punktiir
12.03.2006 23:57:03
| kunagi liikus üks mingi 300 küsimusega test, küll oli seal hardwarest, küll programeerimiskeeltest ja sowtwaredest küsimusi, ega keegi ei tea kus seda leida võib. koogelmoogeldasin aga ei midagi
| Kommentaarid: 49 loe/lisa |
38 |
taavi
| Kommentaarid: 70 loe/lisa |
61 |
Death
13.03.2006 11:16:00
v6sa PCQI testis sain 90% mööda panin ysna nõmedate asjadega, näiteks ei tulnud pähegi et jumperitks võiks pidada neid kahte pinni mis minu meelest jumperiga kokku pannakse.
_________________ "To be or not to be?" is a question of when, not if. |
| Kommentaarid: 39 loe/lisa |
36 |
riaak
13.03.2006 16:17:09
h4x0r olen
Congratulations computer h4x0r! You scored -27!
You may know how to use what you need when you need to, but you should never, ever attempt to help anyone else with their computer woes. And if your's is broken, seek outside help.
My test tracked 1 variable How you compared to other people your age and gender:
free online dating free online dating
You scored higher than 99% on compsmarts
_________________ ¯\_(ツ)_/¯ |
105 |
Death
13.03.2006 18:19:53
taavi, ma sain kolmandal katsel 100 täis...
36 |
doh
13.03.2006 21:43:54
You are definitely above average when it comes to computer knowledge, and are an asset to your friends and family when they are in need of computer related help. However, there is still much to learn, so don't get too big of a head.
You scored higher than 41% on compsmarts
Võiks rohkem olla. Aga test oli sürr
| Kommentaarid: 52 loe/lisa |
50 |
zorten22
14.03.2006 14:49:37
| Kommentaarid: 91 loe/lisa |
Number47
14.03.2006 20:03:24
Computer Guru
Congratulations computer h4x0r! You scored 15!
You spend way too much time tinkering with computers and it's no guess why you're even visiting OKCupid. You already knew you were going to score high, and are probably bitter about constantly being bugged by friends and family to fix their boxes.
You scored higher than 70% on compsmarts
_________________ Ärifoorumi tehingud alaealistega vaid vanemate kirjaliku nõusoleku esitamisel! |
| Kommentaarid: 138 loe/lisa |
110 |
me@homeq
15.03.2006 00:21:33
Computer Neophyte
Congratulations computer h4x0r! You scored -4!
Okay so you know a few things and can probably pass yourself off as smart when it comes to computers, but if anything diffulcult were to go wrong you would be on the phone with tech support.
You scored higher than 9% on compsmarts
PCIQ sain 48%
| Kommentaarid: 23 loe/lisa |
21 |
Ernits
25.03.2006 02:16:02
You scored higher than 32% on compsmarts
88 |
ufo56
25.03.2006 18:13:06
Congratulations computer h4x0r! You scored 15 !
teistkorda sain 5
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
a22t
25.03.2006 20:22:51
Computer Competent
Congratulations computer h4x0r! You scored 8!
8)
rahul.
39% parem vms
| Kommentaarid: 47 loe/lisa |
44 |
hentz88
25.03.2006 21:41:41
You scored higher than 22% on compsmarts
| Kommentaarid: 32 loe/lisa |
30 |
HannesH
26.03.2006 01:50:52
- vana peeru kohta, käib küll
_________________ who is general error and why is he reading my harddisk? |
| Kommentaarid: 24 loe/lisa |
23 |
dac
16.01.2007 13:37:18
Computer Guru
(Congratulations computer h4x0r! You scored 15!)
"You spend way too much time tinkering with computers and it's no guess why you're even visiting OKCupid. You already knew you were going to score high, and are probably bitter about constantly being bugged by friends and family to fix their boxes."
You scored higher than 88% on compsmarts
_________________ team nS |
39 |
contramort
16.01.2007 15:08:02
Computer Competent
Congratulations computer h4x0r! You scored 7!
You scored higher than 35% on compsmarts
Ei hakanud süvenema, panin suht umbes. Eks mingit taolist tulemust oligi oodata.
Lollust pole vaja häbeneda
_________________ ... |
| Kommentaarid: 53 loe/lisa |
51 |
Ruelo
18.01.2007 11:46:13
Congratulations computer h4x0r! You scored 3!
mTim
22.01.2007 06:00:27
That one went rather well I might say...
Congratulations computer h4x0r! You scored 2!
Teise testiga tuli 63% õigeid vastuseid mis arvestades, et ma pole veel magama jõudnud täna, üsna hea tulemus...
_________________ Lexuse summutist tuleb vaid lilleõisi ja ükssarvepeeru - HV foorum
M: E36 varuosad |
42 |
Ramones
24.01.2007 00:16:45
Congratulations computer h4x0r! You scored 14!
Teine test andis tulemuseks 85%
| Kommentaarid: 76 loe/lisa |
75 |
kjaups
MeesKesTuliMetsast
24.01.2007 00:45:27
Congratulations computer h4x0r! You scored 9! My test tracked 1 variable How you compared to other people your age and gender: You scored higher than 62% on compsmarts
Paar küsimust olid nagu et täiesti haiged ja ma ei saanud aru, et kuidas need olid seotud arvutitega
Aga jah, kõik peast ja 62 prossa, peaksin igati rahul olema
_________________ YAGA müügiputka |
| Kommentaarid: 174 loe/lisa |
143 |
doh
24.01.2007 17:09:30
What type of IP address are you currently using?
-Static
-Dynamic
-What's the difference?
-What is an IP address?
hmm, ma ei usu et ta su IP järgi vms loeb vastust õigeks / valeks, vaid loeb õigeks dünaamilise, mida enamus kasutab
50 |
Mihkel.
24.01.2007 17:16:23
Ee... ei oodanud küll sellist tulemust, aga sain 99% ilma google abita.
| Kommentaarid: 92 loe/lisa |
Hardi
24.01.2007 17:31:09
Congratulations computer h4x0r! You scored 11!
"You are definitely above average when it comes to computer knowledge,
However, there is still much to learn, so don't get too big of a head."
.. midaiganes
_________________ ツ |
| Kommentaarid: 85 loe/lisa |
71 |
Eddi
25.01.2007 14:26:14
-2
Sobin vaid sõbra arvutit parandama
_________________ M: Arvutijuppe ( 2x ddram 256mb, video, korpus, mobo )
M: WV Passat 1993a. Lisainfo PS ! |
87 |
Hazar
14.02.2007 17:29:37
You scored higher than 80% on compsmarts
| Kommentaarid: 30 loe/lisa |
29 |
rixk
21.02.2007 14:29:46
Computer Guru
higher than 61%
PCIQ-s mini ja full testiga mõlemaga sain 90%
| Kommentaarid: 35 loe/lisa |
Brom
21.02.2007 14:47:24
17. Which one of these isn't a Linux distribution?
Yellowdog
Gentoo
FreeBSD
Debian
Kõik on õiged?
| Kommentaarid: 13 loe/lisa |
Mario.
21.02.2007 14:48:59
yellowdog isnt
edit: lihtsalt pakkusin, ei tea linuxist midagi
viimati muutis Mario. 21.02.2007 14:56:47, muudetud 1 kord |
6 :: |
217 |
rixk
21.02.2007 14:51:50
| FreeBSD pole linux
Brom
lnxab
21.02.2007 17:41:41
| 5%
| Kommentaarid: 34 loe/lisa |
29 |
mTim
21.02.2007 19:40:36
lnxab, proovi veel lühemalt
M: E36 varuosad |
42 |
ceemic
24/7@kalal
22.02.2007 02:38:39
322 |
lnxab
22.02.2007 14:36:48
| mTim kirjutas: |
lnxab, proovi veel lühemalt  |
mida sa mõtled?
Congratulations computer h4x0r! You scored -2!
ceemic, hästi paned
29 |
miq599
01.03.2007 18:16:27
Computer Guru
Congratulations computer h4x0r! You scored 21!
_________________ "Ooops. My brain just hit a bad sector." |
33 |
