai ja need kiired zombid tulid oli ikka süda saapasääres xD
Seal häiris eriti see, et freemani taskulambi patareid pidasid vastu sama hästi kui 4 aastat vanad igapäev tarvitud odavad NiCl akupatakad Plõks põlema, plõks tühi.
Jookse siis pimedas karjete saatel ringi.
44 |
H!tman
06.06.2006 12:44:44
| UB kirjutas: |
Siin ei ole midagi kirjeldada, sest HL2 ja Episode One ei erine teineteisest väga palju. Järjes on sulle ainult üks lobamokk teele kaasa antud, kes ei vaja kunagi laskemoona ega esmaabi, vaatamata sellele, et tal eiole sellist kaitsvat ülikonda nagu peategelasel, seega võib päris paljud madinad tema hooleks jätta. Eriti just alguses kui laskemoonaga on kitsas käes. Kindlasti on leiutamist rohkem kui HL2s, kuid ei midagi kaelamurdvat, kuid ma usun, et aja peale on seda mängu kindlasti palju raskem mäbi teha kui seda HL2 puhul oli  |
noo see loba mokk saabüsna kergesti tegelikult surma kui sa ta korraks üksinda peaks jätma!
| Kommentaarid: 43 loe/lisa |
28 |
Flavius
06.06.2006 13:17:40
| Raidomarek kirjutas: |
Jookse siis pimedas karjete saatel ringi. |
ise jaman selles kohas praegu, ei saa edasi kuidagi
laen akut nii et 3-4 pulka tuleb, lylitan sisse ja siis kari vehkivate k2tega lambaid ja suitsiidizombisid juba ymberringi
gravity gun muutus tyytuks hl2 l6pus, aga praegu t2itsa lahe asi, granaate annab zombide k2est rebida ja kui padrunid otsas, siis viskad neid dumbasse k6igega, mis ette satub
118 |
Tbit
06.06.2006 13:24:58
viska nende baloonide ja tünnidega mis plahvatavad, need vennikesed võtavad kenasti tule otsa ja põlevad oma tükk aega ning valgustavad ümbrust.
230 |
Auron
06.06.2006 13:41:57
Kuna tahaks ka ise asja proovida siis kanged pelajad võiks keegi öelda kust asja osta saab ja mis hinnaga, oleks tänulik
133 |
Smoking
06.06.2006 14:15:34
| Auron kirjutas: |
Kuna tahaks ka ise asja proovida siis kanged pelajad võiks keegi öelda kust asja osta saab ja mis hinnaga, oleks tänulik  |
Kõige mõttekam oleks vast osta otse steamist. Link. Kui ka mäng peaks tulema plaatidena müüki, siis ei tea millal ta Eestisse jõuab?
298 |
t6nn_k
06.06.2006 14:20:12
| Mulle meeldis eelnev osa kuidagi rohkem, sest seal oli ikka rohkem madinat erinevate masinate ja vastastega. Aga jah... hea mäng, trailerist tundus et järgmine episood tuleb tunduvalt põnevam kui esimene 8)
denis28
06.06.2006 15:49:37
| Kui ma ostan poest half life 2 kas siis ma saan neid episoode ja source elulõpuni mängida we?
| Kommentaarid: 67 loe/lisa |
rene p
06.06.2006 16:41:04
| ei saa sa midagi, kõik episoodid ja mängud mis on sortsu mootoril, pead ikka eraldi ostma.
68 |
madness
06.06.2006 17:03:15
| londiste kirjutas: |
| pluss siis muidugi see, et rämesuurt autovrakki saan tõsta või nügida aga ühtegi vastast ei saa. |
antlioneid sai küll pikali lükata
Auron
06.06.2006 17:35:14
| Kas episode 1'es kahh annab GG'd nagu sellesk eriti kapiks saada, et kõike saab pilduda?
133 |
madness
06.06.2006 17:37:56
| Auron kirjutas: |
| Kas episode 1'es kahh annab GG'd nagu sellesk eriti kapiks saada, et kõike saab pilduda? |
suht alguses on mõnda aega..
ahvilõust
06.06.2006 17:48:17
Miks nad selle Ep2 traileri nüüd juba välja lasid huvi Ep1 vastu täitsa kadunud, keegi siin ei kiida ka eriti nii et ei hakka ostma kah.
Teile ei tundu, et Alyx näeb nüüd palju vanem välja kui orginaalis, näol on palju rohkem kortse.
_________________ Gdesainer |
| Kommentaarid: 8 loe/lisa |
madness
06.06.2006 17:50:23
| ahvilõust kirjutas: |
Teile ei tundu, et Alyx näeb nüüd palju vanem välja kui orginaalis, näol on palju rohkem kortse. |
ei kiida ? no ma kiidan siis
ja Ep2 trailer tuleb peale mängu läbimist..mis selles halba on ?
zaG
06.06.2006 18:10:46
Ma siis kiidan ka!
Episood 1 oli ülihea mäng, kuna koguaeg käis tegevus ja ei olnud mingeid mõttetult pikke sõite masinatega nagu HL2, kus need muutusid üsnagi tüütuks.
| Kommentaarid: 49 loe/lisa |
47 |
t6nn_k
06.06.2006 18:27:29
ei mulle episood 1 täitsa meeldis aga midagi jäi nagu puudu ja lühikese võitu oli kah teine.
eks see ole selle episoodilise mängu miinuseks siis
noQ
06.06.2006 20:00:55
kiidusõnad ka minu poolt. Täitsa äge oli, aga suhteliselt lühikeseks jäi küll. stoori huvilistele kohustuslik
_________________ huumor. |
| Kommentaarid: 24 loe/lisa |
24 |
j22lind
06.06.2006 23:21:51
kas sellest mängust ka demo on tulekul kuhugi??
Psych0
06.06.2006 23:29:04
ei taha eriti uskuda et episode one-st tehakse demo...
aga kõike võib juhtuda
| Kommentaarid: 61 loe/lisa |
57 |
Flavius
07.06.2006 00:10:31
| j22lind kirjutas: |
| kas sellest mängust ka demo on tulekul kuhugi?? |
ep1 oligi nagu demo v2ga lyhike
see reaktor (kera) vms alguses on p2ris ilusti tehtud. yldiselt j2ttis postiivse mulje, kiire tempoga m2ng, k6ike oli: zombisid, pimedust, suitsiiditerroriste, tynne, rohutirtse, lennukeid ja k6vasti tulistamist. l6pus oli pikakoivaline pirtsakas tibi, tykk aega tuli jamada, et teda jalust rabada
nüüd tuleb j6uludeni ep2 oodata
118 |
limp
07.06.2006 08:16:49
sellepärast et see mäng nii lühike on, ei kisu küll 20$ välja käima... neil seal complete valve pack vms. nad võiks goldid ka selleks ümber nimetada saaks ka peleda siis. praegu seisab niisama gold pakk.. varem sai vähemalt miskisugust modi peletud netis..
_________________ Ärgake lapsed, maailm on hädaohus
Windows keskkond on nagu li*s - kõik teda ke*ivad aga keegi teda ei armasta! |
52 |
