Rutz
06.04.2006 19:41:30
Pentium M 740 @2,6GHz (10x260) 1,4v
Asus P4GPL-X + Asus CT-479
Crucial Ballistix Tracer @260mhz 2,5-2-2-5 2,8v
Memory Read: 5404 MB/s
Memory Write: 5531 MB/s
Memory Copy 4062 MB/s
Memory Latency: 58,1 ns
CPU Queen: 2096
CPU PhotoWorxx: 12823
CPU ZLib: 16500 KB/s
FPU Julia: 1084
FPU Mandel: 1866
FPU SinJulia: 1423
Kommentaarid: 401 loe/lisa |
345 |
tonu89
09.04.2006 20:57:00
arvuti profiilis:
Memory Read: 3948 MB/s
Memory Write: 1170 MB/s
Memory Latency: 67,4 ns
CPU Queen: 1904
CPU PhotoWorxx: 2832
CPU ZLib: 12661 KB/s
FPU Julia:408
FPU Mandel: 904
FPU SinJulia: 1091
_________________ In Heaven an angel is nobody in particular. |
Kommentaarid: 20 loe/lisa |
18 |
Zonerman
11.04.2006 21:06:02
Profiilis:
AMD Opteron 146 @ 2700MHz
2x512GB @ 2.5-4-3-7-1T @ 300MHz 2.76v
mälust lugemine: 9001
mällu kirjutamine: 7766
memory copy: 7868
mälu latentsus: 37,7
CPU Queen: 2602
CPU Photoworxx: 16445
CPU Zlib: 16145
FPU Julia: 1540
FPU Mandel: 2291
FPU SinJulia: 1409
_________________ Sõim ja räuskamine läheb SIIA |
Kommentaarid: 66 loe/lisa |
65 |
limp
12.04.2006 18:12:41
Tegin ka uuesti, seekord 280x9 klokiga: mälu 2x512 ja 3-4-4-8
Memory Read: 8366 MB/s
Memory Write: 7256 MB/s
Memory Latenicy: 43,0 ns
CPU Queen: 2422
CPU PhotoWorxx: 14465
CPU ZLib: 14920 KB/s
FPU Julia: 1432
FPU Mandel: 2131
FPU SinJulia: 1310
_________________ Ärgake lapsed, maailm on hädaohus
Windows keskkond on nagu li*s - kõik teda ke*ivad aga keegi teda ei armasta! |
Kommentaarid: 56 loe/lisa |
52 |
One
14.04.2006 13:02:59
¤ Pentium D920 @ 4.626GHz / 1.55v / Air
¤ Asus P5WD2
¤ 2 x 512mb Corsair PC8000UL "Fatbody" @ 990MHz / 4-3-3-8-4 / 2.2v
Memory read 10351
Memory write 7025
Memory copy 6980
CPU queen 4964
CPU photoworxx 27125
CPU ZLib 32689
FPU Julia 4293
FPU Mandel 7164
FPU SinJulia 2514
päris korralik lammutamine
AMD-i vandid, laske üle nüüd
Kommentaarid: 1009 loe/lisa |
728 |
riaak
17.04.2006 22:28:39
24/7 conf:
A64 3800+ @ def
2x512MB AM1 200Mhz 2-3-3-5-1T
Memory Read: 6131 MB/s
Memory Write: 6186 MB/s
Memory Copy: 5248 MB/s
Memory Latency: 46.5 ns
CPU Queen: 2292
CPU PhotoWorxx: 13281
CPU ZLib: 14137 KB/s
FPU Julia: 1351
FPU Mandel: 2017
FPU SinJulia: 1241
_________________ ¯\_(ツ)_/¯ |
Kommentaarid: 119 loe/lisa |
105 |
Mask
17.04.2006 23:31:55
minu 24/7 prääga:
sempron64 2480Mhz def volt, mem 512MB 2,5.4.4.8 2T DDR620 8)
read 4728MB/s
write 3819MB/s
copy 4191MB/s
latency 39,3ns
CPU queen 2389
CPU photoworxx 12806
CPU Zlib 14297KB/s
FPU Julia 1413
FPU Mandel 2102
FPU SInJulia 1292
Kommentaarid: 521 loe/lisa |
434 |
DonNiger
18.04.2006 00:43:59
see siis kõik deffis:
EDIT: mälu on 4-4-4-12-19 2T
EDIT2: siiski mitte päris deffis, kui panna bioses load optimized ... , sätib perfi automatic overclocking. seega, pole õrna aimugi, mis kelladel. mälu timingud aga peaks õiged olema.
Memory Read: 6370 MB/s
Memory Write: 4280 MB/s
Memory Copy 4620 MB/s
Memory Latency: 88,2 ns
CPU Queen: 2267
CPU PhotoWorxx: 11500
CPU ZLib: 13452 KB/s
FPU Julia: 1745
FPU Mandel: 3300
FPU SinJulia: 1442
Kommentaarid: 142 loe/lisa |
116 |
aks
22.04.2006 20:46:00
link :: Sellise tavalise 300x9 klokiga tehtud screen.
Memory Read: 8900 MB/s
Memory Write: 7679 MB/s
Memory Copy 7457 MB/s
Memory Latency: 38,9 ns
CPU Queen: 2598
CPU PhotoWorxx: 15851
CPU ZLib: 16059 KB/s
FPU Julia: 1534
FPU Mandel: 2286
FPU SinJulia: 1407
Kuna Winter siin kinda viskas siis kahes testis sain isegi jagu
Kommentaarid: 128 loe/lisa |
119 |
blaster1
22.04.2006 22:00:28
P4 3,2GHZ 640
DDR2 667MHZ dualis
Memori read-6238
Memory write-4077
memory copy-4308
Memory latency-92.1
cpu queen-2166
cpu photoworxx-10253
cpu zlib-12851
fpu julia-1659
fpu mandel-3166
fpu sinjulia-1373
Kommentaarid: 53 loe/lisa |
47 |
DonNiger
23.04.2006 00:15:31
blaster1 kirjutas: |
P4 3,2GHZ 640
DDR2 667MHZ dual
Mul samad jubinad, seega pani bios mingi osa juurde.
116 |
blaster1
23.04.2006 16:32:36
riisaar kirjutas: |
P4 3,2GHZ 640
DDR2 667MHZ dual
Mul samad jubinad, seega pani bios mingi osa juurde. |
Mul oli kõik defauldis ja taga töötas terve hunnik programme
47 |
One
23.04.2006 18:23:19
aks kirjutas: |
Kuna Winter siin kinda viskas siis kahes testis sain isegi jagu  |
mem write ja latency on amd-l muidugi parem
728 |
Zonerman
23.04.2006 21:05:47
Huvitav, et keegi oma dualcore amd'ga pole viitsinud siia oma tulemust panna. Just opty 165/170 või X2. Enamus on siin single core va WW.
65 |
excalibur
23.04.2006 21:38:18
Memory read: 5909
Memory write: 4240
Memory Latency: 100ns
Memory copy: 3898
CPU queen : 3017
CPU photoworxx: 13241
CPU Zlib: 20654
FPU Julia: 2594
FPU Mandel: 4368
FPU Sin Julia: 1513
muu on nagu enamvähem aga mälu maru sitt
Kommentaarid: 316 loe/lisa |
262 |
jan1
Kommentaarid: 11 loe/lisa |
One
10.05.2006 22:13:02
jan1 kirjutas: |
mille temp see PWM-on  |
emaplaadi toiteahel
728 |
DonNiger
26.05.2006 18:55:14
Testisin just müügisolevaid kingstoni PC4300 mälusid kiirusel 533@651 Mhz ja kelladel 4-4-4-10
Memory Read: 7868 MB/s
Memory Write: 5362 MB/s
Memory Copy 5473 MB/s
Memory Latency: 75,3 ns
CPU Queen: 2841
CPU PhotoWorxx: 12991
CPU ZLib: 16684 KB/s
FPU Julia: 2186
FPU Mandel: 4152
FPU SinJulia: 1814
116 |
aks
02.06.2006 18:39:07
Töökaaslase masinat putitades lipsas prose kogemata korraks ka minu masinasse
Prose siis Athlon 64 X2 3800+ (toledo)
Eriti kaua pusida polnud aega kuid klokkisin selle 300x9=2700MHz ja tulem oli järgmine.
Ei tea kas asi selles, et win oli 64-bit aga näiteks memory copy oli kadunud millegipärast.
Memory Read: 6451 MB/s
Memory Write: 1901 MB/s
Memory Copy: kadunud
Memory Latency: 46,8 ns
CPU Queen: 4848
CPU PhotoWorxx: 22963
CPU ZLib: 32314
FPU Julia: 3061
FPU Mandel: 4533
FPU SinJulia: 2815
119 |
ViskeRelv
03.06.2006 11:03:35
juuri321 kirjutas: |
AMD Sempron 2800+ Venice256 S754
512mb ram pc3200
Memory Read: 2627 MB/s
Memory Write: 887 MB/s
Memory Latency: 75,8 ns
CPU Queen: 1409
CPU PhotoWorxx: 7293
CPU ZLib: 8920 KB/s
FPU Julia: 902
FPU Mandel: 1307
FPU SinJulia: 816 |
Sai nats klokitud ja mälu vahetatud D43 vastu
Everest näitab nüüd 3200+
Memory Read: 3756 MB/s
Memory Write: 3746 MB/s
Memory Copy: 3728 MB/s
Memory Latency: 45.1 ns
CPU Queen: 1851
CPU PhotoWorxx: 10966
CPU ZLib: 11355 KB/s
FPU Julia: 1094
FPU Mandel: 1629
FPU SinJulia: 1002
Kommentaarid: 187 loe/lisa |
167 |
heikis
19.09.2006 20:19:20
24/7 olek: E6400 @ 3200MHz, DDR2-1000 4-4-3-4
Memory Read: 14796 MB/s
Memory Write: 7273 MB/s
Memory Copy: 7548 MB/s
Memory Latency: 49.5 ns
CPU Queen: 5943
CPU PhotoWorxx: 22792
CPU ZLib: 42703 KB/s
FPU Julia: 8684
FPU Mandel: 11629
FPU SinJulia: 3665
Kommentaarid: 338 loe/lisa |
290 |
jyrgen
27.09.2006 00:18:56
24/7 olek: E6300 @ 3402MHz, 2x1GB DDR2-972 4-4-4-4
Memory Read: 14835 MB/s
Memory Write: 8717 MB/s
Memory Copy: 7407 MB/s
Memory Latency: 61.9 ns
CPU Queen: 6309
CPU PhotoWorxx: 28017
CPU ZLib: 45195 KB/s
FPU Julia: 9234
FPU Mandel: 12421
FPU SinJulia: 3890
20 |
Hardi
27.09.2006 00:37:01
Memory Read: 2450 MB/s
Memory Write: 2485 MB/s
Memory Copy: 1994 MB/s
Memory Latency: 123.0 ns
CPU Queen: 1667
CPU PhotoWorkxx: 5059
CPU ZLib: 4879 KB/s
FPU Julia: 1343
FPU Mandel: 2643
FPU SinJulia: 973
_________________ ツ |
Kommentaarid: 82 loe/lisa |
68 |
dexter666
27.09.2006 00:54:19
24/7 olek: AMD 3200+ venice@3500+ 10x220mhz. Mälud Super Talent 2x256mb 2-3-3-6 dualis @ 220mhz 2T (mälud kannatavad ka 2-2-2-5 1T)
Memory Read: 6630 MB/s
Memory Write: 6150 MB/s
Memory Copy: 5336 MB/s
Memory Latency: 46,3 ns
CPU Queen: 2111
CPU PhotoWorkxx: 12626
CPU ZLib: 13070 KB/s
FPU Julia: 1324
FPU Mandel: 2066
FPU SinJulia: 1149
Kommentaarid: 93 loe/lisa |
85 |
Sanderico
28.09.2006 22:40:37
AMD Sempron 2500+ (1,73 GHz)
DIMM1 256MB PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz)
DIMM2 256MB PC3200 DDR SDRAM (2.5-4-4-8 @ 200 MHz)
Memory Read: 2084 MB/s
Memory Write: 637 MB/s
Memory Latency: 144.4 ns
CPU Queen: 1423
CPU PhotoWorkxx: 4878
CPU ZLib: 8936 KB/s
FPU Julia: 940
FPU Mandel: 877
FPU SinJulia: 909
Kommentaarid: 48 loe/lisa |
47 |
