sotamees
29.01.2006 00:11:25
"Ärge tirige alla asju, mida te ei tea" |
"Your registry is corrupted. You need to clean it up,, --HOIDUGE--
Kas keegi on kokku puutunud? (nimi võib olla kirjavaga pealkirjas mul, kui jah andke teada)
Point on selles, et asi liigub internetis ringi ja võib mõnel interneti leheküljel ette lüüa,
ÄRGE MITTE MINGIL JUHUL INSTALLIGE SEDA ALLA
kui olete asja allalaadinud siis kõugepealt teeb ta teie viirusetõrje kahjutuks, ja kutsub sisse teised viirused[tegu troojaga]
(juhul kui panete selle clean_ima)
järgnevalt tahate asjanduse maha installida, Aga ei saa kuna tuleb kiri andke 5 dollarit.
Ühesõnaga asjandus on ohtlik, pettus ja viirus. 8)
hoidke ennast sellise asja eest!
Midagi internetist.
We get a pop up screen every so often that says something like "Your registry is corrupted. You need to clean it up. Go to www.registry-cleaner.com" or something similar (there seem to be about three or four varieties). I know it's important to sort out the Windows Registry, but is this a virus or spyware or, god forbid, for real?
Nick Temple
Many companies try to sell things this way. The pop-up tells you your registry needs cleaning, or you have viruses or something similar, and directs you to free diagnostic software. Download this and it may find dozens or even hundreds of errors. The catch is that you have to pay something like $20 to $40 to register the program so that it will remove the errors.
Of course, the fact that the program "finds" lots of problems doesn't necessarily mean they exist!
Frankly, I would recommend never buying anything sold this way. There are perfectly good free registry cleaners, virus checkers and other utilites on the web. The good ones are reviewed in magazines, recommended in web forums and mentioned in columns like Ask Jack. Also, you can always run a search on the company or product name before you decide on a download.
One good free registry cleaner is CCleaner -- it cleans other sorts of crap as well, such as temporary Internet files. If you find it useful, you can make a donation via PayPal.
Comments
Might this pop-up be a Messenger Service one, rather than a web-page one? The phrasing of it (telling you to go to a specific URL in text rather than just linking to it from a graphic of an 'OK' button or similar) suggests that it could be.
If so, the user could stop these from appearing by disabling Messenger Service in Services, under Computer Management (right-click on My Computer and choose Manage).
This possibility also suggests that the user (if on XP) is not fully patched up to Service Pack 2, which is certainly a situation worth rectifying.
Posted by Paul on November 8, 2005 11:41 AM.
Ja üks asi veel, see popup valetab teile et teie registry is corrupted. tegelikult on teie arvutiga kõik korras. 8) kui midagi muud teie arvutiga viltu ei ole.
viimati muutis sotamees 29.01.2006 22:21:45, muudetud 1 kord |
| Kommentaarid: 34 loe/lisa |
34 |
bigmarx
29.01.2006 01:11:51
Ikka on ullikesi, kes lähevad ja klikivad igale lingile, kus on midagi huvitavat Aga eks elu õpetab ja teeb oma korrektuure.
_________________ "Kes naerab viimasena? Ma olen siis teie järel!" |
| Kommentaarid: 485 loe/lisa |
385 |
sotamees
29.01.2006 19:43:33
Jah sellest asjast on veel videosid kah, kuigi inimesed ei oska inglise keelt väga hästi, ja ei mõista arvuteid siis tuleb selliseid asju ette, .
34 |
kännuämmelg
29.01.2006 19:47:58
Sa peaksid pealkirja muutma : "Ärge tirige alla asju, mida te ei tea"
või veel parem: "ärge tirige veebist midagi alla , las seda teevad need, kes teavad, mida teevad" 8)
205 |
sotamees
29.01.2006 20:01:26
Pealkirja ei soovi vahetada kuna, niimoodi jääb paremini meelde mis nimi sellel asjal on,.
Kas keegi on kokku ka puutunud sellise popup,iga?
kui jah mida olete teinud?
34 |
kännuämmelg
29.01.2006 20:11:59
| kaldun arvama, et enamik pole sellise teate peale sõrmegi liigutanud.. samamoodi,nagu teatele: " Su pea on tühi, pista see põlema"
205 |
Kristo.
29.01.2006 20:19:30
See pealkiri seostub esmalt mingi Windowsi veateatega, mitte pahalasega.
Võibolla ikkagi on mõttekas pealkirja muuta.
| Kommentaarid: 40 loe/lisa |
36 |
blas
29.01.2006 20:20:31
lootusetu üritus, kuna alati on inimesi, kes usuvad, et keegi nende eest nii hirmsat moodi hoolitseb, tahab niisama ära anda palju raha või tasuta arvutustehnikat, et kõige meelamad neiud ootavad just tema kõnet jne jne:D
meenutame vana head majakovskit, kes teatas, et tasuta juustu saab hiirelõksust ja elame selle teadmisega:)
_________________ The truth is out there |
| Kommentaarid: 79 loe/lisa |
76 |
29.01.2006 20:37:36
Internet Optimizer. Download NOW!!! 10x faster internet!!!
Kas keegi tõesti veel langeb sellise BS õnge?
| Kommentaarid: 745 loe/lisa |
561 |
Ho Ho
29.01.2006 21:26:39
| indre329 kirjutas: |
Kas keegi tõesti veel langeb sellise BS õnge?  |
Nii kaua kui inimsugu püsib ei kao lauslollus kusagile.
86 |
TzigaLind
29.01.2006 21:31:39
Lollid on kasulikud. 300.- tunnis kasulikud.
_________________ Piix! |
| Kommentaarid: 16 loe/lisa |
14 |
sotamees
29.01.2006 22:24:07
Vahetasin pealkirja.
Ikkagi on see väike näide asjadest mida ei tohi tõmmata. siin käib siis ikkagi kännuämmelg, lause:
34 |
30.01.2006 00:00:44
| Samahästi võiks panna pealkirjaks "Ärge pirage". Ega see midagi ei muuda, kui üht lehekülge ja üht viirust siin negatiivselt promoda. Neid on tuhandeid. Võitlus tuuleveskitega.
561 |
Marie
30.01.2006 01:56:12
Re: "Ärge tirige alla asju, mida te ei tea" |
... viimased paar aastat olen käinud kus iganes, tirinud mida iganes, pole veel ükski viirus sel teel arvutisse tunginud, brauseriks põhiliselt Mozilla Firefox, viiruse tõrjeks Trend Micro PC-cillin 2002 test , OS Win2k.
Win 98SE ja Linuxi puhul ei kasuta mingit viirusetõrjet, kuid ka seal kasutan ainult Firefoxi, enamus asjade käivitamine on mul Firefoxis keelatud, et las enne laeks asja alla, siis otsustan mida antud failida edasi teen.
| Kommentaarid: 83 loe/lisa |
74 |
30.01.2006 06:14:27
| Marie kirjutas: |
| Trend Micro PC-cillin 2002 |
| ot: |
Kas sellele jagatakse ikka veel uuendusi? |
561 |
kännuämmelg
30.01.2006 06:53:19
| Marie kirjutas: |
| ... ... et las enne laeks asja alla, siis otsustan mida antud failida edasi teen. |
suur mulin, mis ei erine vette peeretemisest
1. miks inimene tirib niisama (..hiljem otsustan, mis teen)? kas tõesti peab andmesidekanalit pidevalt töös hoidma- et kui midagi ei liigu, ummistub kanal ära ja tuleb kutsuda torumees?
2.firefox pole imeravim, jah tõesti, ta päästab paljude netikollide eest, mis optimeeritud activex-le kuid kui Sa ikkagi mingi miljonäriks tegeva lubadusega aplikatsiooni alla tirid ja ära installid, pole sellest tühjagi kasu.
3. see, et Sa veel mingit ussi naha vahele pole saanud, tähendab a) Sa ikkagi igasugu sodi ei tiri ja ei installi; b)Sa ei käi sellistel lehtedel, milledel lausa üle servade loksub arvuti jaoks ohtlikku möga..
kokkuvõttes tahaks seda öelda, et inimene peaks ikkagi aduma, mida ta internetiavarustes teeb
205 |
Marie
30.01.2006 09:54:31
| Marie kirjutas: |
| ot: |
Loomulikult jagatakse, tingimusel, et selle install pole vanem kui aasta ja sa pole ennast varem registreerinud, mõlemat annab alati uuesti ja uuesti korraldada, kui muud moodi ei oska siis siin levinud imeravim format abiks, mida mina pea kunagi ei kasuta.
| kännuämmelg kirjutas: |
| Marie kirjutas: |
IE puhul oleks andmekandjal automaatselt kogu aeg tööd, minul aga jääb võimalus kas ma luban sellisel failil alla laadimist mis ise brauseris käivituks, kas või kõige süütumad dokumendi ja heli failid, pdf, xfdf, xdp, txt, avi, mov, au: mul on nende faililaienditega failide brauseris isekäivitumine keelatud
74 |
sotamees
30.01.2006 14:31:34
Küsin: kas viirus võib kõvaketalt kõvakettale üle minna, ilma et ise mingeid faile tõstaks, (niimoodi ,et saad viiruse ja see sigineb teistele ketastele kohe edas?)
..............Your registry is corrupted. You need to clean it up...............
Küsin: Kuda selle asja siis maha saab? kui paned uniinstallima tahab 5 dollarit saada, failie kustutada ei lase.
(mul peaarvutis yks selline naaskel sees)
Küsin: Kas läbi jagatud neti võib ka viiruseid tulla?
34 |
Ho Ho
30.01.2006 16:45:11
Jah esimesele ja viimasele küsimusele.
Teise küsimuse vastust ei tea. Proovi mõne pahalaseeemaldajaga üle käia.
86 |
keytron
30.01.2006 16:47:50
ahju sellised suslik-petufirmad
| Kommentaarid: 58 loe/lisa |
54 |
crypto
30.01.2006 17:48:36
| keytron kirjutas: |
ahju sellised suslik-petufirmad  |
Ma süüdistaks inimesi, kasutajaid, mitte firmasid nii väga. Need firmad tahavad ka raha teenida ja kui ausal teel ei saa sellega hakkama, siis kasutatakse inimeste lollust ära Nagu ennist juba öeldud: nii kaua kuni on inimsugu nii kaua on ka neid lolle kes usuvad kõike sinisilmselt....
_________________ 61. Logistikapataljoni võitleja |
| Kommentaarid: 42 loe/lisa |
37 |
Marie
30.01.2006 18:07:09
| sotamees kirjutas: |
Küsin: Kas läbi jagatud neti võib ka viiruseid tulla? |
Lavasoft Ad-Aware SE
74 |
sotamees
01.02.2006 15:31:08
crypto,
_________________________________________________________________________
See ei ole põhjus siis inimestele liiga teha, sellised firmad tuleks koheselt kinni panna!
34 |
Marie
74 |
sotamees
01.02.2006 17:16:59
Jah lahti sain. Safemodes, midagi proovisin maha uninstall.ida, lõi kirja anna 5 dollarit, siis proovisin teistelt kohtatelt, ka sama kiri.
Lahti sain tema kõikide failide lihtsalt ära kustutamisega, uninstall.ida ei lubanud, et anke aga 5 dollarit. Selliseid asju ma vihkan ja arvan ,et teised ka vihkavad.
Aga õnneks ei olnud tegu minu arvutiga.(mina sellise saastaga õnge ei läheks)
Ja kas keegi oskab öelda kus see eesti video üleval on, kus nad räägivad viirustest ja teevad katsetusi kui inimene downloadib alla neid. Seal oli see sama registry cleaneri kohta ka video,lõik ja ma arvan et seda vaadates jääb hästi meelde millega tegu!
34 |
