excalibur
09.04.2006 10:43:20
dual core? |
| mille poolest erineb dual core protsessor mitte dual corest. ja palju neil vahet arvutis on?
262 |
margusser
09.04.2006 10:44:43
dualcore aka 2in1
oleneb mida teed.
167 |
excalibur
09.04.2006 10:48:42
Field Value
CPU Properties
CPU Type DualCore Intel Pentium D 820, 2800 MHz (14 x 200)
CPU Alias Smithfield
CPU Stepping A0
Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3
Original Clock 2800 MHz
Min / Max CPU Multiplier 14x / 14x
Engineering Sample No
L1 Trace Cache 12K Instructions
L1 Data Cache 16 KB
L2 Cache 1 MB per core (On-Die, ECC, ATC, Full-Speed)
Multi CPU
Motherboard ID INTEL
CPU #0 Intel(R) Pentium(R) D CPU 2.80GHz, 2810 MHz
CPU #1 Intel(R) Pentium(R) D CPU 2.80GHz, 2810 MHz
CPU Physical Info
Package Type 775 Contact LGA
Package Size 3.75 cm x 3.75 cm
Transistors 230 million
Process Technology 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si
Die Size 206 mm2
Core Voltage 1.3 V
I/O Voltage 1.3 V
Typical Power 95 W @ 2.80 GHz
Maximum Power 130 W @ 2.80 GHz
CPU Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization
CPU #1 / Core #1 3 %
CPU #1 / Core #2 2 %
see on juba arvutis olemas lihtsalt uurin
kas labaselt öeldes on see 2,8x2
262 |
margusser
09.04.2006 10:57:37
ma ei tea sa võid teda kasvuhooneks ka kutsuda.
Labaselt öeldes on ta D820
167 |
Marie
09.04.2006 12:01:46
| excalibur kirjutas: |
CPU Utilization
kas labaselt öeldes on see 2,8x2 |
Arvasin varem, et ikka HT (Hyper-Threading Technology ) tugi ka neil Dual-core protsessoritel olemas, ei näegi erilist vahet siis vana olemas oleva protsessoriga
| ot: |
Protsessori kasutamine
CPU #1 / HTT Unit #1 0 %
CPU #1 / HTT Unit #2 3 % |
tootetakse ka HT toega Dual-core protsessoreid, mille puhul oleks nagu arvutis neli protsessorit.
| Kommentaarid: 83 loe/lisa |
74 |
10.04.2006 09:14:47
oeh, ht ja dualcore on piisavalt erinevad asjad siiski. ht korral pole kahest corest haisugi, lihtsalt suudetakse olemasolevat jõudu pisut paremini ära planeerida.
_________________ - londiste
216 |
Ho Ho
10.04.2006 09:20:47
See pisut paremini annab reaalelus keskmiselt 3-5% kiiruselisa, harva kuni 10%. Loomulikult peab programm oskama ka midagi mitme prosega peale hakata et suudaks HT'd ära kasutada.
86 |
remi
10.04.2006 22:35:01
| Jah, on ka DC+HT prosesid. Extreme edition nimeks, task manageris paistab 4 protsessorit.
| Kommentaarid: 16 loe/lisa |
Ho Ho
10.04.2006 22:47:28
| remi kirjutas: |
| Jah, on ka DC+HT prosesid. Extreme edition nimeks, task manageris paistab 4 protsessorit. |
Kusjuures taoliste prosedega võib juhtuda et HT'st on rohkem kahju kui kasu
Näiteks kui programm jooksutab paralleelselt kaht threadi ning mõlemad satuvad tööle ühe prose lahes virtuaalproses on kiirus sama mis ühe HT tuumaga prose puhul.
Võimalik et saab kusagilt muuta mis järjekorras prosede vahel koormust jaotatakse ning milliseid eelisatakse. Wini all ma kahtlen et see võimalik oleks, Linuxis vast mõne patchiga saab asju confida.
86 |
mmarti
10.04.2006 22:54:24
| Ho Ho kirjutas: |
| remi kirjutas: |
Võimalik et saab kusagilt muuta mis järjekorras prosede vahel koormust jaotatakse ning milliseid eelisatakse. Wini all ma kahtlen et see võimalik oleks, Linuxis vast mõne patchiga saab asju confida. |
Sellisel juhul võib ju bios-es HT lihtsalt välja lükata...
| Kommentaarid: 4 loe/lisa |
Ho Ho
10.04.2006 23:02:15
Kusjuures Intel just seda soovitabki teha oma serverites
86 |
piimaPAKK
11.04.2006 07:47:27
Kusjuures WinXP all saab task manageerist määrata millist proset programm tohib kasutada. Väga abiks kui juhtub X2 olema ja tahad mingit tiba vanemat mängu teha (mis muidu syncro problade tõttu ~2x kiiremini jookseb ).
Auron
11.04.2006 08:26:04
| piimaPAKK kirjutas: |
Kusjuures WinXP all saab task manageerist määrata millist proset programm tohib kasutada. Väga abiks kui juhtub X2 olema ja tahad mingit tiba vanemat mängu teha (mis muidu syncro problade tõttu ~2x kiiremini jookseb ). |
Mitte aint "tiba" vanemat mängu.Näiteks prince of persia two thrones, need for speed most wanted ja nii mõnelegi asjale ei meeldi dualcore.Anomaaliaid on küll erinevaid (üks katkub, teine jookseb liiga kiiresti) aga lahti saab mõlema puhul kas siis ainult ühe prose kasutust määrates kui ka mõndade asjade puhul fixib viimane AMD dualcore driver ära (näiteks everquest 2'es).
132 |
Ho Ho
11.04.2006 08:36:54
| Kusjuures WinXP all saab task manageerist määrata millist proset programm tohib kasutada. |
Seda ma tean, taolist manuaalset värki saab praktiliselt iga OS'iga teham.
Ma pidasin silmas seda et kui ühel prosel on juba koormus peal siis OS määrab järmisele progele tavaliselt üsna suvaliselt jooksutava prose kuid oleks tarvis seda et saaks ise määrata mis järjekorras võiks prosesid koormata. Näiteks kui masinas on kaks HT'ga tuuma, esimese prose numbrid on 0 ja 1, teisel 2 ja 3 siis võiks järjekord olla näiteks 0, 2, 1, 3.
86 |
excalibur
14.04.2006 21:06:20
| palju ja kas on vahet 2mb ja 4mb vahemäluga protsessoril. kas annab reaalset vahet kah
262 |
Ho Ho
14.04.2006 21:37:04
Tegelikult pead sa vast silmas dualcore prosesid milledel on kummagil tuumal kas 1 või 2M vahemälu
Kõik oleneb konkreetsest rakendusest. Üldkeskmiselt võiks öelda et vahe on üsna väike.
86 |
14.04.2006 21:41:49
| Ho Ho kirjutas: |
| Kõik oleneb konkreetsest rakendusest. |
/me irvitab.
lisada kkk-le - küsimuse juures palun täpsustada, mille jaoks või mille osas küsimus vajalik on
| tava koduarvutil. |
mängid, vaatad filme, pakid filme, taustal jookseb ka midagi, ei jookse?
viimati muutis londiste 14.04.2006 21:49:24, muudetud 1 kord |
216 |
excalibur
14.04.2006 21:48:08
| tava koduarvutil.
262 |
Ho Ho
14.04.2006 22:09:11
| londiste kirjutas: |
| Ho Ho kirjutas: |
/me irvitab. |
Eks sellega saaks vastatud ~90% kõigist küsimustest milles pole täpsustusi toodud
Minu teooria järgi peaks näiteks filmide pakkimisel suuremast vahemälust veidi rohkem kasu olema kui mängude puhul.
Samas kui mõni mäng kasutab aktiivselt väga vähe mälu (enamus muutujaid mahub vahemällu, kord kaadris läbi streamitavad andmed ei lähe arvesse) siis võib juhtuda et kui kõik need andmed mahuvad vahemällu siis muutub kiirus märksa paremaks. Kui õieti mäletan siis oli kunagi selline lugu quake3'ga. Enamus prosedel oli siis vahemälu 0.5M või vähem kuid Inteli EE prosel oli 2.5M ning mäng muutus hüppeliselt märksa kiiremaks eeldusel et prose ei piira.
Kui sul on mõttes ühe või teise prose ostmine siis parem küsi seda otse. Tõenäoliselt oskavad HV'lased kamba peale selgeks teha milline variant parem on. Sedasi paari asja kohta aru pärides ning teadmisi kogudes võib nii mõndagi olulist vahele jääda mis kaalukaussi ühele või teisele poole kallutada võib.
86 |
summutaja
25.04.2006 18:02:25
| Auron kirjutas: |
Mitte aint "tiba" vanemat mängu.Näiteks prince of persia two thrones, need for speed most wanted ja nii mõnelegi asjale ei meeldi dualcore.Anomaaliaid on küll erinevaid (üks katkub, teine jookseb liiga kiiresti) aga lahti saab mõlema puhul kas siis ainult ühe prose kasutust määrates kui ka mõndade asjade puhul fixib viimane AMD dualcore driver ära (näiteks everquest 2'es). |
Tegid juttu siin Dual Core driveritest. Kust ma saaksin oma prosele kõige uuemad AMD dual core driverid ja kuidas neid installitakse?
| Kommentaarid: 124 loe/lisa |
117 |
Auron
25.04.2006 18:32:58
| summutaja kirjutas: |
| Auron kirjutas: |
Tegid juttu siin Dual Core driveritest. Kust ma saaksin oma prosele kõige uuemad AMD dual core driverid ja kuidas neid installitakse? |
32-bit win XP driverid http://www.amd.com/us-en/assets/content_type/utilities/amdcpu.exe
64-bit win XP driverid http://www.amd.com/us-en/assets/content_type/utilities/amdcpu64.exe
Kahjuks ei aita need absoluutselt kõigi mängude puhul kuna anomaaliaid on erinevaid ja nondes mängudes tuleb ikkagi affinity't näppida.
132 |
summutaja
25.04.2006 18:46:44
| Auron kirjutas: |
| Auron kirjutas: |
Kahjuks ei aita need absoluutselt kõigi mängude puhul kuna anomaaliaid on erinevaid ja nondes mängudes tuleb ikkagi affinity't näppida. |
Küsimus siis, kas see üldse aitab?
117 |
25.04.2006 19:46:30
kui dualcore toetus on (mis uuematel mängudel järjest rohkem olema hakkab), siis aitab.
muidu on pädev kasvõi sellepärast, et taustal jooksev nänn + draiverid saab teise core peale ära surada.
216 |
