Karzum
30.03.2004 21:11:14
kodu adsl automaatne login |
Kui nii teha, siis käivitatakse ADSL ühendus teenusena (ei vaja Windowsi sisse logimist). Järgi proovitud, töötab.
vajalikud failid:
INSTSRV.EXE
SRVANY.EXE
Windows 2000/XP
Automatically dialing an ADSL (or other) connection without logging on
Note: This is only for advanced users, as it involves icky things with services and the registry.
You will need to get hold of INSTSRV.EXE and SRVANY.EXE, which are distributed with Windows support packs (although, as these two are used so often, they can often be found elsewhere...).
Set up your dial-up connection, and note down its name (e.g. ADSL). Copy the INSTSRV.EXE and SRVANY.EXE executables to C:\WINNT\System32, so they can be run from the command-prompt.
From a command-prompt type:
INSTSRV.EXE ADSL C:\WINNT\System32\SRVANY.EXE
Run regedit (Start Menu, Run, regedit), and do a Find (Edit, Find) for ADSL. Once regedit has found the service entry, create a new String Value in ADSL (right-click on right-hand window), called Description. Once created, double click it and set its value to "Automatically dial the ADSL". Now, in the same way, create a new Key in ADSL, called Parameters. In Parameters create a new String Value called Application. Once created, set its value to:
C:\WINNT\System32\RASDIAL.EXE ADSL "yourusername" "yourpassword"
viimati muutis Karzum 03.04.2004 21:33:53, muudetud 1 kord |
| Kommentaarid: 17 loe/lisa |
16 |
Troll
02.04.2004 13:40:45
Lisaks siia ka teise variandi. Klikkides ADSL ikoonile (mis tekib ADSL ühenduse loomisel)->Properties->Options->Dialing options ja seal jätke linnuke ainult "Display progress while connecting" lahtrisse. Siis tõstke see desktopil olev ADSL ikoon "Documents and settings"->All users->Start menu->Programms->Startup kataloogi. Niimoodi ühendub arvuti netti kohe peale käivitumist.
P.s Kui te kasutate ainult ADSL ühendust ja tahate Windows XP stardiaega tunduvalt lühendada, mine "My Network Places"-> paremklikk Properties->Local Area Connections ja leia seal Internet Protocol (TCP/IP) ning võta selle eest linnuke ära.
_________________ TÜMPA, TÜMPA...EEST ÄRA, TROLL TULEB!!! |
121 |
õllekas
08.04.2004 01:22:41
Pole mingeid faile vaja tirida endale...
start-->run-->%systemroot%\tasks
add sheduled task-->browse-->system32\rasdial.exe--->linnuke kasti when my computer starts
jätta ainult \kasutajanimi-->linnuke kasti open advanced properties...
run reale rasdial.exe järgi kirjuta ühendusenimi kasutajanimi parool
& finito
HacaX
15.04.2004 23:27:53
Saab ka teistpidi ligi:
a) heal juhul on Scheduled Tasks nimeline kaust olemas otse My Computeris
b) ...või on seal Control Panel. Tolles leiab Scheduled Tasks
c) Start => Settings => Control Panel sealt Scheduled Tasks
Sealt juba eelpool kirjeldet protseduuri tehes.
| Kommentaarid: 24 loe/lisa |
22 |
pommitaja
16.04.2004 08:55:25
siiamaani saan tehtud
& finito
see j22b tegemata
| Kommentaarid: 16 loe/lisa |
12 |
Le Inc
17.05.2004 12:53:41
| Või ostke adsl+ruuter, mis hoiab ühendust üleval 24h ööpäevas 8)
| Kommentaarid: 56 loe/lisa |
54 |
umarine
25.12.2004 19:26:43
Piisab ka sellest.
My Network Places>Properties
Siis ADSL ühenduse Properties>Options> ja linnuke ette "Include Windows Logon Domain"
erkki
28.02.2006 00:42:19
| Ma kasutasin esimeses postis toodud juhendit ja kõik töötab väga hästi. Kuid kuidas panna asi töötama nii, et peale hibernationist tagasitulekut see service jälle tööle hakkaks? Praegu on nii, et kui hibernationist naasta, siis peab ise adsli ühendama.
| Kommentaarid: 39 loe/lisa |
29 |
allar4
11.03.2006 11:29:21
| õllekas kirjutas: |
& finito |
Mul töötab ainult nii, et kui olen -->%systemroot%\tasks ja siis klõpsan parem klikk at rasdial ja run...siis ühendab ilusti ära. Kuid startup-i ajal ei ühenda Mis ma veel tegema pean? Kõik tehtud nii nagu ülevalpool õpetati..
Kas keegi oskaks aidata? Kuidas ma saaksin asja korrektselt tööle?
36 |
henz101
26.03.2006 19:17:52
| Troll kirjutas: |
| P.s Kui te kasutate ainult ADSL ühendust ja tahate Windows XP stardiaega tunduvalt lühendada, mine "My Network Places"-> paremklikk Properties->Local Area Connections ja leia seal Internet Protocol (TCP/IP) ning võta selle eest linnuke ära. |
mul on seal kaks seda internet protocoli! ühe suurem pealkiri on File and Printer Sharing for Microsoft Networks ja teine on Client for Microsoft Networks!
kas ma pean selle teisi eest linnukese ära võtma w?
_________________ Kõik hea võib kord kaduda..... |
Ernits
02.04.2006 13:59:59
| mul vist uuem modem, sest see asjandus salvestab parooli ja kasutajanime ise ära ja mingit ühendust pole vaja tehagi. mul kodu3, sõbral kodu2, a tema peab ühenduse looma. tglt mul nett kah kuu aega vana
88 |
pavka
02.04.2006 22:53:03
Kasutan Elioni korrusmaja internetti ja algul oli samuti probleem, et käivitus võttis kaua aega. Sai proovitud Trolli õpetust ja kõik toimis palju kiiremini Kuid pannes Elioni ikooni sartup-i ei looda käivitamisel ühendust automaatselt. Käsitsi ikooni käivitades kõik toimib. Kas on ideid, et Elioni ühendus startup-is toimiks
| Kommentaarid: 19 loe/lisa |
19 |
reimers66
02.04.2006 22:55:44
| jah mul endal oli ka ennem lohistatud Startupi alla asi kuid nüüd ostsin ruuteri ja enam pole vaja ühendust teha
| Kommentaarid: 65 loe/lisa |
60 |
aht0
16.06.2006 16:33:02
| Le Inc kirjutas: |
| Või ostke adsl+ruuter, mis hoiab ühendust üleval 24h ööpäevas 8) |
kasutan seda.. eraldi ruuterit ei pidanud ostma, elioni stardkomplektiga tulnud Zyxeli karp sisaldab adsl2+ võimalusi ja ruuterit+dhcp servut.. ise tuleb veebibrauserisse panna aadressiks 192.168.1.1 ja parooliks 1234
veebipõhine konfimisliides aitab automaatse logimise paika sättida umbes 15 min (esimene kord läheb muidugi rohkem aega).. selles reziimis töötab karp siis ka riistvaralise tulemüürina. kui p2p-d vaja kasutada saab kasutada portide suunamist.. ühesõnaga, kui karbike korralikult seadistatud pole vaja rohkem adsliga pead vaevata
pisike hub ka juurde ja LANi saab ka kasutada nii et kõik masinad pääsevad netti
| Kommentaarid: 82 loe/lisa |
71 |
beyond os
18.06.2006 10:40:20
| aht0 kirjutas: |
| Le Inc kirjutas: |
pisike hub ka juurde ja LANi saab ka kasutada nii et kõik masinad pääsevad netti |
vot selle kohta oleksi kohe rohkem küsimusi,
mis mudeliga tegemist(endal Zyxel Prestigio 660)
konfiguratsioonis on olemas ruutimine, ja dhcp-server,
viimane neist on kasutusel, aga kui modem panna käituma
brigde asemel ruuterina, siis enam netti ei saa,
ja adsli indikaatortuli muutub kollasest oranziks.
konfitud nii wizardi-ga kui manuaalselt, aga
ruuteri värk ei toimi, kas äkki viga mudelis,
tahab mingit firmware update saada enne
19 |
