Marduuhin
21.03.2006 13:48:07
Kuigi minuarust mingi kümne ajal ma läksin mängima..
Aga selliste asjade juures tuleb alati arvetada, et need ei saa tähtajaliselt valmis.
_________________ Eesti õigekeelsussõnaraamat ÕS 2018 |
108 |
kjaups
MeesKesTuliMetsast
21.03.2006 13:59:01
| kirjutas: |
Hello. This is Masangsoft Inc.
First of all, we want to thank all of our fans who love our game, SpaceCowboy.
SpaceCowboy Episode I was developed in Korea, and Episode II was developed within the last year. Since October 2005, the game has been in close beta test through Game&Game. This test is now scheduled to end on May 31, 2006. From them on, our global test service will be provided by Gala-Net, Inc. Currently, Gala-Net is the publish of Flyff (http://flyff.gpotato.com/index.php) in English speaking territories.
Below are the server transfer schedules:
March 31, 2006: Space Cowboy Episode II closed beta service terminated.
April 3, 2006: Space Cowboy Episode II Re-opened through Gala-Net.
Please note that these schedules are subjected to change.
Gala-Net's licensed service areas for SpaceCowboy Episode II are North/South America, Europe, Australia, Philippines, Singapore, and Malaysia. Other areas that have not been mentioned can also log in. However, other areas that has not been mentioned may, in the future, acquire their own local publisher. If that happens, connection to the global server may become unavailable due to contract issues.
Players previously registered with Masangsoft for SpaceCowboy will be receiving notices via email to re-register with Gala-Net. As an added incentive, free GPotato will be award to those players. Please look for the email from Gala-Net, as more details will be available then.
Some Asian countries may receive localized service within their own nation if we find a localized publisher.(Currently, Korea and Vietnam has localized publishers in their own localized language.) |
No siis tehakse si´in neid serveri ümbertõstmis korraldusi. Et 31 märts pannakse praegune server kinni ja avatakse uus server 3 aprill. Vanad kontod jäävad alles.
[EDIT] Kui Marduuhini jutt vastab tõele, siis kella kümnest tuleb hoopis arvestada 2 tundi + 2 tundi ja siis peaks server üleval olemas. SpaceCowboys kodukal oli veel üks teade üleva tegijatelt, et checup venib 2 tundi veel.
No, et siis kella 13-14 -neks peaks olemas server taas püsti
_________________ M: KIA Sportage 2023a
YAGA müügiputka - SNAP pildipank
M: 3D Touch V3.2 15€
viimati muutis kjaups 21.03.2006 14:05:01, muudetud 1 kord |
| Kommentaarid: 172 loe/lisa |
141 |
Ty
21.03.2006 14:03:57
| pange screene
| Kommentaarid: 4 loe/lisa |
kjaups
MeesKesTuliMetsast
141 |
Ty
21.03.2006 15:00:37
loomulikult ingame screenshote
kjaups
MeesKesTuliMetsast
141 |
ZAndlamb
| Kommentaarid: 22 loe/lisa |
22 |
Marduuhin
108 |
tiith
maxnorm
| Kommentaarid: 21 loe/lisa |
19 |
kjaups
MeesKesTuliMetsast
21.03.2006 23:33:04
Kui kellelgi on vaja I ja A GEAR stuffi, siis otsigu mind üles, mul neid igasuguseid ja kusagil level 30 kanti
Muidugi, all gear stuffi on ka lademetes (eriti radareid ja kompuutreid)
Mardu, ironi soovi või??? Mul seda ka mingi 20 kanti, otsi mind üles
Hakkan endal level 26-te tegema peale pisikest auto sõitu
M: 3D Touch V3.2 15€ |
141 |
Marduuhin
21.03.2006 23:35:58
Eks kui ma homme viitsin mängida, siis kindlasti soovin ironit osta.. Ma olen seda kogu mängu peale ~2-3 juppi saanud.
108 |
vantvol
22.03.2006 00:52:27
kjaups, kyl kuda sa selle lev 25 questi tegid?see kus pidid kuskil kosmoses lendama?chaos vms?
_________________ asdf |
Marduuhin
108 |
kjaups
MeesKesTuliMetsast
22.03.2006 05:08:42
vantvol, millist sa mõtled. Ma teen neid kahte erinevat korraga. Et kas seda, kus pead ühe pallikese ära havitama kaarti kesekl ja siis väravasse põrutama ning sealt väravast elu eest kihutama real time või oli siis real world väravasse (üks quest oli selline)... Teine oli vist, et pidid ühe tüübi ära killima ja siis kaarti keskel olevast kollasest rõngast läbi sõitma.
Valus ajude k*pp käib nende levelite täis saamisega. Mulle hakkab tunduma, et tank oleks olnud kõige parem valik, sest 90% asjadest mida ma nüüd pean ära hävitama seisavad paigal ja lennukiga peab sealt ca 10 korda mõõda sõitma ja rakettid teele saatma, kuigi tankiga saaks paigal olla ja niisama pommitada
Kui jõuate missioonini kus peab 60 helltroni (vmt nimega) ära killima, siis soovin teile edu. Ise n*ssisin seal ca 3h-d ning alles lõppu poole jagasin matsu lahti, et kuidas neid v*rdjaid kõige kergem on killida
141 |
vantvol
22.03.2006 08:42:14
kjaups, questi nimi on nightmare ja see on lev 25 quest
kjaups
MeesKesTuliMetsast
22.03.2006 13:36:36
vantvol, Seal missioon kust hakka, tuled vist maailma nurgast väravast välja. Lendad kaardi keskele sinna kividest rõngasse ning lendad maad lingi ja otsid ühte kollakat kera. Selle hävitad ära ning saad selle 1 värgi endale ära. Lendad tagasi sinna väravasse kust tulid. Siis jõuad kosmosesse välja, võtad kohe mapi ette ja kihutad seal kosmoses teisel pool kaarti olevasse väravasse ja oledki teinud selle. Aga kosmoses ole ettevaatlik ja anna hagu kuidas jaksad, sest seal sellised tüübid, kes sind kohe sihikule võtavad
Ise sain selle mingi viie minutiga tehtud (kui on see missioon, pea on suht s*tt)
Kui kellelgi on upgreidimis kaarte (ükstapuha milliseid) siis võiks mind üles otsida. Vastu annaks metalle või relvi (aint, et B-Gear relvi ei ole nii võimsaid anda).
Ma praegu pelama.
141 |
PaRaZiD
22.03.2006 20:40:37
ei tea mis jama mul on aga ma ei saa mängu kuidagi tööle
tõmbasin kodukalt seda installikat 772mega
installin ära panen käima siis tykk aega on nagu kinni jooxnud siis tuleb selline pilt ette
http://www.zone.ee/lmz/1.JPG?2
vajutad ok ja siis tuleb
http://www.zone.ee/lmz/2.JPG?2
reinstalli proovisin juba
| Kommentaarid: 12 loe/lisa |
12 |
kjaups
MeesKesTuliMetsast
141 |
PaRaZiD
22.03.2006 21:23:08
| njah patch aitas aga id on ikka puudu
12 |
xerox
22.03.2006 23:10:22
| ütleb, et vaja id'd, kuid regada ei lase
90 |
kjaups
MeesKesTuliMetsast
141 |
PaRaZiD
23.03.2006 07:42:16
sign up -i vajutamisel tuleb selline asi ette We didn't receive above member joining from this home page.
Check the Notice
12 |
Dominus
23.03.2006 08:31:10
| Kas SpaceCowboys clan war/pvp ja mõni event on ka sisse pandud? või lihtsalt leveldad,tapad,teed queste?
76 |
kjaups
MeesKesTuliMetsast
23.03.2006 10:28:32
Mafka, clanni tegemise variant on olemas. võtad clanniga ette ja lähed tappad nõrgemaid . Mulle lennati eile nii mingi 3 korda peale kahekesi (minust mingi 10 levelit tugevamad ).... Aga ühe m*nni ajasin seal suitsema, siis tuli talle teine appi ...
Ma tegin ise ka praegu clanni, Eestlased, viskan sinna veel eesti lippu ka peale. Muidu, clanni siseselt saab warehousis asju ka vahetada. Et paned sinna ära ja kui kellelgi on vaja sutsu tugevama vastu vahetada, siis läheb ja viskab asjad ringi
Proovi mõnda muud browserit või mõne muu arvuti taga. IE oleks soovitatav
141 |
Ty
