taifunk
11.03.2006 12:34:08
Killhoven, ära aja jama:
Patch v1.21
BUG FIXES
- Fixed the Hmmwv with TOW crash on Battlefield 2: Special Forces maps
- Fixed the Battle Recorder crash
- Fixed the screen capture
- Fixed the issue with Pixel Shader 1.4 video cards
- Fixed the issue that caused heat seeking missiles to stick to oil towers
- Fixed the issue that caused heat seaking missiles to ziz-zag
- Reduced the maximum number of claymores that can be dropped to 2
- Fixed the Server Browser filter to enable search by map name
- Fixed the error in Client - Server communication causing sound, animation and other
sync issues.
ftp://largedownloads.ea.com/pub/patches/readme/readme_en_us.txt
_________________ Remember this day, men, for it will be yours for all time. |
| Kommentaarid: 45 loe/lisa |
36 |
capricorn
11.03.2006 14:38:56
| Kas keegi teab, kas kuidagi saab LAN-is mängides ka A.I. mängu tuua, nagu singleplayeris on arvuti vastu.
| Kommentaarid: 24 loe/lisa |
23 |
jeanman
11.03.2006 18:00:23
| Saab keegi anda lingi kust se patch norm kiirusega tuleb.Muidu oota homse õhtuni kui EA käest patchi kätte saad.
| Kommentaarid: 39 loe/lisa |
36 |
tzinn
| Kommentaarid: 6 loe/lisa |
Slazenger
12.03.2006 21:31:07
| kust special forces EXP'i saaks ?
| Kommentaarid: 74 loe/lisa |
69 |
12.03.2006 21:44:47
| Slazenger kirjutas: |
| kust special forces EXP'i saaks ? |
Otse kätte = Enter`i kauplused... ise ostisn K-Arvutist... (muidu telli ja oota...)
| Kommentaarid: 232 loe/lisa |
195 |
thebull
12.03.2006 22:39:54
Tallinna Kaubamajast ostsin ise
_________________ Salamander |
| Kommentaarid: 8 loe/lisa |
12.03.2006 22:43:30
| thebull kirjutas: |
Tallinna Kaubamajast ostsin ise |
Tore ju, kui keegfi komplkéti kohi välja pakuks: (peale nimetatute) ja ka orienteeruv hind oleks teretulnud (ma ravan)
Minu "asjad" BF 2 545.- enterist (umb. 7 kuud tgaasi) ,m BF2SF Enter 390.- (2 Kuud tagasi...)
195 |
Killhoven
OC`er
13.03.2006 13:56:53
see polnud ju kõval patch notides?
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
| Kommentaarid: 407 loe/lisa |
350 |
redenergy
13.03.2006 17:48:36
Kui osta special forces siis kas mäng hakkab edaspidi selle CD key'd kasutama?
või seda ainult SF servudes?
| Kommentaarid: 30 loe/lisa |
9 |
km2000
14.03.2006 14:47:41
| palju teil muidu FPS on singleplayeris,kui graafika põhjas on ja mis arvuti conf teil on.
29 |
DigeBeni
14.03.2006 14:49:52
... Mängufoorum pole Ostuabi, seega paluks siia vastavasisulisi küsimus vms. mitte postitada !
162 |
kivi89
14.03.2006 17:00:02
| Selline küsimus siis et hetkel on mängu versioon 1.0, kui tahan updeitida 1.21 peale kas siis pean ainult selle 1.21 patchi tõmbama või siis on sinna vahele veel mõnda updeiti vaja??
| Kommentaarid: 53 loe/lisa |
51 |
FPSrulez
14.03.2006 17:15:24
| kivi89 kirjutas: |
| Selline küsimus siis et hetkel on mängu versioon 1.0, kui tahan updeitida 1.21 peale kas siis pean ainult selle 1.21 patchi tõmbama või siis on sinna vahele veel mõnda updeiti vaja?? |
1.21 patchist piisab
| Kommentaarid: 15 loe/lisa |
15 |
neoman
14.03.2006 18:35:54
Mul oli ennem 1.1.2 patch . Tõmmbasin 1.2 , panin peale ja ikka näitab ,et mul on 1.1.2 patch.... kuradi bugine m2ng
| Kommentaarid: 78 loe/lisa |
madness
14.03.2006 19:39:59
Kust ta sul seda näitab? Main menu?
1.1.2716-548.0 peaks olema viimane versioon
| Kommentaarid: 13 loe/lisa |
MarekSäde
14.03.2006 21:02:15
| neoman kirjutas: |
| Mul oli enne 1.1.2 patch . Tõmmbasin 1.2 , panin peale ja ikka näitab ,et mul on 1.1.2 patch.... kuradi bugine m2ng |
mina tõmbasin küll 1.12->1.2 update patchi, see nigu vähe väiksem ja mul igatahes töötas kohe.
| Kommentaarid: 68 loe/lisa |
66 |
neoman
14.03.2006 21:50:12
Mis sul näitab Menüüs ka siis 1.2 ?
madness
14.03.2006 22:02:34
| Ei näita ja ei peagi näitama. menüüs on vähe teistmoodi.
bush
15.03.2006 13:16:07
Huvitav kuidas see Euro Force packi ostmine käib. Kas eestlane ei saagi seda osta?
Sain. Panin soome ja läks läbi. Praegu downloadin.
| Kommentaarid: 31 loe/lisa |
30 |
Erik_Est
15.03.2006 13:51:30
Mina panin USA ja sain kah alla.Praegu just lõpetasin mängimise.Kel 130 EEku üle ,ostke!Kõikse hullem pole ! Aint kehva see et accounti ja gamespy accounti nimed peavad kokku sobima mängus vist muidu jääd eelnevast unlockidest ilma ,vist.Mina oma vana nimega sisse ei saanud aga kui panin sama gamespy nime siis sain.
| Kommentaarid: 41 loe/lisa |
34 |
thebull
15.03.2006 13:59:29
krt, ta ei luba mul mu gamespy kasutaja nimega(thebull_666) uut kasutajat teha seal EA kodukal... st. siis vast pole m6tet yldse seda osta, kui unlocke ka p2rast kasutada ei saa...
47th ronin
15.03.2006 14:11:43
tuttav palus muret kurta, nimelt ei saa ta miski trikiga downloadida seda va eurovorsti. suva, mis ta oma regiooniks ütleb, hinnaks antakse $0 ja download nupule klõpsates sõimatakse a la ei müüda sinna regiooni. väike vihje oleks abiks, aitäh.
_________________ rgrds,
ronin, neljakümne seitsmes |
| Kommentaarid: 52 loe/lisa |
50 |
bush
15.03.2006 15:42:06
Endal jama. Sai mäng ostetud aga mis accountiga sisse minna seda küll nüüd ei oska öelda. Ma ei saa aru miks kurat peab nii keeruline olema see värk mingi gamespy account ja ea account. Mängus sees on ka ju üks account.
Sain tehtud. Kahju ainult et ei saa euro force relvi bf2- originaalis kasutada nagu see oli special forcega
30 |
Erik_Est
15.03.2006 17:56:45
Enne downloadimist küsib ta sinu gamespy accounti. Selle accountiga sa selle alla laedki ja pärast mängid kah.Mina kah ei saa oma accountiga mängida sest mul gamespys oli account teise nime all ja alustan nüüd siis otsast peale ja gamespy accoundi nimega .Ega ma 100% ei tea 2. Peab vist olema account EAs tehtud s.t. regatud siis täidad korralikult ankeedi ära.Regioon ei oma tähtsust ,mina olen näiteks USA st oli vist iowa osariik proovisin pullipärast mis teeb ja hakkas laadima küll. Nii et lugege algust seal peaks ta vist pakkuma EA accounti tegemist. Ja soovitavalt siis teha gamespys account oma mängu nimega muidu on pärast jama vanade unlockidega.nab midagi muuta ??!!
34 |
