anonymic
04.02.2006 12:48:19
dvd'd ei mängi dvd-romis |
tellisin worldwide freebiest B&W (mingi kõlari firma)dvd, aga kui tööle panen siis ta ei hakka arvutis mängima, tuleb selline tekst:Windows Media Player cannot play DVD video. Open Display in Control Panel, and then lower your screen resolution and color quality settings. To view the DVD Troubleshooter, click More Information. ja siis edasi:C00D116A: Cannot play DVD video
A troubleshooter is available to help you solve this problem. To troubleshoot the problem, see the DVD Troubleshooter in Windows Help.
 Note
To play DVDs, you must have a DVD-ROM drive and a software or hardware DVD decoder installed on your computer. If you do not have a compatible DVD decoder installed, DVD-related commands, options, and controls do not appear in the Player and you cannot play DVDs. By default, Windows does not include a DVD decoder. For more information about DVD decoders, see the DVD Support in Windows XP Web page at the Microsoft Web site.
Error ID = 0xC00D116A, Condition ID = 0x00000000
mis tegema pean?
				| Kommentaarid: 20 loe/lisa |
				  17 |
v6sa
04.02.2006 13:08:50
mplayer
 _________________ Otsid kohta nokitsemiseks? Pole vajalikke tööriistu varnast võtta? Kodus lapsed ei lase rahus tööd teha? Tule kiika meie hackerspace'i k-space.ee |
				  91 |
anonymic
04.02.2006 13:47:56
ma ei saanud sellest aru
				  17 |
Demineerija
04.02.2006 18:43:20
Installi arvutisse mõni DVD mahamängimist toetav tarkvara.
BSPlayer peaks ka sellega hakkama saama.
				| Kommentaarid: 122 loe/lisa |
				  101 |
anonymic
04.02.2006 19:25:20
proovisin ka bsplayerit aga sellega sama jama
				  17 |
H_K
04.02.2006 20:14:05
http://www.dvd-x-player.com/
Minu arust sellega kõige vähem jama aga kahjuks pole see vabavara aga proovida ikka saab.
 _________________ --------------- |
				| Kommentaarid: 53 loe/lisa |
				  51 |
anonymic
04.02.2006 22:15:04
töötabki
				  17 |
|  lisa lemmikuks |
